GlobalTalk - Global AppleTalk network for MARCHintosh 2024 (and beyond!)
RetroTechChris
20
Ghostscript has a GDI output option on Windows, so it can print to literally any Windows printer.
I'm not seeing that in the options above, perhaps it was added in a later version of GhostScript? I'm on Windows '95, so am limited to what I can use. As noted, I did try a newer version of GhostScript. I think 8.60 was the cutoff.. I was able to find 8.54 but it had issues processing the PostScript from the "LaserWriter"
RetroTechChris
20
2,232
Awesome 2026 #GlobalTalk image created by nanoraptor
caver01
162
I just posted messages about getting GlobalTalk working on my SE/30 over on Discord, and while I might not normally cross-post here too, I figured there might be someone struggling through the same simple problem I was running into.
The issue was this:
AIR configured properly on an SE/30, system 7.1, BlueSCSI2 Wif internet connection. Following the Mac84 guide, everything went fine without errors, and yet NO ZONES show up in Chooser.
my root cause was a firewall configuration. I run a fairly robust firewall using OPNSense. It wasn’t enough to define an inbound UDP 387 port using NAT. The actual traffic was still getting rejected. I had to create an explicit firewall rule on the WAN interface in OPNSense to permit traffic to my AIR host on UDP 387 too. Once this inbound traffic was allowed, Chooser started showing other GlobalTalk zones (after closing and re-opening Chooser).
While this may seem obvious in retrospect, it did cause a little head scratching for me until I decided to check live traffic logs on the router right after posting about it on Discord. I noticed the firewall denying inbound connections immediately and quickly solved my own problem. Even if you aren’t planning to host a shared folder or printer, it seems you still need to properly map the port and permit traffic for Chooser to see the zones!
Ron's Computer Videos
220
310
The issue was this:
Glad you got it working!
caver01
162
Haven’t seen anyone mention this (haven’t specifically searched yet), but I see GlobalTalk zones from the eMate!
Not sure what else I can do with AppleTalk from a Newton device, but it works (via PhoneNET connectors). Kinda neat. I guess I could sync from my eMate to halfway around the world!
Reactions: misterg33
fergycool
Haven’t seen anyone mention this (haven’t specifically searched yet), but I see GlobalTalk zones from the eMate!View attachment 27255
I've tried printing to LaserWriters on other zones from my eMate. Not yet sure if any of the prints worked! :)
Jacexpo
It does work fine, I’ve been printing to as many fellow globaltalk laserwriters as possible!
Reactions: fergycool
fergycool
Excellent. It appeared to work with a Localtalk cable, but then I went down the rabbit hole of connecting wirelessly to Globaltalk from the eMate. I think a few prints worked but not really sure. Changing zones and selecting printers was good, but for actual printing it generally lost connection with the printer. It also did the same for my own Laserwriter so not sure of the issue.
PL212
56
41
I have a vague memory of a proposed namespace for zones linked in this way -- as otherwise the Chooser list would be trully unmanageable. No idea how that would have scaled, even if the zone names had been kept distinct. Maybe only one 'DMZ Zone' would have been shared per organization?
I do think this was many years before the Network Browser in 8.5, by the way -- although that was clearly a further step towards solving the same problem.
And let's not forget PowerTalk,... uh... as somebody who used to use it, about which less said the better...
