KeroBurn: a Mac app for the XGecu T48 / TL866II+ (beta, testers wanted)
Kay K.M.Mods
756
Tokyo
www.kerosmm.com
Hi all,
I program a lot of ROMs and GALs for the boards I make, and I got tired of booting a Windows machine every time just to run Xgpro. minipro works on the Mac, but typing "SST39SF040@PLCC32" into Terminal 10 times a day gets old fast. So I wrapped it in a proper Mac app.
It's called KeroBurn. It's a front end for minipro, and minipro, libusb and the device database are all bundled inside, so there's no Homebrew or MacPorts to deal with. Universal binary, macOS 12 or later.
What it does:
- Presets for the chips you use. The editor searches minipro's T48 database as you type, and shows a green check if the name is valid.
- Drag a .bin (or .jed) onto the window and hit Write.
- Multi-chip runs. Drop a HI/LO pair or a 4-chip ROM SIMM set and it flashes them in order, stopping between each one so you can swap chips. Handy for ROM-inator or SMC ROM SIMM sets.
- Hex View. Load the file, read the chip back, and it shows both side by side with the mismatched bytes in red. It also tells you if the data looks shifted to a different address, or if all the errors land on even or odd bytes (which is usually a HI/LO mix-up).
- Sum and CRC32 for the file and the chip.
- A log of every chip written, with the file's SHA-256.
- Checkboxes for -s, -y, -v, -u and -P, saved per preset.
As this is still a beta version, it is being updated frequently. Please be sure to check for new releases before downloading.
https://github.com/kerokero5150/KeroBurn/releases
Download (beta):
New
  • Write a file at an address. Each file has an Offset… button: chip address, start in file, length, and "keep what's already on the chip". Put a few bytes of patched code in a small file, give it the address, tick Keep, and only that range changes. Same idea as the file load dialog in Xgpro.
  • Presets remember their files. Line them up (offsets included), press Save to Preset, and they're loaded every time you pick that preset.
  • Each preset keeps its own file list while the app is open, so switching presets doesn't lose anything.
  • File rows show when the file was last modified. A saved file that's been moved or renamed shows in orange and the write won't start.
  • Hex View lines up the compare when a file has an offset.
Fixes
  • Read… crashed when the first file in the list was smaller than the chip.
Under the hood
  • The offset feature uses new minipro options (--offset, --file_offset, --length, --keep) from a patch in patches/. They work from Terminal too.
Thanks to Mike for the saved files idea, and to Lewin and @Stephen for testing.
Source is on GitHub too, GPLv3 like minipro:
https://github.com/kerokero5150/keroburn
It's not notarized, so the first time you'll need to right-click it and choose Open.
What I've tested: an Intel Mac Pro with a T48 on firmware 00.1.39. SST39SF040 in PLCC32, AT28C64B, ATF16V8B and a few others all flash and verify fine.
What I haven't tested, and where I'd really like help:
- Apple Silicon. It builds as a universal binary, but I don't have an M-series Mac to run it on.
- The T56 and TL866II+. minipro supports them, I just don't own one.
One known oddity: my AT28C64Bs fail verify with the normal device name. Only the first and last byte of each 64-byte page get written. Switching to "AT28C64B(Non-Standard)" fixes it. My chips are recycled pulls though, so I'm not sure if it's the T48 or the chips. If you have genuine Atmel parts I'd like to know how they behave.
Bug reports here or on GitHub issues are both fine. Thanks for trying it.
PL212
69
44
This works great! I used it to dump the four PLCC32 ROMs of a Global Village OneWorld (a strange device that makes two GV PowerBook modems available over an AppleTalk LAN.)
M5 Pro MacBook Pro, Golden Gate 27.0.1
For AppleTalk fans, longer thread over here.
  • GV_OneWorld_ROM_512K_base_F80000.bin
Kay K.M.Mods
756
Tokyo
www.kerosmm.com
@PL212 Thanks for the report, and great to see it working on an M5 Pro with macOS 27! That looks like one of the early betas. Since then I’ve added quite a few things in beta 4, like Read opening straight into Hex View (saving is optional now), Chip ID telling you what a chip really is when it doesn’t match, and presets that remember their files. It’s still a work in progress, so I’m keen to hear how it works for you and what you’d like to see next.
https://github.com/kerokero5150/KeroBurn/releases/latest
@Kai Robinson Funny you should mention it, I’ve just finished the SE ROM-inator. I flashed ROMs for it hundreds of times while developing it, and that’s what gave me the idea for this app. In the Mac SE, the BBU was never meant to drive chip select for a flash ROM, so I had to generate the CE and OE signals myself. The whole story is here if you’re interested:
https://www.kerosmm.com/post/se-rom-flash-tool-1-1-and-how-it-got-here
You probably don’t remember, but we talked about putting a ROM disk in the SE a while back. It turned out to be a lot harder than I expected!
I’ve also put up an SE emulator that runs in the browser. It’s Mini vMac, built for the Mac SE instead of the Plus. I originally made it as a test bench while developing the SE ROM disk:
https://www.kerosmm.com/se-wevmac
The latest revision of the board has an extra address linenfir the ROM so people could test using the Classic ROM, as they're identical in almost every way bar the floppy disk select.
Kay K.M.Mods
756
Tokyo
www.kerosmm.com
Interesting. I actually tried the Classic ROM on my SE a while back. I used a MacPlus ROM-inator style 1MB board, so A18, A19 and A20 were all there, and I flashed the 512KB Mac Classic ROM into it twice. It booted fine from BlueSCSI and from a 6.0.8 floppy. Cmd-Opt-X-O did nothing, though.
I went back to the disassembly to find out why... Early in boot the Classic ROM sets VIA PA3 to an input and reads it ($43F770). If it reads 0, it writes $0B to $CB3 and treats the machine as a Classic. On an SE it reads 1, so $CB3 never gets set.
43f770: lea $EFE1FE,a2 ; VIA1
43f776: bclr #3,$600(a2) ; DDRA bit3 = input (PA3 as input)
43f77c: btst #3,$1E00(a2) ; read PA3
43f782: bne → ; PA3=1 → not Classic
43f784: move.b #$0B,$CB3 ; PA3=0 → Classic, so $CB3=$0B
Later, right after it opens .Sound ($43F824), it checks $CB3 again. Only when it’s $0B does it install .Screen, check for Cmd-Opt-X-O (or the PRAM startup device), and then install and open .EDisk. On an SE that whole block is skipped. .EDisk isn’t in the DRVR resource map either, so nothing else will ever load it.
43f828: _Open '.Sound'
43f82a: cmpi.b #$0B,$CB3
43f830: bne $43F840 ; not Classic → skip everything below
43f832: bsr $43F856 ; install/open .Screen (unit 51)
43f834: bsr $43F8DA
43f838: bsr $43F8E6 ; Cmd-Opt-X-O check, or PRAM startup = EDisk
43f83c: bne $43F840
43f83e: bsr $43F898 ; _DrvrInstall + _Open '.EDisk' (unit 52)
The EDisk driver itself looks fine for the SE. Its Open scans from ROMBase up to $500000 in $10000 steps looking for the “EDisk Gary D” header, so it would find the disk at $440000 without any trouble.
So with the extra address line the Classic ROM will boot an SE, but the ROM disk won’t come up unless you patch that $CB3 check. The floppy select difference you mentioned comes from the same $CB3 flag ($43F7F2 / $43F806), which is probably why it runs on SE hardware at all. Looks like Apple left the SE code paths in there.
If anyone wants to try, NOPing the bne at $43F830 (and the bsr to .Screen at $43F832) should be enough to get .EDisk installed. I haven’t tested that yet.
The whole story of how I got ROM disk booting working on the SE is on my blog:
https://www.kerosmm.com/post/bringing-rom-disk-booting-to-the-macintosh-se-the-se-rom-inator-project
Ah, on second thought, since this is KeroBurn’s post, it might cause some confusion. I will create a separate post for the SE ROM-inator to continue our discussion, let’s carry on there...
Kay K.M.Mods
756
Tokyo
www.kerosmm.com
Beta 5 is up: https://github.com/kerokero5150/KeroBurn/releases/latest
A few of you asked for ROM splitting, so that's the big one this time. Split / Join… next to Add… opens its own window, so the main window stays as simple as it was.
- Split turns one ROM into HI/LO files for 16-bit boards, or 1=LL/2=ML/3=MH/4=HH for 32-bit ROM SIMMs. *Applied to our SMC ROM SIMM, this sequence is: U1=LL, U2=ML, U3=MH, U4=HH.
If the chip is bigger than the part, the data is repeated to fill it (x2, x4 and so on), so it doesn't matter how the board ties the unused address lines. The parts go straight into the file list, ready to flash.
- Undo Split puts the parts back into one ROM, either from files or read straight off the chips. For 68K Mac ROMs it checks the checksum too.
- Join stacks files one after another, like a ROM followed by a disk image.
Two other things snuck in:
- Logic IC test for about 290 74 and 4000 series chips. Pins that fail show up in red. If you bend an input pin, the error shows up on that gate's output, which confused me for a minute until I worked out it was right.
- Firmware update for the T48, TL866II+ and T56, using the .dat file from Xgpro. No Windows box needed. On my T48 the first try always stalls right after the switch to the bootloader, so KeroBurn stops and starts again on its own, and the second try finishes in about ten seconds. If your programmer already works fine with KeroBurn, you don't need to update. It works in most cases, but if something goes wrong I can't help recover it.
As always, reports and screenshots are very welcome, especially from anyone with a TL866II+ or T56.
geerlingguy
19
58
St. Louis, MO
www.jeffgeerling.com
Why do I have a sneaking suspicion this would be of use to @geerlingguy ?
It will be; though right now I have my old Mac projects on hold as I'm traveling a lot until the end of the year.
This seems to be a golden era for classic Mac work, I love seeing new tools like this make something a *lot* easier/simpler/faster.
