Apple Lisa 3d Case Project
490
Floppy disk vertical? Disks pop out like a toaster? Aside from the concerns over dust (we could put a flip cover to protect it when not in use, I think the idea would be awesome. The problem is still the display.
Nope, more like these from Radio Shack used as inspiration for a Lisa-like Lisa III makeover:
Do either basic bezel form factor with a single, vertical Twiggy drive slot in place of the 8" FDD slot with the remainder of the bezel a 1080p TPD. Yout 9.& inch LCD would align nicely with the 5.25 inch Twiggy slot I think.
Your current case could be fleshed out into something like this one by herr Esslinger @ Company:
Shorten it up a quite a bit, sans printer with the display in a frogdesign inspired flat panel case and it could look a bit like this:
Had his steveness and the Mac project failed with the Lisa carrying the DTP banner into history, the Lisa III might have looked more the Mac II than its predecessors as happened with the Mac.
With acceleration, the new CatMacFPGA is definitely the Lisa III, so take its wide screen case design into the frogdesign what if verse. Such would be a Macintosh free, future forward SteamPunk kinda thing?
edit: a Laptop slot loader optical would take the place of the 8" FDD for function/looks and can stick out the backside, but a 1.4 FDD enclosure would be provided for side slot flexibilityThe Twiggy Slot would then be for looks alone.
Still liking the the notion of a full metal ProtoIII with hardwood feet.
741
Ok, added a little character to the case. The Apple / Lisa logo didn’t work out as I’d hoped. I was trying to use PETG as a support for the PLA (they aren’t supposed to stick together, so support removal should be much easier, /!: I thought using black against the white would make it easier to see what needed to be removed. Unfortunately, it causes color bleed and because the area around the logos is so small, it all blends together and become unremovable.
Once I tweak the model a bit I’ll print it in platinum pla with a grey background around the apple and Lisa logos. I also don’t like the contrast of the black behind the buttons. The subtlety of the debossed text is cleaner looking and still ensures people can find the right button. I also reduced the size of the cut-outs for the buttons and enlarged the logos to hopefully improve the printability. And I replaced the finger sized cut out for the power switch with a little pull tab.
One question for those who might be interested in this: There are a decent number of switches on the top of the board. Are you OK opening up the case if you need to change these (e.g. keyboard or mouse input, ESFloppy vs FloppyEmu, Speed settings)? Adding a bunch of switches to the top would be a challenge and would really clutter up the look of the top. I would really like to remove the buttons for the Program, and ESProfile/ESFloppy reset buttons. I just haven't used the device enough yet to know how often they'd be needed once set up. If it's only doing troubleshooting / setup, it would be nice just to have the 6 buttons at the bottom.
warmech
121
For what it is worth, the only switch I ever toggle is the power switch. Everything else I've configured (including jumpers) and not touched again.
Reactions: wottle
741
Yeah, that was how I envisioned it. Worst case it’s four screws undone and you have access to all the switches to make adjustments.
Newrly done with the design. Tweaking the power switch plunger design to make it have less play. Ran out of white filament so had to switch to black. I will probably print the next iteration (hopefully v1.0 final) in platinum PLA.
741
Ok, got it printed in platinum PLA. Certainly doesn’t match the original, but I think it does the Lisa look justice.
I need to clean up and organize my files, which are currently optimized for printing in 4 main parts, plus the pull switch on the side. Also, I want to make a version that people with 350mm wide printers can print in two pieces (vs 4). Also might not be able to include the logos on the version on Thingiverse / MakerWorld for copyright reasons.
molten_software
www.molten.pw
That turned out awesome!
Reactions: wottle
741
Now that I'm looking at it, I kind of wish I had rotated it to look like the right side of the Lisa . I could have rotated the text on the buttons, but the problem would be that the ESFloppy screen would be turned sideways. I'll probably leave it as it for now.
Now I need to figure out how to get the video out to work with a 4:3 LCD. And possibly work this into a a case with a display.
490
ProtoLisaIII-FPGA: Second rev-cool foot - interesting sheet metal
Second rev ProtoFoot/sheet metal
Parts printed face down
- flanges turned inward.
- horizontal parts would be aluminum or galvanized steel from Lowes/Depot.
- everything but the feets spray painted with textured silver and aged or matte black
Vertical cage for 3.5" FDD innards
Depth matches vertical 3.5" FDD requirements.
Internal boxes faked up for looks.
LCD is unapologetically 16:9 1080p
741
OK, I spent some time cleaning up my files and getting them ready for others. I also created a couple of variants. For example, the one I printed has the Lisa and Apple logos, which I will include in the zip file here, but I didn't include in my Thingiverse upload. Not sure if it would get pulled down for having the apple logo. The Lisa logo seems less likely to cause problems, so I have it included on Thingiverse. But if you want the version with the apple and Lisa logos already applies, they are in the zip file below. I also have a non-spliced version for people with 350mm x 350mm printers...
Here's the printing advice I put in Thingiverse: Print with the outer surfaces down, although for the debossed areas as well as the recessed area on the top_small part, I recommend supports for the areas not in contact with the print bed. If you do have a multi-color printer, I had very good results with using PETG as the support material and PLA for the print. Otherwise support removal will be annoying and may cause the overlapping tabs to not allow the split pieces to come together completely.
Also, worth noting if you are considering printing this: it seems like I'm not the only one looking to have a case. So if you can be patient, you might have options soon. I'm not going to say who or where, as I don't want to ruin any surprises, but there may be others, and probably by someone who is a much better 3d designer than me. Of course, if you don't mind using a couple hundred grams of filament, you can print this one now, and the other design later, should it happen.
  • LisaFPGA_Case_FinalFiles_v7.zip
Reactions: phunguss
741
OK, decided to graduate from TinkerCad into OpenSCAD for trying to model the Lisa Mini case with display. All of this is still based on the assumption that we can get a 9.7" 4:3 screen to work. I just don't see the reason for using a 16:9 1080p LCD for this project when it will just have black letterboxing on the sides. I'm going to at some point dig into the software side of the LisaFPGA and see if I can enable it and create a custom build.
But, I'll say the ability to get a 3d printable version on a 350mm print bed is possible if I just ignore the floppy drive, which would be an empty slot anyway. Maybe it could have housed an SD card extension, but I am leaning towards just excluding it altogether. The size limitations just mean this is likely not feasible. If I do add a floppy back, I'd likely make the device thicker and have it side loading like the Mac Portable, but vertical. I still think this would present problems with where I could cram in the lisaFPGA board and the floppy drive itself. Might need to make a cardboard mock up to get a sense for how things might fit.
I am still tweaking things to try to match some of my design mock ups. One question, how do people feel about the separate legs. Should I add a skirt between the legs and make it solid? That would more closely match the original, and it would help hide the cables (power, usb / keyboard and mouse) that will stick out from the bottom of the lisaFPGA. Might need to add an optional notch under so the original Lisa coiled keyboard cable will reach to the front
Opinions on whether the gap between the legs should be open? Leaving it open would certainly reduce print time and filament used. I could also add cable management routing to the back of the leg to keep the cables out of view.
Reactions: Trash80toG4
490
OOPSIE! I thought it was outputting some custom resolution that fit 1080p, something on the order of 640x400 on the 'Books which is closer to 16:9.
What resolution does it output?
As far as the FDD goes, it looks like you might be able to install it behind a flip-down cover panel kinda like the TAM optical setup. Disks would insert vertically into the swing down Laptop Drive? Same bay could be access for SD thingamajig in place of FDD?
Nice work. How do TinkerCad and OpenSCAD compare? I need to get back into CAD for this kinda stuff.
edit: looked a bit, there seem to be a few 10.4" 1024x768 display setups in the $120-130 range on eBay:
If printing it in sections, that'd make the flop-out-floppy side and display bezel within your print cubic?
Still stuck on my BareMetal Lisa III protocase though. ;)
741
I think making a pivoting floppy is going to exceed my cad skills for a very long time, sadly. TinkerCad is sort of like glueing together pre-made shapes with the ability to carve out one shape from another. For example, to bevel the edges of my case I posted, I created a second set of squares, angled them 45 degrees and positioned them to overlap the case a bit, changed the shapes to a “hole” and then combined the shapes. Think toddler with a box of shapes (and a cool router that could remove shapes from your existing structure).
OpenSCAD is basically a programmable script where you define your shapes and transformations in code. I love it in the fact you can define properties at the top, then the code will build the objects. If you want something different (e.g. screen size), you can change the properties and (assuming you’ve build the logic properly to base sizing and positions off of other things), everything adjusts. Resizing or tweaking things in tinkered was a nightmare - ungroup, ungroup, adjust regroup the right things, regroup again… I can adjust things with a few swttings changes in openSCAD. However it gets pretty complex when you start doing things like assemblies and having angled front pieces that must fit perfectly into the other. It’s definitely above much of my ability to remember geometry and get my angle calculations right. I’m relying heavily on Claude for much of that.
The lisaFPGA is fixed at 1920x1080 at either 30 or 60Hz. I’m currently looking to see if I could get it to output 1024x767 with minimal leterboxing. Because of the pixel multiplication, I think I can get it close. You definitely cannot arbitrarily scale and expect things like text to be super clear. So we’ll see if I can get it to work and if it looks ok. Then people can chose any XGA display. There’s just a good amount of work to create the mounts for the lcd panel and controller board / control buttons. I personally have an extra iPad display and controller so that’s my initial target.
I’m going to try to make it parameterized if possible to maybe allow others to quickly adjust my model to different setups. If possible, then others could diy their own config and fit their needs. I’m hoping maybe I can take the case I built in TinkerCAD and import it into openSCAD to try to recreate it programmatically. We’ll see. I’ve shifted to the software side to see if I have any chance of figuring out how to update and load the programming on the LisaFPGA side for now. If I can get video output, I’ll shift back to the case side of things.
490
Sounds like a plan!
Does the Lisa board really output 1920x1080? In that case I'd really go for the Bare Metal Prototype Lisa III as it's better than TPD resolution and much faster than the real deal in acceleration mode. Zero point in making it look like original Lisa or Lisa II, IMO.
Can either CAD Package import Illustrator or PDF files of flat faces to be built up in thickness and to add returns (stamped metal flanges) to build up a part?
I could fire up Corel Draw to convert to .DXF if that CAD file format can be imported into either program?
741
I've got some software changes I want to try to make on the LisaFPGA, but it is apparently quite involved trying to compile the software for the FPGA itself, and seems to be something not possible (or at least not possible reliably) on a Mac. I tried an old Lenovo laptop but it was not up to the task to even get the software installed. I now have my 2013 Mac Pro dual booting Windows 10 and have the AMD software installed, but I cannot run it because I need to get a license and their license server appears to be down. Hopefully sometime this weekend I'll have a chance to get a license and try out my code on the LisaFPGA.
Also, if I can't get it to work, I'm wondering if a 3:2 aspect 1920x1280 monitor would work better. The problems I mentioned about possible future availability would still hold, but I might grab one of these (https://a.co/d/0gZOsfJL) and see if it works out of the box and if maybe there is a stretch option that will cut off the side letterboxing on the 1920x1080 video feed. I'd have to see how that would affect my ability to scale to the new resolution. It's possible it would work and I could just design the mount to hide the unrendered areas behind the bezel. It also would be less than ideal because it would be a 10.5" display where we would likely only owe using ~8" of it. It would also potentially affect the position of the cutout on the case, if the letterboxed picture is in the center. I'd likely have to remove it from the casing and try to relocate the controller board to allow the connections, and it seems to be usb-c powered, to I'd need to figure out how to power both the USB-C devices from one power input. Ah, choices! Well, I'll hopefully make some progress this weekend. I'm still waiting on a keyboard that works with the LisaFPGA. Didn't notice the part about it being finicky with what keyboards work, but I can confirm it didn't work with any of the 4 different models of Apple USB keyboards I tried. I think I actually tried all of the various models (not all the colors, but I did try a colored iMac keyboard. Zero worked.
741
So how many by how many pixels does this thing put on a 1080p screen?
I believe it is 3x the original vertical 360 pixels tall, which would be 1080. And 2x wide which would be 1440 (rectangularn” pixels are weird)
I spent some time tinkering trying to get it to output 1024 x 768. Shockingly, with no experience programming FPGAs, I was able to get it to display on my iPad screen!
Unfortunately, I was trying not to have to do any anti-aliasing. But it definitely results in some vertical lines that are drawn being wider than others, creating a weird pattern. I’m going to try to do an anti-alias and see if it is reasonable. Currently, I have it set up where if you have the jumper set to 1080p 30Hz it still gives 1080p. But if you flip the jumper to the 60Hz side, it will output 1024x768. So you could still plug it into a modern tv or monitor if you wanted without having to re-flash the device. It also can be built by flipping one setting in a single file. So by default you get Alex’s 30/60Hz toggle, but if you change one setting, the firmware will give you 1080p/1024x768 behavior. Hopefully that allows enough flexibility that Alex will feel good about me setting it up as an alternative config. But I’m hopeful I can get this set up to work with the iPad screen. If I can improve the visual quality, I’ll revert to working on the enclosure.
If I cannot, I’ll probably see if I can get a 12” 16:9 1080p LCD and controller and then update the LisaFPGA programming to shift the displayed image to the left, allowing me to mount the LCD in the enclosure and simply cover the right side of the screen where all the letter-boxing has been moved. I’ll just try to match the height of the iPad screen as much as I can.
EDIT: It seems like an 11.6" widescreen panel is what I'd be looking for. It is almost exactly the same height (total and viewable) as an iPad screen. It's about 60mm wider, which should be just fine and will extend behind the right side of the front bezel. I don't know if the controller board will fit. Ideally all the screen components would mount to the front piece (LCD and controller board), the LisaFPGA would be mounted to the rear case shell, and you'd connect the HDMI and power to the LCD and slide the front piece onto the rear shell. Also, it could potentially be used as a touch panel if someone wanted to add a digitizer to it and then connect it to the LisaFPGA USB slots.
Reactions: molten_software
490
So that's a 3x scaling of the actual Lisa screen, was playing with those numbers over the weekend.
Was looking into the same over the weekend.
Can't imagine it won't fit. Cable length usually makes positioning of the controller boards very flexible. That particular controller avoids the VGA connector skyscraper problem.
741
Finally got the Logitech M185 in and did some tweaking of my design. It took a few tries but I was able to get it to fit. Still tweaking the right mouse button but should have it ironed out soon (sometimes it seems to get hung up on something).
Overall, though, it works well. The two buttons took some modifications from the original, but it doesn't seem too out of place.
EDIT: it looks pretty good in platinum with an apple logo pulled from a broken case:
HOWEVER, I am realizing with the limited USB support, this isn't going to work on the LisaFPGA. Just like the lack of support for any Apple USB keyboards (apparently I missed the part where Alex said any usb keyboards with a built in hub won't work). Trying to use a wireless one may also not work. So, while it will be cool to have a wireless Lisa Mouse, it won't allow me to use it with my modern Lisa hardware. Might need to see about using Raspberry Pi in my Mini Lisa case so I can use modern USB accessories stuffed in Lisa like cases.
I may also see if there I could take the guts of the cheap Lenovo wired mouse confirmed to work and put it inside the shell. I think one of these printed in the platinum would look nice with the modern Lisa case. I may also looks to see if I can expand USB support in the LisaFPGA... If I can get 1024x768 video out, I should be able to get USB hub support added, right?
