2,227
Here's a screenshot from that Github page...
So just to clarify...
Even though it says "BlueSCSI-Pico2-58226df.uf2" firmware can be tested "on any version of BlueSCSI hardware," the performance improvements for Write Speed only occur when you have a Pico 2 board installed, correct?
In other words, most people with a BlueSCSI v2 will have either a Pico or PicoW. But to get the new Write speed improvements, you would need to remove the Pico or PicoW and solder in a Pico 2, correct?
If so, based on what I am reading here, there won't be a Pico2W until the end of 2024.
2,309
Any version of BlueSCSI hardware (with a Pico2 (which I thought was implied as it's a firmware for the Pico 2 ;) ))
Don't do that, everyone who I see try to remove a Pico destroys the board. Get a kit or build some of your own boards, put a socket on it.
2,227
I know, but you know me. I love it when things are plainly stated on a grammar school level. That's really what my entire YouTube channel is about. Saying things in a more detailed yet plain way so even a true nincompoop like me can understand it! :)
Being the cheapest man alive, I did manage to remove my Pico boards and replace them with Pico W boards on the two BlueSCSI v2 hardware units that I have. They appear to be working fine. But I will admit that it took a lot of time and great care with Hakko FR-301 desoldering gun to achieve it. So advising others to just buy a new kit is probably best. I agree that you avoid both trouble and hassle that way.
Androda
Emeritus Board Member
542
608
USA, Western
androda.work
If you do plan to replace the Pico with a Pico 2, my two cents is that you should not be desoldering from the bottom of the BlueSCSI PCB.
If your board has pin headers holding the Pico in place, then desolder the Pico from the top only. As Eric mentions, it's very easy to damage the BlueSCSI PCB when desoldering. The Pico's pad holes seem to be more robust and hold up better against a desoldering tool.
2,309
Another big new release this month - https://github.com/BlueSCSI/BlueSCSI-v2/releases/tag/v2024.10.26
What's Changed​
Another huge release for BlueSCSI v2! New profiles include NeXT and X68000-SCSI, and X68000-SASI. You can now cycle through folders of any type of removable SCSI device. Merged in the well tested Amiga drivers from beta.
Better info in logs and continued refinements to speed and resiliency of SD card access.
Oh and if you didn't see we have a stable Pico2 build if you'd like to try that out!
Plus, a whole lot more!
New​
Fixes​
Build and Docs​
Full Changelog: v2024.09.15...v2024.10.26
Need Help?​
Find us on Discord, TinkerDifferent, or Github Issues/Discussions.
2,309
This update is recommended for all users and should be the end of any odd SDIO timeouts or errors that were experienced by a small number of users. With the SDIO rewrite by @androda last release and the framework updates this release we have not seen any reports of issues.
Note even though we now support 4(+) Pico boards (Pico1/1w/2/2w/etc) - there is only 1 .uf2 file to flash - no need to wade through 18+ files to figure out the right one to flash, there's only one choice and it'll do the right thing(tm).
This update is recommended for all users and should be the end of any odd SDIO timeouts or errors. With the SDIO rewrite by @androda last release and the framework updates this release we have not seen any reports of issues.
How to flash​
A new BlueSCSI_Universal_<rel>.uf2 can be used on any Pico 1/1w, 2/2w. Updating Firmware for more details.
What's Changed​
  • Pico SDK 2 updates & SDIO timeout fixes by @erichelgeson in #209
  • Pico 2 & Pico 2-W Support with universal UF2 by @erichelgeson in #218
  • Reset watchdog while data transfer is progressing
    • Previously a long and slow SCSI transfer could exceed the 15 second timeout, resulting in early termination. @PetteriAimonen 5396143
Development​
  • GPIO Drive Strength Config for SDIO Pins by @androda in #206
    • This should only be changed if debugging an SDIO issue.
Full Changelog: v2024.10.26...v2024.12.08
2,227
@eric
In layman's terms, when would the cited "small number of users" of BlueSCSIv2 user experience the aforementioned "SDIO timeouts"? When using WIFI only? When performing specific tasks?
2,309
@eric
You would see SDIO timeouts while using the BlueSCSI in the log file. Users would see extremely slow speed due to the timeouts. I think we had a total of 12 users report this (so very small) and took us a while to even narrow down as none of our (same model) computers would exhibit this behavior. Not a huge common factor but 8x00's and some Sun workstations were the main ones. Nothing to do with a specific task or wifi.
On the up side since @Androda completely re-wrote the SDIO communications layer it is a huge improvement over the previous one in terms of reliability.
Androda
542
608
USA, Western
androda.work
With help from Greiman of course. He provided a generic RP2040 SDIO implementation which made a lot more sense than what was already in use. My main contribution was cutting down the number of PIO instructions it required and hooking it into the existing framework.
Nycturne
105
There was some discussion in the BlueSCSI Web thread about SD card fragmentation, and I wanted to add to it without polluting the thread, so I am moving it here if that's okay.
I currently use an M4 Mac to setup my BlueSCSI cards, and while I have had a few stumbling blocks on the way, I have managed to reliably create SD cards that have no fragmentation of the disk images. Unfortunately, with modern filesystem tools basically accepting file fragmentation as a way of life, I haven't been able to do much inspection of the SD cards themselves to really dig in, but here's what I've run across.
  • There's the usual .DS_Store and Spotlight index updates during a copy that can be a problem.
  • Apple's increasingly aggressive Gatekeeper setup is adding extended attributes to files that previously did not include them, including those created by Disk Jockey. Copying a file with extended attributes will cause it to be fragmented as the extended attributes are written to a separate file in parallel.
  • Formatting with Disk Utility triggers macOS to create the .Spotlight-V100 folder before you can even disable indexing on the drive. Disabling Spotlight will not remove the multitude of files that wind up in this folder, and these files seem to do a good job of fragmenting the free space on the drive. The result is the first image for me usually winds up fragmented despite dealing with the above.
There is a flow that I use which is reliable and doesn't require using Windows/Linux to create the card:
  • Add the images I want into a single folder.
  • Open a terminal window and navigate to the folder.
  • First, create a "filler" file to fill in the fragmented free space: dd if=/dev/zero of=00Filler bs=1M count=128
  • Second, strip extended attributes: xattr -c *
  • Third, ensure Spotlight is disabled on the SD card if I just formatted it, and then delete any files on the card.
  • Finally, run rsync to mirror the folder to the SD Card: rsync --progress -av * /Volumes/<SDCARDNAME>
This folder also acts as my backup, so I'll rsync the other way from time to time. The filler file probably doesn't even need to be this big, but I haven't gone through and fine tuned what size works. I usually have more space than I need.
EDIT: rsync will strip out extended attributes, so should not need to use 'xattr -c' with it.
Reactions: PL212 and JDW
2,309
Thanks for some details on what you do - I have an M3 Max MacBook Pro and what I do is updated in the wiki - https://github.com/BlueSCSI/BlueSCSI-v2/wiki/Image-File-Fragmentation#mac-os
You can simply `cp -X file.hda /Volumes/sdcard` which will avoid copying any extended attributes
Note that not all extended attributes are cleared via xattr -c - you have to do com.apple.provenance separately
ALSO note you MUST use Terminal.app (not a 3rd party terminal like iTerm (which i use)) as it can not remove com.apple.provenance!
I honestly don't know why Apple makes this so hard. If file is being copied to a FS that doesn't support xattr's - ignore em! (eg cp -X)
Reactions: JDW and Nycturne
Nycturne
105
Funny enough, rsync strips extended attributes (including quarantine) without any additional parameters in Terminal.app, which I just confirmed. This is what happens when I don't have a lot of time to truly grok what's going on. :)
Apple does things for the sake of macOS behavior, and compatibility with other systems is secondary. Sadly, the lack of the quarantine attribute has special meaning, which is one reason Apple works to preserve these attributes and is getting more aggressive about setting them (provenance is related, which is why it's hard to remove). And the case of it creating fragmented files is mostly only an issue for specific use cases like these which aren't exactly common. It sucks, but I see little chance of change. Especially when the things that bite us the most are part of macOS' defenses against bad actors.
I would have been tempted to go with an SD card layout that enables the BlueSCSI to effectively have a contiguous block of addresses to put HDD images outside of the FAT partition and use the FAT partition for config/CDs/shared. But that means specialized tools to get those drive images on/off the card.
736
@eric I was looking to order a batch of these from JLCPCB and I think I have it pretty well set up, but the LED and the JST connector at J6 are both out of stock. I found a replacement LED, but I could not find a replacement for the 6 connector. The question I have is what is it used for? I haven't seen anything in the documentation about its use and I'm wondering if I could get these ordered without it on the board. Worst case I could always add it later if needed (although it may be tight with a few of the components around it. Any advice would be greatly appreciated!
736
Ah, so it a used to interface between the control Pico and the BlueSCSI. I may wait until they can have the part, then, as I think I’ll be trying to use that setup (I prefer opening my machines as little as possible due to the plastics).
There should be a bunch of common LED's (i'd hope) in the common parts at JLC - some discussion here https://github.com/BlueSCSI/BlueSCSI-v2/discussions/113
Also remember to order them in Blue :D (it really doesn't add 2 days as the UI says)
Yeah, I could find a replacement for the LED (although only in green), but I found you can pre-order parts, so I now have many more JST connectors and LEDs than I will use ordered. Hopefully in 10 days I'll have a complete BOM and can order my assembled PCBs. I didn't realize you could also order from other people's idle parts inventory. Unfortunately, no one had any idle inventory for the JST connectors.
AlexMac
110
61
Bavaria
To get rid of any .DS_Store on my SD Card I always use this.
# Navigate to the relevant Volume (replace the volume name)
cd /Volumes/SD
# Find any .DS_Store files (optional) within the folder
find ./ -name .DS_Store -print
# Delete any .DS_Store files within the folder
find ./ -name .DS_Store -delete
Reactions: eric
Dave928
Seattle, USA
Sorry, it’s a long, detailed post. TLDR: I think I may have borked my BlueSCSI?
The Macs:
1) Mac Classic, 4MB RAM, running OS 7.1.
2) PowerMac G4/400 AGP, with a Sonnet Encore 1.2 GHz CPU upgrade, PCI Grappler SCSI card, 64 GB RAM, running OS 9.2.
3) 2020 iMac, for all the SD card formatting, file creation/moving...
My 2 month old external BlueSCSI v2 was working fine on my Classic (the only one available, my other “classic” Macs are down for recaps), and the .hda and .iso files always mounted fine. Until I tried it on the G4. The G4 didn’t see it at all. After putting it back on my Classic, it gave a “Damaged disk” error with “[Ignore] or [Initialize]”. If I clicked [initialize] it would format the 20MB .hda file and mount the drive on the desktop. The flash card itself still had the .hda and log.txt files on it.
I ran the SD Memory Card Formatter tool with the “Overwrite format” option selected, installed a fresh 20MB .hda file and the same error came up. From here, ever time I say “a new 20MB .hda file”, I mean a newly minted file made with Disk Jockey. Every time.
Now, I may have been having an issue with the G4’s SCSI card, as it turns out it also wasn’t seen by the Mac in System Profiler, even though the BlueSCSI’s power light was on (on this SCSI card the DB25 port is upside-down, so I couldn’t see what the status lights were doing). I read on a post somewhere that SCSI cards need to be in Slot B on the G4 (better power?), so I moved it to Slot B and then the G4 saw it and it worked great with my Iomega Jaz drive backing up some old Jaz disks I have.
The G4 has 4 PCI slots, but Slot A is for the AGP graphics card. And the G4 only has 2 internal ATA drives installed, so there were no SCSI conflicts.
For every test after this I enabled the debug mode with the “bluescsi.ini” file to generate verbose log.txt files.
So next I followed the troubleshooting directions and reflashed the latest firmware. On the Classic, “Damaged disk” again.
I ran the “flash_nuke.uf2” file, reflashed the firmware, installed a new .hda file and got the same fault again, a “Damaged disk” window with “[Ignore] or [Initialize]”. Again, if I clicked [Initialize] it would format the .hda file and mount the drive.
Did that whole process again and put it on the G4 and got a “Disk not initialized” window with “[Ignore] or [Initialize]”. Again, if I clicked [Initialize] it would format the .hda file and mount the drive.
I’ve included links to two log files, one on the G4 and one on the Classic.
PowerMac G4 log:
Mac Classic log:
So what did I mess up? Is a G4 running OS 9 with a SCSI card not a “classic” Mac? Does the BlueSCSI not work on PPC Macs?
Did the at-first non-working SCSI card short something on the pico and I need to buy a new one and never put it on the G4 or newer Macs?
Any input helpful, Thanks.
Dave928
Seattle, USA
figured it out (we think) over on Discord. the not quite correctly installed, and in the wrong slot, SCSI card on the G4 was corrupting the images. premade bootable images from mega.nz now boot on the Classic and mount on the G4. yay.
Reactions: eric
