MARCHintosh 2026 Projects
Nov 4, 2021
129
100
Tucson, AZ
This year, along side @thecloud, I wrote a virtual AppleTalk ImageWriter II printer in Python called Softserve. It shows up on your Ethernet
I also have a python-based ImageWriter emulator that can export PNGs or TIFFs (for proper CMYK prints). This year I'm trying to synthesize the sounds of printing based individual impacts. I'll rig it up as a shared ImageWriter on GlobalTalk and maybe have a web page to view/hear the results.
fogWraith
Antiques Dealer
119
VesperNet continues this year, plenty of updates with even more coming, a bit of a backlog due to also being in the process of moving from apartment to house with everything that entails.
jonschwenn
One thing we used in the education industry was DeployStudio, reimaging an entire classroom at a time.
I was going to mention the same thing. I had a demo lab of Mac minis that I would let people access to test out data center access and performance. I would use DeployStudio to wipe and rebuild them after each session.
Geekman's World
6
www.geekman.ca
Hi folks! After three years of effort (I'm new at this and my work has also been VERY busy) I'm thrilled to unveil my mutant restoration project, and my first making-of video, the PowerMac Blue and White G4. This has been a lot of effort and an intense labour of love, so I hope you all enjoy!
Reactions: bakkus and phunguss
danifunker
I've been working on a couple of open source projects that this community might be interested in.
USBODE-circle - is a USB CD-ROM drive emulator. Finalized Macintosh 9.2.2 support earlier this year. There are a few CD Audio games that are incompatible, but many work fine after disabling your internal CDROM drive (full information via the repository README.md) via a patched AppleCD/DVD Extension. This should also work with OS/X and works on modern versions of MacOS including Tahoe.
My Marchintosh project is something different though.
I've been working on this for a couple of months and believe it's time for some attention onto it.
I am creating a multi-platform, multi-filesystem imaging solution. I look at this as like a 1-stop tool to handle all of your vintage filesystem needs.
There are a lot of features and not everything is thoroughly tested. The application is written in Rust.
The application is called Rusty Backup
Full disclosure, it's all AI (claude) generated but I have a strong understanding of many filesystems since I have worked as a systems engineer for most of my career and have been providing fine-tune direction for all of the code. It's also GPL3 licensed so feel free to contribute back to me for new features!
Operating Systems Supported:
  • Windows 10/11 x86/x64
  • MacOS Sequia & Tahoe (15.x, 26.x) might support lower versions, but I'm not sure what the lowest is. x64 (Intel) and ARM64 (Macintosh Silicon) builds are provided.
    • I recently signed up for an Apple developer account so this is a signed developer application
  • Modern Linux versions
    • Currently providing native packages for Debian (tested), Fedora and Arch, x64 and arm based binaries
Filesystems supported:
  • FAT12/16/32
  • NTFS
  • ExFAT
  • ext2/3/4
  • btrfs (my personal favorite to use on modern linux distros)* experimental support, doesn't support all resizing operations yet
  • HFS
  • HFSPlus
  • ProDOS 3.3 *needs more testing, recently implemented
Features Supported:
  • Backup / clone from floppy disk/jaz/zip drive with supported filesystem (including HFS on latest MacOS) to img file
  • Write .img file to floppy disk (currently untested)
  • Backup from hard disk with supported filesystem & perform compaction on destination file
  • Restore from hard disk with supported filesystem & allow partition manipulation (resize partition
  • Convert from / to VHD files for supported filesystems
    • Current VHD limitations around extended partition handling
  • Re-export VHD files to re-size them
  • Restore from Clonezilla backup, allowing for filesystem resizing (needs more testing)
  • Browse/Inspect existing backups including filesystem browser and simple text editor loading,
  • Export Files from backups and/or physical drives directly (especially useful for cross-platform and unsupported filesystems like HFS)
    • Options to export resource forks for HFS/HFS+ filesystems as different filetypes
  • Create bin/cue/ISO files for physical disks
The application requires a recent-ish version of OpenGL so I was unable to run it on my PPC64 G5 Debian sid install with an Nvidia video card.
I am currently working on adding 'edit' support for both images/backups and live filesystems so I hope to have a way to write files to an HFS partition within my application hopefully for Marchintosh!
Unfortunatley I haven't created thorough documentation yet, but it appears to be very straightforward to use. For issues please open up Github issues.
Reactions: Nitram78
jack 68k
29
Madison, Wisconsin
My primary #MARCHintosh project for this year is a brand new diagnostics app that runs on modern machines and makes it easy to access the diagnostics mode built in the ROM of many Classic Macs.
If you're struggling to get a Sad Mac working, I hope this project can help!
Official announcement post
Website
Mu0n
658
618
Quebec
The Crow's Nest BBS, running Hermes II v3.1.1 on a Mac IIci with multiple wifi modems, is back again for #MARCHintosh 2026! What's new this year?
• Connect via GlobalTalk using only an AppleTalk connection!
• BBS in a Box volume 22 CD's are online.
• Phrack newsletters and ASCII art have been added to the G-Files section.
Full details on how to connect here: http://crowsnestbbs.ddns.net/cn/
I've tried to get set up on my SE/30. I took both the file from your website guide and even tried connecting to your AFP on globaltalk itself, and I think I found the same file inside your ApplePi drive.
both lead me to unstuff Black Knight CN.sit and get this seemingly broken single .sit file inside
I can't seem to proceed past that...
RetroTheory
I made a program with Retro68 cross compiler with a strange likeness to the like clock Maclock. Watch out for the clock bug, where DAY does not match date. I find 1998 works for this year. @This Does Not Compute gave me the idea when he converted the clock into a vintage Mac, I wanted to see if I could do the opposite. I'm sure this will run on his tiny 'Mac' and restore Maclock function :)
Features:
  • Large digitized time display with blinking colon.
  • Date and Day of the week in a custom small font.
  • Double-buffered rendering for a flicker-free experience.
  • Inversion and Gray Background modes for different lighting conditions.
  • Alarm system with customizable time and multiple alert sounds.
  • Face mode (Happy Mac) toggle.
  • Dynamic Resolution Scaling: Automatically detects screen size (Compact Mac 512x342 vs. Hi-Res 640x480) and scales the digits and layout to fit.
Keyboard Shortcuts:
  • 'H': Toggle Happy Mac mode.
  • 'I': Toggle Inverted display (Black background).
  • 'G': Toggle Gray background.
  • 'Q': Quit the program.
486
Welcome the Hulkintosh!
This project has been on the back burner for some time. I keep going back and forth to other projects and finally got to this one. If you have not seen it already, there is a really cool CRT swap of an amber screen a classic, call the Pumpkintosh. I picked up an old Corona Data System Cordata Portable, with a 9" built in screen, condition unknown, super cheap from Free Geek.
Not my photo, but like this but missing several parts like the cover, keyboard, contrast adjustement on front, and floppy drives.
This old system powers on from the PSU side of things, but nothing on the screen. After closer inspection, the analog board definitely needs a recap. Future project. Pulled the caps and really gooey.
Here is the tube.
And I swapped it into one of the Classic macs from my "Tale of Two Classics"
I still need to tune the tube alignments.
Reactions: eric
Arbystpossum
89
57
USA
The iMac G3 is likely going to sit forever, the speakers are blown and the CRT is showing its age. After a while of running, black starts to turn red, and the more black is displayed on the screen, the deeper the red goes. The internets say it's a worn out tube, I have a guy I can call about tubes, but it's possible there's nothing to be done there.
The backup project is a G4 iMac that appears to have/had heat issues and/or is haunted. It crashes, randomly, seemingly unprovoked. I took out the optical drive and installed a fan to blow directly at the processor heatsink, and even stuck some finned heatsinks to the processor heatsink, just for more surface area and cooling. I ran iTunes with a large visualizer full screened for an hour and the machine didn't crash. I rebooted the machine and it kept locking up or kernel panicking on boot. I left it alone for the evening, tried to turn it on this morning, it panicked a couple times then booted. I need to learn where to look for panic logs, the window that pops up in Tiger doesn't take me to the log when I click Report, I'll need to learn where to specifically look for the latest crash. Usually I can feel out what's going on and attempt to address it.
Every consumer-aimed Mac I have has always given me such problems. I can't tell if it's because they've been mistreated in their lifetimes or does the consumer-grade machines just fail.
486
Every Mac I own, I am not the original owner. I assume every single one has had a terrible digital life of abuse. Some take more tinkering than others to get into a reliable state, and some are just not recoverable with my skill set. I do the best I can, FrankenMod what I can, and set the rest back into the wild via Free Geek donations or individual sales.
