Jockelill
36
38
Can a ROM SIMM be created that has a switch to switch between two different ROMs while the Power Mac is running?
The first ROM would be a working ROM to boot into Open Firmware.
The second ROM would be the target for flashing.
Boot the first ROM into Open Firmware, then flick the switch to select the second ROM for flashing. Then use the serial port to transfer the flashing program and the new ROM.
This would eliminate the need for an external flasher and it would add safety to the ROM flashing process.
Yes, is the short answer, but it’s a little bit more complicated than that. Essentially the ISP that @zigzagjoe has created does this for the se/30 and Quadras, it even has a reset output that automatically restarts the computer when flash is finished. It uses a RP2040 which you hook up to your PC, the ROM then appears as a storage device, and you reflash it with uf2-files. Since it has 16MB of storage, there is a switch onboard, switching between two banks, so on one of them you can put “last known working ROM”. This device is perfect for playing with the rom and for rapid development.
Something like this is what I would like to see also for the PPC :). Issue is of course the 64 bit data path, so even with an 2350B with 48 GPio it would need multiplexers to work, plus buffers towards the machine and so on.
For a first test of hacking I believe @dougg3 idea of 8 standard chips is easier to have up and running.
joevt
362
137
As long as it's running fully from RAM at the point that you switch ROMs it would work fine.
Should perform a test in DPPC to see if anything (exception handlers?) in ROM is accessed after Open Firmware is set-up. Can do a copy to RAM and virtual memory to compensate maybe.
dougg3
34
www.downtowndougbrown.com
Yeah, if the ROM is accessed after OF is up, it would be tricky to add a switch because it's game over after the switch is flipped to the second ROM.
If you can prove the ROM is not accessed, or guarantee to not access the ROM after a certain point and give the user a chance to flip the switch after that point, then yes, I think a switch could potentially work. You could have the switch re-route the /OE and /WE signals to a different set of 8 flash chips, or maybe find larger chips and use the switch to toggle the highest address line on them or something. I think that's similar to what Garrett's Workshop's ROM SIMM does with the separate selectable ROMs.
joevt
362
137
The name of the ROM Flashing Utility is "Flasher (TNT 0.6)". I ran it in DingusPPC emulating a Power Mac 9600 v1.
DingusPPC shows the code below after setting the RomWE bit of the ROM Timing Register.
It uses 8 byte read/writes to FFC00000 and FFE00000 to probe the ROM (offset 0 and offset 2 MiB).
It writes patterns 9090909090909090 and 909090909090909.
Then it tries to read the results.
DingusPPC doesn't emulate flashing yet, so the result is just the bytes of the ROMs at those addresses.
I guess real flash chips would return some kind of Flash Chip ID.
It looks like the code for read-ROM-id-AMD-4M? or read-ROM-id-intel-4m? in the B&W G3 Firmware update code which also uses 64-bit read/writes.
You can probably also find similar flash id code in flashrom.
https://github.com/joevt/flashrom
Working on porting B&W G3 Firmware update to ANS/TNT Open Firmware.
I'll try making DingusPPC emulate flashable ROM to test that and to see "Flasher (TNT 0.6)" work to completion.
joevt
362
137
"Flasher (TNT 0.6)" expects AMD 28F020 (vendor/ID = 01,2A) or Intel 28F020 (vendor/ID = 89,BD). Since these chips are 2 Mb there are 16 chips = 4 MiB.
8 chips are accessed using 8 bytes at ROM base + 0 (1 byte per chip). The other 8 chips are accessed using 8 bytes at ROM base + 2 MiB (1 byte per chip). All chips must report the same vendor / ID.
Reactions: ClassicHasClass
Jockelill
36
38
Yes, unless you hack the flasher tool you're stuck with those chips. I know @dougg3 managed to hack the flasher tool to at read the M29F160FB5AN6F2 chips (those are used for Rominator and similar), but I think @dougg3 idea here was to use socketed chips and then flash them one by one (8 times) with an external flasher like the TL-866.
Reactions: dougg3
joevt
362
137
Did Apple reverse the order of the data bits for 8 of the 16 Am28F020 chips?
i.e. D0-D7 -> D7 D0?
dougg3
34
When I was investigating an older version of the Flasher app, I saw that there was an option bit that would cause the unlock/erase/etc. sequence data bits to be reversed on the second set of chips, and at least one of the items in the table of possible machines+SIMMs had the option set. So yeah, I think at least on some programmable stuff, they reversed the data bits.
I'm pretty sure the reason would be that it greatly reduces the complexity of the PCB routing. The data bits are along the bottom of the chip:
So if you have 8 chips on the other side of the board, reversing the data bits on them allows DQ7 on the back chip to be hooked to the same data line as DQ0 on the front for example.
joevt
362
137
What is 28F020 command 30h? I don't see it in the Intel or AMD data sheets. Do flashable ROM SIMMs have extra logic to catch this command?
dougg3
34
Sounds like chip erase but I think that's only the AM28F020A.
Agreed, I think it's chip erase. In my disassembly of Flasher I did see command 30h used in the erase function for a PowerBook Duo flash ROM that has Am28F020A chips (manufacturer 01h, device 29h).
Interestingly, it's also used for erasing with several other configs including a ROM SIMM in several Quadra models that looks for manufacturer 01h and device 2Ah, which matches the Am28F020. I'm not sure if it was an undocumented command in that flash chip, or a bug in the Flasher app, or what. Because some other SIMMs with the Am28F020 use the documented "write all zeros and then command 20h for erase" algorithm instead. Dunno what's up with that! 🤷‍♂️
joevt
362
137
Right. There's some code that chooses between different Erase and Program methods.
My emulation return 01/2A as manufacturer / device IDs so I don't know why the code would use the 30h command for erase.
  • XCOF_129_.dumpxcoff.txt
joevt
362
137
It appears that "Flasher (TNT 0.6)" cannot do Intel 28F020 chips because it's looking for a device ID of DB instead of BD from 8 of the chips.
AM28F020.PDF has device ID 2A. It describes non-embedded erasing/programming commands (20h, A0h, 40h, C0h).
AM28F020A.PDF has device ID 29. It describes embedded erasing/programming commands (30h, 50h)
For AMD chips, "Flasher (TNT 0.6)" expects device ID 2A from AM28F020.PDF but uses the embedded erasing/programming commands of AM28F020A.PDF.
Maybe the PDFs got the device IDs reversed? I dunno.
For Intel chips, "Flasher (TNT 0.6)" uses the non-embedded erasing/programming commands of AM28F020.PDF.
I finished the emulation in my fork of DingusPPC of the AMD chips for "Flasher (TNT 0.6)" (code not committed yet).
It can also do Intel chips (a hack can be used to make 8 of the chips return DB instead of BD to work around the bug in "Flasher (TNT 0.6)" but probably the better solution is to change DBDBDBDBDBDBDBDB to BDBDBDBDBDBDBDBD in the XCOFF resource in "Flasher (TNT 0.6)").
The PDM flasher (Power Mac 6100/7100/8100) and New World Open Firmware flashers (iMac G3, B&W G3) are not supported yet in DingusPPC.
Reactions: bakkus and dougg3
joevt
362
137
Another note: "Flasher (TNT 0.6)" doesn't try to detect the ROM type before flashing. It says AMD for both AMD and Intel chips.
"Flasher (TNT 0.6)" has direct drawing to the screen to show a progress bar - vertically oriented. 480 lines tall, 80 bytes wide. It fills up for each stage of the flashing - three different colors - white, black, checkerboard (or strips if not using B&W mode)
joevt
362
137
There are newer Flasher utilities that support later PowerPC Macs besides PDM and TNT but that doesn't matter for this ANS project.
read 'XCOF' (128) ":Objects:xcoffResources:CopyToFlashPDM.xcoff";
read 'XCOF' (129) ":Objects:xcoffResources:CopyToFlashTNT.xcoff";
read 'XCOF' (130) ":Objects:xcoffResources:CopyToFlashCAT.xcoff";
read 'XCOF' (131) ":Objects:xcoffResources:CopyToFlashPBX.xcoff";
read 'XCOF' (132) ":Objects:xcoffResources:CopyToFlashM2.xcoff";
//read 'XCOF' (133) ":Objects:xcoffResources:CopyToFlashPSX.xcoff";
read 'XCOF' (134) ":Objects:xcoffResources:CopyToFlashTanzania.xcoff";
read 'XCOF' (135) ":Objects:xcoffResources:CopyToFlashOpus.xcoff";
read 'XCOF' (136) ":Objects:xcoffResources:CopyToFlashGossamer.xcoff";
read 'XCOF' (137) ":Objects:xcoffResources:CopyToFlashPEx.xcoff";
read 'XCOF' (138) ":Objects:xcoffResources:CopyToFlashGrackleROM.xcoff";
read 'XCOF' (139) ":Objects:xcoffResources:CopyToFlashGrackleRAM.xcoff";
johntucker
10
10
If you've been following my ANS 700 tinker log you'll have seen that @johntucker has recent come forward having a ANS that is able to boot into MacOS! This was a much talked about and sought after ROM back in the day as ANS's only run AIX, until now!
MacOS 8.6 Booting on an ANS via @johntucker
@johntucker, @joevt, @ClassicHasClass, and myself have been working to get these ROM's dumped and some analysis done on them to see the differences (I'll let @joevt post his OF analysis below).
Current Status: We have the ROM's dumped, but now need a way to program them. The ROM board/s are AM28F020 and I believe are the same/similar to what other PowerMacs had (photo via @johntucker )
I'll keep this first post updated as all the details emerge.
Eric,
Oh my, I was wondering what was happening & I just stumbled upon this.
I had no idea that all of this was going on. I am so sorry.
I will review all of this thread and if there is more that I can do I will step up.
adios,
jt
johntucker
10
10
I will post ROMs to my MacROMan fork and add some notes here later.
The last ROM we're working on has problems. It has errors in byte lane 2 (8 lanes numbered 0 to 7).
Byte lane 2 is the address with least significant bits = 010.
077d.28f2.1  "Boot TNT 0.1p..]"  4096
9630c68b    045a3ff2.04a8169b.03334745.03ffe575    02d3e2e8.0324a294.0219ffa8.02895fd8.02ada29f.038afd23.023e4a4a.02aac18a:a71fb907dd180b8a
93e6ab8b x  045a3ff2.04a8169b.0330fd2a.03ffe575 x  02d3e2e8.0324a294.0217b58d.02895fd8.02ada29f.038afd23.023e4a4a.02aac18a:a4d59e07dd180b8a
    ^^                        ^^^^^^^^                               ^^^^^^^^                                                  ^^              <- errors in byte lane 2
Maybe there's an issue with one of the chips not being seated? Or corrosion on one of the pins related to byte lane 2? Try cleaning the pins or pressing the flash chips.
The attached Open Firmware script will calculate the checksums of an Old World Power Mac.
Connect via serial port, type dl to begin download, then paste the contents of the file. I added the "end of file" marker (Control-D) at the end of the script which ends the download and begins execution of the script.
The output should look like this:
0 > dl
calced: 962F6C13  045A4042.04A81401.033345A1.03FFE57D  02CDF1E7.031ED7CA.0213F083.0283859E.02A7B7CC.0385549F.02388B9D.02A4FFAA:D540B3DD5BCF9CAA
stored: 962F6C13  045A4042.04A81401.033345A1.03FFE57D  02CDF1E7.031ED7CA.0213F083.0283859E.02A7B7CC.0385549F.02388B9D.02A4FFAA:D540B3DD5BCF9CAA
 ok
0 >
"stored" is the values that is stored in the ROM.
"calced" is the values calculated by my script using the bytes of the ROM.
Compare with previous results in romlist.txt.
@joevt,
I have been out of the loop.
Which ROM has the problem. I most certainly can double check and create more dumps if necessary.
Sorry to be slow on the uptake.
adios,
jt
joevt
362
137
I think #6 explains that we have a good copy of that bad rom.
The ROM has version 2.26b6 and should have md5 = d1d3720c38143eb2bac86b8393318529
As for what I'm doing:
I'm working on ANS emulation in DingusPPC. Maybe one day it will boot AIX or macOS. I am working on the emulation of the fast wide SCSI PCI cards. They need to exist for Open Firmware to believe the system is an ANS machine instead of a TNT machine. I don't think they need to actually be able to emulate a connected SCSI device since the ANS has built-in SCSI as well and macOS won't boot from the fast wide SCSI cards anyway.
I've added emulation of flashable ROMs to DingusPPC so we can see how the flash utility works in classic Mac OS and how to create a flasher that does the same job in Open Firmware in case Mac OS is not bootable.
We need a method to create ROM SIMMs compatible with Power Macs so that we can use these ROMs with real Power Macs or ANS machines. Did someone say if ANS has built-in ROM or not?
There are some options:
- a flushable ROM SIMM - needs to be externally flashed.
- a flashable ROM SIMM with a switch - boot into Open Firmware using built-in ROM, then use the switch to replace the built-in ROM with the ROM SIMM to perform the flash in Open Firmware.
- a flashable ROM SIMM with two sets of ROMs and a switch. For machines with no built-in ROM, the first ROM set is externally flashed; the switch can be used to select the alternate ROMs for flashing in Open Firmware. This may be overkill - useful only if you don't have a programmer or if you want to ensure that there is always a usable ROM.
Reactions: thecloud
ClassicHasClass
575
www.floodgap.com
I'm pretty sure (@johntucker can confirm) that the MacOS ROM does allow you to boot from the internal SCSI. But it could certainly boot external if needed.
The ANS does not have ROMs on the logic board; they are always on a SIMM stick.
