Breaking the 36MB RAM limit on the LCIII
lilliputian
276
122
Los Angeles, California, USA
That's a big'un!
Here's a photo of mine that holds them at a slant. Now, these are 30-pin SIMMs, and so wouldn't be suitable for an LC III, but they also made ones for 72-pin SIMMs as well. (These particular ones are "SimmSaver/30" modules, loaded with four 256k SIMMs each.)
lilliputian
276
122
Btw, if you look for SimmSavers specifically, the nomenclature is a little confusing:
SimmSaver/30 - 4x30-to-30
SimmSaver/8 - 4x30-to-72
SimmSaver/8² - 8x30-to-72
SimmSaver/32 - 2x72-to-72
Sphere478
15
Noticed something... maybe you all are already aware but the module I ordered isn't wired like a normal simm it seems the two sides of the simm contacts are separately wired.
was that anticipated?
Sphere478
15
Glad I saw that before trying to plug it into something lol.
any insight?
if memory serves, there is also a 256mb version of this module which basically confirms that pinout is non standard at the very least, damagingly incompatible at worst. As 128mb is the max for 72-pin simms usually
asked the seller what they knew about them, this is what they said
“Hello, Those mem boards come from a HP HPUX Workstaion, models C100, C110, C160, C160L or a C180. Those workstations use PA-Risc processors. They are installed in pairs.”
trag
406
193
any insight?
In my experience, the PA-RISC work stations used standard 72 pin SIMMs. At least the ones I worked with did.
HP made a pretty penny claiming you needed their special memory in their PA workstations and in their printers of the time....
I once ordered a PaintJet XL300 (IIRC) and it would not work with the HP brand 72-pin memory installed. I installed some no-name 72-pin SIMMs I had on hand instead and it worked like a champ.
Sphere478
15
So there is no doubt that these are compatible with normal simm sockets?
why would they separate the pins unlike normal simms? What did the sockets that these went into look like? Any chance they have more pins on the underside?
trag
406
193
I wouldn't say that there is "no doubt". It's always possible that HP made more than one line/revision of PA RISC systems using different pinouts in the 72 pin sockets. That seems unlikely, but back in the day of mini-computers a lot of unlikely things happened...
Sphere478
15
Found a ebay listing with a interesting claim.
this is supposedly a lc-575 logic board in a color classic with the power pc upgrage
here is the interesting bit.
seller says that it is 132mb which is functional under the 6040 but only 36mb is functional under the power pc processor.
