WON'T POWER ON: PowerBook Wallstreet PDQ
2,232
I have two PowerBook Wallstreet PDQ notebooks that once worked fine several years ago), but now neither will power-on when I press the POWER button (long or short press).
When I first plug-in the Apple AC Adapter, the fan spins at full blast and the green power LED lights for a couple seconds, and then the fan and LED power off. After that, pressing the power button does nothing.
I have no working battery anymore, so I only have AC power from the stock adapter. I've tested both PDQ machines with nothing in either drive bay and with even the hard drive removed, but to no avail. Both PDQ machines respond in the exact same way — power button doesn't power them on, despite my hearing the fan spin and LED light initially after connecting the AC Adapter. I've swapped their CPU cards, but again, it doesn't resolve the problem.
Here's a video overview of what I explained and mentions a couple voltage measurements I made too...
Wallstreet repair experts...
How can I fix these machines?
2,232
Just to be clear, it was not a car crash sound but a sound of breaking glass, which is very different.
And I heard that for the very first time, even though I’ve been testing both of these machines for many weeks now. The only thing that I did that could’ve triggered it was my use of DeOxit D5, which was done based on a suggestion made to me earlier in this thread. Of course I let the alcohol in that cleaner vaporize, and I even wiped away the excess and left the machine for 24 hours before even applying power to it, but maybe that caused the sound? Based on my research online, it seems something related to RAM and I did get that one message about a ram module being bad. But I never got a message about that RAM module being bad prior to my use of DeOxit D5, and I even ran multiple detailed ram tests in the past, which showed that RAM module to be just fine.
Froggy814
204
57
Squaw Valley, CA
I don't know if you can, but I would try to eliminate components. Is there anyway to like take the boards and test components seperately? You shouldn't need a keyboard or trackball hooked up. Or HD or floppy. You could try eliminating the power input board by figuring out which voltages it outputs and supplementing your own. If you can try that, That's about all i can think off to try next.
2,232
With two "bad" machines, swapping component between them is not effective to eliminate problems common to both machines. So the simple answer to your question is "No."
There are many videos on that page and I didn't have time to watch them all. If you have a very specific video URL and timestamp, I can jump to that.
Tried making a video this morning, but I videoed the wrong machine and then powered on the other machine without making a video and it made the broken glass sound. I am forced to test that again tomorrow, since these STUPID PDQ machines refuse to boot for 24 hours once they lose power. It's totally and utterly maddening and makes troubleshooting nearly impossible to do while keeping your mind sane.
I truly hate the PowerBook Wallstreet series.
Froggy814
204
57
Squaw Valley, CA
I didn't mean swap parts... I mean't take the bards or take parts off the boards and test them with a multimeter and direct power. Stuff like that.
2,232
The devil is in the details...
What chips to take off?
What boards to de-chip?
What specifically to test?
And how in particular would the test be performed?
2,232
I was planning to make a video of the silly glass breaking sound this morning, but what do you know, yet another maddening development. I came into the office today only to find the machine very hot. Neither of my two PDQ machines have ever done this before. It's almost like it was on all yesterday and last night. But like I said yesterday, I pressed the power button and got the boot chime and then glass breaking sound and then nothing on screen, no HDD powered, etc. So I assumed it just lost power and I needed to wait. So when I found the machine hot this morning, I pressed the power key and got nothing at all, so I disconnected power, removed the keyboard and felt the heatsink, and it was super hot. So the CPU seems to have remained active since yesterday morning. Never thought the glass breaking sound (which seems to be related to a bad RAM module) would cause this. I now have a floor fan aimed at it, hoping to cool it down.
And no, my other PDQ wouldn't respond today either when I pressed the power button.
I'm so depressed and disgusted with these machines.
2,232
Well, despite finding the machine (CPU heatsink) being super hot as I reported yesterday, it seems to have not harmed it insofar as I got a normal boot chime this morning, and seconds later it gave me the glass breaking (or "metal clanking") sound today (which I think means a RAM module error). I captured it on video/audio for you here...
I never had a single RAM module error prior to my use of DeOxit D5, and I only used because of a suggestion earlier in this thread. I've used it before on other things with issue, and I always allow the alcohol to dry before powering anything, and I even allow it to dry further overnight before connecting any power. And yet, now the one PDQ gives me this RAM module error. As if I didn't have enough problems with these horrid machines previously.
Honestly, the Wallstreets are my worse vintage Mac experience ever. With an SE/30, many things can and do go wrong, but there are so many people using them, the advice out there has been plentious for decades, and we can also resolve the issues in short order based on that abundance of guidance. But the guidance regarding Wallstreets is almost non-existent, and this thread is perhaps the most informative of anything out there, even though it doesn't come close to resolving the various problems I've seen. It's depressing beyond words.
