Documentation for DB15 to VGA adapters
Branchus
Tinker Different Public Relations Liaison 2023
503
I'm regularly asked which adaptor to use when connecting a vintage Mac to a modern monitor using a DB15 to VGA adapter.
There are so many different types of adapter around: some with 10 DIP switches, some with 8, some with 16 and some with none. Some sync on green, some do not. I would love people to come forward with the adaptors they own, include a picture of the adaptor and the DIP switch instructions, so that we can build a resource of all the adapters out there, and the associated documentation.
I have a few, but I'll start with one that seems to readily available at the time of writing this.
I will post details on some of my others soon. If anyone has better pics of this one, feel free to submit them.
Branchus
503
I got this one recently:
If you have the doc for that one would be cool, as it seems to support many other modes than the ones in the sticker.
Txs!
Are some of those switches broken off, or are they just in the "on" position? I'm pretty sure I have complete documentation for this one, I'll post it as soon as I find it...
pfuentes69
380
295
Switzerland
All seems OK, and the adapter is working at 832x624.
I think the previous owner painted with a permanent marker the switches that had to be set “on” for his config.
Branchus
503
Here's another.
Elemenoh
396
390
Bay Area
I have a 10-pin adapter, but the instructions it came with include settings for 6-pin as well. The only thing I couldn't get working was my NeXT 21" color display. It wouldn't sync to a Mac with any of these settings. Anyone know if it's possible to get that display working with any model of Mac?
pfuentes69
380
295
Switzerland
As this is of general interest for many models and not only Macintosh II, I suggest this post is moved to
Vintage Apple > Add-ons, Peripherals & Networking > Graphic Cards & Audio / Visual
Reactions: re4mat
Branchus
503
That makes sense, and has been done.
Reactions: pfuentes69
Mr. Fahrenheit
231
I have had the best luck with the NEC MultiSync adapters that used to ship with NEC monitors in the 90s. Ones like this one. No jumpers required.
Reactions: phunguss
alxlab
315
www.alxlab.com
Here's the schematics I made for the Sony MacView:
Stay tuned for the kicad pcd in the The Lab -> Hardware section hopefully soon-ish. Maybe I'll make two designs. One faithful to the original design which uses edge connectors and wire and another which uses through hole connectors. It will be CC BY-NC-SA 4.0 as always.
I'm not 100% sure if this is the same as the UNIMAC 82D. Would have to sit down and start comparing the manuals to see if they match which I don't feel like doing right now 😵
Edit: The Unimac 82D is the same.
Edit: Fixed the line label for the composite sink. CS should have been HS-CS.
alxlab
315
www.alxlab.com
Ok yeah. Curiosity got the better of me and I compared the sheets and schematics and they seem to match. If you combine the two manual together you get a super set of settings. The Unimac 82D seems to mention the jumper settings for portrait monitors, 2 page mono and 512 x 384 and multi res which the Sony MacView lacks. On the other hand the Sony MacView manual will actually specify the Mac models for different settings so both are nice,
Oct 18, 2021
108
217
Ohio, USA
thehouseofmoth.com
Here's a 10-pin ADB to VGA adapter, not branded. Used it with pins 1, 4 and 5 on to connect various IIx's to a 15" VGA display but haven't used it for anything else. (I removed the thumbscrews from the adapter as they kept getting in the way, typically these are present)
Reactions: alxlab and Branchus
