Using the Sun to restore a yellow Macintosh ☀️
I've been looking at the safest ways to restore the color of the Mac without over bleaching the unit or leaving streak marks.
Because the inside of a Mac 128/512/Plus is coated with a conductive covering, I want to avoid submerging the case into hydrogen peroxide as it induces rusting/oxidation. I also want to avoid buying gallons of hydrogen peroxide.
The two methods I tried were using just the sun (nothing else!), and a hydrogen peroxide cream. Here is a before/after gif of a platinum bezel using the two methods.
Results Overview​
As seen in the gif, the center bezel is before and after. The bezel was place between a lightly yellowed bezel on the left and a heavily yellowed bezel on the right just for reference.
The sun was able to restore the color to a modestly yellowed state.
The creme did a much better job and was able to restore the color to a very slight yellowed state.
I was impressed with both results in general
Please note that the cream did NOT over brighten the bezel! From the area under the logo, you can see that the original color was even brighter.
On the negative side for the cream. the bezel color was not evenly restored. On the left side of the inward CRT bend, there's extra yellowing, as highlighted in the image below. This is partially because it's difficult to get all the edges an equal amount of sun in such a short amount of time.
Sun Method​
Bezel was placed outside in the sun, in the middle of January, every day between 11am and 4pm (I get limit sun due to surrounding buildings). 2 of the days were sunny and 3 days were cloudy. Temperature was cold, about 6°C/43°F every day. I did check on it everyday and on cloudy days the bezel would get brighter as well. I would place the bezel at slightly different angles every day to ensure all edges got some sun. Only the top side came out a bit darker, but this can be easily fixed by placing it at an angle to focus on top side.
Below is an image of 4 Mac Plus platinum bezels. From left to right:
1. Original Color
2. Brightened via cream, original color can be seen where the logo was removed.
3. Brightened via sun for 5 days
4. Heavily yellowed bezel (right side bezel from above gifs)
Lastly, I'd like to note that the 5 days of sun had no visible affect or discoloration on the badge, however I'm sure that if I did leave it out for a couple weeks it would.
Cream Method​
I followed the method described in this youtube video.
Recipe (note this makes enough to do at least 5 macs!!):
  • 500ml 3% hydrogen peroxide
  • 1 tablespoon Xanthan Gum
  • 2 tablespoons Glycerin
  • 1/4 teaspoon Oxiclean power
I used a hand mixer to to mix everything, consistency came out very similar to video. I tried to re-apply cream every 15~20 minutes; I'd recommend every 15 as after 20 minutes it was starting to get a bit hard. It was in the sun for just about 2 hours.
Conclusion​
The sun did a surprisingly really good job! However it seems you'd probably need to leave it out in the sun for a month if you'd like to remove most of the yellowing.
The cream also did a great job, but it can be hard to get even results on a heavily yellowed bezel.
My final suggestion would be to leave the case out for 1~2 weeks in the sun, and then follow up with a 1 hour cream treatment to get that extra final mile.
fehervaria
175
North Germany
Very great summaries and extra thanks for the recipe for the "slime".
What is your opinion about a UV-A light bath? (UV-A is for example used for the PCB production or nail building). I would not mention the UV-C (used in medical area for desinfecting tools, rooms) because it is to agressive for anything.
As I understand the temperature (6 Celsuis degree) is not an important factor "just" the Sun light, probably the UV light only?
Could you let us know "where" are you on the North side of the Globe? Closeer to the Equator or far north?
766
Yeah, I've used just pure Peroxide creme (40vol) and reapply every 15-20 minutes (depending on how hot the South Carolina sun is that day). My goal is to keep the creme from drying in between coats. I also try to apply the brush strokes in opposite directions each time to try to minimize risk of streaking in one direction.
I do believe heat has a factor. I've noticed key caps respond much better to hydrogen peroxide when it is heated vs just left in the sun during the winter. I'm trying to get a cheap sous vide machine to help warm / circulate the hydrogen peroxide when the keys are in the tub. I used the cooktop on the lowest setting and over bleached some old keys... I feel like the more precise temp of the sous vide will make it easier to keep it simply warm.
I tend to do my retrobrighting in the summer, partly because of the warmth, but also partly because you get a lot more sunlight to work with. I've seen some videos that compared UV alone vs UV with heat, and I thought I saw that the UV alone did not work well. I could be wrong, but I feel like I saw a YouTube video proving that during one of my Retrobright rabbit hole sessions.
Paolo B
309
181
Very interesting, thanks for sharing. I’m not a big fan of retrobrighting, I find the idea borderline OCD, but I agree the results can be extremely rewarding.
For boosting the effects of Sun (UV rays) and speeding up the reaction, I would try to seal the items into ozone filled transparent bags, which seems to be as effective as hydrogen peroxide.
766
I believe the ozone method has been tried and was not effective. Also could be damaging to metals, I believe.
Certainly something people can try, but so far hydrogen peroxide in the hot sun seems to be the most effective approach, if done with caution.
JeffC
148
92
Seattle, WA
I started a thread on another forum a while ago asking about retrobrighting indoors, and a user on that forum posted a photo of his indoor rig. He said he thinks it's more the heat than the light that causes the whitening. His rig consists of a large cooler with a 75 watt incandescent bulb inside, which keeps the temperature around 50-60c. He then puts the hydrogen peroxide mixture on the plastic and closes the cooler, he said he had good results after only 2 hours on a yellowed 512k case.
I didn't post a link to the thread since I'm not sure what the policy is as far as linking to other forums. If you google "Retrobrite indoors?", it should be the first non-reddit result. The 8th post in the thread has the info and a photo of his setup.
Reactions: wottle
AndyDiags
95
168
I've did a lot of indoor testing with UV light and heated hydrogen peroxide. I was hoping I could create a setup in the home which would get very reliable results. At the end of the day, I didn't find anything worthwhile. UV just doesn't have the abundant power of the real sun. I would have to wait for 24~48 hours to get some good results. Stickers would get ruined by extended time in heat, any metallic parts get ruined by the hydrogen peroxide.
I'm in Japan.
I think with 40% you have a higher risk of streaking, as 3% does just fine in 2 hours. The glycerin helps prevent the drying.
I very highly recommend using a sous vide when using dip method as it really helps distribute the heat evenly. The most common issue I found from my initial submersion tests was uneven heat causing streaks; a sous vide prevents this by providing a constant flow of water.
Here's a sample indoor result. After 24 hour, yellow is still present, and leaving it any longer starts bleaching the whole piece to a different shade. To be honest, this looks comparable to the results I got just from leaving my Mac outside for 5 days.
766
I'm in Japan.
My one concern about the slow sous vide method (especially if going for 24h) is floating pieces. Key caps can float and I worry about keys getting uneven coverage of the peroxide.
Javmast3r
73
66
There's a lot of "Theories" about retrobriting, in my experience (more than a hundred items done for the past 6 years) I use the original formula, no youtube or amateurish methods. The original formula - that comes from an Amiga user and a Brazilian plastic engineer - uses CLEAR peroxide mixed with an oxigen enhancer and a thicker agent. It is applied over the plastic as a paint. It is left out on full sunlight, changing the angle avery few minutes and checking that the mixture does not dry. Cleanse and reapply is done throughout the process.
All the other "methods" are SHORTCUTS that people try to use to leave unattended and be lazy. The "sun process" is the latest of these lazy trends.
The point of retrobrite is to have an exact process that will give you perfect results, but that takes time and effort. Every other way is a shortcut and may or may not have good results, leaving it to luck, fate and randomness.
I don't mind people using their own plastics as test beds, just don't blame the original retrobrite method to their failed experiments.
Just my 2¢
Cheers
Reactions: XKSTEVE and Patrick
Javmast3r
73
66
My friend Herbert has perfected the indoor retrobrite method:
Reactions: wottle
AndyDiags
95
168
I'm a bit worried how he suggests using a glass for weight, if a strong enough light is used or someone does this with the sun, the glass's light reflection can possibly cause hotspots/streaks.
I also want to mention that I have health concerns about using the submersion method indoors. When I did try the submersion method, I ended up doing it outside due to the smell and large amount of hydrogen peroxide fumes created. Having a couple liters of hydrogen peroxide evaporate into your living area can't be good.
Seems you're referring to rkauer, who ran this test in 2008, documented here. Solution discussed there is same as cream used here.
I wouldn't say sun brightening in a shortcut at all. It's more time consuming and takes much longer. I need to go out every day and rotate the items. Every day I also need check the weather and keep brining them in and out whenever there's a chance of rain. The sun method has the advantage of giving a much more consistent result on deeply yellow parts, especially with complex shaped objects where it's difficult to give equal amount of sun in 2 hours with the cream method. I really do think that combining the two methods can provide some of the best uniform result.
Reactions: wottle
ScutBoy
356
Northfield, MN USA
I've put small things like hard drive cases as such out in the sun during the summer. It's slow, but it works. I've not seen any regression (or increased yellowing) on parts I did in the summer of 2020 when COVID started me being home during the day. YMMV
bwicklund
Does anyone have experience using a UV Lamp? I am interested in doing a cream-less brighten but in MN in the winter the UV index is very very low.
davidg5678
38
My (elementary) understanding of the chemistry involved is that hydrogen peroxide is comprised of only hydrogen and oxygen atoms. I think that when it decomposes, one of the extra oxygen atoms is released (as the gas bubbles). The remaining liquid just turns into plain water. If you use pure hydrogen peroxide, it's probably harmless --I couldn't say what's in the beauty product version of the chemicals though, so I wouldn't want to inhale those fumes.
davidg5678
38
I use two 60 watt LED UV lamps and a plastic tub filled with water and hydrogen peroxide to retrobrite in my basement. I've had good results submerging my Macintosh cases in the liquid and letting them brighten over the course of a few days. I purposely use a low 3% concentration of hydrogen peroxide (just a bunch of normal bottles from the grocery store), so while it takes longer, I feel like I have a greater degree of control over the process.
davidg5678
38
I was thinking about something like this: https://www.amazon.com/Sperti-Fiji-...ocphy=9019660&hvtargid=pla-599573796445&psc=1
I have some junk parts that I should test with first this thing is like a tanning bed so it puts out some serious UV.
I question whether this huge lamp is extreme overkill for retrobrite purposes? My experience is that the smaller $50 UV lamps work well without outputting such a great quantity of UV. If I wanted to accelerate the multi day process I currently have, I think I could do it inexpensively by dropping an aquarium heater into my liquid tank or by using a higher concentration of hydrogen peroxide. (I've not done this yet, as I no longer have to align my retrobriting schedule with warm, sunny days, so I can set this system up to run overnight in wintertime if I need to.
bwicklund
Well this is just what I have because Minnesota winters really zap your vitamin D.
My very un-scientific and ignorant question is this, if UV light is what causes the yellowing of these plastics over time then how is UV light alone helping restore the color on the plastics. Its not as dramatic as the HP but still he got results.
