MARCHintosh 2026 Projects
363
View attachment 27206View attachment 27207
only had to slice the PSU side off for this build, but then random bits of metal and a ton of JB weld to fill in all the gaps. printed a cover for the IO shield area as thats where i put the sff power supply. The case is actually a 15x15x7 junction box that had to be cut with a grinder :)
In this shot it looks like you had the same kind of offset slot problem I have, in the other not so much?
Difficult to show the 3.8mm offset required to fit the 9500/PEx boards. But easy enough to see that the rightmost slot edge will be a perfect overlay for the resultant gap.
After the grlf flies home Sunday I can get down to the grinder/cutoff nitty gritty.
Crosshatched sections show the absolute minimum I could do in case mod, but will be doing a bit more to fair the new black slot section in across the back. DB-25 Port A will work for the SCSI connector if I file the ear out a little, even less as shown for the speaker/microphone ports above ALARMS. The indented slots for the backplane cover plate extensions had to be done, so opening things up a bit more than the crosshatched indications will be done.
These two shots detail the further cutback I need to do for to the tan plastic Netra board supports for fitting the PEx mobo. Will work nicely supporting the Board's Memory/ROM slots.
geerlingguy
17
St. Louis, MO
www.jeffgeerling.com
My MARCHintosh has been busy, some year I'll join in GlobalTalk, but for now I'm using it as an excuse to work through the backlog of old Macs I have sitting on shelves un-inventoried...
So far:
  1. I finally put together my Pico Micro Mac — the V2 version that required some extra soldering work. Fun, definitely enjoyable, especially as a Raspberry Pi Pico connoisseur!
  2. My Dad and I were lucky to get a Docklite from Juicy Crumb, and so we installed it in his old iMac 2010 21". Excited to hear they're also working on a way to get the Combo drive working—he will actually find a lotta use for it, as unlike me, he's okay with 1080p displays still :D
  3. I just finished recapping an Xserve G5 PSU (huge thanks to House of Moth for assistance!), and now I'm trying to figure out the best way to do lights out management of the G5 — I know the Xeons had ipmitool support, but it doesn't look like the G5 has a BMC? Shucks.
In the coming weeks, I hope to finish up a video I've been working on a while, on my favorite Mac laptop of all time (and some runners-up), with a few special guest appearances. Then if I can finish it, a video on how I made my first YouTube video — using a similar FireWire + G4 setup I used back then... and then showing a neat new tool that might get some of us to pull our old DV cameras out of the closet! (Hint: it's called the Firehat!)
I've been enjoying all the other projects I see on here, the live streams, etc. — and with this leading up to Apple's 50th, it's been a great month of nostalgia for the computers that I grew up using!
theirongiant
Someone on the Wireshark Discord pointed me to this GitHub repo with a very complete Lua plugin for decoding AURP traffic — legacy AppleTalk.
It's been rather interesting to sniff "vmenet0" of my virtual Quadra 800 acting as an Apple Internet Router. Especially with 100+ nodes in the GlobalTalk network. I can only see the traffic going in and out of my node, and since most of us are directly connected to other AIR nodes, it's pretty much limited to traffic I'm generating like browsing file shares, sending or receiving routing updates, pinging other networks and devices, etc. Nevertheless, AppleTalk is a very descriptive protocol.
Null
GA
This is my first ever Marchintosh. I only started using apple products last year. Before that I was a windows user since 3.11.
So to keep it simple for my first I got a PowerBook G4 1.67. I upgraded the ram to max, placed a mSata drive in it. I’m really struggling to get macOS installed on it by the only way I have which is usb. I don’t own any other older Mac or any FireWire things. So I’m currently waiting for a retail copy of leopard in the mail.
My end goal is to see how far I can push it to run modernish browser, do basic email/word processor stuff. Once I get all that I’m turning my attention to turn it into a retro gaming machine for anything 90s RPG related.
Reactions: MacOfAllTrades
