Background:
I've been working on a clone of the 1986 Radius FPD/SE, reverse engineered from the original PCB. Video goes to a Tang Nano 20K, rotated for display at 1:1 framed on a 1024x768 panel. Video then heads out its HDMI port by shielded ribbon cable to a DVI coupler on the backplane plate.
The SE needs extra oomph to push FPD-level pixel counts, so I figured adding the Performer would do the trick. I started reverse engineering the MicroMac Performer almost eight years ago and @Bolle jumped right into the discussion in parallel with his reverse engineering of the pretty much identical 1990 Total Systems/Quesse accelerator.
When I sent him my card about five years ago, he generously finished it off. Everything here is based on what he's got on GitHub (TheRealBolle/Performer-SE-PL-CL). Thanks, buddy!
The Performer section of my FPD board is the "Pig Pen." Rearranged onto its own 10x10 cm board, it becomes the "Mini-PigPen": a concept card and a starting point for anyone who may want to roll their own RAM or cache card for the Performer.
I read block diagrams and have studied system architectures since before the SE came out, but schematics and EE stuff may as well be Greek. I think in pictures, not words, and certainly not in schematics. Attached in the post below are two of my old "coloring book" pages from tracing the Performer in down time at work, so you can see what I mean. Lately I've been using Claude to help reverse engineer ancient hardware. Having a blast and learning a lot along the way!
Translation from my Adobe Illustrator buzz diagrams to conventional schematic requires AI assistance for this visual thinker.
Why six layers: the FPD/SE turned out to be a mixed-layer board. Radius ran a net through an outlying section of the power plane, which makes it in effect a five-layer board. I carried that over to the Mini-PigPen. Spread out on a bigger board it could probably be done in four layers, but fitting it onto 10x10 cm takes six, with the same general setup as the Pig Pen block on the FPD clone.
What's on Mini-PigPen:
- 68030 in a PGA socket on the SE PDS, stock 16 MHz
- 68882 FPU, clocked from the CPU
- Bolle's four GALs on a small plug-in daughtercard, OR an ATF1508AS CPLD in a socket on the main board. A "fang" on the GAL card blocks the CPLD socket, so you can't fit both. The GAL card is for the bench; inside a closed SE you'd run the CPLD.
- JTAG header to program the CPLD in place, plus a USB-C bench-power corner with a power mux, so USB and the Mac can never feed each other
- P2: an experimental 100-pin "generic memory port" (2x50, 1.27 mm, right angle). It carries the RAM-card signals plus the extras a cache card would want (/STERM, /CBREQ, /CBACK, /CIIN, /CIOUT, /BERR and friends). The pin order is my own and it's documented as experimental, so any RAM or cache card anyone wants to develop can hang off it
Attached: Mini-PigPen rough physical-fit block diagram, best-guess schematic, GAL daughtercard schematic and P2 header signal/pinout and notes, detailed in 261126-PigPen-P2-Memory-Port-Experimental-R2.pdf.
Things I really need help with:
1. Sharing the SE PDS. With the FPD and the Performer on the same slot, where do I need buffers? Apple says the SE can drive two LS loads per signal, and only one on C16M. How do other combo cards handle it? I’ve got an E-Machines card that plugs into some accelerators just as my FPD plugs into my Radius16.
2. GALs into a CPLD. Bolle's U4 has to run in step at twice the Mac's clock. Any gotchas moving that into an ATF1508AS CPLD? Which speed grade?
3. The P2 memory port. Is anything missing, or wrong, for a future RAM or cache card? Is it a good idea? I’d like to take a shot at it one day, so it's there.
4. The GAL daughtercard header. 50 pins, with ground on every pin next to a clock. Sane at 16 MHz? MicroMac’s Performer Pro manages to do it with a 64KB Cache at 32MHz.
So there it is, best effort to explain parallel projects and simple 10x10 spin-off.. Please let me know what I’ve got all wrong!
jt/Trash
jt/Trash
