I finally picked up an Apple eMate 300!
Like many of us, I remember seeing images here and there when the eMate was released for education thinking, wow, that would be a cool device to try. Later, I learned this was a Newton device, but I never really had the chance to try any of this, nor was I in a position to buy every piece of technology that interested me.
Of course, today, almost everything that seemed unattainable then can be found and obtained via the retro-computing treasure hunt that captivates us all!
SO, here I am, finally holding an eMate. This one seems to be in OK condition so I will quickly run through the bullet points of my adventure so far:
I also ordered the memory upgrade card from Androda.
Quesitons and Next Steps for me:
I assume the compact macs are useless here, so I am wondering where I should start with trying to get a backup once I get that far. I see warnings about backups before installing the memory upgrade, but since I have never booted this eMate, how important is this? I have nothing to lose— or do I risk bricking the little guy without a backup?
I know some of you reading this have already been down this road and may have welcome advice. I am looking forward to resurrecting another eMate!
- eMate was purchasd AS-IS, no power adapter, no box, no manuals, no accessories, but WITH original stylus.
- Case looks good, screen seems intact and unscratched. No cracks, but. a little rough around the edges (someone was not careful separating the plastic with a screwdriver or something)
- I have NOT tried to power it on
- Screen hinges seem loose—does not hold display in angled positions (not good sign)
- Started cleaning and disassembly to inspect hinges (and dreaded ribbon cable issue)
- Found both hinges have sprung loose. Ribbon cable punctured ;-(
- Removed display ribbon for possible repair, removed hinges
- Repaired hinge springs and rebuilt, lubed, and installed retention washers
- Power adapter just arrived from a recent eBay purchase.
- Attempt repair of original ribbon
- Reassemble hinges and install NEW ribbon cable (or test my repair)
- Plug it in and see if it boots up!!!
- Obtain some MiMH batteries and attempt the relatively simple looking battery rebuild
- Backup????
- What is the best cable + desktop option for eMate syncing?
- I have compact macs, Powerbook 5300, eMac that dual boots 9/X, 2011 intel Mini, 2014 Mini, M1 Mini.
- I have an old PC card ethernet adapter (works in the 5300)
- I have a small “boneyard” of old cables. maybe a serial cable in there, maybe an old Palm Pilot USB to serial adapter
- Install Memory upgrade card
- Restore???
