Apple Lisa 3d Case Project
572
Some guy did just recently 3d print a full scale Lisa
Here is that Pi case at 325% and thinned out. It will probably be easier to modify this model than recreate from the 3D scanned version.
Reactions: wottle
459
Agreed. Some parts could be seamed with minimal visual impact, but the front panel is still an issue. There is room to shrink it further to fit inside a 300x300x400mm build volume of an old CR-10 or 350x350x350 K2 build volume. Further shrinkage may make the 9.7 screen appear disproportionate, but an original 12" to 9.7" conversion should be 80.83 percent.
Percentage may be off:
- Specs for LCD and CRT are not the same. Tube diagonal is not equivalent to LCD dagonal.
- Need to consider how much larger a 9.7" screen would be than an 80 percent opening for a 12"diagonal CRT
- Display area of an LCD is the tuge diagonal vs. the display area of a 12" CRT.
- The front bezel covers a portion of the CRT.
- The diagonal of the "12inch" bezel opening is only 11 5/8 inch.
- The "pixel field" diagonal is less than that.
- "Squared up" LCD opening dropped back from surface of the front bezel a tad more than 1/4" yields a diagonal of 11 7/8"
- So your baseline for scaling would be something like 11.875" -> 9.7" yielding a scaling factor of at least 81.68 percent
- Still wouldn't look quite right with no Start/Stop/Front Porch/Back Porch blanking areas surrounding the Lisa image
- Assuming my caffeine deprived brain is up to snuff for this. :sleep:
All measurements are from my Lisa2 bezel with pencil scribed setbacks. A 12" LCD won't work in it for same reasons.
572
Thanks for those measurements. I think we still need to wait for word if the LisaFPGA can even output to 1024x768 over HDMI, as the documentation seems to show that it outputs full 1080p. Not sure if an iPad control board scales higher HDMI signals down to 1024x768.
459
Angles for setback of display are different. Sides are steep, Top is more shallow and bottom is very shallow.
Are you taking that into consideration? Matching the multi-angled framing of the LCD would enhance the look, being more natural.
Note scribed lines in pencil. Strange bulge on bottom curve screws up adaptation of stock bezel to LCD. Would probably need an 11" 3:4 panel.
629
I believe it does, but my LisaFPGA arrives Friday so I'll confirm and we can proceed from there with the result. But I forgot the conversion of CRT size to viewable. It definitely seems like even with a smaller 9.7" LCD, it will be difficult to get something printable on a 350mm x 350mm bed.
Possibly if we use the Pie model, and print the pieces vertically at a diagonal on the bed. Anyone print a really large thin piece standing on edge on a large format printer? @jcm-1, I believe you have some large bed 3d printers. How do you think it would handle something like this?
459
Glad to have pointed out that discrepancy, it drove me to distraction playing with my "Little Bit of Lisa" before the LCD/Controller revolution induced by the Raspberry Pi movement. The solution I came up with was the 12" RGB PizzaTopper. Fits like a glove, but not at all practical unless a 640x480 hack can be pulled off. The targeted 6400/6500 boards can drive the smaller resolution, but why bother?
One single piece print done diagonally makes no sense to me whatsoever. All that filament gone to wa$te in one bad shot? The Lisa case is nicely divided into sections, unlike the unitary Macintosh bucket. I say leverage that sectional flexibility to reduce the price impact of a failed print?
Reactions: phunguss
572
Well, if an iPad 1/2/3 at 9.7” is too large for a smaller print, we could try an iPad Mini 1/2/3/5 at 7.9”, but working controller boards are harder to find. I think this may be the only one. eBay for AbuseMark.
459
The front bezel (only Little Bit of Lisa in my collection) is your print limit factor. If you angle just that one part to max size in you printer, might it fit that cubic closer to life size?
edit: I can knock back the return at the bottom of my bezel a hair over 3/4" at the mold break line to gain a few extra degrees of slant for printing.
