Breaking the 36MB RAM limit on the LCIII
453
Not really - some of us migrated entirely away from other forums when TD came into being :)
Hence, the "have been" caveat, Kai! ;)
I've been having trouble finding much of interest back there in terms of development/tinkering with hardware since the mass migration of talent. Hope you folks don't mind my tagging along, hopefully a side order of crazy added onto the menu for this place is appreciated.
Reactions: Kai Robinson
max1zzz
673
It works! Just have to hope that simm will still fit in the case :)
453
Forgot to ask about the two wires on the layout. Couldn't see if they lead to addressing for a single or multiple Ranks. At first glance I'd thought you were powering that bloody big bodge of ICs, very clever way to implement the jumper wiring. Will you be adding the matched header to your Reloaded LCIII designs? Most elegant that I think.
max1zzz
673
The two extra wires pick up the two additional RAS signals form the bottom of the board, it's essentially just a custom quad rank SIMM
I hadn't thought of adding a header to the reloaded designs, I'll defiantly be doing that now :)
453
Thanks, should have figured out it was RAS from the way they run across the ICs as if P&G to the corners of the chips. Brain's only partially online lately, trying to shake off Wuhan Wooziness.
Cool, at least some of my noggin's still up and running. ;)
Plan....... um yes, I deffinatly have one of those!
The good news is a plan is not needed, the SIMM fits just fine with some room to spare :)
HIGH FIVE @max1zzz! You nailed it!
Have you run tests via Apple Personal Diagnostics, MacTest, etc., for 4+ hours to ensure it can handle the rigor of whatever?
max1zzz
673
How goes it on this one? Is your board ready for prime time?
Haven't seen an update on any of your projects for a bit?
Yeah, I am with @Trash80toG4. I am wondering the same thing. :) The LC III is a nice Mac. Can it go to 128 MB like the SE/30?
Well the boards work, I was going to assemble and sell a couple but my cheap source of DRAM IC's fell through and the next cheapest source is about £1 a chip so with 32 chips and assembly I would probably have to sell tham at £60-£70 each which I suspect is more than anyone would pay....
Really need to get around to uploading the board design to github (Along with tha IIcx and Plus boards...)
The LCIII can't go to 128Mb sadly as it lacks the 12th address line needed to get bigger SIMMS to work.
Tangent to this thread on LC III memory expansion, for the 040 based such as LC475, P475, P476, Q605, etc., MicroMac did make a memory that breaks the 36 MB barrier. See this link:
Is this something that can be looked into (or discussed) in another thread? :)
max1zzz
673
Tangent to this thread on LC III memory expansion, for the 040 based such as LC475, P475, P476 Q605, etc., MicroMac did make memory that breaks the 36 MB barrier. See this link:
Would be very intresting to see one of those SIMMS and try to figure out what it's doing, I haven't ever seen one for sale though
You're right. Those come up rarely, if ever. I suspect it was not sold well back in the day due to its high cost versus standard memory, which was more affordable than the "BigSIMM" by MicroMac.
Maybe someone here or on 68kmla will have one? :)
Actually, 64 MB and 128 MB were later possible as memory prices went down. 64 MB and 128 MB SIMMs were installed in various 040 Macs. Many of those 040 Macs have the same boards for specific series. I doubt anything special about the MicroMac BigSIMM as it was a DRAM SIMM. The only issues were single or double banked and other physical constraints of those SIMMs which various discussion can be found elsewhere online.
If anyone knows otherwise, feel free to PM me. Okay, back on topic! :)
453
General maximum memory config info:
It wasn't just memory pricing, release dates of higher DRAM capacity/SIMMs plays a big part as well. Apple's maximum supported memory configs are based on SIMM capacities available and tested at time of release. Models were already obsolescent when higher capacity SIMMs/DIMMs hit the market . . . or Apple Marketing wanted to lead customers to believe so. ;)
Yeah, I agree with those factors. And, I think that Apple did use the words "maximum RAM" in their materials, told all that to the dealers, etc. Many people believed in one big lie about the Q605, LC475, P475, P476, and other newer LC models, such as the 575, that could support more than 36 MB of RAM. :) Of course, people didn't see this as a lie, just simply the "fact" of the time.
However, I do perceive Apple lying to dealers and customers as a huge problem back in the day, and many people blindly believed and trusted Apple. :cautious:
