NJRoadfan
105
36
I'm delighted this work is being done and I appreciate you doing it, though I'm a little torn about this. While it's entirely possible Apple was working with a modified NT4 for the ANS, it is more likely they ran real NT4 with extra files provided separately.
The MaciNTosh project does it the way it likely would have shipped, using a separate media to load VENEER and kickstart NT and then provide the HAL and required drivers (which that project does via a RAM disk available to the installer). That project uses a CD for this mostly because the initial supported machines didn't have a floppy. A period NT 4.0 install for Shiner (or any PPC Mac) would use the stock NT 4.0 PPC CD with a boot floppy and a driver floppy just like a stock x86 install would have.
Mr. Macintosh
35
@PappaDF Thank you for the latest info! I'm going to get started with the project here again soon with all the new work and share the tool data on real hardware.
I also agree that we should probably try to stay with an unmodified cd and continue with a modified HAL and VENEER.exe
Mr. Macintosh
35
Ok, I doubled back to start testing again but using the default 4.0 cd. Then start putting all the pieces needed on a floppy trying to emulate a real setup.
@PappaDF Just to confirm, what cd version are you using? I might have picked windows NT 4.0 server when you were using workstation? But I wanted to confirm.
this is where I'm at right now with that setup.
*** STOP: 0x0000007B (0xE6E84A70,0xC0000034,0x00000000,0x00000000)
INACCESSIBLE_BOOT_DEVICE
Machine State at Call to Bug Check IAR:801A8EA0 MSR:0001B031
R0: 0 R1:E6E84920 R2:80085340 R3:8073D0E0 R4:E6E84A70 R5:C0000034
R6: 0 R7: 0 R8: 13031 R9:8073D000 R10: 1 R11:800F2E00
R12:E6E847E0 R13: 0 R14: 4FA20 R15:AA9A0472 R16: 0 R17:807F0000
R18:80080660 R19:800E741C R20: 0 R21:AA9A045A R22:AA9A0456 R23:AA9A0452
R24:AA9A05AE R25:AA9A05AA R26:801A63F0 R27:E6E84B10 R28:801A7870 R29: 0
R30:E6E84A70 R31:E6E84A68 CR:39000539 CTR: 0 XER:C000BE6F
Callee-Sp Return-Ra Dll Base - Name
E6E84920 801A8EA0 : 8007D000 - ntoskrnl.exe
E6E84920 801A8EA4 : 8007D000 - ntoskrnl.exe
IRQL : 2, DPC Active : FALSE, SYSVER 0xf0000565
Processor Id: 9.514, Icache: 32768, Dcache: 32768
Restart and set the recovery options in the system control panel
or the /CRASHDEBUG system start option. If this message reappears,
contact your system administrator or technical support group.
Mr. Macintosh
35
Yes, I picked:
OEM 000-48303 (October 1996) Workstation release.
md5sum nt-4.0-ppc.iso
# ab37556d72818ed082c1d01c2d7f1898
see https://github.com/pappadf/powermac-nt-hal/wiki/Emulator-Media-you-must-supply
Thanks PappaDF, I'm using the same CD
We have progressed to video now. I'm now making all edits to the floppy and the CD is now default ISO.
Code:
HAL: IoReadPartitionTable: no MBR signature (00000000 00000000)
HAL: IoReadPartitionTable: 0 partitions, signature 00000000
HAL: SRBTRACE7 BULK adapter ee518de8 path 00000000 target 000000ff lun 000000ff status 0000000e
HAL: IoAssignDriveLetters: boot device '\Device\CdRom0' -> E:, 0 floppy 2 disk 1 cdrom
HAL: system path in 'C:\PPC' (len 6 max 130)
HAL: system path -> 'E:\PPC'
Setup has encountered a fatal error while initializing your computer's video.
Contact your product support representative for assistance.  The following
status codes will assist them in diagnosing the problem:
(0, 0xc0000034)
Setup cannot continue. Power down or reboot your computer now.
Reactions: PappaDF
PappaDF
31
Sounds excellent! This is on real hardware, right?
I've reworked my experimental branch to use the floppy + unmodified CD approach as well (I've pushed all updates to that branch). It almost works fully in the emulator.
Reactions: ClassicHasClass
Mr. Macintosh
35
Making progress!!!
Your notes have really helped make these new breakthroughs @PappaDF !!!
Past Video issues
Past Keyboard Issues
Past initial OS boot issues.
Now I'm here
Code:
Windows NT could not start because the following file is missing or corrupt:
\WINNT\SYSTEM32\CONFIG\SYSTEMHardware Profile/Last Known Good menu
VrOpen: Exit - FileId: 2 IHandle: ff8d3d80
You can attempt to repair this file by starting Windows NT
Setup using the original Setup floppy disk or CD-ROM.
Select 'r' at the first screen to start repair.
Program complete - please reboot. ff8d3c00
EXIT called ok0
Reactions: PappaDF
PappaDF
31
Making progress!!!
Past Video issues
Now I'm here
Code:
EXIT called ok0
Terrific!
This is on real hardware right? Very impressive! Getting it running on hardware is always a much bigger challenge than in an emulator.
I as mentioned, I have transformed my emulator experiments (https://github.com/pappadf/powermac-nt-hal/tree/pappadf-experiments) to work with a floppy+cd combo as well, and it's now on par with the previous cd-patch-variant, i.e. it more or less works end-to-end:
See example here: https://youtu.be/E61rIaY2BjY (it's a very lengthy recording with a lot of time spent at OF prompts)
NJRoadfan
105
36
The error is trying to load the main SYSTEM hive of the registry. Are the other parts of the kernel loading?
ClassicHasClass
573
www.floodgap.com
OK, here is my first draft of the Mac OS Extensions pack. I am now pretty certain I can't boot the internal SCSI with the onboard ndrv alone, but I think the video, Ethernet and startup fixer components are solid. You'll need a 1.1.20.1 ROM for this.
I'm currently thinking of a way to use a PCI SCSI card as a secondary controller, set to a different ID, and boot from that. After all, if the RAID card can do it ...
stynx
Germany
Yeah, seems like my dreams of being able to just boot Mac OS is a bit of a fetch haha!
Linked is my archive page for it, one drive doesn't work, I think, still tryna work on it, the other was read by my PC, and I was able to turn it into an ISO, but honestly have no idea really how to view the data...hopefully one of y'all smart cats can figure it out n lmk if there's anything cool!
It came from Texas, presumably where it lived it's entire life, I purchased it off eBay a while ago, and now I feel as though I have highjacked the post haha.
I looked into the HDD-dump a bit (the iso file) and there is a lot of stuff in there that was not deleted when the partition was reformatted.
Many Photoshop images (8BIM header), Apple internal HTML-files (golden-web?) and such.
Also Lotus Domino references, Mac OS 8.6, Games and random fragments like this:
> > without that, now would it
> > So, fire away..I really am
> interested (for Hawk's sake),
> > what the story is
> regarding surfer's and the
> LLB??
> > Doc
> > ...that there is a LOT
> more to this story then
> everyone is
> > telling here. Do I have a
> problem with the copying of an
> > archive for your base work
> ? NO. Do I have a problem with
> > someone collecting 3-4 s/
> n's, waiting while someone
> else
> > does all the major
> compiling, then copying THAT
> every month?
> > YES. Saying I hate
> EVERYTHING Doc is involved in
> is untrue.
> > The Pope's site was up and
> in such great order mainly
> > BECAUSE of Doc. I not only
> recomended that site to MANY
> > people, but said what a
> great job that Doc had done in
> > helping The Pope. I
> remember what that site was
> like before
> > Doc got ahold of it. I
> don't hate the good things
> Doc is
> > involved it, I only hate
> what he does to spite others.
> > He HATES me, he HATES
> surfer, he HATES a number of
> people
> > here and if you don't
> believe that, just ask. If
> you've been
> > "observing" for very long,
> I wouldn't have to be telling
> you
> > these things. I'll not go
> into details for two reasons.
> One,
> > he enjoys using alias so
> he can make others out to
> look like
> > liars, and two, because
> I've told the stories many
> times and
> > a wonderful "observer"
> like yourself should already
> know.
> > You want to know what
> started this WHOLE thing? Doc
> couldn't
> > take the opinions of
> someone else. He started
> preaching on
> > this board about "god" and
> "fearing" and a bunch of other
> > CRAP while he proceeded to
> flame a person that will go
> > unnamed cause this isn't
> between me, him and Doc. Why
> did he
> > flame this person? Because
> this person decid
A lot of stuff will be damaged since the files were likely partly overwritten.
But there may be much more interesting files in the disk-image.
-Jonas
  • extract_test.html.txt
  • extract_test2.html.txt
