Apple Lisa 3d Case Project
462
Floppy disk vertical? Disks pop out like a toaster? Aside from the concerns over dust (we could put a flip cover to protect it when not in use, I think the idea would be awesome. The problem is still the display.
Nope, more like these from Radio Shack used as inspiration for a Lisa-like Lisa III makeover:
Do either basic bezel form factor with a single, vertical Twiggy drive slot in place of the 8" FDD slot with the remainder of the bezel a 1080p TPD. Yout 9.& inch LCD would align nicely with the 5.25 inch Twiggy slot I think.
Your current case could be fleshed out into something like this one by herr Esslinger @ Company:
Shorten it up a quite a bit, sans printer with the display in a frogdesign inspired flat panel case and it could look a bit like this:
Had his steveness and the Mac project failed with the Lisa carrying the DTP banner into history, the Lisa III might have looked more the Mac II than its predecessors as happened with the Mac.
With acceleration, the new CatMacFPGA is definitely the Lisa III, so take its wide screen case design into the frogdesign what if verse. Such would be a Macintosh free, future forward SteamPunk kinda thing?
edit: a Laptop slot loader optical would take the place of the 8" FDD for function/looks and can stick out the backside, but a 1.4 FDD enclosure would be provided for side slot flexibilityThe Twiggy Slot would then be for looks alone.
Still liking the the notion of a full metal ProtoIII with hardwood feet.
649
Ok, added a little character to the case. The Apple / Lisa logo didn’t work out as I’d hoped. I was trying to use PETG as a support for the PLA (they aren’t supposed to stick together, so support removal should be much easier, /!: I thought using black against the white would make it easier to see what needed to be removed. Unfortunately, it causes color bleed and because the area around the logos is so small, it all blends together and become unremovable.
Once I tweak the model a bit I’ll print it in platinum pla with a grey background around the apple and Lisa logos. I also don’t like the contrast of the black behind the buttons. The subtlety of the debossed text is cleaner looking and still ensures people can find the right button. I also reduced the size of the cut-outs for the buttons and enlarged the logos to hopefully improve the printability. And I replaced the finger sized cut out for the power switch with a little pull tab.
One question for those who might be interested in this: There are a decent number of switches on the top of the board. Are you OK opening up the case if you need to change these (e.g. keyboard or mouse input, ESFloppy vs FloppyEmu, Speed settings)? Adding a bunch of switches to the top would be a challenge and would really clutter up the look of the top. I would really like to remove the buttons for the Program, and ESProfile/ESFloppy reset buttons. I just haven't used the device enough yet to know how often they'd be needed once set up. If it's only doing troubleshooting / setup, it would be nice just to have the 6 buttons at the bottom.
warmech
120
For what it is worth, the only switch I ever toggle is the power switch. Everything else I've configured (including jumpers) and not touched again.
Reactions: wottle
649
Yeah, that was how I envisioned it. Worst case it’s four screws undone and you have access to all the switches to make adjustments.
Newrly done with the design. Tweaking the power switch plunger design to make it have less play. Ran out of white filament so had to switch to black. I will probably print the next iteration (hopefully v1.0 final) in platinum PLA.
649
Ok, got it printed in platinum PLA. Certainly doesn’t match the original, but I think it does the Lisa look justice.
I need to clean up and organize my files, which are currently optimized for printing in 4 main parts, plus the pull switch on the side. Also, I want to make a version that people with 350mm wide printers can print in two pieces (vs 4). Also might not be able to include the logos on the version on Thingiverse / MakerWorld for copyright reasons.
molten_software
www.molten.pw
That turned out awesome!
Reactions: wottle
649
Now that I'm looking at it, I kind of wish I had rotated it to look like the right side of the Lisa . I could have rotated the text on the buttons, but the problem would be that the ESFloppy screen would be turned sideways. I'll probably leave it as it for now.
Now I need to figure out how to get the video out to work with a 4:3 LCD. And possibly work this into a a case with a display.
462
ProtoLisaIII-FPGA: Second rev-cool foot - interesting sheet metal
Second rev ProtoFoot/sheet metal
Parts printed face down
- flanges turned inward.
- horizontal parts would be aluminum or galvanized steel from Lowes/Depot.
- everything but the feets spray painted with textured silver and aged or matte black
Vertical cage for 3.5" FDD innards
Depth matches vertical 3.5" FDD requirements.
Internal boxes faked up for looks.
LCD is unapologetically 16:9 1080p
649
OK, I spent some time cleaning up my files and getting them ready for others. I also created a couple of variants. For example, the one I printed has the Lisa and Apple logos, which I will include in the zip file here, but I didn't include in my Thingiverse upload. Not sure if it would get pulled down for having the apple logo. The Lisa logo seems less likely to cause problems, so I have it included on Thingiverse. But if you want the version with the apple and Lisa logos already applies, they are in the zip file below. I also have a non-spliced version for people with 350mm x 350mm printers...
Here's the printing advice I put in Thingiverse: Print with the outer surfaces down, although for the debossed areas as well as the recessed area on the top_small part, I recommend supports for the areas not in contact with the print bed. If you do have a multi-color printer, I had very good results with using PETG as the support material and PLA for the print. Otherwise support removal will be annoying and may cause the overlapping tabs to not allow the split pieces to come together completely.
Also, worth noting if you are considering printing this: it seems like I'm not the only one looking to have a case. So if you can be patient, you might have options soon. I'm not going to say who or where, as I don't want to ruin any surprises, but there may be others, and probably by someone who is a much better 3d designer than me. Of course, if you don't mind using a couple hundred grams of filament, you can print this one now, and the other design later, should it happen.
  • LisaFPGA_Case_FinalFiles_v7.zip
Reactions: phunguss
649
OK, decided to graduate from TinkerCad into OpenSCAD for trying to model the Lisa Mini case with display. All of this is still based on the assumption that we can get a 9.7" 4:3 screen to work. I just don't see the reason for using a 16:9 1080p LCD for this project when it will just have black letterboxing on the sides. I'm going to at some point dig into the software side of the LisaFPGA and see if I can enable it and create a custom build.
But, I'll say the ability to get a 3d printable version on a 350mm print bed is possible if I just ignore the floppy drive, which would be an empty slot anyway. Maybe it could have housed an SD card extension, but I am leaning towards just excluding it altogether. The size limitations just mean this is likely not feasible. If I do add a floppy back, I'd likely make the device thicker and have it side loading like the Mac Portable, but vertical. I still think this would present problems with where I could cram in the lisaFPGA board and the floppy drive itself. Might need to make a cardboard mock up to get a sense for how things might fit.
I am still tweaking things to try to match some of my design mock ups. One question, how do people feel about the separate legs. Should I add a skirt between the legs and make it solid? That would more closely match the original, and it would help hide the cables (power, usb / keyboard and mouse) that will stick out from the bottom of the lisaFPGA. Might need to add an optional notch under so the original Lisa coiled keyboard cable will reach to the front
Opinions on whether the gap between the legs should be open? Leaving it open would certainly reduce print time and filament used. I could also add cable management routing to the back of the leg to keep the cables out of view.
Reactions: Trash80toG4
462
OOPSIE! I thought it was outputting some custom resolution that fit 1080p, something on the order of 640x400 on the 'Books which is closer to 16:9.
What resolution does it output?
As far as the FDD goes, it looks like you might be able to install it behind a flip-down cover panel kinda like the TAM optical setup. Disks would insert vertically into the swing down Laptop Drive? Same bay could be access for SD thingamajig in place of FDD?
Nice work. How do TinkerCad and OpenSCAD compare? I need to get back into CAD for this kinda stuff.
edit: looked a bit, there seem to be a few 10.4" 1024x768 display setups in the $120-130 range on eBay:
If printing it in sections, that'd make the flop-out-floppy side and display bezel within your print cubic?
Still stuck on my BareMetal Lisa III protocase though. ;)
