597
I was playing with a new OSX 10.5 PowerPC multimedia plex/soundcloud/internet radio front end that SRP just released the beta for over HERE. I was able to connect with my Plex token and the app saw my recent Walking Dead episodes along with my server and I was briefly able to stream an episode before my Powermac became grumpy and crashed lol.
But that is pretty cool! Plex on a 20+ year old mac. It has some other functionality that I haven't really tapped yet but am excited to once I get Plex working. I hope everyone had a great weekend.
Reactions: Volvo242GT
597
I made some progress today. I was able to adjust config in settings to get srps beta Aquacenter to play clean and smooth playback from Plex on my Powermac G5.
It's not perfect as when the episode is over, it doesnt forward to the next one but watching 2026 Plex on a 2004 Powermac G5 is pretty awesome. :) I mean that's typically something I do on a M2 12c mbp16 that has literally 10x-100x's faster processing power.
Reactions: Trash80toG4
Volvo242GT
386
225
Currently Duvall, WA
Plans changed a bit. I downgraded to the A1278 MBP and am planning to sell the A1286 as a project machine for someone who has an A1286 with a bad GPU chip, but a good drive and battery. So, swapped the 1TB drive from that computer over to the A1278. My reason for doing this is that one of my clients has a mid-2012 A1286 that I set up for him, but that has an iffy battery. My late 2011 machine has a good battery in it. I'll either get a machine identical to the "problem child" mid-2012 A1286, but one that's not with multiple issues, or I'll get a slightly newer retina 15" MBP. Something that can run Mac OS 11, 12, etc. Use that as a work machine, then have the Mac Pro as my image editing and home internet machine, and the A1278 for travel light purposes.
597
Today I was messing with retroarch v1.20.0 on MX v25.1. There were many issues to just get to the point of installing cores. My basic install was missing download cores menu, which for whatever reason was turned off haha, so I had to enable it via settings>user Interface>Menu Item Visibility>Show Core Downloader & tick that radio button. Ok fine. I do that and update the core list and then I am met with failed to download cores as I choose which cores I want. Turns out that where retroarch installs to is within a read only core MX file and so I had to provide myself administrative read/write access to down load cores. Haha, ok whatever so in terminal I used.
sudo chown -R $USER:$USER / path of file needing write access.
To get the specific file path, one needs to go back into retroarch to settings>directory>cores and it will provide the exact file path you need. This did ultimately work and I was able to download all the cores I wanted for the various systems I already physically own without manually having to stick them there.
It is worth noting that I have never had to do any of this with retroarch on macos lol. I also am really not a big fan of retroarch's gui although I get that it is designed more with a controller in mind vs kb/m. Oh well dems da breaks :)
What has prompted all of this fun is that I am contemplating installing MX25 on my kids imac 9,1. If I were to go the route of legacy corepatcher, it still only brings their imac up to macos11 (w/o a metal compatible gpu) which is still old at this point lol so if I were to drop MX onto their imac, I figured I needed to understand what all Id need to do in regards to their emulators they use. MX has retroarch which is great but I have been using openemu which is a macos only frontend unfortunately and one they have an easier time navigating generally. Still, I may do this as it will bring their aging imac into a much more modern and supported os, apps etc and it will be their first exposure to Linux & I think MX would be an easy & pretty intuitive lift for them plus as always if they had any questions they can ask.
We'll see. I might also start looking around for a newer 2013-15ish imac and go that route but the caveat there is thats when everything starts getting taped/soldered together and not readily user serviceable, so there's that caveat as well. Unless I can get a great deal, I think squeezing a few more years out of this old 24" workhorse with MX might be the better path forward. Id hate to drop a couple hundred on an iseries Intel taped together PITA imac and have it break.
597
Back in February on a trip to the dump, I found a junked Presario box with no case (just the frame) and a broken vga port in the recycling box. I didn’t know if it worked or not but figured if anything, the dvd burners and era bobs n’ bits would be worth the scoop. I got around to cleaning & lubing the dirty psu and replacing the vga port on the logic board and success! It is alive :)
My super clean and organized bench with the propped up logic board lol.
Dead vga port and solder removed.
New port soldered in. Good enough for who it’s for :)
And we have LIFE :) looks like a XP installation on the old pata drive that was in there.
