melw
51
72
Hello everyone,
I am looking for a clean, unmodified stock firmware 2.0 dump (FWDV280.BIN) to restore my Kodak Reels 8mm Film Digitizer back to factory settings.
Here are my unit details:
  • Serial Number: D0926148BK00379 (2026 batch, came with factory firmware 2.0)
  • Current issue: The Mac84 lookup tool misidentified my serial number as Type B. After flashing Type B firmware, the unit powers on, but the buttons are completely unresponsive and I cannot access the menu.
If anyone has a clean factory backup from a 2.0 unit (or a D0926... / H2825... revision) and could share the .bin file so I can recover my scanner via SD card, I would really appreciate your help! Also letting @Mac84 know about this new D0926 serial prefix for the lookup tool database.
Thank you!
Hi @zbig
Your unit is a Type D. Serials starting with D0926 are Type D. The lookup tool currently suggests B for every serial that isn't on its Type A list, which is how this happened. Another D0926 owner had exactly the same symptom with B firmware: unit starts, buttons dead.
It's recoverable:
  1. Download 0dan0's stock Type D recovery image from this thread post #143: Unzip it, so you have FWDV280.BIN itself, not the zip.
  2. Copy FWDV280.BIN to the root of a FAT32 SD card, 32 GB or smaller.
  3. Unit off, insert the card, power on, and leave it alone for half a minute or so while it flashes.
Stock Type D should then start with working buttons. After that you can also use the Type D builds from this thread ifyou like.
zbig
Hi @0dan0, thank you for uploading the Type D stock recovery image in post #143!
Unfortunately, my standard forum account doesn't have permission to download attachments without a supporter upgrade. Could you please upload the FWDV280.BIN (or zip) file to a free file host like Google Drive / Dropbox, or send it to me via DM? It would really save my D0926 scanner!
Thank you so much!
JohnCT
31
10
I must be the only one, but I run my film under the middle "roller" first, then up to the take up reel directly skipping the other two. I don't see any advantage of running it around the other two guides, and there has been zero instability in my scans. A roller conversion would be great though.
John
ioeuqr
7
John
I'm with you - I don't understand the circuitous path around the tight bends with old and possibly fragile film. The only thing I can figure is that the take up reel motor is a little too strong and those guide pins drag it down so it doesn't pull the film out of the gate. I'm also confused by the 3 guide pins vs. 4 guide pins that we see on the two different models.
I just published my roller conversion on Thingiverse: https://www.thingiverse.com/thing:7437080
melw
51
72
For A3026 owners - calling @thilosde @ArgieBargie @FrenchNum :
Nobody has an A3026 firmware file yet, and the type probe showed the factory firmware isn't A, B, C or D. But the bootloader on these units can run a firmware file straight from the card without flashing it. That lets you test whether Type D works on your scanner:
  1. Download the attached FW96658T.BIN - it's Type D FW 292 in test mode. It will not flash anything on the device.
  2. Put it alone on a FAT32 card. Make sure no FWDV280.BIN is on the card,.
  3. Power on. The startup screen should say "FW 292 Type D". Check whether the buttons respond, the motor runs and the picture looks normal. If the motor misbehaves, or there are any other problems, switch off the unit.
  4. Power off, remove the card, and power on again: the scanner should be back to its previous firmware and state.
Please report what you see. If everything works, your scanner runs Type D firmware fine, and you can flash FW 292 normally (the previously shared FWDV280.BIN) if you prefer to do so. If you already flashed B and your unit is dead, this tells you whether flashing D is worth trying.
From all the information posted so far A3026* units are not Type B and you should not attempt flashing Type B firmware on them.
  • FW96658T.BIN
JohnCT
31
10
Could be. Before I ran my first reel through, I figured the take up reel was pulling too hard for my liking (I've had old projectors snap tape for the same reason). I took the takup hub apart and removed one washer to reduce the drag. Just once the takeup reel stalled, but I would rather have it not pull too hard on 80 year old film.
I'll check it out!
John
ioeuqr
7
I'll check it out!
John
Do you have any photos of your hub disassembly? I'm trying to picture what the process is, and even if we have the same scanner. I have a 2025 Type C with the 3 guide pins on the right. I've seen other posts that sound like there's a different take up arm used.
Thanks!
JohnCT
31
10
Thanks!
I did not take any photos. I'm up to my ass in alligators right now with several projects (I have my house ripped apart doing a full copper repipe). I may have a chance in a few weeks to get back to the Reels and take apart the hub. If I don't, give me a nudge.
John
ioeuqr
7
John
I totally get it. Just quickly then, did you have to go through the back of the machine and remove the motor and gear set? Or were you able to just disassemble the arm itself? That will get me 90% of what I need to know to proceed. Thanks!
p.s. Instead of copper, go with PEX-B 5306!
JohnCT
31
10
I took the back off the reels, removed the motor, and disassembled the hub. There were two washers on either side of a heavy spring, but since the spring didn't use the washer as a bearing to rotate, I removed one washer.
The plan was to go with Uponor PEX A - I bought the Milwaukee expander and heads, but recently there's been problems with Uponor (supposedly the best PEX). I'm talking new houses that needed to be repiped 5 years after a new install of PEX, so Uponor was definitely off the table. The next plan was either going with PEX B that was certified for F1960 expansion connections or Legend Valve's PE-RT, but in my mind I see copper as the gold standard, and few plumbers want to do copper anymore and those that do will only do Propress (basically a Sharkbite that's crimped - both rely on a gasket to seal).
I've always been good at copper sweating, so I said screw it and literally the day after I had the ceilings opened to expose the piping, I decided on copper and went to HD and spent over $1500 for copper, new stops, and new shower valves. I finished most of the sweat work yesterday and the water is back on (wife now happy), but I have to finish one more shower, then plan on a full remodel of the kitchen...
ioeuqr
7
Got it, thanks. Sounds like a full disassembly instead of the simple fix I was hoping for. No problem, I've been in there a few times before. Thanks!
alexanderlewis
Before you tear into it, photograph or sketch the washer/spring order and keep the removed washer labelled—that makes it reversible if the take-up tension ends up too low. Since removing a washer changes spring preload rather than just bearing drag, test with a scrap reel first and watch for loose winding or stalling. If you've had the arm apart before, the full motor removal may still be the only way to get at the hub on the Type C.
Reactions: JohnCT
