Need solution for HDI-45 to DB-15 connectors for video out
590
OK, the beginning of the repo is up.
Feel free to check it out and provide feedback. I plan to take photos of the next adapter I assemble and insert them into the assembly instructions in the readme. Also, I'm working with @jcm-1 to get some pre-made versions listed in his store for those that don't want to go through the hassle of getting PCBs made, assembling, 3d printing a case, etc. Hopefully this will help people save some money. And actually be a better adapter than Apple's because it won't require an adapter attached to an adapter to get VGA output.
590
OK, the first "professionally" printed cases came back from JLC3DP and they fit really well. I was worried that variations in my printer and small tolerances of the parts may mean that my 3d models work well only on my 3d printer with the filament I use. But, the resin prints from JLC3DP, using their cheap 9600 resin are very, very nice. The fit of the PCB is good in the case, the screws work well at keeping it together, and the pin shroud goes into the female HDI-45 port smoothly. This first order was for the HD-15 version of the adapter.
The DA-15 version is on the way, but is an earlier revision, so it may not work as well when assembled. The current version of the case adds some spacers for the PCB and the bottom piece to keep it from becoming crooked in the case due to the DA-15 port having pins that stick out further than the screw standoff. I have an order of a few of the new versions coming as well that I'll try out. But I'd say both the PCB and the 3d cases are safe for people to order their own if needed.
Also, the pre-assembled versions are on their way to Joes Computer Museum, so hopefully they will be there shortly and then live in his store.
590
Very, very nice. Don't forget my licensing fee for getting you onto this track way back in the thread! :ROFLMAO:
I expect the profits to be easily distributed with pennies (maybe even quarters). If you want your payout in the form of a produced adapter, send me the address and I would gladly whip you a couple adapters for you help! I've gotten pretty good at assembly and I bought the PCBs in bulk, so I should have enough to send out.
Reactions: Trash80toG4
590
So, I had a coupon for a full color silkscreen PCB from JLCPCB, so I decided to make a special version of the adapter for my own use. The process was pretty easy using the EasyEDA pro app on the Mac, submitting it to JLCPCB was also easy. However, it looks like I may have done something wrong because the silkscreen was only printed on one side.
With the coupon, the PCBs were basically the same cost as the standard solid color ones. I also had JLC3DP print me some transparent resin cases and I’m pretty happy with how it turned out. I may need to see if I can use AI to make me a cool logo for a more custom design.
Overall, though, I’ve been thoroughly impressed with how cheaply I was able to get this produced. The clear resin doesn’t insert quite as cleanly as the white resin I used before, but I think the look will be cool to have my own special version.
Also, I’ve sent off the first batch I made to @jcm-1 , so you should be able to order an individual one of these from his store soon.
jcm-1
Maybe on future runs, we can get some of these done. Depending on bulk cost, we may be able to do them for only a couple dollars more per unit. They look GREAT! I'd love to give folks the option for either/or.
590
FYI, if anyone made their own (unlikely), I added a new 3d printed part for better ensuring the pins line up properly. hdi-45_pin_guide.png
I'm installing them on the next batch I'm sending to @jcm-1. But I've also added the 3d file to the GitHub repo for people that might want to make their own. Note that due to the tiny hole sizes, I recommending printing with a 0.2mm nozzle. Also, if your slicer allows, print inside walls first.
590
The day I pick up a Performa 6116cd is the same day the last adapter from @jcm-1 sold out. If any one has one to sell count me interested.
Sounds like there might be a new patch coming, based on @wottle's post above yours?
Yeah, I believe they have been delivered and he should have some for sale. Not sure how his website manages inventory, but I suspect you’ll be able to buy shortly.
If not let me know and I could assemble one for you. I have a fresh batch of 2mm spacing extra long pins, as well as a stack of PCBs so should be good to go for a while.
590
I was trying to get out in front of assembling the next batch for @jcm-1 and my HDI-45 port I was using to hold pins during assembly is pretty worn out and the pins aren't staying put like they used to. I also could never get it to install all 5 rows at once, which slowed assembly. I then realized I have the pin spacer design I added that matches the pin layout - I could probably use a modified version to serve as a new jig. So, I elongated it, gate it a hard bottom which should make the pins stick out just enough to reach through the PCB...
And it works better than I expected. I can load up all 5 rows, and I can use it to force the pins in, even on my recent batch of boards where the pin holes were drilled a bit too small. The pin alignment is perfect, and I hope it will last longer than my salvaged HDI-45 port, although if it doesn't I can just print another. For this one, I didn't even swap nozzles for a 0.2 nozzle like I did for the spacer piece.
Anyway, in case anyone is looking to build their own (unlikely), the job should be easier now.
svenvendetta
42
56
Boston, MA
View attachment 27069View attachment 27070
I did end up getting one from @jcm-1, thanks for keeping them in stock.
Works great though I had at least one "bump" against the connector which crashed the 6116. Nothing usually ever touches it so it's fine, but i think this new design will be even more solid.
Reactions: wottle and jcm-1
590
Interesting. Does yours have the plastic spacer in it? I’ll try to replicate that with one I have here that doesn’t have the spacer and then again with one that does to see if there is an improvement.
really odd
I’ve not had that happen in any of my testing. Does yours have the gray plastic pin guide down in the connector? I’ll try to do some testing of my units I have here with and without the pin guide and see if I can recreate the issue and see if the pin guide helps or hurts. If you have one without the pin guide and it helps I can probably send you one in an envelope.
