Mac84
315
459
New Jersey, USA
www.mac84.net
Hello everyone,
Welcome to the new thread!
Here we can continue discussing the Kodak Reels 8mm film digitizer and some cool, unsupported modifications some smart folks have discovered to improve the capture quality of this product.
 Thank you to everyone who has helped in this project since it's creation! 🥳
This project began in 2023 and the original thread sparked nearly 900 replies, 48 pages of discussion, and over 100,000 views! Therefore, it was time to do a bit of a reset. The goal is to consolidate information for newcomers and help better organize updates and how-to information inside, saving folks from sifting through 45 pages to find answers.
The original thread is still available to view, but all new discussions will take place here to avoid conversations getting lost. If you have a Wolverine model film digitizer, please see this helpful article "Firmware hack fo Wolverine 8mm film digitiser" by @Branchus.
An in-depth video review of the Kodak digitizer and an exploration of firmware options:
⛳ Before going further, please read below and consider this your first and only warning about the risks involved in modifying your digitizer device…
ABOUT FIRMWARE UPDATES AND THE RISKS INVOLVED
⚠️ WARNING - THIS IS IMPORTANT, SERIOUSLY!: ⚠️
 These updates, mods, or instructions are in no way authorized or supported by Kodak or anyone. Any actions you take you do at your own risk, these instructions or files are provided as-is, with no warranty!
WARNING - A NEW FIRMWARE EXISTS that has NOT been archived yet!
If your serial number
starts with, or is similar to H2825148BKxxxxx this may be a new "D" revision firmware which is NOT SUPPORTED by the current mods. Do NOT attempt to flash your firmware, we'll need to get a backup of this first before we can continue.
☠️ READ ME FIRST, PLEASE PROCEED WITH CAUTION! ☠️
This thread discusses firmware updates. These are software updates that are flashed (or written) to a chip on a circuit board. These updates involve erasing and replacing the current data on the chip. Therefore, any updates done to your device permanently alter the original data or code, with no easy undo option.
If something goes wrong, theoretically it could brick the device (turn it into a brick) or create weird quality of life problem, like the LCD screen not displaying correctly, or other undesirable results that could hinder use of the product.
As of December 2025, Kodak’s Reels product currently has three identified variants or revisions, based on minor internal hardware changes. These are silent product versions that are not labeled or marked clearly in anyway. We can only use the serial numbers of the device, along with some guesswork, to loosely determine what model is what variant. We’ve nicknamed these revisions models A, B, and C. Based on this knowledge, in 2024 I created a simple Digitizer Lookup & Firmware Lookup web tool to try and determine which model a unit is. However, this simply CANNOT be aware of any new models or different serial number patterns Kodak may be silently releasing, etc. Please do take the lookup tool’s results with a grain of salt.
In 2024 Kodak briefly had firmware updates on their website, but these are no longer posted. Furthermore, these only supported models A and B - not newer C models. Users who updated their C models were forced to send them off to Kodak for an exchange, as these updates messed with the LCD screen or caused other issues. Kodak was not willing or able to provide firmware files so users could self resolve their problems.
While we’ve learned a lot since 2023, this is still a risky process! If you are able, you can backup the original firmware of your unit in one of two ways. This would give you a safety net before proceeding. However, both of these methods are quite involved and require you to open up your unit (very carefully). One method involves micro soldering three tiny wires and having a UART serial to USB adapter, the other method requires having an EPROM programmer with a clip-on adapter or desoldering the memory chip.
WHAT DO THESE MODS DO AND WHY?
Essentially, the original Kodak Reelz/Reels unit offers zero quality controls or video capture settings. During the capture of your 8mm film the device takes hundreds of individual photos and works to build a video file out of them. As part of this process, due to limited processor horsepower and memory, the unit compresses the final video file saved to the SD card. This often results in pixelated, poor looking transfers that can throw out a lot of picture information, like film grain. These videos also have incorrect speed and altered colors or poor white balance. While some have used AI upscaling tools to try and improve quality, as the old adage goes... "garbage in, garbage out".
Worst of all, fellow user @0dan0 discovered that when capturing images and creating a video file, the device is only using a small fraction of the image sensor. Therefore, each capture only uses a fraction of the total image resolution, roughly 640x400 pixels. Then, the device upscales that image to a larger size, like 1728x1296 pixels. This discards tons of picture information and detail! Therefore, previous firmware mods that only increased the video resolution and bitrate were still limited by this internal process. Lastly, the units have an auto white balance feature that cannot be turned off, this can often cause drastic shifts of colors or tones mid-scene.
There are currently TWO flavors of modifications available today, alongside the stock Kodak firmware files. One is fairly simple one, created by me, and the other is more complex and offers advanced features and better picture quality. Please note, that for my firmware (labeled “Mac84”) the picture resolution is not exactly better than the 0dan0 firmware. My mods were done long before the discovery of the image sensor cutoff in the workflow.
KODAK DIGITIZER HARDWARE SPECS
Image sensor used: AR0330 3.15 megapixel sensor (datasheet is attached below)
System on a chip: Novatek 400 MHz processor with 128 MB of RAM (model NT96658MBG-NH)
Flash
memory chip: 4 megabytes (MX25L3236F)
Power supply: DC 12V, 1.5 AMP (Center positive)
Storage: SD card slot (FAT32 format is required for flashing firmware)
USB: Micro USB port for playback power and storage connectivity (downloading)
FIRMWARE OPTIONS
Currently 0dan0’s firmware is the most advanced. However, each option has some quirks. You can download them using the links below or from the Lookup Tool. PLEASE also see the Firmware user guide (also linked below under Documentation & Resources).
Here is a brief summary.
  • Stock Kodak Firmware (available for unit models nicknamed A, B, and C) - Download via the lookup tool
    • Resolution: 1728x1296
    • Video bit rate: 6,400
    • Frame rate: 20 fps
    • Enhancements: None, this is the firmware that comes with all units.
    • Issues to know about: Low image sensor capture resolution, poor white balance, low video bitrate
Mac84 Modded Firmware (for units A, B, and C) - Download via the lookup tool
    • Resolution options: 1728x1296 or 1920x1440*
    • Video bit rate: 12,600
Enhancements: None
Quirks: Digitizer cannot playback some captured recordings on built-in screen due to higher resolution or bitrate options.
    • Important notes: The 1920x1440 resolution is not a true representation of the image quality due to the image sensor cutoff described above.
    • Quirks: Due to the image sensor cutoff, the picture quality isn't as clear as it could be.
  • 0dan0 Firmware (For units A, B, and C) - Download here (version 7.3, December 2nd, 2025) - User Guide
    • Resolution: 1600x1200)
    • Video bit rate: Variable, with a peak of 35 Mb/S
    • Frame rate: Variable, user can select 16, 18 or 24 fps
    • Primary enhancements: RGB histogram, editable white balance, adjustable auto exposure, ISO & exposure statistics, additional color tint controls, advanced frame adjust (allows for additional digital zooming/cropping).
    • Other enhancements: Visual histograms, MP4 metadata fix, disabled 3D noise reduction, auto stop when film reel is done, custom boot / shutdown graphic with firmware information, and many more.
    • Quirks: Detailed images can overload the unit, leading to a crash and requiring a restart. 32GB FAT32 formatted SD cards are strongly preferred to reduce errors. 4GB max file sizes. Digitizer cannot playback captured recordings on the built-in screen.
DOCUMENTATION & RESOURCES (coming soon!)
  • How to open the device
  • How to flash firmware to the device
  • How to install serial headers / adapters
  • Firmware user guide for @0dan0's mods, guide by @ThePhage
  • Hardware photos / camera datasheet / chipset info
  • 3D models:
VIDEO EXAMPLES (...coming soon!)
TBA...
HISTORY, HOW WAS THIS DISCOVERED?
Watch the Mac84 video or read the archived thread for details about how this project started.
ADDITIONAL MODS AND TECHNICAL THINGS
Besides firmware, there are some other physical improvements you can make to your device to let it perform better, or resolve problems.
  1. Takeup reel motor issues
    If the takeup reel motor fails, you can either replace the motor or unplug it. A failed motor can cause the system to not turn on.
  2. Power supplies
    The power supply is a standard barrel jack adapter, DC 12V, 1.5 AMP (Center positive). I've been successfully using a hard drive power supply that is similar, but with a 2 AMP rating and have had no issues.
  3. Plastic reel posts
    Earlier Reels/Reelz products had 3 plastic posts, newer units have 4. Either way, these can scratch the film, some users have wrapped these in soft materials, or have skipped them and just let film collect in a plastic bin.
  • AR0330_Camera_Data_Sheet.pdf
dsenechal57
7
Hi Steven. I watched your excellent video, and just got my tinkerdifferent registration approved. I did download the firmware update for my Firmware B unit. SN: K3124148BK01604. It waited the expected 30 seconds, but I was then greeted with the following display. When I push any of the buttons, it changes in appearance, and the LED in the film gate lights up, but can't do much beyond that. I tried to reinstall the original firmware and got the same display. Have I bricked my scanner? Any suggestions to fix this?
Mac84
315
459
New Jersey, USA
www.mac84.net
Hi, thanks for the kind words. Hm, the revision C firmware. There is a small chance some of the firmware files are mixed up on my end due to them all having the same file name.
Please report back after trying various versions of A or C.
Reactions: eyeidea
dsenechal57
7
Hi Steve. Thanks for the prompt response. I'll give them a try and let you know. As an aside, even though the screen is not working correctly, the scanner still does scan. Following the button-pushing sequence from memory
Hi Steve. Same result using Firmware A. I attempted Firmware C, but it's a zip file, and when I attempt to unzip (via Windows 11 PC), and transfer to an SD card, it says : Error 0x80004005: Unspecified error.
dsenechal57
7
I fiddled around with the zip file and tricked the computer into letting me transfer to the SD card. Installed the firmware on my scanner, and GOT A HEALTHY SCREEN!! Haven't tried scanning anything yet, but I'm quite relieved!! THANK YOU!!
dsenechal57
7
And a further update: The startup screen looks perfect. When the film gate LED lights up, the film image on the screen displays a slight ghost of those horizontal lines, superimposed over the film image. However, the scan itself looks fine, and even better, when I compared this scan with a previous scan of the same film, this one is noticeably better.
Reactions: Mac84
442
623
Here is v7.4.1. Just a bug fix (although important.) If the permanent memory was in the wrong state (7.4.0 wasn't initializing it), the unit could have been locked to the wrong exposure values, with no way to change it. This version will reset the locked exposure settings on firmware update to avoid this illegal state.
For anyone else trying to customize firmware, you may have found NktTool frustratingly slow. It uses two Windows compiled utilities from https://github.com/str2b ntkcalc and bfc4ntk. These where 32-bit compiled, so I recompiled at 64-bit for more speed. I also found a flaw in ntkcalc, that makes that step a thousand times faster. So the whole process now takes only 8-10 seconds.
Unzip NewNtkTools2025.zip into the folder in which you are editing .rbn files. Double click on build_local.bat, and it will make a FWDV280.BIN from the most recent .rbn in the same folder automatically and fast.
  • FWDV280-TypeA-V741-0dan0.zip
  • FWDV280-TypeB-V741-0dan0.zip
  • FWDV280-TypeC-V741-0dan0.zip
  • NewNtkTools2025.zip
sheider
26
@0dan0 Thanks again for implementing my prior feature request (in-capture exposure lock) so quickly. If you are still accepting feature requests, then I have another one: in-capture adjustment of the blue and red channel gain.
After you provided in-capture adjustment for the green channel, the WB of my scans has improved. However, much of my ancient Kodachrome film has a significant blue cast when viewed with the naked eye, because the magenta film layer has faded significantly more than the cyan layer. Unfortunately, even the '2.0' WB setting of R:592 and B:256 is unable to correct my color fading problem. Note that I'm not requesting that you change the R/B values of the '2.0' WB preset, because presumably that is high enough for most users. I believe that my color fading problem could be corrected in-capture if I had the ability to adjust blue down and/or red up enough. If you use the same percentage gain for each blue/red step that you did for green, then the blue adjustment range would be from 144 to 368 (same as for green), and the red adjustment range would be from 261 to 667 (assuming the current red baseline value remains the same, which I believe is 464).
I appreciate your consideration and your thoughts.
dsenechal57
7
View attachment 25263View attachment 25264View attachment 25265
Hi. Successfully installed your "c" version. As I am not a software developer, what are the steps to change the frame rate from 16 to 18fps, and also manipulate the auto exposure?
With great admiration for someone who knows what they're doing (and I do not).
Dave
442
623
Use the up and down arrows move the square braces between controllable settings, +/- change the settings. These are only changeable during record.
dsenechal57
7
Thanks. That did the trick!!
Reactions: Kai Robinson
P-car
25
7
Hello everyone
I've been quietly following this forum for a few months and finally decided to purchase a KODAK REELZ, which should arrive soon.
I just wanted to thank Mac84 and OdanO for an absolutely incredible accomplishment!!
Mac84, none of this would have been possible if your inquisitive and creative mind had not started this project in the first place.
OdanO, what can I say - I am in utter shock and awe - in regards to what you have accomplished and your immense generosity!!
I genuinely would like ot know how I can send you a "donation" for your gargantuan efforts.
(As a matter of fact, I would love it if someone can help me setup a donation space for OdanO, so that we can all show him our gratitude and compensate him, for the innumerable hours of work he has invested, in order to give us these amazing firmware MODS.)
Thanks again to Mac84 and to OdanO - and also to all the other members that have made contributions.
I was painfully contemplating selling some of my more expensive - and beloved - photo equipment, in order to purchase one of the more expensive "digitizing devices'; until, this firmware mod came to my attention. They are "GAME CHANGERS" - making the Kodak reelz device and ACTUAL digitizing option.
This is nothing short of a small miracle!
OdanO, you are a GENIOUS!!
Thanks again.
Reactions: Mac84
442
623
Thank you. Many people have offered donations, which I have generally ignored, as it would not be a positive motivation for me. If I felt I was being paid for this, in anyway, it wouldn't be as fun. But I have a solution. This project of reverse engineering a consumer product is in the grey area legally, but it shouldn't be. We own this hardware, we should be free to modify it as we want, and share those modifications without any concern. A charity that I donate to every year, Electronic Frontier Foundation (EFF), deals with customer rights like these. So if you want support projects like this one, please donate to the EFF.
You can thank me in your donation via:
https://supporters.eff.org/donate/tribute
Use this contact info.
Thank you again.
P-car
25
7
Thank you again.
Will do!! Thank you.
442
623
Here is v7.5.
Additions:
- You can customize all the RGB gains for white balance, to deal with very blue (or red) film.
- The font has been increased in size for improve readability.
- FPS, EV, Qp and Frame count are now only during capture.
Bug fixes:
- Sometimes the ISO/Shutter wasn't displaying correctly.
  • FWDV280-TypeA-V75-0dan0.zip
  • FWDV280-TypeB-V75-0dan0.zip
  • FWDV280-TypeC-V75-0dan0.zip
dsenechal57
7
View attachment 25351View attachment 25352View attachment 25353
Here is v7.5.
Additions:
Bug fixes:
This is all great!!
The font size is especially appreciated by these old-ish eyes :). Is there a standard WB setting, or does the scanner set up the intial WB upon startup, and then the user can tweak the gains?
Thank you!
Dave
442
623
The Picture setting still set the white balance like before, with has a maximum of 9 WB settings. Now during recording you can tweak red, green and blue, up and down as much as you like, it will remember any changes. Unfortunately I yet to implement a reset, to restore the defaults. The firmware update will reset RGB gains to there default offsets. If you change red or blue, off the defaults, the value will be odd, rather than even. I didn't do this with green, as I was just preserving the existing behavior with that channel.
WBAL (current defaults)
2.0 384,256,256
1.5 352,256,256
1.0 320,256,256
0.5 288,256,256
0.0 256,256,256
-0.5 256,256,288
-1.0 224,256,320
-1.5 96,256,448
-2.0 64,256,448
sheider
26
442
623
...For anyone else trying to customize firmware, you may have found NktTool frustratingly slow. It uses two Windows compiled utilities from https://github.com/str2b ntkcalc and bfc4ntk. These where 32-bit compiled, so I recompiled at 64-bit for more speed. I also found a flaw in ntkcalc, that makes that step a thousand times faster. So the whole process now takes only 8-10 seconds.
Why did twenty people (so far) download NewNtkTools2025.zip, this is for developers to "customize firmware". I was just sharing a change to one the tools I'm using, I only expected maybe Mac84, and one other to try it. If there are more out there want to try extending the firmware, let me know and I can show the steps I'm using. Now that serval hacks are in C, it might be little easier for others to try.
Reactions: Umba67 and Mac84
