2,232
I have two PowerBook Wallstreet PDQ notebooks that once worked fine several years ago), but now neither will power-on when I press the POWER button (long or short press).
When I first plug-in the Apple AC Adapter, the fan spins at full blast and the green power LED lights for a couple seconds, and then the fan and LED power off. After that, pressing the power button does nothing.
I have no working battery anymore, so I only have AC power from the stock adapter. I've tested both PDQ machines with nothing in either drive bay and with even the hard drive removed, but to no avail. Both PDQ machines respond in the exact same way — power button doesn't power them on, despite my hearing the fan spin and LED light initially after connecting the AC Adapter. I've swapped their CPU cards, but again, it doesn't resolve the problem.
Here's a video overview of what I explained and mentions a couple voltage measurements I made too...
Wallstreet repair experts...
How can I fix these machines?
S. Pupp
98
53
It's been almost a month since my last post, so I want to provide an update so as to hear your kind thoughts.
ONE PDQ NOW POWERS ON RELIABLY​
First, I've been testing one of my Wallstreet PDQ machines almost daily (the one with a 266MHz CPU card). For much of September, I left the stock Apple AC Power adapter connected to the wall socket and to my PDQ. What I found after several days was that it would regularly power-on when I pressed the Power Button. No need for any PMU reset. It just worked. That only applies to one of my two PDQ machines, but at least one of them powers on well now (so long as the AC Adapter is left connected to the wall and PDQ).
However, the main problem has been that the machine suddenly powers off (loses power) after a while. And that span of time varies, almost like it is random. Sometimes, I can use it for 1 hour before it suddenly powers off. Other times, it's a half hour. There have been times when it was more than 1 hour. And yes, it still happens even if I keep a floor fan on the machine to ensure heat is not the issue.
MY OTHER PDQ REFUSES TO POWER ON​
My PDQ with 300MHz CPU card refuses to power on even if I put the 266MHz card in it and swap RAM and even remove the main Hard Drive and keep both drive bays empty. I left the Apple AC Adapter connected to it and the wall socket for days last month, but to no avail. Even with the new 24V Adapter, it still won't power on. The hard drive works, despite having shown signs that something liquid had spilled on it in the past. I can put that drive in my other PDQ and it boots. So perhaps something spilled on the drive while the 300MHz PDQ was powered on in the past and that shorted something, but clearly not the hard drive, even though I see the liquid flowed under the drive and onto its PCB. I'm not seeing any burn marks on the machine's main PCB, however. Not sure what's wrong with this machine.
MODERN AC ADAPTER TESTING​
I purchased this modern 24V 2.5A Adapter from Amazon, and I recently received my ZigZagJoe order which contained the adapter plug from Bix Power. (I had the plug shipped to him, and he kindly shipped it to me with my NuCF order.) No need to keep this connected to the wall or the PDQ, I'm pleased to report! The adapter will reliably power-ON one of my PDQ machines without fail! So I guess the improvement must come from bad caps inside the stock Apple AC Adapter, which is only overcome if you leave it connected all the time. The same is true of the G4 Cube power brick -- it often fails to boot the Cube unless you recap.
Sadly, this modern AC Adapter does NOT resolve my sudden power loss issue. As was true of the stock adapter, this new adapter too fails to keep the machine alive all the time. Sometimes it powers off after 1 hour, and sometimes less. (When I say "power off" I mean "loses power suddenly.")
When the machine loses power, if I press the power button soon afterward, it often fails to boot chime or show any signs of life. But if I wait 15 minutes or more, it sometimes powers on. That was true of the Apple adapter and this new one too. I've tested that over and over.
WHAT I'VE TRIED​
CPU CARD SWAP​
I am able to put the 300MHz CPU card into my PDQ which has a 266MHz card, and the 300MHz card works just fine. But the sudden power loss problem remains.​
RAM SWAP​
I have used 8-chip and 16-chip RAM Cards, but the power loss problem remains.​
CONTACT CLEANER​
I have used DeOxit D5 on the CPU Card connectors and the RAM socket connectors, but the suddenly power loss problem remains.​
EMPTY DRIVE BAYS​
I've tested extensively with nothing in either drive bay, and with the Apple CD-ROM in the right drive bay. Made zero impact on the machine. Sudden power off issue remains.​
PMU Reset​
Does not fix the sudden power off issue.​
BATTERY (in the distant past)​
In the past, when I had a good main battery, I don't recall ever experiencing this sudden power loss problem (when the main battery was inserted and charged). It's only now that I have no main battery at all that I have the power loss issue.​
SLEEP MODE​
If I put the machine to sleep (while booted into OS 9.2.1), I can come back the next day and it wakes just fine. But I cannot leave it powered and awake for more than an hour or so before that power loss problem occurs.​
SOLDER JOINTS​
I re-soldered the joints on the main DC input plug in the past, but that was never a solution for me.​
PRAM BATTERY​
I confirmed that PDQ machines will indeed boot WITHOUT any PRAM battery installed at all. Mine was dead, so I removed it. Presence or absence most likely has nothing at all to do with the sudden power loss problem.​
RECAPPING​
I still think the electrolytic capacitors that are on the PCB which sits between the two drive bays are too far away from the primary DC board that has the DC input jack on it (at the back of the machine). I therefore am highly skeptical if that would be "the magic fix" for this sudden power loss problem. Nevertheless, to avoid a situation where folks continue to point to finger at those caps, I will need to now buy the caps and see what happens.
YOUR THOUGHTS​
Now that you've read my report, I'd certainly appreciate your thoughts and suggestions.
If I recap and still have the same power loss issue, then it's clear something else is the cause.
THANK YOU!
I agree with recapping, even if it does not seem clear how it would fix the problem. Recapping has solved some odd malfunctions that were difficult to diagnose in some of my older Macs.
2,232
I am currently waiting for Mouser to get their act together regarding backordered items. The last backordered item won't arrive until Oct. 19th, so I will place my order then and hopefully nothing else will go out-of-stock before then.
But again, my gut tells me that recapping won't solve this problem because on that large physical distance of those caps from the main DC board at the back of the machine. Caps sit between the two drive bays to keep voltage levels from falling when drives in those bays suddenly power up (like the CD-ROM drive). The caps make sure the power to those drives remains stable. There are no electrolytic caps at the back of the machine where you connect your external power brick. Instead, that board uses tantalum and ceramic types, which have a solid electrolyte and do not need replacing.
So I am 90% sure a recap won't resolve the sudden power loss one of my PDQ machines has, nor will it likely fix the other PDQ which refuses to power on (even though a PMU reset does make the fan spin as it should).
So for the time being, let's pretend I've recapped the machines and still have the same issues. Would any of you have thoughts about the root cause in that case?
S. Pupp
98
53
If not done already, I would evaluate for barrel plug PCB failure by exchanging the barrel plug PCB's between the two PDQ's:
- If the booting behavior follows the exchange (i.e. the non-booting PDQ now boots and the booting PDQ now doesn't boot), then the problem is the barrel plug PCB of the non-booting PDQ.
- Unlikely, but if the booting behavior AND the sudden shutdown issue follow the exchange, then there is a problem with both barrel plug PCB's.
What brought this to mind was a non-booting Lombard I obtained last month that turned out simply to have a bad barrel plug PCB.
Knife Cult
6
Schematics would help, but a problem that fixes itself as you described sounds like a bad cap. Is this the board in question:
I think that board generates the different voltages used by the machine from the main battery and/or the power brick. If you carefully probe the caps on this board with the power brick attached, you should find constant 24v from the brick as well as 5v trickle/standby that goes to the cuda/PMU. If moving this board from the now-working machine fixes the still-dead one, that could help narrow the search.
Is there a 10v 100uF electrolytic next to the cuda/PMU chip? Is this near where the clock battery plugs in?
One other thing to try could be temperature. Without going to extremes, you could try different temperatures, like a warm sunny spot vs 15min in the fridge. If 15min in the fridge breaks the now-working one, that would also point to electrolytic caps.
2,232
I’d like to provide an update since my post yesterday.
I decided to leave my dead PDQ machine connected to my new AC Adapter for many hours to see if that would help but it didn’t. Still no sign of life on that machine. But then when I put the AC adapter back into my other PDQ, which I told you in my earlier post that was regularly powering on now, it refused to power on. The fan spins up when you first plug-in power, and then spins down, and PMU reset always causes this fan to spin up too. But pressing the power key does nothing. And I tested it over the course of an entire day, but it still won’t power on. So I left it connected to the wall when I left work and I will leave it like that over the weekend and see what happens on Monday.
If you go back through this entire thread, you’ll see that neither one of my machines would power out initially, and it took a long time for one of the two machines to be connected to wall socket power before I suddenly started powering on again. And then when I left it connected to the wall, it would regularly power on whenever I press the power key. But the secondary problem was that it was suddenly loosing power after having been on a while, such as for 30 minutes to an hour.
These Wallstreets are turning out to be some of the most frustrating vintage Macs I own. 😢
2,232
I left the machine connected to the AC Adapter over the weekend. (The "good" one, not the one that never powers on.) It booted up right away when I pressed the power key today (Monday morning). I used it for 30 minutes without issue, then it suddenly lost power. I waited 60 seconds, then pressed the power key. It booted up just fine and let me launch Classilla, but just as I was about to connect to a website, it lost power again.
615
Could it be a failing PSU that takes a while to get warm and fail? Just measuring the voltage output without load does not always signify a working PSU. I know it is grasping at straws, but you have tried everything under the sun.
2,232
If by "PSU" you mean the "external AC Adapter," then as I mentioned in my earlier posts, I purchased a brand new, modern power brick with more than a half Amp more power output than the stock, and to make the connector fit, I purchased a special adapter too. So it is absolutely not the external power source that is failing.
By if by "PSU" you mean "the small PCB on which you find the DC power input jack," all I can say is that there are no electrolytic capacitors on that board, and I have re-soldered the joints on that DC power jack so I can confirm absolutely that is not the problem.
2,232
I waited about 24 hours. When I pressed the power key this morning, it gave me the boot chime right away, did the memory checks (painful -- I wish we could ROM-flash those away!), and then it started to boot by showing the little happy Mac icon, but it suddenly lost power seconds after that. That test today proves the sudden power loss problem is absolutely NOT "heat related" because the machine was cool, in a cool room, and had been off the entire night. The external power brick was cool to the touch as well.
Sadly, I know I won't be able to get it to boot chime again for another 24 hours.
This problem is soooooooooooooooooooooo frustrating!
Ack!
2,232
I did more voltage measurements today.
When the "semi-good" PDQ refuses to power-ON, I can still press the keyboard keys & PWR key to do a PMU reset, and as long as I hold down those keys, the fan runs at full blast. The fan is so loud it's impossible to hear the hard drive, but I confirmed today that the hard drive powers up while the fan is spinning full blast. Under that condition, I measured the following voltages (all rock solid stable while the fan is running full blast with keys pressed):
  • C31 (to the left of connector J5) on main DC board at back with the power plug: 4.99V
  • C3 on Modem: 5.05V
  • Various capacitors on the CPU card: 2.0V or 3.3V, depending on which capacitor
  • Capacitors on the RAM module attached to top of CPU card: 3.3V
But as soon as I release those keyboard keys, all power gets cut and the above voltages all drop to zero, and the HDD and fan spin down. Pressing the power button soon after that does nothing, and voltages do not rise even for an instant. Usually, if I wait 24 hours and then press the power key (with the AC Adapter connected to the wall and PDQ), then it will power ON, but for whatever reason, it refused to power on today after that waiting period.
2,232
I've been pressing the darned Power key every freaking day and finally today the "semi-good" PDQ booted. I was able to booted from an OS 9.0.4 CD, do an OS install, download software from Macintosh Garden, and do other things for more than 1 hour, and it didn't suddenly power off. I was out of time, so I put the machine to sleep, and currently the LED is blinking, showing it is sleeping without issue.
For the life of me, I cannot figure out these ridiculous machines. These PDQs are the single most frustrating vintage Macs I've ever owned, and I've owned some frustrating ones, believe me.
2,232
I left the PDQ in its LED-blinking sleep state over our 3-day holiday weekend, and when I arrived back in the office, the LED was no longer blinking, and pressing the Power key did nothing.
So even while in Sleep, the stupid sudden power-loss problem still rears is pathetic ugly head.
Froggy814
204
57
Squaw Valley, CA
This is like weird.
I just had a thought. Could it be like the Xbox 360 and how people were able to temporarily fix the consoles, but it was because of BGA. Could it be something like that?
Just throwing the idea out there :/
2,232
I've never owned an Xbox of any kind, so I am not equipped to answer that question.
It's been two days since my last post. Today, I pressed the power key and got nothing. Normally, if I leave it at least a couple days plugged into the wall, it will most often power on, but not today. However, in the past, whenever I would find it would not power on, I would do the keyboard PMU reset sequence which spins the fan at full speed. I would do that a few times, actually. But even then it would often not power on even 24 hours later, but 48 to 72 hours later it often would.
So I will leave it like this over the weekend, having not done the PMU reset sequence, and see if it powers on or not on Monday. If it refuses to power on, then I will do the PMU reset, wait a couple days, then see if it powers on. If it does, that testing would seem to show that the sudden power loss problem requires the PMU reset (or the fan spinning at full blast) to do SOMETHING to this BLASTED machine to make it power on at some point. Even then though, as I have repeatedly said throughout this thread, it will stay on maybe an hour or so and then lose power. And even if it doesn't lose power, if I sleep the machine and wait a couple days, it will suddenly lose power even during sleep.
PowerBook Wallstreet PDQ machines are nightmare machines.
2,232
It's Monday morning and the machine was connected during the weekend. Pressing the power key caused the normal Bong song and the HDD spun up and the LCD backlight illuminated, but 10 seconds later, it suddenly lost power.
Anyway, this test seems to indicate that a PMU Reset is not necessarily needed to generate the bong and brief power on.
Honestly, if these ridiculous machines weren't so darned useful, I'd have rid myself of them long ago. Sadly, they are great bridge machines to have, which is the lone reason I've been busting my fanny trying to figure out what the heck is wrong with them.
Still have to wait one more silly day though before I can order Mouse caps. But my gut has long told me that won't do any good. Maybe we should take bets on whether a recap will work or not. ;-)
S. Pupp
98
53
I'll bet that the recap works. I'm confident enough to put up as my bet five recapped M8407 TiBooks, one of which even occasionally boots (almost 1% of the time, upon last count).
2,232
Today is Wednesday — two days since my last power-on attempt. I pressed the power-key today and got the bong and a complete boot. I deleted files and did various things in the Finder, and it suddenly lost power 25 minutes later. I waited 3 minutes and pressed the power-key again, and to my surprise I got the bong and it booted. But as soon as it reached the Finder, it lost power again.
What this test is proving is that a PMU Reset is not necessary to get the machine to power ON. It's not easy to get it to power on, but when it does, it does.
Still waiting for stupid Mouser to get their act together so I can get my order in. :-(
NJRoadfan
109
37
This was a known WallStreet problem even back 20 years ago. A friend had a unit that did the same thing (endless PMU resets needed to get the thing to power on). If I recall, replacing the DC power board solved the problem at the time. I might have replaced the PRAM battery as well (I think this keeps the PMU powered when the machine is off reducing the need to reset it out of a wedged state). I suspect another component on that board either shorts or burns out due to a design flaw. The barrel plug Apple used was not reliable and the power supplies that used it all had various flaws that caused damage to machines as well.
I think the only version of the power supply that was semi-reliable was the pre-yoyo black brick that came with the WallStreet and Kenga/3400 (?). One of those came with my Lombard and is still working. No failing cables or weird shorts unlike the yoyos and white bricks. Still doesn't solve the issue of that flaky barrel plug though.
2,232
…replacing the DC power board solved the problem at the time.
I appreciate your time, and thank you for your thoughts.
There are 3 power boards:
1. The small PCB at back with barrel plug for connecting to the external AC power adapter.
2. The T-shaped power boards sitting between the two drive bays and which separate from each other via connector, yielding two different boards.
So it’s not clear to me which of the three PCBs you replaced 20 years ago. I have high resolution photos of those board posted earlier this discussion.
Some contend the problem I have is tied to the electrolytic capacitors on one of the two DC boards that sit between the drive bays, so I’ve been waiting to place my Mouser order to put that to rest. I have pretty much zero confidence that’s going to do any good, but sometimes the only way to end a line of thought is to actually try that thing, and so that’s what I need to do next.
The other two things your post mentions are the PRAM battery and the external power brick.
Earlier in this discussion, I’ve proven that the PDQ machines can boot fine even without any PRAM battery installed at all. I currently have no PRAM battery installed.
To eliminate any possibility that leaky electrolytic capacitors inside the black rectangular Apple AC power brick could possibly be leading to voltage instability and the problems I’m having, I decided to purchase a barrel adapter and a modern power brick that has more amperage output that the stock Apple power brick does. However, that did not change anything when I tried it.
So, once I have those electrolytic capacitors and recap the DC boards that sit between the two drive bays, if my gut instinct was correct and I find it does absolutely nothing good, then what you said in your post about damage boards is the only explanation that remains. But perhaps we should say they are only “semi-damaged” because there are times it powers on and stays on for about an hour. Then the machine suddenly loses power. It’s very perplexing.
But even if you are correct about one of those three DC boards needing replacement, assuming I identify the correct one of the three for replacement, who is to say that replacement board won’t go bad overtime?
This is not me chastising you or anyone else. It’s simply me analyzing all of the facts and talking out loud while feeling truly frustrated.
Even though some of our speculations are well thought out, we don’t really know what’s going on. That makes the problem all the more frustrating.
