WON'T POWER ON: PowerBook Wallstreet PDQ
2,230
I have two PowerBook Wallstreet PDQ notebooks that once worked fine several years ago), but now neither will power-on when I press the POWER button (long or short press).
When I first plug-in the Apple AC Adapter, the fan spins at full blast and the green power LED lights for a couple seconds, and then the fan and LED power off. After that, pressing the power button does nothing.
I have no working battery anymore, so I only have AC power from the stock adapter. I've tested both PDQ machines with nothing in either drive bay and with even the hard drive removed, but to no avail. Both PDQ machines respond in the exact same way — power button doesn't power them on, despite my hearing the fan spin and LED light initially after connecting the AC Adapter. I've swapped their CPU cards, but again, it doesn't resolve the problem.
Here's a video overview of what I explained and mentions a couple voltage measurements I made too...
Wallstreet repair experts...
How can I fix these machines?
S. Pupp
97
53
@S. Pupp I take that to mean you had the same problems I've been mentioning in this thread?
Honestly, I've had a hard time believing it is just me and just my two PDQ machines. Surely this must be more widespread. Yet, there are few fellow PDQ owners who've chime in with something to add to this thread. Maybe most threw out their machines long ago. Quite sad, because the PDQ is an otherwise great "bridge machine" to have (if and only if it works reliably).
It has been a few years since I worked on my PDQ's, and my memories are not at all clear. I do recall that at least one of the two had a booting issue that was somehow fixed. I recapped both PDQ's, but unfortunately don't recall what else I did that might have solved the booting issue.
