Elemenoh
460
450
Bay Area
Hey @Elemenoh! This is a great cap compilation [especially for the PSU]. One question, which of the Cube PSU's does this list refer to? There were a few of them used. The older of them was used in original 030 Cubes, while older '030's and '040' used another. The PSU's model number [thankfully] is on the tag. It'll either be 151 or 953. Thank you for posting this....and if it's for the 953, you've saved me a bunch of time!
My power supply is model 152.00 but matches the cap list above.
Elemenoh
460
450
Bay Area
I finished recapping the analog board on the MegaPixel display. Though it seemed to be working fine, many of the caps were out of spec or outright bad.
RatedMeasured% DevDFNote
0.47µF 100V447nF-4.9%0.08In spec
1µF 100V778nF-22.2%0.18Out of tolerance
1µF 160V930nF-7.0%0.20Borderline DF
22µF 25V BP20µF-9.1%0.30DF high
22µF 50V15.7µF-28.6%0.20Out
14.7µF-33.2%0.20Out
15.6µF-29.1%0.20Out
16µF-27.3%0.20Out
15µF-31.8%0.20Out
19µF-13.6%0.18In spec
22µF 100V19µF-13.6%0.30DF high
20µF-9.1%0.10In spec
18.5µF-15.9%0.30DF high
17µF-22.7%0.50DF high
16.8µF-23.6%0.90DF severe
47µF 50V40µF-14.9%0.27DF high
100µF 35V266µF+166%0.70Failed
100µF 50V85µF-15.0%0.80DF severe
100µF 100V93µF-7.0%0.20In spec
330µF 35V2.4pF~-100%1.60Dead/open
265µF-19.7%0.70DF severe
255µF-22.7%1.00DF severe
286µF-13.3%0.50DF high
1000µF 35V891µF-10.9%0.60DF high
880µF-12.0%0.60DF high
513µF-48.7%0.35Failed
1200µF 35V1078µF-10.2%0.50DF high
Elemenoh
460
450
Bay Area
While I was at it I measured the caps pulled from all of the other boards. So many!
Power Supply
0.47µF 100V506nF+7.7%0.02In spec
10µF 63V9.4µF-6.0%0.04In spec
9.6µF-4.0%0.04In spec
10µF 250V10.9µF+9.0%0.02In spec
10.8µF+8.0%0.02In spec
47µF 25V44µF-6.4%0.09In spec
100µF 25V97µF-3.0%0.08In spec
95µF-5.0%0.08In spec
220µF 25V203µF-7.7%0.09In spec
1500µF 16V1273µF-15.1%0.10In spec, watch
2200µF 16V2100µF-4.5%0.13In spec
1769µF-19.6%0.60DF severe, borderline cap
3900µF 16V3500µF-10.3%0.20DF high
8200µF 16V8100µF-1.2%0.16DF high
10000µF 6.3V9600µF-4.0%0.20DF high
15000µF 6.3V15000µF0.0%0.30DF severe
14000µF-6.7%0.30DF severe
Magneto Optical Drive
RatedMeasuredDFNote
1µF 50V86pF0.5Failed/open
608pF0.8Failed/open
118pF1.7Failed/open
680pF2.3Failed/open
1µF 100V866nF0.08-13.4%, in spec
977nF0.07-2.3%, in spec
3.3µF 50V74pF0.5Failed/open
67pF0.5Failed/open
10µF 16V165pF0.9Failed/open
96pF2.9Failed/open
91pF0.6Failed/open
78pF1.5Failed/open
1982pF1.7Failed/open
75pF0.7Failed/open
77pF0.8Failed/open
88pF0.8Failed/open
10µF 50V206pF0.2Failed/open
2.4nF1.2Failed/open
355pF0.7Failed/open
1240pF3.4Failed/open
324pF0.5Failed/open
22µF 10V147pF6.3Failed/open
1728pF5.8Failed/open
22µF 16V80pF0.1Failed/open
180pF0.5Failed/open
47µF 16V479pF0.7Failed/open
779pF1.9Failed/open
430pF0.4Failed/open
620pF1.8Failed/open
410pF0.7Failed/open
1350pF2.7Failed/open
3nF1.9Failed/open
MegaPixel Sound Board
47µF 16V45µF-4.3%0.4DF high
45µF-4.3%0.4DF high
44µF-6.4%0.4DF high
44µF-6.4%0.4DF high
44µF-6.4%0.4DF high
44µF-6.4%0.4DF high
43µF-8.5%0.4DF high
43µF-8.5%0.4DF high
42µF-10.6%0.4DF high
1500µF 16V1333µF-11.1%0.43DF high
Reactions: Paolo B
Elemenoh
460
450
Bay Area
Almost 100 capacitors later and this machine is working again. I need to adjust the CRT a bit, but otherwise she's working well!
jktw
6
@Elemenoh Do you happen to have a mouser or DigiKey part list handy for any of the caps? I started looking them up, but some of these have a lot of options. My only other recap job was from a kit, so it would be helpful to cross-check my list.
jktw
6
@jktw which board(s) do you need to recap?
I haven't actually tried to power this up yet (still need to buy a BR-2/3 battery), but I'm planning to do both boards in the N4000, the main board and the power supply. The analog board in mine ends in -13, and there are a few differences to the -12 you posted above, but most of them are the same.
