PiStorm on the Macintosh SE
superbenk
17
I'm also interested in the current state of this project. Sounds extremely interesting!
AlexCL
73
Not too much to update for functionality...
Someone got a Macintosh Classic to boot with the PiStorm but still with limited functionality of Floppy only..
Most of the updates are on the PiStorm Discord Server under the #macintosh channel.
Reactions: Nitram78 and retr01
AlexCL
73
Minor Update on the PiStorm on a Mac SE...
I used an AI agent to patch the standard PiStorm Emulator to force 24-bit addressing on the 68020, 68EC30 and 68030 emulated CPUs.
Those CPUs couldn't boot on a Mac SE due to being 32-Bit addressing CPUs.
The patched emulator is here:
I ran speed tests on all the working CPU types on Speedometer 3.23. The 68020 appears to be the fastest. The Mac Classic is equivalent to 1.0 for speed factor.
AlexCL
73
Huge Milestone for PiStorm on the Macintosh SE tonight!
I was working with an AI agent to try to get a virtual disk system working so I could install software larger than the 800k floppies I've been working with. After two days of back and forth I got a janky but working SCSI emulator that runs off of an image from the SD card. I had to format the SCSI drive on the Mac with LIDO and then copy over the System Folder. It actually booted! Then I opened the disk file with Basilisk II and installed System 7.5.5 and it works.
Ran lemmings and MacFilm for tests too.
Nitram78
12
Thank you for your experiments, which are really pushing things forward, @AlexCL
Thank you for trying to help me on discord as well, by the way.
Reactions: AlexCL
AlexCL
73
I did a build limiting writes to physical RAM to just the sound and video buffers and tripled the CPU speed. Video also seems faster but disk is reporting slower.
I re-ran it with the 68EC020 CPU and it is even faster...video went up to 7x speed and HDD went to 3x.
AlexCL
73
Update on status of project:
-128 MB of extended memory working.
-68040 CPU working internally with RAM, ROM and Software Accessories working 32-bit.
-ROM seen as 32-bit by software using a Quadra 900 donor ROM for drivers.
-QuckDraw Color working well enough for some software and games to run without crashing (Crystal Quest 2.2c).
-Dynamic dithering of greys to simulate up to 256 greys on-screen.
-Working on getting Sound Manager 3 working so more software will work.
-Raspberry Pi Zero 2 W confirmed working and not causing undervolt issues like the Raspberry Pi3 a+.
-Remote control and diagnostics built in to the emulator allowing Hermes AI agent to remotely control, diagnose and run tests.
AlexCL
73
This is awesome! Could this work on a Plus?
In theory...the BBU on the Macintosh SE runs sound and video directly from RAM bypassing the CPU so it was easier to use the PiStorm on as it just needs to write the video and sound to RAM and can keep the rest of the memory in 32-bit Raspberry Pi RAM.
phipli
261
The BBU is mostly just a rationalisation of the logic on the Plus - the big performance difference is that the video buffer is twice the size meaning that it only needs to stop the CPU accessing RAM half as often and you get a speed gain, but long and short - the logic on the Plus is pretty similar, just not all under one roof.
