After having to step away from my scanning project for nearly a year, I am back on it. I have a B model, and was using 0dan0 's v6.9 with no issues. After getting everything setup, I updated to v7.7.1 for B's and updated with no issues. Right after the update, the splash screen came up and a I could move around the menus. I did not change any settings, but did look through the various menus. I went to capture and it stopped right after the first frame and shut completely off. It was right after there was a signal to the drive stepper on the front reel, it turned a bit, and then shut off. After unplugging and turning back on again, the splash screen comes up, it goes to the menu, sends a signal to the stepper motor and then shuts off. I tried going back one to V7.7.0 and then all the way back to V6.6 and the same thing continues to happen.
I am thinking this is not a function of the FW, but maybe my hardware went bad sitting for a year? Has anyone else seen this?
Update - I found a post elsewhere where this was being discussed. Turns out I needed to use the USB plug for power. Plugged in the USB and it no longer turned off, but would not start capture when I selected capture. Plugged in both the 12v and the USB and it now captures, but stops advancing the film several frames in, but still continues to capture. Very odd, but will keep troubleshooting. Did this after going back to 7.7.1
Update - turned it off and went swimming for a couple of hours. Got cleaned up, sat down to try it again and it is working great! No idea....
