Here is that Pi case at 325% and thinned out. It will probably be easier to modify this model than recreate from the 3D scanned version.Some guy did just recently 3d print a full scale Lisa
Percentage may be off:Agreed. Some parts could be seamed with minimal visual impact, but the front panel is still an issue. There is room to shrink it further to fit inside a 300x300x400mm build volume of an old CR-10 or 350x350x350 K2 build volume. Further shrinkage may make the 9.7 screen appear disproportionate, but an original 12" to 9.7" conversion should be 80.83 percent.
Thanks for those measurements. I think we still need to wait for word if the LisaFPGA can even output to 1024x768 over HDMI, as the documentation seems to show that it outputs full 1080p. Not sure if an iPad control board scales higher HDMI signals down to 1024x768.Percentage may be off:
- Specs for LCD and CRT are not the same. Tube diagonal is not equivalent to LCD dagonal.
- Need to consider how much larger a 9.7" screen would be than an 80 percent opening for a 12"diagonal CRT
- Display area of an LCD is the tuge diagonal vs. the display area of a 12" CRT.
- The front bezel covers a portion of the CRT.
- The diagonal of the "12inch" bezel opening is only 11 5/8 inch.
- The "pixel field" diagonal is less than that.
- "Squared up" LCD opening dropped back from surface of the front bezel a tad more than 1/4" yields a diagonal of 11 7/8"
- So your baseline for scaling would be something like 11.875" -> 9.7" yielding a scaling factor of at least 81.68 percent
- Still wouldn't look quite right with no Start/Stop/Front Porch/Back Porch blanking areas surrounding the Lisa image
- Assuming my caffeine deprived brain is up to snuff for this.
All measurements are from my Lisa2 bezel with pencil scribed setbacks. A 12" LCD won't work in it for same reasons.
I believe it does, but my LisaFPGA arrives Friday so I'll confirm and we can proceed from there with the result. But I forgot the conversion of CRT size to viewable. It definitely seems like even with a smaller 9.7" LCD, it will be difficult to get something printable on a 350mm x 350mm bed.Thanks for those measurements. I think we still need to wait for word if the LisaFPGA can even output to 1024x768 over HDMI, as the documentation seems to show that it outputs full 1080p. Not sure if an iPad control board scales higher HDMI signals down to 1024x768.
Glad to have pointed out that discrepancy, it drove me to distraction playing with my "Little Bit of Lisa" before the LCD/Controller revolution induced by the Raspberry Pi movement. The solution I came up with was the 12" RGB PizzaTopper. Fits like a glove, but not at all practical unless a 640x480 hack can be pulled off. The targeted 6400/6500 boards can drive the smaller resolution, but why bother?I believe it does, but my LisaFPGA arrives Friday so I'll confirm and we can proceed from there with the result. But I forgot the conversion of CRT size to viewable. It definitely seems like even with a smaller 9.7" LCD, it will be difficult to get something printable on a 350mm x 350mm bed.
I must be misunderstanding what you are saying. The front piece is ~18" wide The full width of the Lisa assembled is 18.75". The difference between a part that can print a 457mm wide print and one that can print one that is 476mm wide is not going to rule out any 3d printers. Even scaled down to ~80% (which is not going to accommodate a 9.7" LCD, that difference is 365mm vs 380. Again, at that point you'd need a 400mmx400mm print bed printer and you'd be better off printing together.The front bezel (only Little Bit of Lisa in my collection) is your print limit factor. If you angle just that one part to max size in you printer, might it fit that cubic closer to life size?
edit: I can knock back the return at the bottom of my bezel a hair over 3/4" at the mold break line to gain a few extra degrees of slant for printing.
I thought you were saying you don’t want to post it standing on end. And you wanted to print it flat on the surface. Are you saying we should print it like this with the shorter edge on the print bed angled up to use the 400mm of height diagonally to take advantage of the 530mm or diagonal space going from the bottom right of the bed to the top leftmost on the x axis:if printer cubic is a 350x350x400 it looks like I could print my bezel at full size?
"The hypotenuse is the side opposite the 90° angle. Using the Pythagorean theorem, √(350²+400²) ≈ 531.4 mm."
Yep! The bezel is a bit over 450mm wide. NoPro!
If the right triangle’s legs are both 350 mm (an isosceles right triangle), the hypotenuse is found by the Pythagorean theorem: c=3502+3502=3502c=3502+3502=3502. That equals about 495 mm.
Dunno, why can't it be printed for 9.7" screen?
If the base is 350x350 then that's 495 mm diagonal.
Of course, a 495 mm long rectangle could only have a thickness of 0 in that case. So I googled this:Yep! The bezel is a bit over 450mm wide. NoPro!
