MB.68k
Belgium
Disassembled a newly acquired QuickTake 150 and mentally prepared to desolder the dead power supply (12 normal pins and 2 humongous grounding pins).
rplacd
Small steps. I'm exposing an emulated OPENSTEP 4.2's telnetd to my host macOS. I've learned:
1. It turns out you have to aggressively set TERM=xterm so that macOS telnet can report something OPENSTEP 4.2 understands:
TERM=xterm telnet [IP] [PORT]
2. Once you figure that out, a good AI agent will know what you mean when you say "Run commands on my OPENSTEP 4.2 virtual machine, which I have made accessible via telnet; you login as user: password with TERM=xterm telnet [IP] [PORT]. If you really need to, you can use su with the password [password here], and FTP in on port [port here]".
3. ChatGPT 5.6 makes an enthusiastic but very novice NeXTSTEP sysadmin...
It did teach me, though, that you can get a serial console on an OPENSTEP/x86 host! If you have an emulated serial port, and a corresponding serial device setup in Configure.app, you can also configure a "TTY Port Server" device on Configure.app. Edit /etc/ttys to configure ttya, and bob's your uncle.
699
Today I took a different route to getting cores installed in Retroarch. Instead of a blanket permissions override via terminal, I redirected RA to install cores within my home folder. MX25 locks down the apps default folder directory /usr/lib/libreto/ so while RA will DL the core, it cant install to that folder and will fail. What I ultimately did that was successful, was to go to settings > core > directory > cores and redirect RA to download cores to this folder that is within /home .
This worked perfectly. The weird thing about this is that I had to repeatedly hit "parent directory" to descend back to /home. This was not intuitive at all at least to my monkey brain, so it took me a minute to understand what I was doing/where I was going. Anyways, this worked for me and kept me out of terminal potentially srcewing up user permissions lol so wanted to document this.
This is on a 2008 unibody macbook running MX25 & retroarch v1.20.0.
Reactions: Froggy814
vossole
Dropped the de-capped mainboard of my M5126 into the big ultrasonic cleaner, rinsed it and am now waiting for it to bake dry in the oven. Just in time too, the caps were drooling all over the place.
MB.68k
Belgium
Removing the PS was not easy, but could be done, and many leaking caps were found inside. However, a complete recapping did not bring it back to life. Still suspecting voltage controller MB3776A (small IC on the right), but it could also be some external input that prevents it from working properly. What could V10K stand for, leading from the control panel to the PS? Sorely missing QuickTake schematics.
699
Yesterday I “fixed” the BT on my 08 MacBook. This is a Mac I use Pithos to stream music to my BT record player that is connected to some nice KRK g1 studio monitors and that my middle son uses as a retro console station when he’s trying to beat Super Mario World. Anyways, post MX update and reboot, it decided to not work as in MX25 no longer even saw it as a device in Terminal using Bluetoothctl. MX was telling me “what Bluetooth radio?”. Haha ok fine. Being a busy Sunday, I pushed it off until I had some time this week to futz or worst case scenario, replace the radio/antenna assembly in the screen with one from a donor machine I have. I wake up this morning and my middle son is asking to play SMB so I go up and notice the machine was off … not sure why as I leave this one up 24/7 for music streaming duty. Anyways I figured the boys did something as three under 10y/o’s will collectively do things yet have zero recollection or explanation of how they were done (ie: I don’t know daaaad?) 🙄 haha so not worth my energy to investigate between firing up breakfast & lunches etc. and getting them on the school bus and off to daycare.
Aaanyways, reboot the MacBook and voila, it mysteriously worked again. This would have been after reboot # 3 I think? I really don’t understand why but whatevs I’ll take the “win”. One less thing to have to do/fix in the ocean of things to clean, do and fix around here lol.
One other update was to enable and map rewind and fast forward to their PS clone controllers on this 08mb and their 09 iMac in their bedroom. That was rather painless in retroarch actually. I had to look up how to it as I myself do t play that way but they could use the help especially on harder platformers, reducing their stress and making learning easier for them.
oh yeah I did also break open the red PS controller and gave it a good clean as the kids spilled something sticky on the start/select buttons. Took the time to clean and lube everything so that one’s working like a champ now.
699
Today I was able to get Jan.AI working on my kids 2009 24" imac. Jan.AI is an open-source, privacy-focused desktop application that lets you run large language models completely offline on your own computer which is pretty cool I think. There were some issues however - primarily with the super old Nvidia GT120 gpu which lacks moden cuda and the lack (lol) of vram but also stops at OpenGL 3.3 and Shader Model 4.0 and no vulcan or metal support, it would crash the imac so I had to disable the gpu outright forcing Jan to utilize the Intel(R) Core(TM)2 Duo CPU E8435 @ 3.06GHz for all functions. I did this with:
flatpak run --env=LIBGL_ALWAYS_SOFTWARE=1 --env=GALLIUM_DRIVER=llvmpipe ai.jan.Jan --disable-gpu --disable-gpu-sandbox
This yielded a functional UI. I verified that Jan could not see the gpu by navigating to settings>advanced>Hardware>GPU>No devices found. Yay, it worked. This was great except when I exit the app and click on its icon to restart, it reverts to a non useable white box. To update and force the app to use these new cpu centric instructions, I entered:
flatpak override --user --env=LIBGL_ALWAYS_SOFTWARE=1 --env=GALLIUM_DRIVER=llvmpipe ai.jan.Jan
This worked perfectly and now Jan.AI opens happily awaiting further instruction.
Reactions: Volvo242GT
PentaxEnthusiast
SATX
My son has been using the G3 (from which I'm posting right now) to mess around with Kid Pix; it's so awesome to see him doodling with something I remember doodling on as a kid in the mid-90s, granted I was doing it on a DOS machine back then.
489
Cool, you were doing exactly the same thing my son was doing in that time frame and your son is doing the same forty years later.
Not today exactly, but it was about 1:00AM today until I finished up with the speaker extension. I got the SE/RadiusFPD/MagicBus put together and tested it to the curious Floppy, no BOMB! It's in the old SE/30 NuBus project and PDS card testing setup from years back.
Just have to figure out how to image an SD card for boot and card function testing.
MB.68k
Belgium
Found a Microtech XpressSCSI USB to DB25 adapter online, listed in France for very little money. Intact ones are listed sometimes for some fantasy prices, but this one was advertised as destroyed. The case was indeed quite damaged, with multiple plastic pieces that had to be epoxied back into place. But the main problem could be seen even in the listing photo:
After some prodding, it was clear that USB voltage does not propagate far. The empty space marked in the photo should have a ferrite bead, but it looked like an unpopulated pad. I imagine the ferrite was soldered badly, and came off without leaving a mark. Putting a new one in brought back the LED, and the adapter is now detected on the SCSI bus. To do more testing, I have to dig up some SCSI devices from the attic. I'm not brave enough to connect a BlueSCSI to it.
For working with such tiny components, I found one tip essential, that was mentioned somewhere here in a recapping guide: To tin only one of the pads first, so that one end can be pressed against a flat untinned pad when soldering the other side. Then work on the second pad, and if needed, return to the first one. Otherwise these things slide sideways or twist when trying to hold them over two tinned pads.
