Elemenoh
457
445
Bay Area
I'm in the process of recapping a couple of NeXTCubes and was a little surprised it's kind of hard to find good cap info. So here's an attempt. The MLB/PSU info here is based on an early serial NeXT Computer. So your milage may vary if there are other revisions of these boards. The Magneto Optical drive cap info is based on a thread from NeXTComputers.org.
Note the MO drive cap sizes are very small through-hole caps. Be careful when ordering. I had to source from both DigiKey and Mouser to get the right sizes.
Main Logic Board
QuantityTypeCapcitance (uF)Voltage RatingSizeLead Spacing (est.)
6SMD4716CN/A
4Through Hole2202510x125
Power Supply​
This list is for model 152.00 but may also be applicable to others.
QuantityLocation(s)TypeCapacitanceVoltage RatingSize (mm D x H)Lead Spacing (est.)
2C122, C123Through Hole78040040x5210mm LI type
2 — 1.2x6 mm
2C124, C125Through Hole1025022x4011
1C209Through Hole8,2001618x408
1C210Through Hole2,2001616x208
1C211Through Hole3,9001616x308
1C212Through Hole1,5001612.5x245
2C213, C214Through Hole15,0006.318x408
1C215Through Hole10,0006.316x408
1C216Through Hole220258x135
2C217, C223Through Hole100256.5x135
2C174, C218Through Hole11006.5x135
1C220Through Hole47255x135
2C173, C221Through Hole0.471005x5x135
2C178, C179Through Hole10635.5x135
Magneto Optical (MO) Drive​
9Analog C221/C266/C269 (3)
Digital C421/C433/C447/C448/C477 (5)
Motor C9 Rev B (1)
Through Hole10164x61.5
1Hidden cap behind eject motorThrough Hole10254x61.5
5Motor C4/C5/C6/C7/C8 — 50V covers both Rev A and Rev BThrough Hole10505x62
5Analog C281/C244 (2)
Motor C2 Rev B (1) OR Motor C1/C2/C30 Rev A (3)
Through Hole1504x61.5
1Motor C3Through Hole2.2504x61.5
2Analog C306/C369 — must be polarizedThrough Hole3.3505x62
2Motor C31/C32 — Rev A only; skip if Rev BThrough Hole22105x62
2Analog C364/C365Through Hole22165x62
7Analog C277/C279/C303/C352/C353/C354/C355Through Hole47166.3x62.5
1Motor C11 — blue body, not electrolyticThrough Hole1016N/A
MO Drive Capacitor Maps​
MegaPixel Display Analog Board N4000 (Revision: 1-623-855-12)​
Note: adapted from asterontech.com and not yet verified on my display.
QuantityLocation(s)TypeCapacitanceVoltage RatingSize (mm D xH)Lead Spacing (est.)
1C33Through Hole1,2003512.5x315
2C43, C80Through Hole11005x112
1C56Through Hole11606.3x112.5
1C68Through Hole100358x113.5
1C5Through Hole10010010x205
1C48Through Hole100508x113.5
3C7, C8, C34Through Hole1,0003512.5x255
1C24Through Hole3306.36.3x112.5
5C3, C6, C14, C15, C36Through Hole3303512.5x155
5C2, C11, C17, C37, C62Through Hole221006.3x112.5
6C31, C35, C44, C70, C200, C202Through Hole22505x112
1C99Through Hole47506.3x112.5
1C69Through Hole (Bi-Polar)22256.3x112.5
MegaPixel Display Analog Board N4000A (Rev: 1-623-855-16 A)​
1C33Through Hole1,2003512.5x31.55
MegaPixel Display Sound Board N4000 (Rev.: 1-623-854-12)​
2C140, C141Through Hole4701611x15TBD
2C144, C145Through Hole1,0001610x205
2C212, C262Through Hole220258x11.53.5
2C220, C270Through Hole22505x112
9C143, C146, C203, C219, C221, C253, C256, C269, C271Through Hole10505x112
1C136Through Hole47165x112
1C135Through Hole100167x11TBD
10C125, C126, C130, C131, C149, C150, C151, C152, C209, C259Through Hole22165x112
MegaPixel Display Sound Board N4000A (Rev.: All)​
12UnmarkedSMD4716B (for tant) or 1206 (ceramic)N/A
1UnmarkedThrough Hole1,5001610x205
AlexMac
109
59
Bavaria
At least for the NeXT Stations I have seen almost no leaky caps. Only one Station Turbo showed some and I recapped them. Usually it is enough to replace the 47 / 16 Caps AFAIK. Having plenty of those handy is anyways advised :)
JdM74
41
44
Georgetown TX
Hey @Elemenoh! This is a great cap compilation [especially for the PSU]. One question, which of the Cube PSU's does this list refer to? There were a few of them used. The older of them was used in original 030 Cubes, while older '030's and '040' used another. The PSU's model number [thankfully] is on the tag. It'll either be 151 or 953. Thank you for posting this....and if it's for the 953, you've saved me a bunch of time!
Elemenoh
457
445
Bay Area
I'll check and add the model info. The PSU I built this list from is from an early serial 030 'NeXT Computer'.
Paolo B
309
181
The best source is definitely the book “Inside NeXT - A guide to the Black Hardware“, where you can find a list of capacitors for each item.
Concerning the MO Drive, I have refurbished a few units, with fair rate of success (5/6). I did the last two units a few years ago using surface mounted components instead of through hole. Tricky, but doable and the result is very neat. They still work flawlessly.
Elemenoh
457
445
Bay Area
I looked through my copy of the book (which I adore). It doesn't have a cap list for the Cube at all. The NeXTStation lists do not include power supplies. But most importantly the first page of the repair section says
The author of this book, who has simply collected this documentation from the web, is in no way responsible for any damage caused to the machine when attempting to repair it, or for any personal injury caused by inexperience or negligence in the execution of the procedures described below.
So while it's a very nicely laid out resource, it's just a collection of info found online, is not itself searchable, and the book is out of print. It's not an ideal or complete source for someone looking to recap their NeXT stuff IMO.
Update: the book references this as the source for most of its cap lists: http://www.asterontech.com/Asterontech/Welcome.html and the MO caps are credited to https://www.nextcomputers.org/NeXTfiles/Docs/Hardware/NeXT_Magneto_Optical_Service_Manual.pdf but that link is 404
jktw
Hello, I am dusting off a monitor and cube that have been in storage for 20ish years. I started disassembling the N4000 display to check the capacitors, but on step 6 here is it really required to remove all 20+ screws!?
I'm about halfway through and out of time for now. The top seems like it should come off first, but it's firmly wedge into the front. I feel like if I undo all the screws on the side and bottom, the whole thing is going to collapse!
Paolo B
309
181
The metal cage is just a shield. Main concern is to avoid getting electrocuted (follow the instructions for discharging the fly back), and - of course - avoid cracking the neck of the tube. Replaced all the caps on my N4000 unit some years ago. Tricky, but doable.
jktw
I found instructions in Appendix B of the service manual, will try this when I have time:
Removing the L-board from the N4000 MegaPixel Display.
1. Use a #2 Phillips screwdriver to remove the screws from each access panel on the left
and right sides of the display.
2. Remove the 4 screws that attach the black painted area of the top cover.
3. Remove the anode cap inside the access hole on the right side of the monitor. The anode
cap is a red, rubber suction cup that contains a wire clip. Firmly squeeze the anode cap
to depress the wire clip leads and extract them from the hole in the side of the CRT.
4. Detach the nylon retaining strap connect to the anode cap wire.
5. Reach inside the access hole to disconnect the tube socket:. Pull straight back on the
connector at the back of the CRT. The connector is a ring and is keyed for proper
removal and installation.
6. Disconnect the yoke connector by removing the flat plastic connector attached to the
upper portion of the L-board.
7. Lift slightly on the top cover and hinge the L-board down.
8. Rock the L-board up and down gently to release it from the metal tabs that grasp the
L-board mount.
Elemenoh
457
445
Bay Area
Added capacitor maps for the MO drive. Lots of tiny through holes. Be cautious with the 1uF / 50V caps. I was only able to find them in 9mm height where the originals are 6mm. In some cases they can be installed normally. In the board sandwich you may need to tilt it over a bit to make room.
Many of the little ones had spilled their guts and corroded surrounding pins. The majority of time spent recapping this thing was spent cleaning up all of the crud. Fortunately there didn't seem to be any major damage.
Reactions: PL212 and jktw
jktw
Nice work on the MO drive, that's a lot to remove.
I got my L board off the N4000 and the logic board is part number 1-623-855-13 - a later revision than the N4000 logic board pictured on asterontech. I see some differences between the Next logo and the flyback transformer. Anyway, I started cataloging all the caps but it's going to take me a while.
KennyPowers
351
384
I re-did 5 of those MO drives recently...they are certainly a pain. At least you can separately verify that the motor board is working and properly regulating RPMs before reassembly using a bench power supply. Still, I won't be upset if I never work on one of those again :LOL:
It should be noted that there are multiple variants of the motor and analog boards:
  • NeXT Magneto Optical Service Manual.pdf
Reactions: Paolo B
Elemenoh
457
445
Bay Area
I added a cap map for the N4000A analog board and made a correction in the list: C202 was mislabeled as C1. The sound board is very straightforward so no cap map needed. But there is a connector very close to one of the 47uF/16V SMD caps. I removed that before replacing the cap to avoid melting the connector. See photo below.
A tip/warning for anyone servicing the power supply. There is a LOT of thermal grease on the heat sink. I ended up buying an 8oz tub of 120-8 Thermal Joint Compound which seems to be exactly what was used in the factory. I recommend cleaning the old stuff off before proceeding with recapping or you'll get everything, including yourself, very messy.
Also, if anyone has a spare 256MB MO disk they're willing to give/sell/trade, please let me know. I serviced the drive but don't have a disk to test with.
Remove this connector before trying to replace the nearby cap on the MegaPixel sound board.
There's thermal grease on both the top and bottom side of this heat sink plate on the power supply.
