melw
Hello, I'm new to the forum, bought a European D version and am very impressed with the work with the modded software. Everything is better except for the bad auto exposure that I had major problems with, have tested version D 272 and the auto exposure behaves exactly as in the original software, it gets light / dark every two seconds, especially at parts with light sky. According to some posts here, the modded version would have that feature turned off, but not that I can see. Is it possible to turn that off in the modded software? If it could be turned off, everything would be perfect. Is it something that could perhaps be implemented in the future perhaps?
Hi @mattiazze! And welcome, glad the mod works well for you otherwise!
You're right: the Type D builds (270–272) don't change the auto exposure. It works exactly as in stock firmware, so the pumping on bright skies is Kodak's own auto exposure. The Type D mod only reads the exposure value (the Exp: number on screen). It doesn't control it.
What you probably read about is 0dan0's mods for Types A–C. Those replace Kodak's auto exposure with a custom one and add an exposure lock. That code was never ported to Type D, because the D firmware is laid out differently and the A–C code doesn't work on it as such.
I'll have a look at whether it can be ported. No promises on if or when, but the first step is clear: Check that the mod can control the exposure at all on Type D. I can test that on my own unit.
Tuning the auto exposure needs real film with the problem, though, and I don't have any reels currently to test with. That's where you could help:
  1. A short clip (~10s) where the pumping is clearly visible, recorded with FW 272, ideally the bright-sky part.
  2. The Exp: and Gain: values on screen while it pumps: roughly the lowest and highest you see, and how fast it swings back and forth. A short phone video of the screen works well for this.
mattiazze
Thanks for the reply. I’m uploading a couple of files so you can see the aperture value. I can’t find a file with the sky in it right now, but it usually gets worse. I hope this is ok. I can look for other examples if needed. A feature that locks the aperture value would be enough; it’s possible to split the file during editing and make adjustments. (Sorry for my awkward English—I’m using a translation tool!) :)
  • 20261107_122024_1.mp4
  • Movie0013.MP4
DecPDP10
I have serial J2925148BK01038 , so this should be firmware D. Rvision code " J "is after H but the lookup tool says
Your serial number was NOT found on the list.
Use Firmware B labeled files for your device.
Any guidance would be appreciated
From Gemini:
If your unit is a Type D, flashing the standard Type B firmware will result in a black screen and unresponsive controls.
This is the central flaw of the web lookup tool: the tool was built before Type D existed and has not been updated to include Type D serial ranges. When it fails to find an entry in its database, its catch-all default is to advise using "Firmware B". In the community thread on TinkerDifferent, users with newer serials (specifically H28..., K22..., and J...) received that exact same lookup message, flashed Type B, and immediately experienced a non-booting display.
JohnCT
The lookup tool I used on line directed me to B, but mine is a D unit. I waited for one of the learned folk here to point me in the right direction. Standby.
John
DecPDP10
John
Thank you!
What Happens If You Flash Type B on a Type D Unit​
  • The Bootloader Survives: The Novatek SoC hardware bootloader sits at a low ROM level and is rarely overwritten by standard .BIN files.
  • The Display/Camera HAL Fails: Type D hardware uses a different internal display controller and updated sensor bus layout. When a Type B binary loads, the display driver fails to initialize, leaving the screen completely black while the power LED stays lit.
    TinkerDifferent
  • The Recovery Path Remains Open: Because the low-level bootloader is still operational, the scanner will still read the root of a FAT32 SD card upon boot. You can revert it simply by loading the proper Stock Type D or Custom Type D binary as FWDV280.BIN.
How to Safely Handle a Suspected Type D Unit​
Do Not Flash Type B
Critical Precaution
1.Do Not Flash Type B:Critical Precaution.
Hold off on flashing any standard Type A, B, or C binaries (such as 0dan0's v7.x series). Verification: The firmware binary you plan to use is explicitly designated as Type D (developed by user melw / videodoctor on TinkerDifferent).
Stage the Official Stock Type D Binary
Safety net
2.Stage the Official Stock Type D Binary:Safety net.
Before testing any modified builds, download the Stock Type D Recovery Image from the TinkerDifferent repository (archived around post #666 and in the Type D thread directory). Keep this file ready on your computer so you have an immediate factory rollback. Verification: You have an untouched factory recovery .BIN verified specifically for Type D hardware.
Flash the Type D Custom Firmware
Release Candidate
3.Flash the Type D Custom Firmware:Release Candidate.
Format a 16GB or 32GB SD card to FAT32. Copy the custom Type D build (which unlocks native 18 fps and bumps encoding bitrate to ~31 Mbps) as FWDV280.BIN to the card root, along with an empty NVTDELFW folder. Power on and allow 30–45 seconds for the screen to cycle. Verification: The scanner completes the flash sequence and displays the on-screen display (OSD) showing frame counts and adjusted capture parameters.
What to Do If You Already Flashed Type B and the Screen Is Black​
Disconnect Scanner Completely
Power isolation
1.Disconnect Scanner Completely:Power isolation.
Unplug the AC power cord from the back of the scanner. Wait 60 seconds to allow the internal capacitors to drain. Verification: The power LED is completely off.
Prepare the Type D Recovery Card
FAT32 format
2.Prepare the Type D Recovery Card:FAT32 format.
Take a 16GB–32GB SD card to your computer, format it as FAT32, copy the Stock Type D binary to the root directory, rename it to FWDV280.BIN, and add an empty NVTDELFW folder. Verification: The card root contains only FWDV280.BIN and NVTDELFW.
Boot and Restore
Blind Recovery Flash
3.Boot and Restore:Blind Recovery Flash.
Insert the card into the powered-off scanner. Plug in the power cord and press the Power button. Although the screen remains black, the bootloader will detect the card, rewrite the flash memory with the Type D image (~30–45 seconds), and reboot. Verification: Once flashing finishes, the screen turns back on with the factory Kodak interface.
Reactions: fishgee
melw
New Type D build, version 280 attached. The main new feature is manual exposure setting, for film where the picture keeps flickering between light/dark frames.
Manual exposure
On dense or dark film the stock auto exposure can flip back and forth between two values, causing unnecessary pumping and flickering effect. Manual exposure keeps simply the latest set value. Just adjust according to what works for your film. In manual exposure mode, the reel-end auto-stop is off, and the menu shows ASt: off (M). Stop the recording yourself at the end of the reel.
More details in the start-up screen
The start-up screen now lists the features, with the build number and build date at the bottom (Vers: FW 280 Type D Date: 2026/11/10). If it shows anything else, the new file wasn't flashed.
Big thanks to @mattiazze for reporting the exposure pumping, and for testing the builds on real footage!
All other settings carry over from 272. The source, the user guide and the changelog are on GitHub: https://github.com/melw/reels-type-d
  • FWDV280.BIN
Stick50jr
Manual exposure
Thanks for FW280 and your continuing interest in this device. This is fantastic to have. I'm re-scanning some of my reels that were underexposed. However, it appears that videos shot in the snow while skiing have variable exposure due to rough ride (Bolex Super 8) in 1971. Sometimes one must accept that the footage is garbage in (= garbage out). The manual scan exposure did improve it somewhat. These days I would use a GoPro but my skiing days are over :(
Google tells me that my alkaline battery powered Super 8 camera was likely affected by the cold rather than just the rough ride! Apparently there are software tools to tackle this sort of skiing footage... I'll see where it ends up.
Having the manual exposure on the scan is a good starting point:)
Reactions: melw
Cogniclaw
Manual exposure
Thank you for this firmware! I have installed in on my type D, and it worked at first- although a bit laggy- until, upon rapidly pressing buttons whilst adjusting the framing, the screen suddenly went funny on me giving only color bars ect (see attached photos.) This would only happen while in "recording mode" and seemingly has to do w/ displaying the camera. I tried recording to see if many it would actually capture the film when played back on another device, however it only recorded the static, glitchy color.
I then re-flashed the original firmware, however the effect of the screen remained which was troubling. I then tried flashing the previous community firmware for Type D (which I used for many films previously) and the screen still would go funny when in recording mode.
*HOWEVER* I attempted adjusting the framing again, and after zooming a couple more stops, the camera feed came back! Only upon being zoomed out X amount did it glitch. So, I again flashed the machine w/ your new firmware, knowing know how to beat the particular glitch my machine was having (which again, persisted across two other known working firmware variations) and the glitch was no longer effecting the camera feed, so long as I was zoomed in X amount. It eventually subsided entirely, allowing me to use the entire range. I should note that I had just finished modifying the camera mount location by lowering it 6mm per ChrisTheChiller's post. Because of this, having the zoom all the way out is important!
Anyhow, it's working now on my type D just fine!
melw
Thanks for the detailed report and the photos, and glad it's working now!
What you ran into is a bug in Kodak's own firmware. It happens on stock firmware too, so it isn't caused by the mod.
Your 6 mm mount change can make the bug more likely, because of different frame settings. If it happens again:
  • Zoom in a step or two, or move the frame back towards the centre, and the image comes back
  • Re-centre the frame first, then zoom out, then fine-tune the position
  • If the arrows stop responding, leave the frame-adjust screen and enter it again
About the lag: the framing and zoom screens are Kodak's own, and each zoom or position step does quite a bit of work in the background, so rapid presses can pile up there. In the mod's own menu during recording, a press only counts once it has been held for two frames in a row. We read the buttons about 30 times a second so very quick taps may not all register. This is a known issue.
Balto1986
From v.2 update for type C
For Scanner Type C.
  • Use the existing reframing controls to scan everything the sensor sees
    • This is great for hardware hack that want to do 16mm scan with the existing lens, or replace the lens for high-res scans of 8mm
    • This hack increases the zoom-out range 2.3X over the stock firmware
Is this something that is possible to add to the type D firmware? Or is it already a part of it?
I see that alot of users with D-version machines who have done the lens mod, cant zoom all the way out to get the full frame.
melw
Type D FW 292 is attached. Two fixes:
  • Fix corrupted screen when zooming out in frame adjust. This was a bug in Kodak's own firmware: with the frame position near an edge, zooming out pushed the picture off the sensor. At the three widest zoom steps the frame position is now kept within what the sensor allows, so the picture stays clean. A unit already stuck in that state is fixed at startup.
  • More responsive buttons in Recording mode Quick taps in the on-screen menu no longer get lost. The value on screen may still take a moment to update.
Everything else is the same as FW 280, and your settings carry over. Flashing as usual: FWDV280.BIN plus an empty NVTDELFW folder in the root of a FAT32 card, then power on.
Source and changelog: https://github.com/melw/reels-type-d
  • FWDV280.BIN
Reactions: Stick50jr
Graziano
Hello, today the parts for modifying the optic arrived. I had to source everything from the USA via MyUS.com, paying them for the parts, the various shipping costs, and customs duties a total of $287.71
I am located in Italy
I had contacted the manufacturer in China regarding the AZURE 1228MAC; they quoted a price of $60, plus $70 for shipping, but they didn't have the 7mm extension. They asked me to provide a drawing, saying they would manufacture it, and they already had the locking ring available.
  • AZURE-1228MAC.pdf
  • AZURE-M12 Locking Ring.pdf
  • PT-ERM12-700M.pdf
melw
Hi! Something new and experimental! I made a small test build that shows which type your Reels device is.
See attached image to see how it works on my Type D unit.
Now I'd like to know what it does on Type A, B and C units. Would anybody be willing to try this out? Type D owners are welcome test this as well.
What it is
The Reels' bootloader can run a file straight from the SD card, without writing it anywhere. This file uses that. At power-on it reads the firmware your unit already has (read only), recognises it, puts a "Type probe" screen in place of the start-up picture, and then starts your firmware as usual. Nothing is flashed or changed on the unit. Remove the card and it's exactly as before.
How to try it
  1. Copy the attached FW96658T.BIN to the root of a FAT32 SD card.
  2. Unit fully off, insert the card, power on.
  3. The start-up screen is only shown for a few seconds, so have your phone ready for a photo.
  4. Afterwards remove the card, or delete the file from it. While it's on the card it runs at every power-on.
What you may see
  • "Type probe / TYPE A, B, C or D", the firmware's name and a code: identified. Then your unit starts normally.
  • "Type probe / Unknown firmware" and a code: it found firmware it doesn't know yet. Then it starts normally.
  • Your normal start-up screen: your bootloader ignored the file. That is useful to know too.
  • About 15 seconds of black, then a normal start: unknown firmware, and it couldn't show the code.
  • A black screen that doesn't go away: it stopped on purpose because something didn't check out. Power off, remove the card, power on, and the unit is back to normal.
Please post
  • Which of the above you got, with a photo of the screen if you can, or the code;
  • Your device type, if you know it, and which firmware you have (stock Kodak, 0dan0's, or something else).
It recognises Kodak's stock Type D firmware, videodoctor's Type D build, the Type D releases from this project and 0dan0's latest A/B/C/D builds. Stock A, B and C aren't in the list yet. If you have Kodak's own A, B or C firmware file, I'd be glad to add support for those.
This is an early test. Once it's confirmed working, the source will go into the GitHub repo with the rest of the project.
  • FW96658T.BIN
Stick50jr
What it is
How to try it
What you may see
Please post
No problem with this firmware and machine:)
Reactions: melw
fishgee
34
30
Type Test Utility. Worked as advertised on my Type C unit. Results below.
Reactions: melw
ioeuqr
A wiki would be absolutely clutch for organizing a multi-stream project like this.
I second the need for a wiki. These massive posts are just too much to be useful anymore. Questions get asked over and over again, and power users who know were this stuff lives keep replying with the same answers over again (thank you!), deep linking to old posts that are difficult to find.
ioeuqr
What it is
How to try it
What you may see
Please post
For those of us who aren't so fast on the trigger for taking photos of the screen, could the .bin be made to output to a text file on the SD card?
zbig
Hello everyone,
I am looking for a clean, unmodified stock firmware 2.0 dump (FWDV280.BIN) to restore my Kodak Reels 8mm Film Digitizer back to factory settings.
Here are my unit details:
  • Serial Number: D0926148BK00379 (2026 batch, came with factory firmware 2.0)
  • Current issue: The Mac84 lookup tool misidentified my serial number as Type B. After flashing Type B firmware, the unit powers on, but the buttons are completely unresponsive and I cannot access the menu.
If anyone has a clean factory backup from a 2.0 unit (or a D0926... / H2825... revision) and could share the .bin file so I can recover my scanner via SD card, I would really appreciate your help! Also letting @Mac84 know about this new D0926 serial prefix for the lookup tool database.
Thank you!
melw
Hello everyone,
Thank you!
Hi @zbig
Your unit is a Type D. Serials starting with D0926 are Type D. The lookup tool currently suggests B for every serial that isn't on its Type A list, which is how this happened. Another D0926 owner had exactly the same symptom with B firmware: unit starts, buttons dead.
It's recoverable:
  1. Download 0dan0's stock Type D recovery image from this thread post #143: Unzip it, so you have FWDV280.BIN itself, not the zip.
  2. Copy FWDV280.BIN to the root of a FAT32 SD card, 32 GB or smaller.
  3. Unit off, insert the card, power on, and leave it alone for half a minute or so while it flashes.
Stock Type D should then start with working buttons. After that you can also use the Type D builds from this thread ifyou like.
