Radius FPD/SE - Rotation Transform/HDMI Output via FPGA Project Board - CLAUDE SESSIONS
466
I'll edit in the other threads leading to this at some point.
It's a Cloning Project of the 1086 first gen 64/68Hz version of Radius/SE Card. Card is built in discrete 74LS Logic and readable GAL20V8 ICs. Pre-dates the second gen card with unreadable ASICs. TPD card is infested with same, so neither later card would be cloning target possibilities.
Card is of limited use due to scanline mismatch with conventional displays. I developed a transform that will allow display on a conventional Landscape Display rotated to Portrait presentation.
Adrian's Basement YouTube Video about the earlier FPD/Mac Plus explains card function and rotation problem:
Plus and SE Card supported the same Full Page Display, so connector interface should be identical.
__________________________________________________________________________________________________
Spent a bit of time with Claude Code this evening, here's what Mr. Code laid out:
edit: adding links as I go
"pick up the Radius FPD clone" "continue the PCB reverse engineering project"
466
# Scanline Rotation Transform — Engineering Spec
## 0. Project Context: Cloning the 1986 Radius FPD (64/68Hz Board)
This project clones the original 1986 Radius Full Page Display card for the Macintosh SE — specifically the first-generation **64/68Hz board**, not the incompatible second-generation 1987 75Hz board (different signal timing, not interchangeable).
**Confirmed specs:**
- Resolution: **640 wide × 864 high**
- Color depth: **1 bit per pixel** (monochrome, black/white)
Because this is a clone of real vintage hardware (not a new design driven purely by a written spec), the project has an added prerequisite phase: **capturing and characterizing the actual analog signal timing from a real 64/68Hz card**, since the sync/blanking/porch timings are a product of 1986-era hardware design choices, not a standard later-era VESA mode. Guessing at "similar" timings risks producing a signal the original FPD monitor (or a monitor emulating it) won't lock onto.
### Phase 0 — Signal capture & characterization (new, precedes Phase 1)
**Decision: single fixed timing mode.** The clone targets **Crystal 1 (55.000 MHz)** only:
- Horizontal scan rate: 68.75 kHz
- Vertical refresh: 67.139 Hz
- Total pixels/line: 800 (640 active + 160 blanking)
- Total lines/frame: ~1024 (864 active + ~160 blanking)
This crystal is selected because its nominal rates resolve cleanly to round binary-friendly totals, consistent with straightforward TTL counter-based sync generation — the most likely candidate for the board's actual native/primary mode. Crystal 2 (dual-mode support) is out of scope for this clone.
**Action items (single-mode capture, simplified from prior dual-mode plan):**
- Capture real horizontal sync, vertical sync, and pixel clock timing from an actual 64/68Hz card operating in the 55.000 MHz / 68.75kHz / 67.139Hz mode, using a logic analyzer/oscilloscope
- Confirm exact horizontal blanking split (front porch / sync pulse / back porch, out of the 160-pixel blanking total) and vertical blanking split (out of the ~160-line total) — the 800×1024 totals are inferred from nominal rates, but the internal timing breakdown still requires direct measurement
- Document sync pulse widths and polarity (positive vs. negative sync)
- Deliverable: a single timing table (equivalent to one VESA mode entry) for this specific fixed mode, to drive the FPGA's sync generator
### Phase 0.5 — Physical tap point & interface identification (new)
Separate from signal *timing* characterization (Phase 0), this phase identifies *where* and *how* to physically divert the page buffer output from the original card to the FPGA, without disturbing the card's own display path.
**Hardware setup:**
- "Tested good" card: reference/baseline, kept intact and unmodified — used for continuity-verified schematic development and as a known-good comparison signal source
- Project-box spare card: used for invasive work (tapping, soldering, probing) since it's expendable
**Signals to identify at the display connector (TTL interface):**
- Serial pixel data (1-bit monochrome — likely single data line)
- Pixel clock (PCLK)
- Horizontal sync (HSYNC)
- Vertical sync (VSYNC)
- Possible blanking/display-enable line (BLANK/DE) — confirm whether this exists as a discrete signal or must be reconstructed from sync timing in the FPGA
**Key considerations:**
- **Logic levels:** confirm TTL voltage (likely 5V). If FPGA I/O is not 5V-tolerant, tapped signals need level-shifting (buffer IC recommended over a resistor divider, to avoid signal degradation)
- **Non-invasive tap:** use a high-impedance buffer (e.g., 74LVC245 or similar) to tap signals without loading the original circuit — needed since the original card should continue driving the FPD monitor unaffected, if that's still a project goal, while simultaneously feeding the FPGA
- **Tap point location:** identify the point after the page buffer's shift-register/serializer (where pixel data is already serial, sync'd to PCLK) rather than tapping earlier in the pipeline where data may still be in a different form
**Deliverable:** an annotated schematic (extending the continuity-tracing work already underway) identifying exact pin/trace locations for each signal, plus a level-shifting/buffering plan for the FPGA interface.
## 1. Problem Statement (updated)
The (cloned) video card outputs a portrait-orientation raster scan (row-major, top-to-bottom, left-to-right within each row) at 640×864, 1-bit monochrome, using the original 1986 Radius 64/68Hz board's native timing. The physical display panel is a landscape-native modern device (e.g., HDMI monitor), driven via the FPGA project board. A compensating 90° rotation must be applied between source and panel so the image displays right-side-up.
## 2. Confirmed Coordinate Transform
Verified against a worked 4×7 (W×H) example, pixel-by-pixel, against both terminal points (top-right and bottom-right source corners).
**Source (portrait):** width `W`, height `H`, pixel addressed `(x, y)`
- `x ∈ [0, W-1]` (column)
- `y ∈ [0, H-1]` (row)
- Scanned row-major, top to bottom
**Output (landscape buffer):** width `H`, height `W` (dimensions swap)
- Pixel addressed `(x', y')`
**Transform (rotation direction: clockwise):**
x' = (H - 1) - y
y' = x
### Worked example (W=4, H=7)
| Source (x,y) | Pixel # | Output (x',y') | Output # |
| (0,0) | p01 | (6,0) | x07 |
| (0,6) | p25 | (0,0) | x01 |
| (3,0) | p04 | (6,3) | x28 |
| (3,6) | p28 | (0,3) | x22 |
All four corners confirmed consistent with the formula above.
## 3. Buffering Requirement (Critical)
This is **not** a line-buffer-compatible transform. Output row `y'=0` requires the first pixel of *every* source row — i.e., the entire first source column — which isn't complete until the last source row has been received.
**Implication:** a full source frame must be buffered before any output row can be emitted.
- Minimum: 1 frame buffer (adds ~1 frame time of latency)
- Recommended: 2 frames (ping-pong / double buffer) to avoid tearing while the next frame is being written while the current one is being read out rotated
- Latency estimate: at 60 Hz, ~16.7 ms minimum (single buffer), ~33 ms typical (double buffer)
## 4. Generalization to Production Resolution
The formula is resolution-independent — substitute actual `H` (source height) for production use:
x' = (H_actual - 1) - y
y' = x
**Action item:** confirm actual production resolution and aspect ratio before implementation. The 4×7 example was a worked proof-of-concept only; do not hardcode `H=7` into production code.
## 5. Production Configuration: 640×864 Portrait → 1024×768 Landscape (Centered)
**Confirmed:** source is W=640 (wide) × H=864 (tall). Target panel is 1024×768, physically mounted rotated so the viewer sees a portrait image. Since the rotated source (864×640) is smaller than the panel's native landscape resolution (1024×768), it must be centered with a border.
### Step 1 — Rotate (CW)
Using the general formula from Section 4 with `H=864`:
x' = 863 - y
y' = x
Produces a rotated buffer of 864 (wide) × 640 (tall).
### Step 2 — Center in 1024×768
- Horizontal border: `(1024 - 864) / 2 = 80` px, left and right
- Vertical border: `(768 - 640) / 2 = 64` px, top and bottom
### Combined transform — source `(x, y)` → final panel address `(X, Y)`
X = 943 - y (= 863 - y + 80)
Y = x + 64
Valid for `x ∈ [0,639]`, `y ∈ [0,863]` → `X ∈ [80,943]`, `Y ∈ [64,703]`. Pixels outside this box are border and need an explicit fill value (e.g., black).
### FPGA Implementation Notes
- **Frame buffer sizing (confirmed 1-bit depth):** source frame = 640 × 864 = 552,960 pixels = 69,120 bytes (~68 KB) at 1 bpp. Double-buffered: ~135 KB total — very likely fits on-chip BRAM on most mid-size FPGA boards, avoiding external DRAM/memory controller complexity.
- **Clock domain crossing:** source pixel clock (native 1986 64/68Hz board timing — to be measured in Phase 0) and 1024×768 HDMI output clock (~65 MHz for standard 60 Hz XGA timing) are independent domains. The frame buffer must be implemented as a proper dual-clock RAM/FIFO, not a single-clock design, to avoid metastability.
- **Border fill:** decide and hardcode a fill value (black recommended) for the 80px/64px borders; gate output explicitly during border regions rather than leaving them undefined.
- **HDMI timing:** 1024×768 is a standard VESA mode with well-documented timing tables — confirm target refresh rate (60 Hz assumed) since it sets the pixel clock and output-side buffer read rate.
## 7. Target Display Selection
**Primary target (this spec): 1024×768** — 15" DVI panel already in hand, HDMI→DVI converted. This is the configuration detailed in Section 5 (centered, no scaling required).
**Considered alternative: 1280×1024** — inexpensive, widely available LCD panels. Deferred to a future phase for the following reason: centering the 864×640 rotated image alone leaves large unused borders (208px sides, 192px top/bottom), so a scaled-up image would be preferable — but scaling a 1-bit monochrome image cleanly requires nearest-neighbor pixel replication (no interpolation possible), and 864×640 doesn't scale by a clean integer factor into 1280×1024. This needs a Bresenham-style pixel-replication accumulator, added frame-buffer read bandwidth, and an extra pipeline stage — nontrivial additional scope.
**Recommendation:** build and validate the 1024×768 centered (no-scaling) pipeline first as the primary deliverable. Treat 1280×1024 (with scaling) as a follow-on enhancement once the core rotation/timing pipeline is proven, not a parallel initial target.
## 8. Open Items Before Implementation
- [x] Confirm production source resolution — **confirmed: 640×864 (W×H), 1986 Radius 64/68Hz board**
- [x] Confirm color depth — **confirmed: 1-bit monochrome**
- [x] Single vs. dual timing mode — **confirmed: single fixed timing, targeting the 55.000MHz/68.75kHz/67.139Hz crystal 1 mode**
- [x] Target display for initial build — **confirmed: 1024×768 15" panel, centered, no scaling (primary); 1280×1024 scaled deferred to future phase**
- [ ] Capture and document exact horizontal/vertical blanking breakdown (front porch/sync/back porch) for the fixed mode (Phase 0)
- [ ] Identify exact tap point for pixel data, PCLK, HSYNC, VSYNC (and BLANK/DE if present) on the display connector (Phase 0.5)
- [ ] Confirm TTL logic voltage and FPGA I/O compatibility; select level-shifting/buffering approach
- [ ] Decide whether original card must continue driving its own FPD monitor simultaneously (affects whether tap must be non-loading/high-impedance) or whether the original display path can be fully diverted
- [ ] Confirm target refresh rate for 1024×768 output (60 Hz assumed)
- [ ] Confirm frame buffer implementation: on-chip BRAM (now very likely sufficient at 1bpp) vs. external memory
- [ ] Confirm latency budget tolerates ~1–2 frames of added delay — flag if this is a touch/interactive/real-time application
- [ ] Verify rotation direction (CW, as derived here) against actual physical mount orientation on real hardware
- [ ] Decide and implement border fill value/logic for the 80px/64px letterbox regions
- [ ] Clarify what "64" and "86" refer to in the board's name (vertical refresh? horizontal scan rate? two distinct modes?) — relevant to Phase 0 timing capture
466
Couldn't have explained this better mysel . . . that way at all! :ROFLMAO: Hope this makes sense to the gang here.
Claude figured out the need for dual-buffering with a single frame delay before I could tell him. Maybe triple-buffering with a two frame delay will be required?
Here's my "Worked example (W=4, H=7)" image from the earlier threads:
I input the IF/Then parameters for the top row and left column of the Portrait setup which translated to the top row and right column of the "Standard Landscape Display" setup and it was a done deal! Extension to 640×864 transform is a done deal! :)
edit: never did fix that 75Hz error!
466
Second interaction with Mr. Claude Code, thought it might be interesting:
Maybe make a new discussion specifically addressing the reverse engineering of the PCB
Saved memory
Saved memory
Good to know — that changes how I should hand you stuff. Since you're working visually in Illustrator (even v8, which is EPS/vector-native and predates a lot of "modern" export assumptions), let's lean into that for the PCB reverse-engineering work rather than dense prose or spreadsheets.
Concretely, that could mean:
  • Board maps as layered vector tracings — you photograph/scan the PCB top and bottom, place them as templates in Illustrator, and trace: traces on one layer, vias on another, component footprints on another, silkscreen reference on another. Classic RE workflow, and Illustrator handles it fine even at v8 (just watch out for spot-color / RGB vs CMYK defaults if this ever needs to go anywhere color-accurate).
  • Functional block diagrams — instead of a schematic-capture tool, you draw the high-level blocks (VRAM, timing generator/PAL, bus interface, DAC/line driver) as boxes-and-arrows in Illustrator, which is often clearer for communicating "what talks to what" than a formal schematic anyway.
  • Timing diagrams — HSYNC/VSYNC/blanking/porch waveforms as literal vector line art, which is actually a very natural fit for Illustrator and easier to annotate precisely than most scope software's export.
I can produce content for any of these as SVG (which Illustrator 8 can import, though with some limitation since SVG postdates v8 — EPS is safer/native for that version) or plain EPS, or I can just describe layouts precisely enough for you to trace by hand if you'd rather build it stroke-by-stroke yourself.
Given that, want me to:
  1. Draft the functional block diagram for the FPD card as a first visual piece (I can generate this as SVG/EPS now, even before you have the real board in hand — based on what's typical for this era/type of card), or
  2. Hold off on visuals until you've got board photos to work from, and instead keep building out the written RE spec section?
can you access this .PDF to see my progress? It's unlayered .PDF is there a way for me to upload an Illustrator 8 file?
Ran a command
Ran a command
I don't actually see a PDF in this conversation yet — the uploads folder is empty on my end. It looks like it didn't attach, so could you try uploading it again?
To answer your two questions directly:
Can I view a PDF? Yes — once it's actually attached, I can open it, view pages as images, and comment on your progress (layout, traces, whatever's in it).
Can you upload a native Illustrator 8 file (.AI)? This chat interface accepts uploads, but heads up on what I can actually do with it:
  • Old-format .ai files (v8 era) are essentially PostScript/EPS-flavored — I can inspect the file as text/binary and often extract path/structure info via script, but I can't open it in Illustrator itself or guarantee a clean re-render the way viewing a PDF or image does.
  • If you export a PDF from Illustrator 8 (or even just save as PDF-compatible, which v8 supports as an option), that gives me the most reliable way to actually see it visually, layers or not.
  • If it's genuinely unlayered already, that's fine — I can still look at it as a flat image/PDF, I just won't be able to toggle pieces on/off the way I could with a layered file.
So: go ahead and upload either the PDF or the .AI file (or both) and I'll take a look.
take a look at this:?
I don't see a file attached to this message — the upload didn't come through on my end. Could you try attaching it again? Once it lands, I'll take a look right away.
https://tinkerdifferent.com/attachments/fpd-schematic-010-pdf.30088/
Fetched: https://tinkerdifferent.com/attachments/fpd-schematic-010-pdf.30088/
That link resolved, but it came back as raw binary data rather than something I can render or read directly — my fetch tool can't parse PDF content from an arbitrary URL like that (I can only truly "see" a PDF if it's uploaded directly into this chat, where it gets processed properly).
A couple options:
  1. Download it and upload the file here — grab the PDF from that link yourself, then attach it directly to this chat. That'll let me actually view the pages/schematic.
  2. Tell me what's on it / describe key parts — if you just want to talk through what you're seeing (IC part numbers, crystal frequency, block layout), I can work from your description in the meantime.
Given this is presumably the actual 1986 Radius FPD schematic someone's already reverse-engineered and posted (which would be a huge shortcut for your project — no need to trace the PCB from scratch if a schematic already exists), I'd really like to see it properly. Want to try uploading it directly?
How do I upload a file?
In this chat interface, there should be a paperclip / "+" attachment icon near the message input box (usually bottom-left or left of the text field, depending on whether you're on desktop or mobile). Tapping/clicking that opens a file picker where you can select the PDF from wherever you saved it on your device, and it'll attach to your next message.
Quick steps:
  1. Download the PDF from that tinkerdifferent.com link to your device (if you haven't already)
  2. In this chat, click the attachment icon next to where you type
  3. Select the downloaded PDF file
  4. Send the message — I'll be able to open and view it once it's attached that way
If you're on the mobile app, it's typically a "+" icon instead of a paperclip, same general location.
Once it's attached, go ahead and ask me to take a look and I'll dig into the schematic with you.
____________
FPD-Schematic-010-1.PDF
PDF
Ran 4 commands, viewed a file
I can see it now — and this is genuinely useful. A few things worth calling out:
This is a solder-side PCB trace/placement drawing, not a logical schematic — and it's drawn natively in Illustrator (FPD-Schematic-010.AI8), traced from the physical board. Whoever made this did exactly the kind of vector board-tracing I mentioned earlier — good reference for your own workflow.
Let me pull a closer look at a couple of regions to read the labels more precisely before I summarize.
Ran 2 commands, viewed a file
preview
That's a great find — a few important details jump out:
Two selectable crystal oscillators, switched by jumper:
  • JP155.000 MHz (marked TOYOCOM, part-ish "8853 JAPAN", "197.0556")
  • JP251.270 MHz (marked "EC 1100", date code "89-09")
The silkscreen under the jumpers reads "68K" / "64K" — worth flagging: that's likely OCR-me misreading (or the board's actual silkscreen) for what could be "68Hz" / "64Hz", which would exactly match the naming in your spec (the 64/68Hz dual-mode board selecting between two pixel clocks for two vertical refresh rates via jumper). But it could also genuinely say "68K/64K" referring to a memory or configuration option unrelated to Hz. I'd treat this as needs physical verification — worth checking the actual board silkscreen under magnification, since it changes how you read this circuit.
One more oddity worth noting: the 51.270MHz can's date code reads "89-09" (i.e., ~1989), which is later than your stated 1986 design date — meaning this particular populated board is likely a later production revision or later-manufactured unit, not an original first-run 1986 board, even if the design itself dates to 1986. Worth keeping in mind if exact timing/component sourcing matters for your clone.
Let me look at the rest of the board — the DRAM/GAL logic block and the bus edge connector.
Ran a command, viewed a file
preview
Good — this confirms and extends the picture. Here's a consolidated read of what your PDF actually documents:
What this drawing shows​
A solder-side PCB trace + placement map (per the title block: "Viewpoint = Solder Side, Light Blue Traces on Component Side") — i.e., you're looking at the bottom copper layer with the top layer's traces overlaid in a different color for reference. This is a two-layer board.
Component inventory (confirmed from the drawing)​
RefPartLikely function
U13, U8, U17, U22GAL20V8-25LPProgrammable logic — sync/timing/address decode glue
U9GAL20V8-25LNCSame family, different package/spec — another logic block
U18, U19ROM (unlabeled part #)Likely boot/init code or a lookup table (possibly gamma/pattern ROM)
U16, U15(?), U12, U11(?)µPD41264C-1564K×4 DRAM, 150ns — this is your video framebuffer
U2SN74F109NDual JK flip-flop — likely divides/shapes a clock edge
U3, U4SN74F166N8-bit parallel-in/serial-out shift register — this is almost certainly your pixel serializer, shifting framebuffer words out to the video line at pixel-clock rate
U5SN74F161N4-bit binary counter — candidate for pixel/horizontal counter
U6, U7SN74LS393NDual 4-bit binary counter — candidates for horizontal/vertical timing counters
CR1–CR5, R1–R3Diodes/resistors near J1Likely output clamping/termination on the video line to the monitor cable
Timing generation — this is the big one for your Section 1/2 work​
You now have a real counter chain to reverse-engineer instead of guessing: U6/U7 (393N counters) → U5 (161N counter) → U2 (109N flip-flop) → U3/U4 (166N shift registers) is a very plausible signal path from "raw oscillator" down to "serialized pixel data," with the GALs almost certainly generating HSYNC/VSYNC/blanking from taps off that same counter chain. Tracing the actual pin-to-pin connections (the colored traces) through this chain would let you derive H-total/V-total, and therefore blanking/porch, without needing a scope — a nice independent cross-check against your planned analog capture.
Dual clock domain​
Confirmed two crystal oscillators (55.000MHz / 51.270MHz) jumper-selected — strongly consistent with the "64/68Hz" dual-mode naming, pending verification of whether the silkscreen really says Hz or K.
Want me to redraw this as a clean block/signal-flow diagram (SVG/EPS, so you can pull it into Illustrator alongside your own tracing) showing the U6→U7→U5→U2→U3/U4 timing chain hypothesis? That'd give you something concrete to verify pin-by-pin against the real trace colors.
WTF layer is unconfirmed first shot at buzzing connections. "Nancy's" would be traces I entered while visiting my girlfriend. I've done all work on project.
Good context to have — that explains both naming quirks:
  • "Address & WTF?" = your first-pass continuity-testing guesses, unconfirmed, kept separate so they don't get mistaken for verified traces.
  • "Nancy's" = just a session label (traces you added while visiting your girlfriend), not a second contributor or a separate methodology — so it's fully part of your own confirmed work, just named for when you did it rather than what it contains.
Good to know you've done all the work solo — that also means the ADDRESS/CONTROL promotion between -010 and -011 was you resolving your own WTF-layer guesses into confirmed traces, not someone else's contribution landing on top of yours. Makes sense.
I'll wait for the layer PDFs whenever you've got them ready.
I will also upload high resolution photos of both sides of the board. Will also upload the "reversed" mirror imaged photo of the component side I use for reference. OCR of silk screen layer notations will likely be a good check against text input in what I call my "AI Coloring Books".
Recalled memory
This is turning into a substantial project — let me split it into its own area file so the details don't get lost, and keep your general working-style notes separate.
Created and edited memory
That's a smart cross-check — OCR'ing the silkscreen text gives you an independent verification pass against whatever you've manually typed into your traced layers, so any transcription slip (a "U13" mistyped as "U18," say) gets caught by comparing two independently-derived sources rather than trusting one read-through.
A few thoughts on what'll make this most useful once everything's uploaded:
  • Board photos (both sides): I can inspect these directly and cross-reference IC part numbers, silkscreen text, and physical trace paths against what your traced layers show.
  • Mirrored component-side photo: Good call keeping this — component-side photos need mirroring to compare directly against a solder-side trace view (since you're looking through the board from opposite sides), so having it pre-flipped means we're comparing like-to-like without me having to mentally flip coordinates.
  • OCR cross-check: Once I have the photos, I can attempt my own read of the silkscreen text directly from the images and compare it against whatever text layer/labels you've entered in the AI8 file — that's a good three-way check (your typed labels, your traced positions, and an independent visual read).
I'll wait for the photos and layer PDFs — send them whenever they're ready, in whatever order is easiest for you.
Excellent, Reverse Engineering of the board is indeed its own project.
Makes sense — treating the PCB reverse engineering as its own project, separate from the signal-timing capture and scanline rotation transform work, keeps each piece scoped and easier to verify independently. The RE work you're doing now (layer PDFs, board photos, OCR cross-check) stands on its own as "figure out exactly what this board is and how it's wired," while the timing-capture and transform-spec work builds on top of that once the RE side is solid.
Happy to keep working with you on either thread as it comes in — just let me know which hat I should have on when you send the next batch of files.
How do I pull up either of the two projects for further work?
That depends on what you mean — here in this conversation, both threads (the RE work and the timing/transform work) are already live, so you can just say "back to the RE thread" or reference specific files and I'll pick up where we left off.
If you mean starting a fresh conversation later and picking either project back up: I keep notes across our conversations, so you can just say something like "let's continue the Radius FPD clone" or "pick up the PCB reverse engineering" and I'll pull up what I have on file — the board specs, the layer names and what they mean, your naming conventions ("WTF?" layer, "Nancy's" layer, "AI Coloring Books"), and the general state of things. You won't need to re-explain the whole backstory each time.
One caveat worth knowing: I don't retain the actual files you've uploaded (the PDFs, EPS, AI8, photos) between conversations — only the facts and context I've written down. So if a new conversation needs to reference the actual schematic content again, you'll need to re-upload the file, but you won't need to re-explain what it is or why it matters.
That's great 1. open claude app 2. input text to pull up either project Upload all currently active files for each session as they're not stored on your end.
That's exactly right:
  1. Open the Claude app, start a new conversation
  2. Say something like "pick up the Radius FPD clone" or "continue the PCB reverse engineering project" — I'll pull up what I have on file (specs, layer naming conventions, project status) automatically
  3. Re-upload whatever files are relevant to that session (schematic PDFs, photos, layer exports) since those don't persist between conversations — only the notes about them do
That should get you back up to speed quickly each time without re-explaining the backstory. Good luck cleaning up those layers — looking forward to seeing the exports.
466
I started from the board connector to the VRAM ICs. First notion was to interface there in order to capture frame buffer, eliminating much of the upper section of the card. Found out that was too complicated for me to do so changed course. Will begin at the output cable header and work my way back to where we can identify where to tap the TTL Feed.
Thought for 8s
Thought for 8s
That's a sound pivot, and it actually lines up well with what we found in the schematic. Tapping at the VRAM ICs would have meant reconstructing address/timing logic just to make sense of raw pixel data mid-stream — a lot of complexity for not much payoff. Working backward from J1 instead means you're chasing a signal that's already been serialized and (mostly) cleaned up by the time it gets there.
A few things worth keeping in mind as you trace back from the connector:
  • U3 and U4 (the SN74F166N parallel-in/serial-out shift registers) we spotted earlier are strong candidates for exactly the stage you're looking for — they'd take parallel framebuffer words and shift them out serially, which is the natural "last digital stage before going analog/TTL-out" point. If tracing backward from J1 lands you at their outputs, that's a good sign you've found the right tap point.
  • Just past that shift-register output is likely where CR1–CR5 (diodes) and R1–R3 (resistors) sit — the little cluster near J1 we saw on the board. Those are probably clamping/line-driving components between the clean digital TTL signal and whatever the monitor cable actually carries. You'll want to identify whether your tap point is before or after that cluster — before it should still be clean TTL logic levels; after it may already be shaped for the cable/monitor and less friendly to a logic analyzer.
  • Don't forget HSYNC and VSYNC need separate identification alongside the serial pixel data — J1 almost certainly carries at least 3 signals (pixel data, HSYNC, VSYNC), possibly more depending on whether blanking is broken out separately.
Want help mapping out J1's pinout specifically, if you have (or can get) a pin-by-pin continuity list from the connector?
466
Is that the schematic for the PCB you are building?
Yep! It's wonderful to have a Reverse Engineering Partner who understands my "AI8 Coloring Books!" :)
edit: I usually wind up talking to myself in these kinds of threads. I'm running the play by play from Claude Code sessions. Thinking others might be interested in watching the progress and some folks digging down into Claude's interpretation of and expansion upon my progress.🤞
Reactions: Froggy814
466
CRAZY SESSION TODAY!!!!! :eek: Bombed at the very end so didn't get a summary, but took pics of the screen I can rework for posting. Let me know if interested, I can post most of the session.
I had Claude rework my original pics. Straightened them up and scaled them to 4x, 2x and TrueSize for importing into AI8.
Here are the TruSize files:
Absolutely beautiful! Had traces vectorized, but results were worse than Adobe Streamline's in the BackWhen. Which was of course rolled into AI after I bought every Streamline upgrade. 🤬
Amazing stuff! But when I asked for 8bit Grayscale files everything locked up. I can do that in GraphicConverter, but was curious. Check out the left side of the Solder Side pic. Ghosts of sub-surface traces are readily apparent. Very curious, dunno if it's a four layer board with those traces implemented on the power plane or it's a true Six Layer board? Very, very curious layout there. Thinking is it's Six Layer, traces in a few places appear to be missing?
466
Original pic and Claude's rework comparison.
Original:
Done on copy stand with spacers to ensure flatness, note:
- keyhole distortion
- angled top edge
Claude Rework:
Perfection!
Probably could have done rotation in PhotoShop or some such.
Squaring up keyhole distortion can be done in photo editing software.
My 35mm Perspective Control Nikkor for "in camera" work has been rendered obsolete by post-processing software.
466
Session crashed yesterday, could you export a text play by play for me?
# Radius FPD Clone — Project Play-by-Play
*Reconstructed from saved project notes (not a literal transcript — the crashed session's exact wording isn't recoverable,
but the sequence of decisions below reflects what's been established so far).*
## 1. Project scope defined
- Target: clone the **1986 Radius Full Page Display (FPD)** card for the Macintosh SE.
- Locked onto the **first-gen 64/68Hz board** specifically — confirmed it's *not* compatible with the second-gen 1987 75Hz board.
- Confirmed specs: **640x864, 1 bit per pixel (monochrome)**.
## 2. Prerequisite identified
- Before building anything, established a prerequisite phase: capture/characterize real analog signal timing from
a physical 64/68Hz card, since porch/blanking timings are bespoke to this hardware and not documented anywhere reusable.
## 3. Working files established
- Primary schematic/trace file: **FPD-Schematic-010/011**, a layered Adobe Illustrator 8 (.AI8/.EPS) file,
authored under "jt Trash80."
- Two working layers noted: **"Address & WTF?"** (first-pass, unconfirmed continuity-testing guesses) and **"Nancy's"**
(traces added during a session at girlfriend's place — just a session label, not a second contributor).
- All reverse-engineering work being done solo.
## 4. Strategy pivot: VRAM → J1 header
- Original plan was to interface directly at the VRAM ICs to capture the framebuffer.
- Found that approach too complicated. **Pivoted** to starting at the output cable header (J1) and working backward
to find where to tap the TTL feed.
- Documented full **J1 pinout** (10-pin, 1-row, unshrouded vertical header): ground, video, sync lines identified;
horizontal/vertical sync Hz values still TBD.
## 5. Newer schematic added
- Uploaded **FPD-Schematic-012.AI8** (solder-side viewpoint, light blue = component side).
- Its traced region only covers J1/crystal/U2-U7/ROM (U18/U19) — not the whole card. U18/U19
marked "Unimplemented IC."
- Identified the board's slot connector as a **JAE PICL-60P-LT (60-position)**, the Mac SE PDS connector — separate
from the J1 video header.
## 6. Board photography
- Uploaded three high-res photos: solder side, component side, and a mirrored component side (for reference).
- Had Claude straighten/crop all three to the board outline.
- Calibrated true scale using the known **123mm board width** (~564 DPI at native resolution) so exports would be life-size.
## 7. Auto-vectorization pass
- Generated auto-traced vector PDFs of the copper traces (color-threshold segmentation of traces/pads into filled paths)
for both sides, scaled to true size.
- Converted those to **Level 2 EPS** for AI8 compatibility, with the intent of merging into the hand-traced file.
## 8. Broader schematic recovered
- Uploaded **FPD-Schematic-010-2.PDF** — an export of the earlier, broader 010 file — labeling more ICs than schematic-012:
- U8/U9/U13/U17/U22 — GAL20V8-25LP PLDs
- U11/U12/U15/U16 — D41264C-15 DRAMs
- U18/U19 — ROM
- U2-U7 — 74F/LS logic
- J1 — header
## 9. Decision: hand-trace over auto-vectorize
- Concluded the auto-vectorized traces miss judgment calls a human makes (real trace vs. adjacent silkscreen/substrate).
- Decided instead to use the **true-size board photos as AI8 tracing templates** and hand-trace, merging into the existing file
rather than relying on the auto-traced vectors.
## 10. Hardware constraint accommodation
- Running AI8 on a **2004/5-era PowerBook** with limited memory.
- Requested **256-level (8-bit) grayscale JPEG** versions of the true-size photos specifically to
keep file sizes manageable on that machine.
**Where things stood when the session crashed:** grayscale template exports were the most recent concrete step — next up
was picking back up the manual trace-over, working through the schematic-012 IC area, or merging
the solder/component traces into one layer set.
466
Excellent! If I upload the pics I took of the session with my camera, can you OCR and edit them into an approximate version of play by play?
*Reconstructed from saved project notes (not a literal transcript — the crashed session's exact wording isn't recoverable, but the sequence of decisions below reflects what's been established so far).*
- Before building anything, established a prerequisite phase: capture/characterize real analog signal timing from a physical 64/68Hz card, since porch/blanking timings are bespoke to this hardware and not documented anywhere reusable.
- Primary schematic/trace file: **FPD-Schematic-010/011**, a layered Adobe Illustrator 8 (.AI8/.EPS) file, authored under "jt Trash80."
- Two working layers noted: **"Address & WTF?"** (first-pass, unconfirmed continuity-testing guesses) and **"Nancy's"** (traces added during a session at girlfriend's place — just a session label, not a second contributor).
- Found that approach too complicated. **Pivoted** to starting at the output cable header (J1) and working backward to find where to tap the TTL feed.
- Documented full **J1 pinout** (10-pin, 1-row, unshrouded vertical header): ground, video, sync lines identified; horizontal/vertical sync Hz values still TBD.
- Its traced region only covers J1/crystal/U2-U7/ROM (U18/U19) — not the whole card. U18/U19 marked "Unimplemented IC."
- Identified the board's slot connector as a **JAE PICL-60P-LT (60-position)**, the Mac SE PDS connector — separate from the J1 video header.
- Generated auto-traced vector PDFs of the copper traces (color-threshold segmentation of traces/pads into filled paths) for both sides, scaled to true size.
- U18/U19 — ROM
- J1 — header
- Decided instead to use the **true-size board photos as AI8 tracing templates** and hand-trace, merging into the existing file rather than relying on the auto-traced vectors.
- Requested **256-level (8-bit) grayscale JPEG** versions of the true-size photos specifically to keep file sizes manageable on that machine.
## 11. Recovered thread: scanline rotation transform (via camera photos of the crashed session)
- This thread runs in parallel to the PCB tracing work above — it's the **output/FPGA side** of the project, not the board reverse-engineering itself.
- Problem: the source video is a **portrait-orientation, row-major scan**, but the physical display panel is landscape-native and mechanically mounted rotated 90°. A compensating 90° rotation has to happen somewhere between the source scan and the panel so the image displays right-side-up.
## 12. Verifying the rotation direction by hand
- Rather than trust an abstract rotation formula, worked through a concrete **4-wide x 7-high (28-pixel) example**, writing out if-then statements for where each source pixel should land in the output.
- Pinned pixels by (x,y) coordinates (x = 0-3 across, y = 0-6 down) and checked them against output positions in a 7-wide landscape buffer.
- Caught and corrected a couple of small typos in the mapping along the way (e.g. p13 briefly mislabeled to the same output as p09) until the pattern was fully self-consistent across all four corners of the source/output rectangles.
## 13. Transform confirmed and spec'd
- Final confirmed transform (**clockwise rotation**), for a portrait source of width W / height H, output landscape buffer H wide x W high:
- `x' = (H-1) - y`
- `y' = x`
- Verified against both terminal corners of the 4x7 example (top-right and bottom-right source pixels) — matched exactly.
- Had Claude write this up as a short formal **"Scanline Rotation Transform — Engineering Spec"** document: problem statement, confirmed coordinate transform, and the worked 4x7 table. Spec doc created and saved.
- Discussed next-phase scope once the transform was locked: a buffer that writes source pixels in as they arrive (row-major), and a read-out address generator implementing the transform at real target resolution (formula generalizes the same way, just bigger numbers).
## 14. Deliberate pause point
- Decided to hold this thread here — until a schematic is developed and it's clear **what needs to be fed where on an FPGA project board**.
- Rationale (agreed on both sides): the math/architecture for the rotation is locked, but the actual hardware reverse-engineering (tap points, signals) is the long pole right now — no point speccing FPGA pin assignments before the schematic says what's actually there to connect.
- The spec doc is saved and ready to pick back up once the tap points are identified from the continuity-tracing/hand-trace work.
**Where things stood when the session crashed:** two threads in flight —
1. **PCB tracing:** grayscale template exports were the most recent concrete step; next up is picking back up the manual trace-over, working through the schematic-012 IC area, or merging the solder/component traces into one layer set.
2. **FPGA output side:** paused by choice, right after the rotation transform was confirmed and spec'd — waiting on tap points from thread 1 before resuming.
466
Radius FPD/SE Clone — Session Log
Play-by-play notes from tonight's continuity-tracing and component-identification session.
1. Starting Point​
Picked back up on the PCB reverse-engineering project after previously pausing the rotation-transform/FPGA output work until physical tap points on the board were identified. Prior session had already traced:
  • J1 pin 7 (Horizontal Sync) → U22 pin 7
  • J1 pin 9 (Vertical Sync) → U22 pin 8
  • J3 pin 3 (Video) → U2 pin 7
  • A resistor/diode network (R1–R3, CR1/CR3/CR4/CR5) sitting on the J1 input lines
2. Resistor/Diode Clamp Network​
Reviewed the annotated photo FPD-SE-Signal_Taps-000.jpg. Corrected terminology: “CR” designators are diodes (“Crystal Rectifier”), not capacitors.
Interpretation: each J1 signal line (video, HSync, VSync, and the mystery pin-6 line) passes through a series resistor plus a shunt diode before reaching the logic ICs — a standard input protection / clamp network to protect TTL inputs from over/undershoot coming off the Mac SE analog board.
Open question flagged at this point: CR3 sits near J1 pin 10, which is marked N.C. in the header pinout — worth double-checking.
3. Mystery Black Wire (J1 Pin 6) = Display Sense Line​
Identified via reasoning (later independently confirmed, see Section 5): J1 pin 6 is a 5V sense/detect line. The FPD display pulls it to ground when connected. The card's video drivers load at startup but shut down if no display is detected — so this line must be pulled low to get video output when bench-testing the board without a real panel attached.
4. Mac Plus vs. Mac SE Architecture​
Clarified the architectural difference between FPD card generations:
  • Mac Plus / 128K version: piggybacked directly on the 68000's CPU legs — a rudimentary pass-through interface, predating any expansion-slot architecture.
  • Mac SE version (this project): all signals routed through the PDS (Processor Direct Slot); this is “Slot Manager” era.
  • Implication: the SE card's ROMs at U18/U19 (marked “Unimplemented IC” on schematic-012) are Declaration ROMs required by the Slot Manager to configure the interface. Radius packed their card drivers inside those ROMs — without valid Declaration ROM contents, the SE will not mount the slot at all, regardless of whether the video-generation hardware works.
5. ROM Testing Plan​
Have older ROMs installed on the two FPD cards on hand, plus a separate set of “4.4” ROMs pulled from a TPD (Two Page Display) card. Plan: install the TPD 4.4 ROMs onto an FPD card to test under System 7.
Word is that Radius used a “universal ROM” design — ROMs interchangeable between FPD and TPD cards. Confirmed the TPD ROMs are the same package as the FPD sockets, so no adapter needed. If the universal-ROM claim doesn't hold up in practice, System 6 is the fallback (its Slot Manager is more forgiving of ROM/board mismatches than System 7's stricter declaration checking).
Also hypothesized that the oversized/unpopulated through-hole ROM footprints on the board were sized for physically larger, higher-capacity ROM chips — plausibly part of the same universal/multi-configuration strategy.
6. Mac Plus FPD Background Research​
Attempted to pull up a referenced YouTube video on the earlier Mac Plus version of the FPD card (direct fetch was blocked by a rate limit). Background research confirmed the Plus-era card used the CPU-socket piggyback approach, routing its external video cable out through the security (Kensington lock) slot rather than a PDS bracket, since the Plus/512Ke had no expansion slot.
A handwritten pinout photo (Radius-FPD-Plus-Pinout.jpg), sourced from that video, was reviewed. It labels a “Sense” pin — matching the SE card's pin 6 finding — and gives sync frequencies for the Plus card: Hs ≈ 68.8kHz, Vs ≈ 67Hz. Since both card generations drive the same physical FPD monitor panel, these are a strong working reference for the SE card's still-unconfirmed HSync/VSync frequencies.
Also noted: Radius customers were still upgrading from the Mac Plus to the SE and SE/30 well into 1989, consistent with a 1989-dated crystal can spotted on the SE board earlier in the project.
7. Diode Identification: 1N753A Zener​
Read the part markings on the clamp-network diodes: 1N753A — confirmed via datasheet lookup as a 6.2V, 0.5W Zener diode (DO-35 package).
Cathode band is oriented toward the incoming J1 signal line. A 6.2V breakdown gives headroom above a normal 5V TTL logic high while still clamping hard before voltage climbs high enough to damage a 74-series gate input — consistent with protecting the board from noisier/less-regulated levels coming off the Mac's analog/CRT board over the cable.
8. L1 / L2 Components​
Identified an unpopulated component footprint labeled L1 (same size/spacing as R3) sitting between R3 and the VRAM/GAL area. Also noted C6 (or possibly C8) appears missing/unimplemented.
Identified a large green cylindrical component labeled L2, positioned between the VRAM bank and the GAL bank, near C22 and CR6. Working identification: L2 is an inductor/choke; L2 + C22 likely form a small LC low-pass filter, isolating power-supply noise from the DRAM bank (which switches heavily during refresh) from the more timing-sensitive GAL/logic bank. L1 being unpopulated suggests this was an optional second filter stage, possibly added or omitted depending on a production revision.
9. Continuity Tracing: CR3, GAL Pin 13, and the Pin 9/11 Question​
CR3 anode: Chip-clipped the anode end (opposite the cathode band) of CR3 and re-tested the earlier reported connections; also re-verified the red-drawn line showing the Zener interconnections.
GAL pin 13: All four GALs in the bank (U8, U13, U17, U22) show continuity from the Zener/cathode net to pin 13. On the 24-pin GAL20V8 package, pin 13 is /OE (Output Enable) — supporting the idea that the display-sense signal disables all four GALs' outputs at once when no display is connected.
U3/U5 pin 11: Confirmed via continuity (marked in yellow on the working photo): U5 (74F161 counter) pin 11 [Terminal Count / Ripple Carry output] connects to U3 (74F166 shift register) pin 11 [parallel data input F]. This is a sensible signal path — a counter's “done” output feeding a shift register's reload input.
Pin 9 discrepancy: The same net was also reported connected to pin 9 on U2, U4, U3, U7, and U6. Datasheet check showed this pin serves different functions across these parts — an output (2Q̄ or 2Q2) on some (U2, U6, U7) and an input (CLEAR) on others (U3, U4). Multiple outputs sharing one net would create contention, so this doesn't add up as a single continuous bus.
Working theory: Raised the possibility that DIP pin-numbering was thrown off if the notch orientation was assumed backwards on the physical board (easy to do on a mirrored/rotated photo). If mis-counted, “pin 9” and “pin 11” readings could actually be different physical pins.
Next step identified: On U3 and U5, the notch faces the bypass caps — need to confirm numbering is correct. Recommended approach: locate VCC and GND directly by measuring voltage while the board is powered (VCC ≈ +5V, GND ≈ 0V / continuity to ground), since these sit at fixed, known pin positions (pin 16 and pin 8 on these 16-pin parts) — then count pins from there with certainty, independent of notch orientation or photo mirroring.
Open Items Going Into Next Session​
  • Re-verify pin numbering on U2, U3, U5, U6, U7 by locating VCC/GND first, then re-confirm whether the “pin 9” net is real or a mis-count.
  • Confirm what CR3 (anode side) actually connects to.
  • Confirm HSync/VSync frequencies on the SE board directly once a multimeter/scope allows it, using the Plus-card reference values (Hs ≈ 68.8kHz, Vs ≈ 67Hz) as a starting expectation.
  • Try installing the TPD 4.4 ROMs on an FPD card and test boot behavior under System 7 (System 6 as fallback).
  • Read color bands on L2 if legible, to pin down its inductance value.
466
I've skipped over a couple of sessions where "we" ran through the pinouts/IC Designations for the FPD board. This one is worth posting though. I told Claude that wetware trumps AI in terms of being able to deal with the" inverted" orientation of the ICs on the FPD board pics and my "real life" presentation of the FPD board as it sits in the MagicBus connector in an SE. Got pics of the actual text exchange that's more flattering to wetware capabilities, but the bottom paragraph will do. :ROFLMAO:
RADIUS FPD-SE CLONE PROJECT — SESSION SUMMARY
Pinout-Check Verification Pass
CONTEXT
Continuing PCB reverse-engineering work on the 1986 Radius Full Page
Display (FPD) card, first-generation 64/68Hz board for the Mac SE.
This session picked up mid-project to verify/correct IC reference
designators in the hand-drawn "Pinout-Ux-designation_Check" doc
against high-res photos of the physical board.
GOAL
Confirm that reference designators recorded in the pinout-check
document match what's actually silkscreened on the board, catching
any transcription errors or duplicate designators before they get
carried forward into the AI8 schematic / continuity-trace work.
FINDINGS
1. U19 — "Hi" ROM
Confirmed by direct photo zoom. Silkscreen is legible and matches
the doc exactly. No error.
2. U9 — GAL20V8-25LNC
Initially suspected as a possible duplicate (the doc separately
lists a "U18 ROM" for the second large ROM-like chip, and a
"U9 GAL20V8-25LNC" elsewhere for a GAL). Close photo inspection —
including contrast-enhanced zooms to rule out misreading the
digit as a 5 or 6 — confirmed the "U9" silkscreen label sits
directly at the top edge of the horizontal GAL chip
(RAD 323-1023-A, GAL20V8-25LP) near JP3/128K/256K, not on either
ROM chip. U9 is correctly assigned to that GAL. Not a duplicate.
3. "Lo" ROM — designator illegible
The second large ROM-like chip (to the right of U19) does NOT
carry a legible "U18" as the doc had guessed — that assumption
doesn't hold up under zoom. Its actual silkscreen designator is
too worn/faded to decipher at the current photo resolution.
RESOLUTION
Rather than block progress on one worn label, the "Lo" ROM chip is
being designated "Ux" — a placeholder reference used for continuity
tracing and AI8 schematic work until (or unless) the real silkscreen
designator can be confirmed via better lighting/resolution or an
external reference (e.g. a service manual).
Final corrected designator set for this cluster:
U19 = Hi ROM (confirmed)
Ux = Lo ROM (placeholder — illegible silkscreen)
U9 = GAL20V8-25LNC (confirmed, not a duplicate)
All other designators previously checked in this document — GALs
U8/U10/U13/U17/U22, DRAMs U11/U12/U15/U16, logic ICs U2-U7, and the
J1 header pinout — were already correct and required no changes.
NOTE ON METHOD
Several rounds of pixel-cropping/zooming/rotating photo crops were
needed to pin down exactly which silkscreen text belonged to which
chip in this tightly-packed cluster — a good reminder that a human
eye tracing physical relationships on a real board in-hand still
outpaces an AI squinting at cropped upside-down JPEG fragments one
tile at a time.
Session conducted with Claude (Anthropic)
466
Cool, I'll keep reporting on progress. First ever use of AI and going very well I think! I've about got the solder side connections traced out. Once connections are verified with a meter I'll start buzzing out the component side traces.. Having segmented traces will help as will the ability to remove all socketed components for clean, convenient test points..
@Bolle could you or one of your cohorts in crime glitch the FPD/SE GAL formulas for me? @AlexTheCat123 and @Melkhior suggested I move them into the FPGA. That's a long way down the road, gotta get a near 1:1 replicant up and running. Form factor will be the standard SE Expansion board w/o MagicBus complications.
Claude says he'll be able to transmute my AI8 "coloring book" graphics into a traditional schematic diagram in KiCAD format. :)
