Mr. Macintosh
31
Incredible progress @PappaDF !!! Please share what you can as working together can work at continuing to the main goal! I know you said you were going to post something but I'm very excited. I want to get this info into astra as soon as possible. 😊
Reactions: PappaDF
Mr. Macintosh
31
OHHHHHHHH
Open Firmware ARC Interface Version 3.0 (Jul 12 1996 - 18:46:28)
OFClose(ff8d3740) failed
OFClose(ff8d3640) failed
OFClose(ff8d3500) failed
Booting from 'multi(0)scsi(0)cdrom(0)fdisk(0)\PPC\SETUPLDR'
OFClose(ff8d3000) failed
HJ
OFClose(ff8d2d40) failed
Windows NT Setup
OFClose(ff8d2ac0) failed
OFClose(ff8d2800) failed
Setup is loading files (Windows NT Executive)...
Setup could not determine the type of computer you have, or you have
chosen to manually specify the computer type.
Select the computer type from the following list, or select "Other"
if you have a device support disk provided by your computer manufacturer.
IBM Power Series 6015
IBM Power Series 6020,40,42
IBM Power Series 6050,6070 and RS/6000 Model 7248
IBM RS/6000 Model E20/E30/F30
IBM RS/6000 Model 45M/H45
MOTOROLA PowerStack
MOTOROLA PowerStack2
MOTOROLA Big Bend
Powerized ES, MX, LX, TX (Uniprocessor)
Powerized MX, LX, TX (Multiprocessor)
> Other
ENTER=Select ESC=Cancel F3=Exit
Reactions: PappaDF
PappaDF
14
I've now uploaded it here: https://github.com/pappadf/powermac-nt-hal
We can always find a better home for it later on - just want to make sure that you get access to it asap. Note that I didn't really take the time to clean it up or review it properly. There could be a lot of strange Ai-generated things in there.
To follow what exactly my AI agent have done - start with README.md and STORY.md, and continue with docs/* for additional details. Under traces/ you can follow the exact progress in terms of terminal output/screenshots.
It now passes hard drive partitioning and ends with:
Mr. Macintosh
31
I think same spot where @PappaDF left off yesterday needing HAL support.
WOW!!! Thank you @PappaDF
On real hardware with your work and a modified cd I was able to select past multiple screens and have arrived here
Reactions: PappaDF
Mr. Macintosh
31
Thanks! Great progress! How far into the boot are you here, i.e. what were the previous screens/output that you passed?
For sure! I was able to get past picking the display adapter, and storage controller. I will be able to pick back up in a few hours. I’m telling you we are all so close I can taste it!!
567
www.floodgap.com
I would check the Name Registry using Display Name Registry or DisplayNameRegistry or my DumpNameRegistry to see what is visible to the OS.
https://68kmla.org/bb/threads/silic...ng-easier-way-using-flashrom.7013/post-472471
https://68kmla.org/bb/threads/attem...-the-great-gazelle-pci-hack.45493/post-503468
Oh, I thought I had posted that here before. Here is what the relevant sections look like:
/Devices/device-tree/bandit
    name                             bandit
                                62616E64 697400
    ?ESB                             FFFFFFFF
                                "<FF><FF><FF><FF>"
    device_type                      pci
                                70636900
    model                            AAPL,343S1126
                                4141504C 2C333433 53313132 3600
    reg                              F2000000 02000000
                                "<F2>......."
    #address-cells                   00000003
    #size-cells                      00000002
    clock-frequency                  01FCA055 = 33.333333 MHz
    slot-names                       00006000
                                     SLOT1_PCI0        534C4F54 315F5043 493000
                                     SLOT2_PCI0        534C4F54 325F5043 493000
    ranges                           02000000 00000000 F3000000 F3000000 00000000 01000000 01000000 00000000    "........<F3>...<F3>..................."
                                     00000000 F2000000 00000000 00800000 02000000 00000000 80000000 80000000    "....<F2>........<80>..........<80>...<80>..."
                                     00000000 10000000
    bus-range                        00000000 00000000
    name                             bandit
                                62616E64 697400
    device_type                      pci
                                70636900
    model                            AAPL,343S1126
    reg                              F4000000 02000000
                                "<F4>......."
    slot-names                       0001E000
                                     SLOT3_PCI1
                                534C4F54 335F5043 493100
                                     SLOT4_PCI1        534C4F54 345F5043 493100
                                     SLOT5_PCI1        534C4F54 355F5043 493100
                                     SLOT6_PCI1        534C4F54 365F5043 493100
    ranges                           02000000 00000000 F5000000 F5000000 00000000 01000000 01000000 00000000    "........<F5>...<F5>..................."
                                     00000000 F4000000 00000000 00800000 02000000 00000000 90000000 90000000    "....<F4>........<80>..........<90>...<90>..."
                                     00000000 10000000
    bus-range                        00000001 00000001
/Devices/device-tree/bandit/53c825
    name                             53c825        35336338 323500
    vendor-id                        00001000
    device-id                        00000003
    revision-id                      00000011
    class-code                       00010000
    interrupts                       00000001
    min-grant                        00000008
    max-latency                      00000040        "...@"
    devsel-speed                     00000001
    AAPL,interrupts                  00000016
    model                            NCR,825A        4E43522C 38323541 00
    compatible                       pci1000,3        70636931 3030302C 3300
    device_type                      scsi        73637369 00
    reg                              00008800 00000000 00000000 00000000 00000000 01008810 00000000 00000000    "..<88>...................<88>........."
                                     00000000 00000100 02008814 00000000 00000000 00000000 00000100 02008818    "..........<88>...................<88>."
                                     00000000 00000000 00000000 00001000 02008830 00000000 00000000 00000000    "..................<88>0............"
                                     00000000
    AAPL,connector                   scsi-int        73637369 2D696E74 00
    assigned-addresses               82008830 00000000 F3102000 00000000 00000000 82008818 00000000 F3101000    "<82>.<88>0....<F3>. .........<82>.<88>.....<F3><F3>..."
                                     00000000 00001000 82008814 00000000 F3100000 00000000 00000100 81008810    "........<82>.<88>.....<F3>...........<81>.<88>."
                                     00000000 00000400 00000000 00000100
    AAPL,address                     F3102000 F3101000 F3100000 F2000400                                        "<F3>. .<F3>...<F3>...<F2>..."
    driver-ist                       00057380 00000006 00000000 00000000 00000000 00000000                      "..s<80>...................."
/Devices/device-tree/bandit/54m30
    name                             54m30        35346D33 3000
    vendor-id                        00001013
    device-id                        000000A0        "...<A0>"
    revision-id                      00000022        "...""
    class-code                       00030000
    interrupts                       00000001
    min-grant                        00000000
    max-latency                      00000000
    compatible                       pci1013,a0        70636931 3031332C 613000
    reg                              00007800 00000000 00000000 00000000 00000000 42007810 00000000 00000000    "..x.................B.x........."
                                     00000000 01000000 01007814 00000000 00000000 00000000 FFFF0400 02007830    "..........x.............<FF><FF>....x0"
                                     00000000 00000000 00000000 01000000
    device_type                      display        64697370 6C617900
    model                            STB,HORIZON+                                                               5354422C 484F5249 5A4F4E2B 00
    AAPL,connector                   monitor        6D6F6E69 746F7200
    assigned-addresses               C2007810 00000000 82000000 00000000 01000000 82007830 00000000 81000000    "<C2>.x.....<82>...........<82>.x0....<81>..."
                                     00000000 01000000
    AAPL,address                     82000000 81000000                                                          "<82>...<81>..."
    did                              00000020        "... "
    driver,AAPL,MacOS,PowerPC        4A6F7921 70656666 70777063 00000001 B0E2BF9E 00000000 00000000 00000000    "Joy!peffpwpc....<B0>⿞............"
                                     00030002 00000000 FFFFFFFF 00000000 00007CC4 00007CC4 00007CC4 00000080    "........<FF><FF><FF><FF>......|<C4>..|<C4>..|
<C4>...<80>"
                                     00000000 00000000 00000000 00000000 00000001 6E647276 7669646F 01000000    "....................ndrvvido...."
    driver-ptr                       009C8BE0        ".<9C><8B><E0>"
    driver-ref                       FFC9        "<FF><C9>"
    gprf    mods:00000020            000E000A 00000000
Notice that the 54M30 is not attached to any PCI slot, nor the 53C825. The OS treats the 54M30 as a "built-in display" but that's not good enough for the SCSI controller. The devices I installed in its actual PCI slots do show up, and have slots, e.g.,
/Devices/device-tree/bandit/IMS,tt128mbA
    name                             IMS,tt128mbA
                                494D532C 74743132 386D6241 00
    vendor-id                        000010E0
                                "...<E0>"
    device-id                        00009128
                                "..<91>("
    revision-id                      00000001
    class-code                       00030000
    interrupts                       00000001
    min-grant                        00000008
    max-latency                      00000008
    AAPL,interrupts                  00000017
    AAPL,slot-name                   SLOT1_PCI0
    fcode-rom-offset                 00000000
    model                            tt128m
                                74743132 386D00
    device_type                      display
                                64697370 6C617900
The slot enumeration is also different (2.0 uses things like "E1" or "C1" instead of "SLOTx_PCIy").
Mr. Macintosh
31
This is where I am currently at:
  • New HAL: HALSHINR-0.1-MARKER.
  • Both SCSI controllers receive the expected memory addresses and IRQs.
  • Interrupts occur on both controllers.
  • Final result remains STOP 0x7B — INACCESSIBLE_BOOT_DEVICE, with 0xC0000034.
354
136
Right. Apple System Profiler doesn't list every PCI device. Just ones in slots that have slot names.
The ANS 2.0 ROM does away with the Apple Network Server slot naming and uses PowerSurge type slot names.
Your problem is that the method used to attach the 54M30 driver to the device does not work for the 53C825 driver. Have you tried looking at TradDriverLoaderLib sample source code?
Search for it at:
https://developer.apple.com/library/archive/navigation/#section=Platforms&topic=macOS
Also search there for MoreIsBetter which contains a more recent TradDriverLoaderLib in the MoreDevices section.
But wait, TradDriverLoaderLib is for 68K drivers. You're trying to load a native PPC driver. In that case, you may need the DriverLoaderLib.
Loading native drivers is discussed in Tech Note 1189 "The Monster Disk Driver Technote".
https://developer.apple.com/library/archive/technotes/tn/tn1189.html
It has a section "Installing and Removing Drivers and Drives" which refers you to other relevant documents and sample source code.
It says that "you can set up your DriverDescription so that the system automatically finds and opens your device driver. "
Have you examined the DriverDescription from the ndrv to make sure it matches the hardware?
The tech note says "A native driver is commonly stored in a file of type 'ndrv'". Is the file type correct? Does the file have a cfrg(0) resource? Is it in the extensions folder?
Maybe you need to use the DriverLoaderLib to load the driver manually.
There's a "SCSI Driver Example" example mentioned by the Tech Note. I think that's a 68K driver though.
Actually, the PCI DDK 3.0 has source code for "an NCR 8250 PCI interface card that uses an NCR 53C825 SCSI interface chip".
You should definitely look at that PCI Driver Development Kit.
This mentions SCSI SIM:
https://developer.apple.com/library/archive/qa/dv/dv22.html
I wonder if you can add the driver to the SCSI controller while in Open Firmware? Create Open Firmware commands to create the driver,AAPL,MacOS,PowerPC property and download it via serial port using the dl[icode] command. Then see if the SCSI controller is bootable or accessible in Mac OS.
