Graziano
Hello,
I am using a "C" version, and the scanning process is too fast.
I scan the film reels without using any zoom; by raising my 12mm macro lens just 5.2mm, I achieve a full frame without needing to zoom in.
To avoid the risk of jitter and the need for multiple passes over the film, it would be ideal to reduce the speed to one frame per second instead of two.
Is this possible by modifying the firmware?
melw
Type D - FW 295​
  • 24 FPS support. In recording mode it's possible to toggle now between 16/18/24 frames per second.
  • Card only mode. Build and deploy with -Card to generate FW96658T.BIN - this build never flashes anything on the device, it is executed at boot as long as the bin file is kept on the SD card.
  • Type probe. Experimental Type probe that launches in Card mode and attempts to detect which firmware or device type you're running.
For permanent flash:
  • FWDV280.BIN: put this on the card together with empty folder NVTDELFW
For runnings from the card:
  • FW96658T.BIN: the firmware will boot as long as it's found from the card. Once removed, the previous / permanently stored firmware will be used instead
For type probe:
  • See thread post #833
The source, the user guide and the changelog are on GitHub: https://github.com/melw/reels-type-d
  • FW96658T.BIN
  • FWDV280.BIN
thilosde
7
Type D - FW 295​
For type probe:
Ich denke dieses FW96658T.BIN ist nicht das richtige. 171.3 KB is too small
BravaCentauri83
Type D - FW 295​
For type probe:
New A3026 owner here (picked one up during the Amazon Black Friday deal). I tried running FW 292, which works until I hit record—at that point, an "X" box appears across the bottom of the screen and the buttons become unresponsive. After a few seconds, it returns to the capture menu.
Also, the attachment for this FW 295 release seems unusually small, and it looks like the same temporary firmware used to check the existing version rather than the full build. Could you confirm if the right file is attached?
Reactions: zip131
ioeuqr
I had the same issue. For me it turned out to be the SD card. Get a quality card (V30 is recommended) and format it in the Reels machine itself. Settings > Erase Card.
melw
I haven't seen the "X" box before. As another reply suggested, check your SD card setup? 32GB FAT32, high speed class (v10 or better). The ExFAT formatted large SD cards are known to have issues on the Kodak Reels devices for struggling with keeping up with required write speed.
Regarding the unusually small file: It's a patch file, the runs on top of the device firmware. If there's an unrecognized firmware, it does nothing - in practice it should work only on top of Type D compatible devices/firmwares. There seem to be quite many firmware and device variants, so again it's possible that it doesn't work (same as the probe showing unrecognized device). But still worth a try.
EDIT: I tested it on my device having FW 292 and then running the FW 295 as a patch on top of it from the SD card. Once card was removed, it went back to booting with FW 292.
Reactions: zip131
thilosde
7
Type D - FW 295​
For type probe:
I think the FW96658T. BIN should be the same size as in post #846.
Reactions: FrenchNum
Boojakascha
31
16
Out of curiosity, did any other D owner attempt the hardware mod and found themselves with too much zoom?
What kind of lens/spacer did you finally land on?
I know one person kept the stock lens and reduced the distance, which worked well for the D type :D
Reactions: lrdgreen89
FrenchNum
12
For A3026 owners - calling @thilosde @ArgieBargie @FrenchNum :
Nobody has an A3026 firmware file yet, and the type probe showed the factory firmware isn't A, B, C or D. But the bootloader on these units can run a firmware file straight from the card without flashing it. That lets you test whether Type D works on your scanner:
  1. Download the attached FW96658T.BIN - it's Type D FW 292 in test mode. It will not flash anything on the device.
  2. Put it alone on a FAT32 card. Make sure no FWDV280.BIN is on the card,.
  3. Power on. The startup screen should say "FW 292 Type D". Check whether the buttons respond, the motor runs and the picture looks normal. If the motor misbehaves, or there are any other problems, switch off the unit.
  4. Power off, remove the card, and power on again: the scanner should be back to its previous firmware and state.
Please report what you see. If everything works, your scanner runs Type D firmware fine, and you can flash FW 292 normally (the previously shared FWDV280.BIN) if you prefer to do so. If you already flashed B and your unit is dead, this tells you whether flashing D is worth trying.
From all the information posted so far A3026* units are not Type B and you should not attempt flashing Type B firmware on them.
Hi @melw @thilosde, @ArgieBargie, great news ^^
Great, the engine is working again and the buttons too !
Reactions: melw
Hook Line and Tinker
37
21
I don't have an explanation for why this worked but it worked for me and at least one other member. With the SD card in the Reels unit and using the unit's menu, scroll over to settings and find "Erase SD Card". After clicking to erase, cycle power and see if it returns to normal operation. Of course, save any scans from the card before erasing it. I even tried formatting the card prior to discovering this and it did not work.
BravaCentauri83
Fixed it! Turns out I grabbed an older spare SD card to load the temporary firmware and didn't think about how it might struggle with recording. Switched back to my main high-speed card with the firmware on it, and it's working great now. Thanks for the help, everyone!
zip131
First of all, greetings to everyone.
I have a Kodak Reel with A3026 firmware, version 2.00 (Firm2.0.jpeg).
I tried using the FW96658T.BIN file, but without success (err.jpeg).
Since the firmware for A3026 serial numbers is not yet available, I decided to disassemble my device and extract the firmware from the flash memory chip (25L3236F) mounted on the motherboard.
I am making it available to @melw and anyone else who might be able to work with it (KH25L3236F(OTP)@SOP8.BIN).
Additionally, I have included photos of the front and back of the motherboard, as well as the display; perhaps these might be useful to someone.
To @melw: I am available to carry out any necessary tests.
Best regards and have a great evening, everyone.
  • KH25L3236F(OTP)@SOP8.BIN
Stick50jr
what is your hardware revision? I feel 12 mm is too much for model D
Mine is a Model D, Serial No K2225148BK000286 Model No KODREELSEU
i've been successfully running Melw's FW295.
How are the model D optics different than previous models.
I looked at your posts and see that you ultimately used a 10mm FL.
I have lots of Std8 and Super8 reels to archive.
I've used Gemini AI from Google to confirm that the Model D optics are in fact best suited to 10mm FL lens.
Thank you for triggering this for me.
I see you used a mount from AliExpress to get the distance from the sensor... I'll see if that is still available.
I'm hoping I'll be able to do it all without cutting the case and re-inserting the sensor/lens cover.
What hole spacing was your lens mount from AliExpress?
Thanks again
Reactions: Boojakascha
Boojakascha
31
16
Thanks again
The Model D changed to a different sensor, the OmniVision OS04D10. This necessitated different optics.
On the topic of Aliexpress: The party trick is the 18 mm spacing between the drill holes. The support pegs are missing on those, but that's not a problem. This is the link of the ones I bought:
Personally I did drill and rose up the sensor, but you can surely start out with the as-is state and change lens position to regain a sharp image after a lens swap.
Make sure to not touch the image sensor with the lens.
Reactions: Stick50jr
Stick50jr
Thanks for the link... I find Aliexpress a bit tricky to find things normally. Which did you buy, 6mm or 8.5mm?
Boojakascha
31
16
I got all three =) Two pieces each, in case I hurt the treading again. But I must say the build quality is way better than on the stock standoff and my lenses and adapters thread much better to these three.
