Released — MacDoom for SE/30
patters
56
47
Finally made time to sit down and try this out, but sadly my SE/30 has only 20MB of RAM. When you say you'll reduce the 64MB requirement, do you expect a machine like mine to be able to run the game eventually? I seem to remember that 4MB was enough on a DOS PC back in the day, so 20MB should be ok even with Mac OS consuming some.
MacOfAllTrades
220
243
Aside from fps there are just a couple of minor improvement areas I could think of, if I may:
The status bar at the bottom does not refresh on its own (at least for me). If I press esc and then back, it does, so it sort of works.
Do you plan on adding the background music in? Would that be difficult?
You absolutely may! Feedback is always welcome.
The status bar bug is new to me — I don’t see that issue on my se/30 or in emulated testing. What version are you running (the splash screen with my goofy head animation tells you the version). I’m close to posting a new one with additional optimizations as that’s all I’m working on at the moment but curious that yours is having status bar / HUD issues. I don’t remember releasing any with issues there.
Also tell me what machine you’re running on, plz!
Thanks for the feedback!
MacOfAllTrades
220
243
yes absolutely — it actually will work right now for you I bet — go to the app, hit “Get Info” on it in the finder and just lower the minimum amount down to say 12 MB. You should have 12 MB available since of your 20MB only like 2.5MB goes to the OS.
I’m going to release a new build imminently (been too busy iterating to stop and put together the little deployment package but I’ll make sure it has less ram requirements — it doesn’t use anything close to what it’s being allocated now).
Mr_Anomalya
Sure, it's 1.0. b4 on a Classic II.
I wanted to see if it's present on your latest version, but unfortunately I can't run that one at all, as now the memory needed is presented as a hard requirement instead of a "do you still wish to run it"-type warning.
Arbystpossum
102
71
USA
I have an LCII with a 68040, I'd love to try this but I'm sure the low RAM limit blows a hole in that. Would using the shareware WAD theoretically lower this requirement?
MacOfAllTrades
220
243
fixing assap.. i simply upped the minimum from 8MB to 10MB (probably stupid) — of the major IWADs supported in linux doom (doom1, doom2, TNT, plutonia) — Plutonia map20 is the largest and causes the heaviest mem requirement. So I iterated my way to 8MB being the minimum required for that map to work (yes this is prob worse than standard dos doom because of how I load content into memory for speed to avoid loading textures as you play the game - DoomSe30 loads them all up front which causes the mem requirements to be much higher. But the last thing I want impacting frame rate is lots of disk reads during play.
Anyway - i should set the minimum mem requirement to perhaps be just the worst case for doom1.wad and the recommended size be the size needed for the worst case across the bunch (which is plutonia map20 to my knowledge)…. checking now to see what the min req is for doom1 levels
Edit to add:
Yup precisely what I’m doing!
Reactions: Arbystpossum
MacOfAllTrades
220
243
For funsies here’s the Doom 1 wad file mem usage per map. Don’t mind the “Free KB” column, that’s based on an 8MB allocation, the USED one is the important one….
Code:
  │ Map  │ Free (KB) │ Used (KB) │ Used % │
  │ E1M1 │ 7782      │ 410       │ 5.0%   │
  │ E1M2 │ 7637      │ 555       │ 6.8%   │
  │ E1M3 │ 7644      │ 548       │ 6.7%   │
  │ E1M4 │ 7705      │ 487       │ 5.9%   │
  │ E1M5 │ 7708      │ 484       │ 5.9%   │
  │ E1M6 │ 7571      │ 621       │ 7.6%   │
  │ E1M7 │ 7671      │ 521       │ 6.4%   │
  │ E1M8 │ 7743      │ 449       │ 5.5%   │
  │ E2M1 │ 7793      │ 399       │ 4.9%   │
  │ E2M2 │ 7540      │ 652       │ 8.0%   │
  │ E2M3 │ 7687      │ 505       │ 6.2%   │
  │ E2M4 │ 7650      │ 542       │ 6.6%   │
  │ E2M5 │ 7596      │ 596       │ 7.3%   │
  │ E2M6 │ 7654      │ 538       │ 6.6%   │
  │ E2M7 │ 7530      │ 662       │ 8.1%   │
  │ E2M8 │ 7815      │ 377       │ 4.6%   │
  │ E2M9 │ 7862      │ 330       │ 4.0%   │
  │ E3M1 │ 7844      │ 348       │ 4.2%   │
  │ E3M2 │ 7767      │ 425       │ 5.2%   │
  │ E3M3 │ 7654      │ 538       │ 6.6%   │
  │ E3M4 │ 7596      │ 596       │ 7.3%   │
  │ E3M5 │ 7589      │ 603       │ 7.4%   │
  │ E3M6 │ 7689      │ 503       │ 6.1%   │
  │ E3M7 │ 7696      │ 496       │ 6.1%   │
  │ E3M8 │ 7860      │ 332       │ 4.1%   │
  │ E3M9 │ 7760      │ 432       │ 5.3%   │
tldr — doom1 requires very little memory even with my load everything up front at map load approach
patters
56
47
Just tried v1.0.0, but it hangs on the black screen LOADING WAD FILE. I left it for several minutes, and nothing.
I used shareware Doom1.wad v1.1, and I transferred that to the Mac using Fetch set to binary mode. My SE/30 has the gglabs MacSIMM 32bit clean ROM. I was running System 7.5.3, which has 17MB of free RAM. CPU and FPU are stock.
Tried disabling sound, same issue. If I click the mouse after the 10 second wait the application just quits by itself.
Does it support the many different versions of this WAD?
Oooh. Nevermind, it works with the Doom 1.9 shareware WAD. (md5: f0cefca49926d00903cf57551d901abe). :) very cool
Reactions: MacOfAllTrades
Mr_Anomalya
The status bar bug is still there for me, but only if I maximize the screen size. If I'm one setting below, it's ok. Idk if that helps with later tinkering. I do see some improvement in FPS, though not much and not constant. In any case, it's a good enough port for me.
Now, if only someone also were to do a port of Bomberman TG-16 / Dynablaster... :D
MacOfAllTrades
220
243
Yes - i was able to resolve this!! Thanks. It was a goofy one…. Basically the math was using a “<“ instead of a “<=“ to determine if the HUD was visible and thus needed updating. I’ll post an update soon along with other stuff I’m trying.
**Unrelated — does anyone have a Snow emulator setup using a 68040 system like a IIci or Quadra 650 or otherwise? I want to set myself up with a good emulation method for these better-than-se/30 machines to confirm perfomrance there.
I’m also kind of curious how my port performs compared to the original Lion Entertainment Mac Doom port from the 90s (which didn’t run on an se30 so i’d need something newer to run it and mine)
