Here is that Pi case at 325% and thinned out. It will probably be easier to modify this model than recreate from the 3D scanned version.Some guy did just recently 3d print a full scale Lisa
Percentage may be off:Agreed. Some parts could be seamed with minimal visual impact, but the front panel is still an issue. There is room to shrink it further to fit inside a 300x300x400mm build volume of an old CR-10 or 350x350x350 K2 build volume. Further shrinkage may make the 9.7 screen appear disproportionate, but an original 12" to 9.7" conversion should be 80.83 percent.
Thanks for those measurements. I think we still need to wait for word if the LisaFPGA can even output to 1024x768 over HDMI, as the documentation seems to show that it outputs full 1080p. Not sure if an iPad control board scales higher HDMI signals down to 1024x768.Percentage may be off:
- Specs for LCD and CRT are not the same. Tube diagonal is not equivalent to LCD dagonal.
- Need to consider how much larger a 9.7" screen would be than an 80 percent opening for a 12"diagonal CRT
- Display area of an LCD is the tuge diagonal vs. the display area of a 12" CRT.
- The front bezel covers a portion of the CRT.
- The diagonal of the "12inch" bezel opening is only 11 5/8 inch.
- The "pixel field" diagonal is less than that.
- "Squared up" LCD opening dropped back from surface of the front bezel a tad more than 1/4" yields a diagonal of 11 7/8"
- So your baseline for scaling would be something like 11.875" -> 9.7" yielding a scaling factor of at least 81.68 percent
- Still wouldn't look quite right with no Start/Stop/Front Porch/Back Porch blanking areas surrounding the Lisa image
- Assuming my caffeine deprived brain is up to snuff for this.
All measurements are from my Lisa2 bezel with pencil scribed setbacks. A 12" LCD won't work in it for same reasons.
I believe it does, but my LisaFPGA arrives Friday so I'll confirm and we can proceed from there with the result. But I forgot the conversion of CRT size to viewable. It definitely seems like even with a smaller 9.7" LCD, it will be difficult to get something printable on a 350mm x 350mm bed.Thanks for those measurements. I think we still need to wait for word if the LisaFPGA can even output to 1024x768 over HDMI, as the documentation seems to show that it outputs full 1080p. Not sure if an iPad control board scales higher HDMI signals down to 1024x768.
Glad to have pointed out that discrepancy, it drove me to distraction playing with my "Little Bit of Lisa" before the LCD/Controller revolution induced by the Raspberry Pi movement. The solution I came up with was the 12" RGB PizzaTopper. Fits like a glove, but not at all practical unless a 640x480 hack can be pulled off. The targeted 6400/6500 boards can drive the smaller resolution, but why bother?I believe it does, but my LisaFPGA arrives Friday so I'll confirm and we can proceed from there with the result. But I forgot the conversion of CRT size to viewable. It definitely seems like even with a smaller 9.7" LCD, it will be difficult to get something printable on a 350mm x 350mm bed.
I must be misunderstanding what you are saying. The front piece is ~18" wide The full width of the Lisa assembled is 18.75". The difference between a part that can print a 457mm wide print and one that can print one that is 476mm wide is not going to rule out any 3d printers. Even scaled down to ~80% (which is not going to accommodate a 9.7" LCD, that difference is 365mm vs 380. Again, at that point you'd need a 400mmx400mm print bed printer and you'd be better off printing together.The front bezel (only Little Bit of Lisa in my collection) is your print limit factor. If you angle just that one part to max size in you printer, might it fit that cubic closer to life size?
edit: I can knock back the return at the bottom of my bezel a hair over 3/4" at the mold break line to gain a few extra degrees of slant for printing.
I thought you were saying you don’t want to post it standing on end. And you wanted to print it flat on the surface. Are you saying we should print it like this with the shorter edge on the print bed angled up to use the 400mm of height diagonally to take advantage of the 530mm or diagonal space going from the bottom right of the bed to the top leftmost on the x axis:if printer cubic is a 350x350x400 it looks like I could print my bezel at full size?
"The hypotenuse is the side opposite the 90° angle. Using the Pythagorean theorem, √(350²+400²) ≈ 531.4 mm."
Yep! The bezel is a bit over 450mm wide. NoPro!
If the right triangle’s legs are both 350 mm (an isosceles right triangle), the hypotenuse is found by the Pythagorean theorem: c=3502+3502=3502c=3502+3502=3502. That equals about 495 mm.
Dunno, why can't it be printed for 9.7" screen?
If the base is 350x350 then that's 495 mm diagonal.
Of course, a 495 mm long rectangle could only have a thickness of 0 in that case. So I googled this:Yep! The bezel is a bit over 450mm wide. NoPro!
Yeah, that would probably be ideal. The problem, that I've been worried about this whole time is the challenge of how do you manage taking the 1920x1080 (16:9) output with letterboxing from the LisaFPGA and getting it to display the middle portion on a 4:3 display. I was hoping (probably irrationally) that the controller board would scale it and offer options for doing so (with one option being to cut off the sides (which are black).If you want to go full size, I would suggest finding an old ibook 12" and salvaging that screen, as there are driver boards for it. I think there even may be used screens available for replacement.
Of course, that would require a new build to the LisaFPGA, extra work for Alex or someone familiar with FPGA output.Best simple FPGA implementation: 960×728
This produces an image aspect ratio of:
- Horizontal: 720 → 960, exactly 4/3 scaling
- Vertical: 364 → 728, exactly 2× line doubling
- Borders: 32 pixels left/right and 20 pixels top/bottom
960/728 ≅ 1.319
That is only about 1.1% narrower than perfect 4:3, so it should look essentially correct while allowing very simple FPGA scaling:
- Repeat each vertical line twice.
- Horizontally output four pixels for every three source pixels, using a repeating pixel pattern.
Floppy disk vertical? Disks pop out like a toaster? Aside from the concerns over dust (we could put a flip cover to protect it when not in use, I think the idea would be awesome. The problem is still the display.Bare Metal Lisa III Prototype:
Print just the metal framework & internal boxen. Feet would be hardwood as in the Lisa Prototype pics showing bare metal side panel. FDD goes vertical next to 1080p panel and innards hidden in the box. Make grooves on side panel vertical?
edit: FDD or Optical case can just stick out the back. In make believe Lisa III world Twiggy was a big success. Love that slot with a laptop optical drive mechanism. Overlong back and bottom printed int boltup sections or laser cut plexi?
I've got some tweaking to do on some of the parts, but I'm pretty pleased for the first full print. The seam line, while pretty good, isn't quite as smooth as I'd like - will try to adjust the overlap to allow it to be fully flush. I'll also try to add some vintage apple inspired styling to it. I'm hoping to add some vent lines that will make the seam less noticeable. And maybe try to make the floppy screen opening shaped a bit like the floppy port...Floppy disk vertical? Disks pop out like a toaster? Aside from the concerns over dust (we could put a flip cover to protect it when not in use, I think the idea would be awesome. The problem is still the display.
I started making progress on my standalone case for the LisaFPGA... It's bigger than I thought, and even on my Max Neo 3 printer, it cannot be printed in one piece. So I'm breaking it into piece that can be glued / solvent welded. My first attempt ignored a very real issue - when the board has ports on all 4 sides that stick out past the board, you cannot just take cut-outs . I went with having the halves cut right though the ports. It works, but I might do something where one side panel is actually on the top and the other 3 are on the bottom piece. Waiting for the other two pieces to come off the printer to gcheck the fit and hopefully glue the pieces together...
Also hoping my Logitech mouse comes in so I can see if it works in my Lisa mouse case...
