Apple Lisa 3d Case Project
nilobject
64
39
I devised a simple way to add a lighted power button to the front that I really like. It's just a clear keyboard switch with an LED attached, and a 3d printed button that allows the light to shine through.
Super clever! Well done, that's looks so awesome!
Do you have photos installing it or it was simple to do?
709
^ I'd love to learn from your launcher code. Will you be making that public?
EDIT: Found your repository...
Yeah, spent some time tonight getting all the documentation squared away for the software side (setting up the Pi, installing my launcher and all the emulators) and the hardware side (the 3d printing and the assembly and wiring of everything).
It's live now, although it sounds like you already found it:
Technically you don't need to setup the hardware to use the software (it just looks cooler in the case!). But note that the launcher I created is optimized for a 1024x768 display. I will probably try to tackle letting it scale responsively, so keep an eye on the repo. Out of town this week for work, so probably won't have time to tackle anything for a bit.
709
I tried to make it somewhat simple, but it will involve some soldering to complete. The assembly instructions now include images of the various steps. The software is mostly automated with a provisioning script, but I don't want to get sued, so I didn't include ROMs and drive images with any OSes on them. I will look to better help users figure out where to acquire the ROMs and disk images.
Reactions: nilobject
709
Full kudos to you. I could never make something this complex, be implemented so simply. If you need any coding work done, hit me up.
Honestly, the emulator performance on the Pi 4 is pretty disappointing. I may focus some time trying to see if I can get the LisaEm and Previous emulators to perform better. I was hoping the Pi 3 would be sufficient, but the performance pretty unbearable. It's passable on the Pi 4, and I have a Pi 5 I have installed on and it works best, but requires a power board and a couple of fans to keep things cool, and I suspect I'll need to size up the cooling slots on the back for it to not overheat. I'll let you know. I'm also going to look at other emulators - I just heard about gssquared (https://gssquared.net/) that I might add to it, or replace the current standard Apple II emulator I am using. But I might start doing a deeper dive into performance tuning the emulators. I tried to use the Rust version of the Lisa emulator and I did eventually get it to run, but it still did not performa well on the Pi. I'll let you know if I start trying to tackle it.
2,219
Excellent work, @wottle !
I have the LISA FPGA so I am eager to see when that edition of your amazing case is complete.
I don't have a 3D printer either, but I tend to use JLC3DP for most printers. However, the downside is they don't have vintage beige filaments. :-(
709
Yeah, there are going to be some compromises for adding support for the lighted power power key to the LisaFPGA version. The back is no longer symmetrical, which bothers me, but is probably acceptable.
Also. the 12v power jack cannot stay where it is because that's where the enclosure for the switch will need to be. So I had temporarily moved it to the top back of the machine (not nearly as clean with all the cables going into the port cutout along the bottom of the back). Along with adding the rocker switch to the top of the back as well, allowing for easily powering off the LisaFPGA and LCD together. I'm going to see if it would be possible to squeeze the 12v DC jack in elsewhere in the port cut-out.
I actually just thought of a possibility for embedding it in the left leg, and hollowing out a chamber for securing it sideways into the leg. It looks like it would work and would be printable with minimal supports. seems like it would work and actually be better than my current location (except maybe trying to secure the nut on the inside of the barrel jack connector) .
Screenshot 2026-09-28 at 10.18.26 AM.png Screenshot 2026-09-28 at 10.18.48 AM.png
When I get back from my trip, I'll see about moving the Floppy screen and buttons, and re-doing the power inputs and testing the lighted power button.
If anyone knows of a good solution for pre-made momentary switches that can be wired in easily, and secured in some mounts in a 3d printed enclosure, let me know. I was thinking about these? I would wire them to be remote buttons for the 3 ESFloppy buttons on the LisaFPGA. Then add little buttons underneath the chin for navigating, with the LCD now exposed on the front of the case. Then I would seal up the opening on the back, and remove those buttons.
https://www.adafruit.com/product/44...w7nygIZXNhkvKhReXbNd_P8QXpscUIFAi2n-GWhE_-o_Q
Now that I'm thinking about it. I might be able to put the 12v input where those ESFloppy buttons are today. IF that and the screen is moved, it opens up the space on that side for the power. I'll tinker with it when I return. This gives me a lot of respect for engineers building physical devices...
KnobsNSwitches
47
Ha. Yeah I used it as justification to get a second, larger 3d printer to be able to print without splitting! It is nice having a 350mm print bed printer.
Not to be a noob derailing this thread, but is it possible to print this on a smaller printer? Like a 256mm print bed?
709
It is, but you’ll need to join the parts after the fact. My first test prints were on my BambuLab A1. I simply sliced it at a point where it would be a clean cut, printed some blocks I could use as glue supports, two on the back and one on the top and bottom. It’s not perfect and you’ll see the seam lines, but it would work.
I believe the height makes it possible to simply print each piece (front and back) as two parts.
Just make sure where you glue the blocks won’t interfere with the case parts coming together or where the LisaFPGA ports and board components are. Also make sure you don’t slice through any of the buttons.
I think I finally threw away my early test print boards but I can try to show you where I sliced the parts to make it easiest and least obvious.
KnobsNSwitches
47
Thank you! black friday approaches, a 3d printer is in my future.
