Discord Weekly Summary
2,309
Discord Weekly Summary — Week ending 2026-06-27
Another busy week across the channels — highlights include progress on the SHORK 486 Linux distro, deep dives into Mac II 68030 upgrades, an A/UX archival effort, and a big discussion sparked by Linux dropping AppleTalk support. Here's the rundown.
Summary
#the-lab-software
Admiral Shark has been preparing SHORK 486 for its first public release with ready-to-go builds. Highlights this week:
  • A new unified settings app, SHORKSET, with a menu-based interface, consolidating the various settings tools.
  • Plans for an easy disk-mounting interface and a basic network manager.
  • A new SHORK DISC variant — an ISO containing precompiled 486 and DISKETTE .imgs plus a guided install script that automates dd'ing an image onto a disk or diskette (handy for those without an IDE-to-USB adapter). Shark noted that for pre-El Torito 486s that can't boot the CD, you can still mount it via SHORK DISKETTE and run the installer.
Stinkerton18 built SHORK DISKETTE and booted it on a 486SLC, reporting two bits of feedback: config/build had to be run as root directly on their distro, and the full build failed on libXdmcp-1.1.5 with a 404 (fixed by updating to the xorg.freedesktop.org URL — Shark has since updated all the x.org URLs). The plan is to try building the DaynaPORT SCSI/Link driver module.
#the-lab-hardware
  • Cracking protected PAL/GAL chips: Xiang asked about unlocking protected AMD PALCE16V8H chips with blown security fuses. zigzagjoe and Bolle discussed the Chinese "RunFei" programmers, which appear to use power glitching (cutting power mid-erase so only the protection bit clears) for GALs, while SuperSVGA noted the PALCE method seems to apply VPP for a permanent unlock. Bolle confirmed it has worked on countless chips but has occasionally fully erased one in the process — a known risk with glitching. Bolle offered to share logic analyzer dumps.
  • Adding a PCI slot: Trina's Technobabble asked whether an unpopulated "PCI1" footprint on an ASUS F2A55-M board could be made functional by soldering on a slot. The consensus (bakkus, Dorkulon, Justin D. Morgan) was that it's possible but risky — bakkus estimated ~30% odds given unknown missing components — with cautionary tales of people soldering slots onto footprints that turned out not to be standard slots.
  • Aging HDDs: techknight shared photos of age-related head coil adhesive failure on a black 2.5" IBM drive, prompting a "Powerbook/iBook owners beware" thread and reminiscing about how painful HDD replacement is on white iBooks and PowerBook G3s.
#vintage-apple
The busiest channel this week (300+ messages):
  • Apple II Serial Grappler: Wavebird picked up an Apple II Serial Grappler card and sought documentation. Andy pointed to several archives and noted that since it (like the Apple Super Serial Card and AE Serial Pro) uses a 6551, those manuals should apply. Confirmed convention: slot 1 for printers, slot 2 for modems; back-panel connectors mount with #4-40 nuts.
  • Mac II 68030 upgrade deep-dive: An extensive technical discussion (DosFox, zigzagjoe, twvd, Bolle, Andy) on upgrading a Macintosh II from the 68020/HMMU to a 68030. Key takeaways: you need FDHD ROMs (the same ROM used in the IIx/IIcx/SE/30) as the original II ROMs go into a reboot loop with an '030; the IIx-style PAL is very simple and the rest is mostly jumpering PMMU socket signals; the AMMU is just a set of simple GALs (reproducible in three 16L8s per the prototype). Bolle is considering including an '030 adapter in a PowerCache/Turbo040 adapter for the Mac II. twvd clarified the ROM detects an MMU by running an instruction, so an '030 is detected fine. Andy also cleared up confusion over PAL SIMMs (a fix for larger SIMMs on the Mac II, not the IIfx's dual-port RAM).
  • 68851 PMMU hunt: Sharpie sought a Motorola 68851 PMMU for a friend's Mac II upgrade; Kai Robinson found one (expensive, but rare these days).
  • A/UX archival: Sharpie is archiving a full A/UX 1.1 set — 33 floppies (some needing extensive repair), manuals to be photocopied, and a QIC install tape. twvd floated the idea of building tape drive emulation into Snow so A/UX could be installed directly from such media. Sharpie noted an A/UX install tape may not have been archived before.
  • "Is it vintage yet?": A lively debate kicked off by the news that the next macOS is the last to support Intel. TopherPerson linked Apple's official Vintage/Obsolete list. Xodium argued early Intel Macs (pre-Nehalem) already qualify, while Dorkulon countered that old machines feel slow mainly because modern web browsers and apps (e.g., Discord) are so bloated.
  • Repairs & projects: Josh (new to the scene) posted a detailed Mac SE restoration troubleshooting thread — moisture damage, a ~30s delay before the cursor appears, and a BlueSCSI that reaches the data phase then times out. Suggestions covered the 5V rail (raised to 5.04V via the PSU pot, no change), bad SCSI controllers, termination/assembly issues, and rolling your own known-good disk image rather than trusting prebuilt ones. Still unresolved. Wavebird sorted out an Apple II joystick button issue — Apple wired the buttons to +5V rather than the conventional ground, unlike the IBM joystick they'd been testing with. Coal Shork is sourcing a 3D-printed inner bezel for a slot-loading iMac G3, prompting discussion of the structural challenges (the CRT effectively hangs from it, and 3D prints are weak along layer lines). For plastic polishing/scuff removal, Novus 1/2/3, Magic Eraser, and brake fluid were recommended (always test first). killvore recommended the Noctua A6x15 FLX as a drop-in 68040 fan.
  • KansasFest 2026: Ron's Computer Videos reminded folks that on-campus lodging registration closed midnight Friday June 26th. The event runs July 14–19 at the University of Illinois Springfield, with special guests Dan Kottke, Jimmy Mensch, and IIgs engineer Dan Hillman announced.
#the-lab-networking
The big story: Linux is dropping AppleTalk support (EOL in 7.2). nulleric shared the Phoronix article, kicking off a long discussion:
  • The source has been moved to the linux-netdev/mod-orphan repo, so the module can still be compiled and loaded out-of-tree. Andy already does this for his Synology NAS, and daniel confirmed building the out-of-tree AppleTalk module has been "remarkably painless" so far (DKMS can auto-rebuild on kernel upgrades, per Nick-el) — the main worry is future-proofing against kernel API changes.
  • Maighstir noted the removal is largely about the maintenance burden of low-quality (or potentially malicious) patches. The Linus commit message ("Let it join hamradio in our out of tree protocol graveyard") was described as "on brand."
  • daniel (Netatalk) framed Apple killing AFP and Linux dropping the kernel module as "a blessing in disguise" that opens up the design space for rewrites. They reported major progress on a userspace AFP client — at feature parity with Apple AFP in macOS 26, with ResourceFork and FinderInfo xattrs transferring correctly against both Netatalk and vintage Apple servers; only speed optimization remains. daniel also noted NetBSD will soon be the only living OS shipping DDP in the kernel out of the box (though thecloud pointed out it's commented out on some arches like evbarm and needs a recompile).
  • Other userspace efforts mentioned: the Netatalk client, and dev1098's pointer to TailTalk (a Rust/Tokio async userspace AppleTalk stack), which dev1098 has used to share files Windows → Farallon iPrint → LC II. daniel noted TailTalk's author chose not to make it interoperable with Netatalk's C API.
  • A reminder from thecloud and daniel that AppleTalk is more than filesharing — games, chat, printer drivers, etc. all build on DDP.
  • Earlier in the week, CTB troubleshot a missing AFPServer on a netatalk 4.2.3 install; daniel's common fixes: add appletalk = yes to afp.conf and start atalkd before netatalk.
#vintage-programming
1Bit Fever Dreams released cozyMIDI v0.1, a standard MIDI file player for classic Macs (runs fairly well on a Plus, very well on an SE/30). It plays type 0 and type 1 MIDI files, pre-calculates timing to avoid real-time divisions in the playback loop, and uses lean CopyBits animations. It needs a synth MIDI module (recommended: vintage Roland Sound Canvas SC-55ST and up, or modern mt32-pi). They initially used the modem port due to a printer-port issue, later traced to mistaking the modem-in port address for the printer-out port. Source is on GitHub (view as raw to avoid classic Mac line-ending issues).
#self-promotion
Plenty of streams and videos this week:
  • Ron's Computer Videos: a Let's Chat with Karl Baron (Kalleboo) on GlobalTalk, a 1989 Apple Desktop Media VHS feature, and a Let's Chat oral history of TNT Amusements with Todd Tuckey.
  • Trina's Technobabble: multiple streams — laptop testing, motherboard recapping/desoldering, and a Lenovo ThinkBook 15 G4 teardown.
  • BigBadBiologist: a two-part saga reballing and (improperly, with hot air) reattaching an Intel 440BX northbridge on an Acorp 6BX86 Pentium II board.
  • 1Bit Fever Dreams: a full video on coding the cozyMIDI MIDI file player for the Mac Plus.
  • HardwareHacker / Lord Heincrad: Let's Play streams of Subnautica 2 and Ni No Kuni.
  • seatsafetyswitch: a new blog post on an Apple IIgs pickup and RAM expansion.
Links & Resources
This summary was generated by an LLM and may contain errors or omissions. Please check the original Discord conversations for full context and accuracy.
2,309
Discord — Weekly Summary (Week of July 12, 2026)
Another busy week across the server, with a standout deep-dive into getting Apple's A/UX UNIX running (and archived), continued progress on the SHORK 486 Linux distro, and plenty of hardware repair adventures. Here's the rundown.
Summary
#the-lab-software
Admiral Shark made major progress on SHORK 486, a Linux distro for 486/586-era PCs. Highlights this week: forward-porting all the 7.1.x kernel patches to the new 7.2-rc kernel, including restoring build targets for 586 (K5, Cyrix 5x86), AMD Élan, IDT Winchip, RDC R-321x, UMC U5x, Geode GX1 framebuffer,and x87 math emulation. He also traced a kernel panic on Pentium Pro / Pentium II OverDrive to the SEP (SYSENTER/SYSEXIT) syscall path — the Pentium Pro reports the SEP CPUID flag but doesn't actually support the instructions — and added a no-vdso32 build option to fall back to int 0x80. He got mpg321 compiled and running (roughly 90% smooth on an emulated DX4 with a 320Kb/s MP3) and forked terminal-mines into "SHORKMINES."
There was also discussion about ML/LLM-assisted conversion of silicon die photos to schematics, which led to sharing Giulio Zausa's MMO-CHIP multiplayer chip reverse-engineering tool. DosFox reiterated the standing call for help reverse-engineering the Macintosh II GLUE chip.
#the-lab-hardware
Xiang spent much of the week chasing a horizontal video ripple on a recapped Apple Lisa. Suspicion landed on non-low-ESR replacement caps on the 12V line feeding the horizontal drive; various bypass-cap and 7805-regulator fixes (per the Lisa FAQ and Adrian's earlier fix) were tried without fully resolving it.zigzagjoe and Garrett dug into why Sonnet Presto/Tokamac LC 040 accelerator cards work in some Color Classics but not others — Garrett's testing across four logic boards froze on extension load, and Bolle suggested the issue is Presto driver version (1.3.1 or 2.x rather than 3.1) plus removing VRAM SIMMs. A long thread on soaring DDR4/DDR5 RAM prices spun into a broader Linux-vs-Windows daily-driver discussion (Fedora KDE, CachyOS, Mint, GoG launcher woes on Linux).
#vintage-apple
The big story of the week: Sharpie and twvd getting A/UX 1.1 installed, verified, and archived. Sharpie owned the original media but suspected his hardware was faulty; twvd verified the disk images in the Snow emulator, worked out the full partition/sash/floppy-root install sequence, and confirmed everything was good. Sharpie then got it running on his real Mac II (discovering it defaults to single-user mode — fixed by editing inittab) andposted the complete A/UX 1.1 floppy install set to Macintosh Garden, bringing this rare early release back into circulation. thecloud got the preinstalled 1.1.1 ISO booting in Snow (using the Toby video card instead of the 8•24). A lengthy, informative side discussion covered A/UX's real-world niche in the late '80s/early '90s — lab/industrial NuBus integration, in-house corporate software, and Apple Workgroup Server / AppleSearch deployments.
Elsewhere: killvore researched G3 accelerators for a 6500 and the quirks of running an ATi PCI card on a 6200 PSU (no 3.3V rail); a username needed help recovering an iBook G3 after a bad setenv real-base Open Firmware edit; jakuoreality battled OS install failures on a PowerMac G4 with a 160GBIDE drive; killvore diagnosed a G4 Cube that needs a charged PRAM battery to boot; and killvore also got repair advice (bad solder joints / possible lightning strike) on a dead 12" RGB monitor's mains switch. gogogoluke and Azryael had a good exchange on Macintosh Portable data-bus troubleshooting that branched into DFIR career advice.
#self-promotion
twvd released Snow v1.5.0
, adding A/UX support (1.1 through 3.x), an emulated printer, new CD features, and floppy writeback — and published a companion write-up on installing A/UX 1.1. Ron's Computer Videos posted three "Let's Chat" interviews (Steven Lake / The Examined Game, Daniel Turner / Less Miserables, and Marcus Mera on Mystery House 3D). Jason Merrill teased a new video asking "Was the Macintosh Classic II Crummy?" seatsafetyswitch blogged about adapting a Fujitsu PC-9801 CRT monitor, and timw4mail released a new version of his Rustid CPU-ID utility. BigBadBiologist, Trina's Technobabble, HardwareHacker, and 1Bit Fever Dreams all promoted streams.
#the-lab-networking
daniel shared that the next Wireshark release will dissect two antique Apple packet types — MacIP (IPv4 over DDP) and the AFP 2.x ProDOS Info block — thanks to work with NJRoadfan. mbbrutman released a rewritten-in-x86-ASM DaynaPORT SCSI/Link packet driver for DOS ("smaller, faster and stronger"). daniel alsoannounced the inaugural 0.9.5 release of the Netatalk Client (a fork of afpfs-ng), aiming to be a cross-platform, full-featured AFP client, and a more-capable JavaScript engine build of MacSurf for Classic Mac OS.
Links & Resources
Streams & videos this week: Ron's Computer Videos "Let's Chat" episodes with Steven Lake, Daniel Turner / Less Miserables (site / College Fun Games), 65Scribe, and Marcus Mera / Mystery House 3D; Jason Merrill's "Was the Macintosh Classic II Crummy?" and I-Dog video; 1Bit Fever Dreams' Snow emulator review and cozyMIDI stream; BigBadBiologist's Sony PVM recap and Display Card8•24 GC / BlueSCSI-as-video-card stream; Trina's Technobabble motherboard/RAM testing streams (1, 2, 3) and shorts (power button, Supremetronic); and HardwareHacker's Let's Play streams (Ni No Kuni, Escapethe Backrooms, RV There Yet?); plus EricsEdge's dev blogs (Orient Star character, Peircean semiotics).
2,309
Discord Weekly Roundup — week ending 2 August 2026
#the-lab-software
SHORK 486
had a very productive week. Admiral Shark added a long list of software to the 486-and-Pentium Linux distro: dialog, Make, NASM, GNU Indent, CScope and Ctags, Lua, the Tilde editor, Vim, and dosfstools + e2fsprogs (bringing ext3/ext4 and FAT12/16 support — FAT12 being handy for floppies). Tworounds of BusyBox expansion enabled 33 and then 18 additional coreutils/commands.
A couple of interesting constraints came up along the way:
  • Adding Make pushed the default build past the original 80MiB target, which was based on the ~80MB drive in Admiral Shark's ThinkPad 700. That sparked anopen question about whether "default" should optimise for a well-rounded experience instead of period-accurate drive sizes, with the custom build configurator as the escape hatch for anyone on smaller media.
  • Vim turned out to be a RAM hog on 486-era memory when syntax highlighting kicks in — the kernel was killing the process on machines with ≤24MiB and no swap. The fix was a wrapper in /etc/profile that creates a swap file sized to system RAM (clamped 16–128MiB, at most half the root partition)when Vim launches, and deletes it afterwards.
  • Rust is off the table for an on-device toolchain for now — timw4mail noted the Rust compiler requires SSE2, likely an LLVM constraint, though cross-compiling for 486-level hardware does work. Go had a similar problem: GOARCH=386 produced a binary that still wanted MMX, prompting the observation that "386" has become shorthand for "32-bit x86" across a lot of modern projects.
Following a post on r/writerDeck, a new "writer" edition was added, and the minimal/maximal build names were simplified to Mini and Max, with the build type now reported in SHORKFETCH output to make bug reports easier to reproduce.
There was also an extended thread on using LLMs for ROM disassembly. Kai Robinson fed the Inside Macintosh volumes to Claude and worked through several iterations on a Macintosh SE ROM disassembly, building a consolidated 639-entry trap table and posting the annotated output. techknight shared prior experience reversing XC2018 FPGA bitstreams back into logic the same way, with the caveat that the output needs checking — it will produce convincing text that mixes up registers. bakkus picked up the thread and started building on jonathanschilling's existing mac_rom project, aiming for a reproducible/rebuildable annotated listing, while being upfront that it's an experiment. techknight's interest is in extracting Color QuickDraw from the SE/30 ROM for use on accelerated 68000 machines, which was clarified after a brief mix-up over which model was meant.
timw4mail also published rustid 1.6.0 with Mac model detection.
#the-lab-hardware
The headline project is DosFox's "IIxi" — an all-through-hole, no-SMD test bed that's essentially an SE/30 using only the GLUE and ASC from a donor board, with the goal of eventually replacing both with functional equivalents (DosFox wants to build them out of PALs rather than an FPGA). Boards were ordered, arrived, and parts are on order. There's no FPU socket on this revision, so A/UX is out for now; it'll run a Rominator II ROM (IIsi or IIfx). zigzagjoe suggested shoehorning in at least a partial PDS slot for debug purposes so a BlinkenPDS card could be attached. twvd floated emulating it in Snow.
DosFox also laid out an Apple II mouse interface card from scratch — and then discovered while browsing photos that Apple's original used the exact same MC68705P3S microcontroller DosFox already has on hand. An Apple II SilenType sync card followed.
A long thread on the LC III "Ariel" chip: techknight described a failure mode where the chip stops producing a pixel clock (wobbly video for a couple of seconds, then eventually nothing), and noted you get death chimes with it removed — which led max1zzz to wonder whether the Sonora has its own oscillator. mmu_man dug into a Sierra SC11412 datasheet and the ø1/ø2/ø3 signals going to Sonora and Egret, wondering whether they're a bus as well as clocks. LC III schematics don't appear to be in the big Apple Data Archive (only LC II).
max1zzz reported that GALs/PALs are getting scarce — PALCE26V12s were locally available last year and are now near-impossible, and GAL26CV12Bs have gone from ~£1 to ~£5. CPLDs were agreed to be the way forward. (A programmer compatibility gotcha also surfaced: it supported GAL26CV12 and PALCE26V12 but not GAL26V12.)
The channel's cautionary tale of the week: zigzagjoe found an LLM-generated Sony CR-45 PSU "technical reference" being sold on Amazon/Kindle, apparently built by feeding Bomarc schematics, photos and measurements into a model with no disclosure of AI use. The consensus was that this is genuinely dangerous given the lethal voltages involved, and that "pretty close" isn't good enough for a power supply. zigzagjoe left an Amazon review; the author later pulled both the Reddit post and the book.
Also: elemenoh flagged Metcal's new MicroFine handpieces (12 grams, tips down to 0.1mm), and there was a good-natured tangent about using overpowered microcontrollers to replace a handful of logic gates — with seatsafetyswitch noting a sub-$1 PY32 came out cheaper than a 555 and some gates.
#vintage-apple
Busiest channel by far. Highlights:
Linux 7.2 booting on a Mac Plus. BicLighterEnthusiast returned to the server and got past a blocker that had stopped them last October — userspace now works, having previously crashed loading init. Next steps are a busybox build and a tty driver so there's a shell, then eventually a framebuffer tty so a separate terminal on the modem port isn't needed. An initial report of a STOP instruction bug in Snow was retracted — it had already been fixed, just an out-of-date build. bakkus got it partly running too, up until a kernel panic. Related: a SWIM floppy driver has landed in mainline Linux, and zigzagjoe's 68060-on-Mac patches were committed to NetBSD along with an ADB fix for the Q650/800 at higher clock speeds.
G4 Cube week. thecloud traced a non-booting Cube through the known failure modes — the 25-year-old battery still measured 3.66V, the touch sensor looked frazzled, but the culprit turned out to be the PSU putting out around 1V instead of 28V. The touch sensor "scotch tape with a small hole" fix was discussed for over-sensitive sensors (the isolating gasket dries out), and killvore shared the modern TDK Lambda DTM-series PSU they used as a drop-in replacement. Separately, Xodium fought a Cube that lost video entirely on ADC monitors when switching to 640×480 — isolated to the Nvidia extensions, with VGA completely stable — and repaired a failed optical drive that was hanging the whole IDE bus, reviving the rubber rollers with a dab of superglue.
Extended Mac OS 9 install troubleshooting. Ryker46859 worked through a long chain of issues on a beige Power Mac G3 with thecloud, bakkus and ptricky helping: a corrupt "Open Transport ASLM Modules" extension blocking the installer, a CD that wouldn't boot, and finally a working reinstall after initialising the drive from Drive Setup on a bootable CD. The MacSurf issue at the end turned out to be an application memory allocation setting. A side discussion on CD burn speeds produced mixed evidence — several people have had discs that only read correctly when burned slowly, while thecloud pointed out that bootability is a function of how the image was mastered, not burn speed.
twvd reverse-engineered the extended POST on the Quadra 700 and posted the full table of test codes ($80–$9B) mapped to the ROM's string literals, covering everything from the mapper RAM tests through SCSI, sound, PRAM, FPU, parity, the ADB microcontroller and the SONIC Ethernet tests. nulleric suggested putting it on TD so it gets indexed and found.
A long Mac mini 2011 dGPU investigation. MParaGames bought a macmini5,2 with a failing Radeon and wanted to know whether the Intel iGPU could be used instead. ptricky and Loafin worked through it: both display ports are wired to the Radeon, so blacklisting the driver just gets you an unaccelerated framebuffer on the same port rather than switching to the iGPU. The mux hardware that makes GfxMode=4 work on MacBooks relies on the internal panel being on the Intel side, which a mini doesn't have. Both GPUs showing in fastfetch just means both are on the PCI bus. The machine arrived at the end of the week and only shows an image under Linux.
Other bits: This Does Not Compute has a Sony MPF-52a manual-inject drive that always thinks an 800k disk is inserted and locked despite all three microswitches testing fine — BigBadBiologist posted comparison photos of the underside of a known-good drive to check for a missing pull-up. Sharpie got a newly acquired Apple /// running after blown RIFAs (with three more on the bench), then had a floppy scare that turned out to be a magnet-damaged disk — which led to the story of Apple's official "lift the front of the machine 3–5 inches and drop it" chip-reseating advice. Xiang is hunting for a period-appropriate SCSI-to-Ethernet adapter for a Lisa. killvore recovered a Norwegian keyboard layout by pulling the KCHR resource out of a System 6.0.7 image with ResEdit, and is planning an ATX PSU conversion for a Power Mac 6200 to get 3.3V for Alchemy-style boards. Oelmuvun found an AEK II underwhelming compared to Model F/M boards, which turned into a discussion of the various Alps switch variants and the general disdain for the AppleDesign keyboard. Clarus the Dogcow turned up on the front page of apple.com. And techknight noted the RTC rollover ahead — 2040 for 68k/classic, 2038 for PowerPC/OS X.
#the-lab-networking
daniel shared the ambition behind current Netatalk work: making AFP the best and fastest way to transfer and browse remote files generally, not just for old Macs — with classic Macs remaining a first-class citizen. DosFox is hunting for the original Kinetics Fastpath manager (not Fastpath II, which is on MacGUI) for a KFPS-1, and may well own the only one documented online — it has a 220V PSU, so it was clearly destined for the European market.
1Bit Fever Dreams described a Python memory-mapping tool built for the Wildbits/K2 project: four banks of 512kB SRAM viewed through the 6502's 64kB window,with an FPGA graphics side that can fetch from anywhere and 6502 code that very much cares. The tool spawns objects with defined sizes and start addresses, slides them around 2kB cells, gives an exploded view for cells holding multiple small objects, compacts them, and exports embedding instructions for a C source file.
#self-promotion
A busy week of streams and videos — see the links section below. Notable: Ron's Computer Videos published the first two batches of edited KansasFest 2026 sessions plus the virtual event schedule; Mac84 released a Macintosh SCSI basics guide; seatsafetyswitch started a blog series on the BBC Bridge Companion; This Does Not Compute did a live Macintosh Classic repair; timw4mail shipped rustid 1.7.0 with RISC-V support on Linux; and BigBadBiologist documented thatmoving resistors under a Kingston TurboChip 486 upgrade (R10 → R8) measurably improves L1 cache performance.
Links & Resources
Projects, code & documentation
Reference material & datasheets
Tools, parts & shopping
Articles, posts & discussion
Videos & streams
2,309
Weekly Discord Summary — Week Ending 10 August 2026​
Summary
#the-lab-hardware
The busiest channel this week, kicking off with a deep dive into Apple eMate 300 battery packs. mmu_man tracked down what appears to be the correct Molex 2mm-pitch 5-position connector on DigiKey (plus the mating part), with MrTechGadget confirming the pin spacing with calipers against his own rebuilt pack. MrTechGadget noted he rebuilt his using flat NiMH AA cells transferred into the original harness, and that the eMate will charge and run fine on 5V. mmu_man cautioned that the charging circuit likely relies on the PSU current limit (as on the MessagePad 2000 and most PowerBooks), so a high-current power bank isn't a free substitute. Discussion moved on to characterising the thermistor and PTC, and to the blue rubber LCD grommets — techknight noted his are liquefying and that equivalents are likely still made, just with unknown dimensions. Several people (This Does Not Compute, Mark Benson, DosFox) have eMates but long since ditched the batteries, and there was hope that someone could turn this into a reasonably priced replacement pack product. One linked refurb guide showed a standard AA holder won't fit without cutting into the shell.
Turbo 601 / IIci projects: zigzagjoe showed off a 3D-printed mid-fan bracket and air guide for the Mac IIci (file shared in-channel, more detail in the 68kmla worklog). His machine is a IIci running a Turbo 601 upgraded to 120MHz with 1MB cache, one of max1zzz's Radius Rocket clones, a GrandVimage AV and a MacCon — three switchable CPUs in one box. He reports 601s are very cranky at 120MHz (over ~50°C on the heatsink means a crash, hence why they shipped with peltiers), and that networking with the Rocket under 7.5+ appears limited to LocalTalk. On the Turbo601 internals: it's essentially the 040 PDS 601 card grafted onto the remains of a Turbo 040 — a PPC→68040 bridge on top of a 68040→68030 bridge — with a 64-bit wide L2 cache (256K shipped, 1MB possible) and new PPC ROMs onboard. Reverse-engineering potential is low thanks to the Apple/ARM ASIC, locked MACH and Daystar ASIC, though Bolle is reportedly toning it out (currently on holiday in a truck somewhere in France). Kai Robinson revealed he has 90 brand-new PPC601s still in trays and would love to see someone do something fun with them.
Kai Robinson's controllerless LCD terminal: Kai found a pair of unused 400x160 LCDs with no controller — six KS0086 COG drivers, no framebuffer or refresh logic — and worked up a design for an all-discrete-logic display controller driving them, feeding a 65C816 + 65C22 VIA + 65C51 serial terminal along VT220 lines. Bit-banging the VIAs comes in ~2.5x over the per-row timing budget, so the design uses a free-running 74HC counter chain (about 11 chips plus oscillator) reading a framebuffer independently of the CPU. Goal is all through-hole for fun, with an SST39 series parallel NOR flash in a PLCC socket for storage. techknight suggested a cheap FPGA devboard would be easier but applauded the discrete-logic approach.
Elsewhere: max1zzz discovered his troublesome IIfx Reloaded board works fine — it just doesn't like his repro RAM in that particular board (shims got it booting). Azryael traced a RAM error on a Mark 12 Piano/Organ board to shorting pins and got it working. elemenoh showed before/after shots of a recapped NeXT MO drive motor board (tiny caps, big leaks). Stinkerton18 tested 10 AliExpress EEPROMs (AT28C16 and SST27SF512) with a read/blank/verify/reflash cycle and found only one dud, though none were actually new as listed. This Does Not Compute asked for pricing advice on selling a spare SE/30 Reloaded board as a DIY kit with spare parts and a donor board, possibly via a friend at VCFMW. And killvore is building the ATX Q630 adapter, hitting an outdated BOM — Mark Benson explained the -12V rail is for the audio circuit (works fine fed straight off the ATX connector, but it runs down the ribbon cable with the soft-power signal, not the main harness).
#vintage-apple
A long-running thread from MParaGames on getting Linux running with a GUI on a 2011 Mac mini with a dead Radeon dGPU. Blacklisting radeon/amdgpu got TTY output working, but KDE Plasma wouldn't start; radeon.modeset=0, EFI variables and vgaswitcheroo all came up short. Eventually an X11 session came up but only under software rendering, because the Intel driver never loads. The likely culprit found late in the week: Apple hides the Intel IGD unless the OS identifies itself as macOS, which the apple_set_os.efi tool works around — loading it via GRUB hasn't fixed it yet (that tool targets the MacBook Pro 11,3). MParaGames also posted a thread on TinkerDifferent's Intel-based Macs forum. Related discussion: max1zzz noted the 2011 Radeon GPUs genuinely go bad, and that both baking and reballing only buy time; Azryael went the route of swapping in a 2012 board instead.
Q950 / Q900 fever: Sharpie showed off a newly acquired Quadra 950 (~$400-450, overclocked to 40MHz with a BlueSCSI) alongside the correct IIgs monitor, prompting a chorus of "one day". Loafin has a free Q950 board with no PSU or case, and jockelill — who built the RGB 900 project — offered one of the ATX adapters he's made for the Q900/950 for shipping plus something symbolic. jockelill also mentioned that NuBus is useless in his RGB 900 build, requiring a custom riser, and that he made a combined BlueSCSI/ATX adapter and a port cover. DosFox found a Quadra 900 with a PowerPC card on Facebook Marketplace for £100 and has moved the PPC card into a Quadra 700.
Other threads: Loafin has a IIgs monitor with a dim/dead blue channel — seatsafetyswitch suggested a bad solder joint on the neck or a bad cap in that path, and warned against a shotgun recap before the fault is actually located. daniel asked about booting an SE/30 from CD-ROM (twvd noted the stock ROM can't; the issue may lie in PiSCSI code being debugged). A tangent on 720KB floppies on Macs concluded there was no native Mac 720K format, though SuperDrive models can read them — twvd noted writing to them can be unreliable long-term due to the 600rpm rotational speed. campbellashe blew a PMGR chip on a Macintosh Portable while experimenting with powering an LCD replacement off the floppy port and is hunting for a donor. Oelmuvun finally removed the fan grille fighting the Noctua fan in a 6500 PSU. Several members (Loafin, Sharpie, danifunker, zigzagjoe, ptricky) are planning to be at VCFMW, with tables and trades in the mix.
#self-promotion
A busy week for creators. seatsafetyswitch posted part two of the BBC Bridge Companion saga, with real hardware, a mangled cartridge slot and a homebrew cartridge design. ptricky released a video on whether Retro68 can build MacSurf — the takeaway being Retro68 is great for smaller projects but CodeWarrior remains the better bet for complex ones, with the appeal of Retro68 being modern C/C++ and working directly on Linux. That led to a side conversation with mmu_man (who originally ported NetSurf to BeOS) about upstreaming and C89/C99 portability issues. 1Bit Fever Dreams published a barebones C game project tutorial for the Wildbits/K2 and a video on MIDI playback for Mac C projects. BigBadBiologist shared a short on using Meguiar's PlastX and a car buffer to restore an iBook G3 dual USB, and streamed another attempt at repairing a rare Macintosh Display Card 8•24 GC — this time with a way to test the SOIC logic chips, another AM29000 from a PET scanner board, and the unobtanium cache chips located by Jack68k. Ron's Computer Videos posted interviews with Joe Redifer of Game Sack and Gary Winnick (LucasArts / Maniac Mansion), plus the complete Virtual KansasFest 2026 playlist. Trina's Technobabble streamed an LGA 1151 build and a motherboard testing session. mmu_man streamed an ORIC Atmos diagnosis and noted RRR is back with a two-part summer update. RToD posted a tell-all on the cease and desist letter received over AIM Yahoo.
#the-lab-software
ptricky asked the room which classic Mac OS versions people are actually using, to help pick a next project — the rough consensus being most here are on 7 through 9, though Loafin would like more for stock 128k and original Apple ][ machines. fogWraith teased a Hotline protocol project with some protocol extension work, close to public beta. bakkus asked whether there are other sources of genuine Apple source code for Macintosh stuff beyond the SuperMarioProj repo and the Computer History Museum's MacPaint/QuickDraw release — nulleric pointed at the apple-oss-distributions/xnu repo, which contains some ancient NeXT-era material, and MkLinux got a mention. Admiral Shark released SHORKBIN, an ASCII text/8-bit binary converter modelled on Coreutils tools like base32 (accepts a filepath or stdin, symlinks bin2text and text2bin on install) — with a follow-up admission that sharutils/uudecode already existed. timw4mail's Rustid CPU identification utility crossed the DOS 64k barrier thanks to dos32a, with 1.8.0 consolidating into one main DOS binary with argument support.
1Bit Fever Dreams continued work on the 1bit dream machine, building an easy-to-use library pack for MIDI playback in Mac C projects: two ways to embed, one prep function, one loop function, end-of-playback detection, works on real hardware, and can rewind and replay. Loading from a .mid in the application folder and from an embedded 'smf ' resource are both done. Demos followed of a MIDI file dispatched to the Macintosh Sound Driver's four-tone synth — described as "the most cursed Mac thing you've heard all day" — including a sawtooth version of 'human2' from Warcraft 1. kat! is hunting for the Macro Assembler for the Data General NOVA (specifically NOVA 4), or any Linux cross-assembler for it — still no luck, so pointers welcome.
Links & Resources
2,309
Weekly Discord Recap — Week of August 24–30, 2026​
Summary
#the-lab-software
Admiral Shark had a very productive week on SHORK 486. Linux 7.2 landed and is working, with Public Test 1 targeted for the end of the week. Highlights: cfdisk and util-linux sorted out (replacing BusyBox's fdisk), network and sound drivers moved from baked-in kernel options to loadable modules (all current modules fit on a 720KB floppy), and a GUI driver manager in SHORKSET. A new SHORK 486 Micro build option targets systems with just 7MiB RAM and a ~4MiB disk. GnuPG, pinentry, Ncdu and memtester were all compiled in — GnuPG needed a custom software floating-point static library derived from LLVM/compiler-rt to work on an FPU-less 486SX. A kernel patch also restores ISA and PCMCIA ARCnet drivers. Admiral Shark also put out a call for /proc/cpuinfo dumps from PPC Macs running Linux 5.x or newer to improve SHORKFETCH's POWER/PPC CPU name parsing.
timw4mail released Rustid 1.9.0 (adding EFI/UEFI binaries, 32- and 64-bit) and then 2.0.0, a big accuracy-focused release especially for non-x86 architectures. They also hit a snag booting SHORK 486 on an SiS 530 machine and an XT-IDE system — root defaults to /dev/sda1, and missing chipset drivers are the likely culprit.
techknight has been building a weather/radar app for System 7, using QuickDraw palette 8x8 chunks for radar mosaic data — the result looks charmingly like a newspaper weather map.
fogWraith wrestled with Retro68 "out of memory"/"address error" issues on System 6 (since fixed), and asked about efficient chat history storage on low-end machines; 1Bit Fever Dreams suggested splitting log files by day/month/year.
#the-lab-hardware
The big story: DosFox got the OSHintosh IIxi booting to the desktop. The saga ran all week — first chimes and death chimes, then no video (traced to both replacement VRAM chips being wired to data lines 24–27 instead of one set to 28–31, spotted by Mark Benson), then a long RAM debugging hunt. The eventual fix was swapping a 74LS240 for a 74F240, plus sorting out RAS A/Bank B wiring and some bad connections. ADB input is still not working as of the end of the week. DosFox also showed off some replica (or possibly original) Twiggy PCBs.
The RadioThermal open-source Metcal-compatible induction soldering station got a lot of attention. elemenoh has been testing one and reports it's excellent — 100W in a tiny footprint, with the PSU BOM around $37 in parts, probably $100–150 all in versus ~$750 for a new MX-500. Xodium has been testing one for the developers and found it far better than a Hakko T12 knockoff.
A long solder thread concluded that name-brand from a trusted supplier is what matters — Kester, Duratool from CPC/Farnell, Henkel Multicore — and that cheap Amazon/eBay rolls are frequently unusable.
techknight found that M.2 SATA and mSATA adapters don't work in a PowerBook 1400c, which spun into a broader discussion about the shortage of storage options for early Apple IDE machines: CF is hit or miss, the Si3112 chipset PCI SATA cards are drying up, and FPGA alternatives are expensive. Several people are hoping for a "PicoIDE lite" aimed at 2.5"/laptop use — bakkus notes PicoIDE is open source so a laptop remix is plausible, and that the notorious 630 has been made to work. Oelmuvun shared PicoIDE's August production update: no ETA, but production is about to start.
Other bits: techknight declared a Mac Portable board beyond economical repair (at least a dozen open connections), which prompted talk about the reverse-engineered Portable schematics project and max1zzz revealing they're working on something in that space. mmu_man designed a 3D-printable jig for cutting silicone trackball roller tubing to 3mm. max1zzz offered to take a look at Kai Robinson's Lenovo E15 Gen 4 that only charges at 5V.
#vintage-apple
PowerVLC
was the find of the week — DosFox pointed Loafin at it for streaming Jellyfin to a 1GHz iMac G4, and it works, though transcoding is limited to h264 and needs the bitrate dialled down to about 1 to play smoothly. Direct MPEG-2 streaming works without issue.
Loafin ran a Sorbet Leopard vs. Shuriken (10.4) comparison on a 1.67GHz PowerBook G4 using Cinebench. Verdict: Shuriken is only barely faster in Cinebench, and Sorbet even scored higher on OpenGL after a cold boot. Tiger feels a bit more zippy overall and drops marginally fewer frames in video, but the gap is small.
Xodium created a Boot Camp Support Software page on Macintosh Garden after finding old versions nearly impossible to source from Apple — currently 3.1, with more to be added. Modern Boot Camp versions apparently do a server-side check and refuse to install on older Macs.
kefkafloyd identified a mystery "blank" serial number on Kiru The Puppy's board as the result of a service board swap where the serializer utility was never run, and pointed to the Blank Board Serializer tool (note: it only works once, so get the serial right).
nulleric released What The SIT! v2, an in-browser tool for unwrapping the layered `.img.cpt.sit.bin.hqx` archives common in vintage Mac preservation.
Kadmus is looking for quieter cooling for a GeForce 3 Ti in a G4 Cube; suggestions included oiling the existing fan bearings, transplanting a Noctua by clipping its frame legs, and mitchkramez's 3D-printed VGA cooler fan mount. killvore got a Meanwell conversion working for a Quadra 610-style PSU (fan still to sort out) and is working on an ATX-to-LC630 adapter PCB. Trina's Technobabble asked about diode ratings for the Mac Plus SCSI term power mod — 50V 6A is fine, and a 1N4001/1N4004 will do the job.
ptricky is archiving old Mac forums (68kMLA, MACNN PPCMLA, Mac OS 9 Lives, AppleNova) and is looking for suggestions of others worth preserving.
DW released Generic Block Game 2.0 for 68K Macintosh, with the full C source, CodeWarrior PRO 4 project, resource file and libraries now available on Demozoo. It runs on an LC475, Color Classic Mystic and Basilisk II.
techknight spent an evening fighting the Rez/DeRez workflow, trying to get a `.r` file into something ResEdit could edit. Andy provided a copy of SARez (Standalone Rez, from THINK C 5) and walked through the settings, but the conversion didn't take — techknight ended up rebuilding the dialog from scratch in ResEdit, which Andy agreed was probably the better path anyway. Along the way: DeRez in MPW isn't directly runnable (ToolServer is the usual route), Macintosh Garden's search mixing forum results with software results is a persistent annoyance, and downloaded disk images frequently arrive with broken resource forks.
phlogios got two OS 9 Macs talking via OpenTransport with hand-written C++ packet code, and separately got printing working from Mac OS 9 to a modern Canon printer via CUPS and netatalk on a Fedora server. They also started a Classic Mac Game Dev community on Fluxer.
#the-lab-networking
daniel has the bleeding-edge Netatalk Client connecting to Mac OS 9 file sharing over AFP, and is looking for testers on the PR. There's an open question about when Apple first introduced personal file sharing over TCP/IP — Wikipedia says Mac OS 8.0 for native AFP over IP, but 7.6 is worth checking. Separately, netatalk is getting low-level optimizations to the AppleTalk (ASP) transport layer, bringing it in line with work done on DSI back in February; real-world testing is welcome, though don't expect big throughput gains since AppleTalk is bottlenecked elsewhere.
A cautionary tale from Kai Robinson: an in-place Windows Server 2019 → 2025 upgrade left ReFS v3.4 volumes (hosting all the VMs and Veeam backups) unmountable, since 2025 requires v3.7 minimum and wouldn't upgrade them. The workaround that saved the data was `refsutil salvage -QS <drive>: C:\work C:\data -x`, which forces a dismount and upgrades the volume to v3.14 as a side effect.
max1zzz asked about multimode fiber cleaving consistently coming out at 5–7 degrees (enough for the splicer to complain), even with a fresh blade — singlemode is fine. No resolution yet.
#self-promotion
Ron's Computer Videos celebrated 20 years on YouTube (August 21st, 2006) and ran a full Maniac Mansion week, capped with an interview with LucasFilm Games programmer and JSON discoverer Douglas Crockford. seatsafetyswitch wrapped up the BBC Bridge Companion saga with a composite video mod and a Z80 Tetris clone. 1Bit Fever Dreams shipped cozyMIDI v0.9 (and danifunker used cozyMIDI to get MIDI over SCC working on the Mac LC MiSTer FPGA core). mmu_man fixed an ORIC Atmos (two bad RAM chips) and a Minitel keyboard on stream. Admiral Shark wrote a tribute article for the 45th birthday of the IBM PC and Model F/XT keyboard. Jason Merrill covered the LisaFPGA. Xodium published a printable G4 Cube PSU stand. Audio arrived for the PicoMicroMac via a v3 refit kit from jcm-1.
Links & Resources
Software & Projects
Hardware
Videos & Streams
Articles & Posts
2,309
Weekly Discord Roundup — Week Ending September 5, 2026
Summary
#the-lab-software
techknight
continued work on Peekie/WeatherBar 7, a weather menu bar extension for classic Mac OS. The menu bar item stubbornly refuses to sit left of SuperClock even after cloning SuperClock's slot-search method. Techknight explained the architecture: a foreground app with Apple Events and networking access, a control panel INIT that installs the menu bar item, and a shared globals blob in the system heap reachable via a Gestalt selector. SuperClock isn't a real menu, it's patched in via traps, which is why it doesn't invert when clicked.
A real bug got found and fixed in public: techknight hit stale files when using BlueSCSI SD Transfer under Snow on Windows — overwriting a file on the host kept pulling the old copy. nulleric and twvd traced it to Snow keeping the shared file open for reading, nulleric submitted a fix (Snow PR #366), twvd posted a Windows build, and techknight confirmed it working within minutes.
Snow networking limits also came up: there's no bridge support on Windows or macOS (Linux only), and the NAT setup is limited, so AppleTalk and general TCP services don't work there. Raw networking on Windows would need WinPcap or similar. techknight also hit a checkerboard-screen bug on the emulated Toby card at certain color depths; switching to the Display Card 8•24 worked around it.
Admiral Shark had a strong week on SHORK: Linux 7.3-rc1 patches applied nearly cleanly (mostly function renames like `static_cpu_has` → `_static_cpu_has`), DOS emulation via dosemu2 started working on SHORK 486 (RAM-hungry, sound looks painful), and SHORKSET gained a Network menu with an interface up/down toggle that runs ifconfig and udhcpc automatically. Stinkerton18 suggested domain suffix appending, manual IP/gateway/subnet config, and custom routes for the todo list.
A long thread on resource forks: daniel noted macOS still carries them in APFS via xattr with a special offset for large forks, and warned much of the AFP support is going away with the upcoming macOS Golden Gate release — he has Netatalk Client plus macFUSE lined up as a partial replacement, usable on Sonoma today.
timw4mail released rustid 2.1.0 with Windows GUI binaries including Windows 9x support.
#the-lab-hardware
DosFox
got the OSHintosh IIxi working — a through-hole Macintosh II, after a pile of bodges, a PLCC-to-DIP adapter, and VIA replacements (three Apple ICs remain, and the ADB PIC still isn't happy). Useful finding for SE/30 and SE Reloaded builders: R65C22P2s boot but break ADB, likely because the E clock's positive pulse is ~250ns (2MHz-ish) even though the overall signal is ~700kHz. W65C22N6 parts work fine; the S (CMOS) variants may need diodes.
max1zzz finished routing the through-hole version of ITXPlus, an ITX-sized Mac Plus clone. DRC passes; only silkscreen and tidying left. Fully through-hole didn't work out — the passives had to stay SMT. Previous SMT run pricing was roughly £45 bare PCB, £100 kit, £120 assembled, with gerbers going up on GitHub.
Froggy814 iterated on a Macintosh Portable battery-bay power supply supporting up to 15A input, using TI TPS566242 buck regulators for 6.3V, 5V and 3.3V. Androda and DosFox pushed back on output capacitance, and techknight covered ceramic derating, TI's WEBENCH tool, small hot loops, and ground planes under switching sections.
#vintage-apple
Sharpie
got an Apple /// ProFile hard drive running and found data dating back to 1983, sharing two imaging passes as .po files for anyone wanting to poke at an original Catalyst-enabled ProFile image.
daniel confirmed he's taken over PiSCSI development from akuker. Notable changes: piscsi-web can now create and format HFS volumes using the open-source MiniSCSI driver instead of proprietary driver dumps, Netatalk installs from a binary deb rather than building from source, and all PiSCSI binaries now ship as debs — no more four-hour compiles. He also explained the atalkd startup dance: stop netatalk, restart atalkd, then start netatalk, because atalkd must be fully up to receive the service registration.
nulleric shared the BlueSCSI milestones page and noted NeXT toolbox apps are likely next after the front panel work wraps. The front panel is shared with polpo's open-retro-storage-frontpanel project, and there's interest in a cheap ESP32-C3 web-interface-only build for tucking inside a PowerBook. daniel's take on the comparison: BlueSCSI v2 is the default choice for most people (faster, instant boot, no OS overhead), while PiSCSI is more of a tinkerable appliance.
Kiru The Puppy fought a Rev 1 Power Mac G3 B&W (known-bad ATA controller) through a destroyed OS 9 install and two dead drives, then attempted the glowing Apple logo mod on a PowerBook G3 PDQ. First attempt left a large dark square on the LCD; the fix was cutting the plastic bar and adding backing film salvaged from a 2009 MacBook screen. Careful cutting of the LCD back appears to avoid the artifacts entirely.
Loafin and kat! compared notes on recelling PowerBook batteries — spot welding is reportedly the easy part, getting the epoxied case back together without warping is not. Sharpie walked Loafin through ADTPro requirements (null modem cable, Super Serial card) and suggested ASCII Express as an alternative that loads over the cassette port.
DosFox lost an Apple 1200 modem to an eBay "item has been liquidated" notice, prompting discussion of the ongoing 68kMLA thread about eBay shipping and destroyed vintage items.
bakkus found Apple's old hardware technotes still live on developer.apple.com despite the parent pages 404ing; seatsafetyswitch pointed to an Internet Archive collection and bakkus found the MacOS7Corpus database on Macintosh Garden.
phlogios
worked through splitting a CodeWarrior project into a library target (solved by starting from the Library template instead), and is looking at exposing the network layer of a game engine as a shared library so others can skip the server/client boilerplate. Later, a detailed writeup of PowerPlant's footguns: wiring a button click requires manually setting a non-zero button ID, `RegisterClass_(LButton)`, deriving from Listener, and calling `LinkListenerToControls` with an `rRidL` constant you're expected to just know (128 for the default window). It silently fails if the ID is left at zero. Verdict: "There is no hassle-free UI for Mac OS 9."
#self-promotion
§wordfish
announced a stream for the 30th anniversary of Avara, the low-poly Mac shareware FPS, featuring creator Juri Munkki as guest. Trina's Technobabble streamed Mac Plus board testing and 486 cache chip work, BigBadBiologist took on an LCIII someone drilled through, Bruce (Branchus) recapped a Classic II, and Ron's Computer Videos posted interviews with AdventureX co-director Tom Hardwidge and Beekeeper's Picnic creator Helen Greetham. 1Bit Fever Dreams showed off muFTP, an FTP client in C for the Wildbits/K2 6502/65816 machines.
Links & Resources
Reactions: Kai Robinson
2,309
Weekly Discord Roundup: September 7–14, 2026
Summary
#the-lab-software
  • Admiral Shark kept adding software to SHORK 486. New this week are jq, which by their count is the 40th bundled package, and gpm for console mouse support, shown working alongside the Tilde editor. A Ukrainian DIY YouTuber also made a video about SHORK 486. After watching it, Admiral Shark opened an issue to work on the problems it showed: adding GNU Midnight Commander, fixing websites that think Lynx is out of date, a missing dependency for scp, slow g++ and better locale support. Midnight Commander is already running with gpm mouse support, FTP and SFTP.
  • Tanner got RuneScape running on a 68040 Mac with 23MB of RAM and a 40MHz CPU, connected to a local server. It needed Open Transport support. They called it "a silly experiment" but a successful one.
  • timw4mail released rustid v2.2.0, a CPU ID utility. This release adds a Linux GTK GUI with AppImage packaging and a native Haiku GUI.
  • mitchkramez showed a browser-based tool for making capacitor maps. It stores data in localStorage and can export backups. seatsafetyswitch suggested reading cap values from a top-down photo of the board to generate a map and a DigiKey BOM. mitchkramez noted that on the power supplies they usually work on, the caps are hidden by wires.
  • fogWraith asked whether anyone has worked with large lists in System 6, since they keep running into its limits.
  • Froggy814 shared progress on their personal site and challenged people to find the hidden game.
#the-lab-hardware
  • DosFox's Mac project drew congratulations. Their next step is removing the four Apple-specific ICs, and Kai Robinson said a reproduction GLUE or SWIM would be immense. Later in the week DosFox found that a ROM adapter wasn't working because a pin was missing, and asked if anyone has a dump of the ROMinator ROM.
  • saybur got an RP2350B working on NuBus. Reads and writes to the card are minimally functional and it shows up in MacsBug, but there's a lot left before full bring-up.
  • mmu_man had a recapped PowerBook 5xx PSU pop. When techknight asked how to open a PB500 charger without destroying it, mmu_man pointed to their video on opening plastic-welded cases.
  • Kai Robinson swapped the 25,000 RPM PSU fan in a Synology RS3617xs+ for a much quieter Delta fan. The NAS then thermally shut down, so Kai is looking at a middle-ground fan instead.
  • mmu_man also asked why KiCad has no 3D models for single pogo pins.
#vintage-apple
  • Kiru The Puppy asked about getting USB, FireWire and optical drives working on a PowerBook G3. Oelmuvun suggested CardBus cards or networking. nulleric shared yyzkevin's PicoPCMCIA, a Pico-based PC Card that does Wi-Fi and SD storage, shown in a demo getting a PowerBook 5300c onto a WPA2 network. Kai explained that CardBus is basically PCI and PCMCIA is basically legacy ISA.
  • Kiru also shared a set of wallpapers from a Mac OS 9.2.1 internal edition CD. Oelmuvun pointed out that many of them shipped on the 9.1 retail CD.
  • unlawfulsoup got a BlueSCSI working externally on a PowerBook 170 and plans to check traces on an internal unit they damaged while opening it. They and Sharpie traded notes on the 100 series, which are easy to work on compared to the 2400c, 1400 and friends. Alphabitz asked about "tunnel vision" on 170/180 screens, and Kai said nearly all those panels are affected and baking is really the only viable fix.
  • Loafin found what looks like a burned (possibly LightScribe) Mac OS X Tiger replacement DVD dated 2005. Others guessed it could have come from Apple Stores, and Xodium recalled that Genius Bars usually used LaCie drives with install images.
  • StarDumb dumped a Heisei Tensai Bakabon After Dark screensaver pack they hadn't seen online anywhere. It's now on Macintosh Repository and Macintosh Garden, and a VGA capture from real hardware is planned.
  • ShadeDream asked about replacing the soldered batteries on a newly acquired IIfx. Sharpie recommended CR2032s, or new leaded batteries from DigiKey for a stock look. ShadeDream also asked for DIP switch settings for a RasterOps 224 video card but hadn't found them on Bitsavers.
  • The group also discussed MacTCP and System 6.0.8 networking. Oelmuvun described the confusion caused by leftover DaynaPORT drivers after installing an Ethernet card.
  • Kai Robinson may be getting an out-of-support Intel Mac Pro for free, since it's being replaced by a Mac Studio, and noted how many recent Intel Macs are headed for e-waste. Sharpie described their Mac Pro (16-core Xeon, Vega II Duo, 384GB RAM), which still runs Sequoia. Kai said every Intel machine he's seen has struggled on Tahoe.
  • dev1098 asked for advice on a dead dual G5 (A1047) that only clicks when plugged in, and timw4mail confirmed the PSU is a chore to remove.
  • Cassette-Chan showed an SE/30 running as a MOD jukebox.
#the-lab-networking
  • nulleric shared a write-up about factoring the RSA keys of a 1990s certificate authority, which lets you sign your own SSL certs for 90s browsers. techknight compared the 862-bit key to the 768-bit keys used by older Nagravision.
#self-promotion
  • seatsafetyswitch published a blog post on embedding a bitmap font in a HyperCard stack.
  • mmu_man streamed testing a Thomson MO5, which turned out to need only one transistor on the power input.
  • BigBadBiologist streamed an attempt to save a Macintosh LC network card that a scrapper had drilled through.
  • Trina's Technobabble streamed a chat about the World of Retro Computing event in Waterloo, ON (September 12–13) and a "2 Girls 3 Boards" motherboard repair session.
  • Jason Merrill premiered a video on whether the 2013 Mac Pro was crummy.
  • HardwareHacker / Lord Heincrad continued Let's Play streams of Ni No Kuni and Halo Reach co-op.
  • Hackaday covered DosFox's open source hardware Mac and, separately, another community member's attempt to fix a suspiciously cheap enterprise network switch.
  • Kai Robinson pointed §wordfish to the TinkerDifferent Software & Operating Systems forum for sharing a project.
Links & Resources
Reactions: bakkus
2,309
Weekly Discord Roundup — September 15-20, 2026
Summary
#the-lab-software
Admiral Shark had a busy week on SHORK 486. The build configurator will soon offer to create a separate boot partition when you specify a disk over 504MiB, guarding against 1024-cylinder problems. A new "Terminal" build edition also landed, trimmed down to remote session, file transfer and supporting utilities, aimed at turning an internet-connected machine into an SSH or TN5250 terminal. It still ships a BusyBox config plus cURL, FTP, SCP and tmux. The missing /usr/bin/dbclient issue with scp was fixed with a symlink, and the console font pack grew to include Arabic, Armenian, CyrAsia, CyrKoi, CyrSlav, Greek, Georgian, Hebrew, Lao, Lat38 and Vietnamese variants, with keymaps going from 25 to 51.
Later in the week PCMCIA networking got sorted out. nocomake, the YouTuber who covered SHORK 486, suggested fixes in a GitHub issue which Admiral Shark polished up. Two problems: no PCMCIA bridge drivers were offered, and PCMCIA sockets weren't being seeded with IO port and memory ranges. Both are now handled through SHORKSET's Drivers menu, with seeding repeated on reboot by /etc/init.d/rc. Demo shots show it running on an IBM ThinkPad 365ED with a Xircom RE-100 card.
Froggy814 shared progress on their site, which now has a blog and a question feature. nulleric passed along a 68K Macintosh "game shell" posted to GitHub by EngineersNeedArt for anyone wanting to write a vintage Mac sprite-based game, noting the author demoed it in a talk at VCF Midwest.
#the-lab-hardware
DosFox reached a milestone reverse-engineering the Macintosh II: with a single octal buffer and a handful of resistors, they got a booting system. That leaves only one IC not yet reverse engineered to boot a Mac II, though the result has no sound or working peripherals and still needs a GLUE. The board runs slowly, likely because the ASC interrupt is left floating. DosFox is still planning a proper ASC implementation, leaning toward dual-port RAM plus an RP2040, and floated the idea of a 40MHz board variant with a Radius PDS-to-NuBus interface so a real NuBus sound card could be used instead.
techknight raised whether GLUE could be recreated in an FPGA, pointing out that ASC, SWIM and GLU in CPLDs/FPGAs would effectively give you an SE/30 clone. DosFox noted the Mac LC MiSTer port already includes an FPGA ASC implementation, but GLUE is a big chip. Kai Robinson wondered about feeding a die image plus VLSI/VTI gate book data into an LLM to produce a logic diagram; DosFox's concern is that the die image is around 2GB.
Also: KennyPowers and DosFox admired some purple RAM, and DosFox went down a rabbit hole over NCSA Mosaic 2.0.1 apparently working with an accelerator, wondering whether it runs on 68000 systems or needs 68020+ instructions.
#vintage-apple
Busiest channel of the week. Two big repair threads:
Power Mac G5 PSU — dev1098 wanted to confirm a bad G5 supply before buying a replacement, asking whether shorting PSU_ON to GND would do it. mitchkramez explained that like an ATX supply it needs to stay shorted, and that ATX supplies have enough failsafes that the risk is low. The test confirmed the supply is toast: still clicking, nothing on +12V. Discussion turned to the +25V ADC rail, with Stinkerton18 noting that unless you're driving an ADC Cinema Display you lose nothing without it. FireWire ports still work for data without the rail, just no bus power, and most FireWire devices need auxiliary power anyway.
G4 Cube bootloop — StarDumb got a Cube that powers on to a white screen for a second, then cycles. Loafin suggested the capacitive power button registering as held down, a known issue. Reseating the VRM, clearing PRAM and checking the power supply were all raised. Disconnecting the power button board right as it powers on lets it boot all the way through, confirming the switch. The Apple fix was reportedly a gasket replacement, but StarDumb doesn't think the gasket is the culprit here. Xodium added that grounding is very finicky on the Cube, particularly where the top frame holding the power button PCB contacts the rest of the frame. StarDumb ended up rigging a makeshift USB power switch and mused about designing a better power button board.
Color Classic and Mystic mods — KennyPowers showed off a Mystic build using jmacz's 3D-printed 68040 heatsink clip from Tinker Different. killvore noted Color Classics are borderline unusable at stock speed and mentioned a patched System 6.0.8 that can run on them. kefkafloyd suggested an LC550 board, or a 520 overclocked, as the best play if you can't find an LC 575. Xiang worried that LC5xx systems are vanishing because everyone harvests them for Mystic mods; others countered that many of the donor machines have already-destroyed plastics, CRTs or shells.
On the 640x480 mod, techknight advised against it: boards are getting more fragile with age and the higher voltages and currents are causing component failures. A safer path is moving the flyback and second transformer from an LC55x donor board and removing the zener diode, with no trace cuts, since the 550/575 power transformer is wound with a higher B+ tap and a lower secondary B+ tap. techknight went on to explain the zeners clamp voltage before the E/W pincushion correction IC, and how pincushion correction works by altering deflection width across each scanline, with more advanced monitors deriving a dynamic focus parabola from the same signal. He also flagged SMD ceramic caps going leaky on Color Classic analog boards in humid environments, one causing a tick-tick-tick symptom on the cold-side regulation feedback path of the main SMPS.
Macintosh Garden de-onioning — nulleric shared a post by mihaip about a tool that unwraps the nested apps-inside-disk-images-inside-StuffIt-archives-inside-zips situation on Macintosh Garden. 1Bit Fever Dreams tried it and got three out of three, though results in System 6 and 7.0 varied; nulleric noted that's emulator-specific rather than system-specific since the unwrapping happens in the browser.
Japan shipping warning — StarDumb spotted what looks like a dropshipped PowerLogix G4 Cube upgrade on eBay with mismatched photos. Kai Robinson warned that whoever buys it may receive a bare PCB, as there are new export restrictions around Japanese auction sites. Oelmuvun confirmed reports of items not leaving Japan, and bakkus linked a Tinker Different thread on the topic. Exact scope is unclear from the discussion, so read the thread before ordering.
#the-lab-networking
daniel announced Netatalk 4.6.0, described as faster and more secure, alongside v1.0.0 of the companion Netatalk Client. daniel framed it as a fresh start for AFP following its removal from macOS Golden Gate.
That kicked off a real debugging session. Oelmuvun and dev1098 both hit a build failure on Debian bookworm on Raspberry Pi: implicit declaration of function 'strlcpy' in bin/nad/ftw.c. daniel explained the compat library is always statically linked with libatalk and guessed at a header include order issue. dev1098 tracked it down: #include <atalk/compat.h> needs adding to ftw.c, etc/cnid_dbd/db_param.c, etc/atalkd/config.c and etc/papd/print_cups.c, commented on the GitHub issue, and submitted a PR. daniel merged the fix to main and plans a bugfix release shortly.
Useful build note from the same thread: AppleTalk is not enabled by default. dev1098's setup line is meson setup build -Dbuildtype=release -Dwith-appletalk=true -Dwith-overwrite=false -Dwith-pam=true -Dwith-zeroconf=true. daniel clarified that PAM and Zeroconf enable automatically when the libraries are found, while legacy features like AppleTalk must be compiled in. Other notable opt-ins are -Dwith-cups-pap-backend=true for the CUPS 2.x PAP backend and -Dwith-stuffit=true for nad stuff/unstuff support, which needs the stuffit-rs library. If you're only connecting clients from 8.5 onward, TCP-only is fine.
nulleric shared bbsdial.com, which doesn't just play modem audio but actually modulates data into the tones. Cassette-Chan started a mini homelab with a Pi-hole and a NAS/FTP/Jellyfin/Netbird server, and is considering adding an SPA and a mini PC to act as an ISP for dial-up experiments. Xiang asked how people route cables front to back from patch panels; This Does Not Compute just installs switches at the back of the rack.
A short exchange on Carbon, with dev1098 describing it as a bridge between classic Mac and Mac OS X apps. lauland observed that the pain involved was roughly comparable on other platforms including Windows with or without MFC, and that even OpenStep required about half the same work.
#self-promotion
mitchkramez highlighted Shelby's video on the Sony SMC-70 from 1982, Sony's first computer, and shared a short showing the drilled Mac LC III logic board working on the network after a factory bodge was added. Oelmuvun noted that bodge is what makes it work with modern switches and routers. Ron's Computer Videos posted coverage of the Retro Tech Foundation's Steve Jobs 1976 Garage Exhibit at VCF Midwest 2026.
mmu_man streamed a second round of eMate hinge repair after the first attempt's washers turned out too small, letting the springs pop out. The fix involved new washers, lubrication, and repairing two broken tracks on the top side of the ribbon. techknight mentioned washers made his hinge nearly impossible to open and close; mmu_man suggested not over-tightening the screws first, opening the screen fully, then tightening a bit more, or using a small washer beneath the large one.
§wordfish hosted the Avara 30th Anniversary Stream with the game's creator Juri Munkki as special guest, covering recent development and player memories. Avara is a low-poly multiplayer FPS originally released as Macintosh shareware, now open-source and available for modern macOS, Windows and Linux. Trina's Technobabble streamed a World of Retro Computing Expo haul and is now streaming on Twitch in addition to YouTube.
Links & Resources
Projects & Software
Guides & Forum Threads
Videos & Streams
2,309
Weekly Discord Summary: Sept 20 – Sept 26, 2026
Summary
#vintage-apple
  • Shelf showcases: nulleric is turning a "pile of stuff" into a display and has the first shelf mostly done. Stinkerton18 shared photos of a collection they've built over five years. Most of the machines run BlueSCSIs. The Quadra 650 has Androda's BlueSCSI F4, the Power Mac 7500 has a PiSCSI with the SuperUPS, and the G4s use SATA SSDs through IDE-to-SATA adapters.
  • Mac OS 8 on 68k: timw4mail asked whether a Centris can run Mac OS 8. nulleric pointed out that 68k support ended at 8.5 and linked a guide for getting OS 8 onto 68030 machines like the SE/30. Kai Robinson said it works up to 8.1 but only '040s can really handle it. Having run 8.1 on an LC475, their advice was "DON'T."
  • Clamshell iBook troubles: Loafin is looking for a way to dim an LED backlight mod on a clamshell G3 because the lighting is uneven. Their clamshell also stopped booting 8.6, possibly because installing OS X updated the boot ROM. A burned OS 9 installer CD then got stuck at boot, which is hard to work around on the non-FireWire model.
  • PowerBook 150 rescue: Sharpie brought a trash-picked PowerBook 150 back to life with This Does Not Compute's 3D-printable parts. It still has its original hard drive and LCD caps, and the floppy works. Sound doesn't work, so the VARTA PRAM battery has probably leaked. techknight warned that the battery eats the logic board and said they have a whole stack of 150s it killed. They also suggested an internal SCSI FFC cable so a BlueSCSI could go inside.
  • VCF Midwest finds: KennyPowers went looking for a 512Ke analog board and came home with a Mac Plus and a 128K for $30, both of which powered on. SteveH turned out to be the seller. The 128K had been upgraded to 512K with hand-soldered 41256 chips. KennyPowers plans to fix both, keep the 128K and give the Plus to a friend. Jeremiah_B and Loafin talked about keeping or reverting 128Ks to stock so they can experience how limited the machine really was.
  • IDE-to-SATA adapter woes: Froggy814's cheap IDE-to-SATA adapter made the iMac's keyboard unresponsive whenever it was connected. Stinkerton18 runs three of the same adapter without trouble. Loafin once had one that was missing a resistor.
  • Other hardware chat: Tony picked up a tidy iBook G4 from its original owner, and the group agreed that anything PowerPC counts as vintage. kat! asked about a pair of untested 17" and 12" aluminum PowerBook G4s for $50, and Loafin called it a good deal. Loafin also noted that Snow Leopard runs on the Mac Pro 5,1, and with Rosetta it could make a good bridge machine. MParaGames is trying to get GPU acceleration working under X.org on a 2011 Mac mini. Kadmus asked where to find a cheaper flyback than eBay for an Apple Studio Display 17 CRT.
  • Ergonomic keyboards: timw4mail picked up a DataDesk SmartBoard ergonomic ADB keyboard with ALPS switches and is getting used to its layout. §wordfish recommended it over the MS Natural and the Apple Adjustable Keyboard. timw4mail and §wordfish both find old ALPS switches more reliable than modern Matias ones, which tend to get unreliable over time. Kai Robinson wants a 40% staggered keyboard for a recovery kit built in a Pelican 1640 case, but every one they've found is ortholinear.
#the-lab-hardware
  • max1zzz's new build: max1zzz assembled a new board and had to work around ordering PLCC68 sockets when it needed PLCC44, plus some clearance problems. By the end of the week the board worked. The AliExpress TL072s turned out to be fake, and the substitute TO-18 transistors failed short, so BC108s and BC177s are on order. The build included an axial cap in a radial footprint, which led to a round of stories about capacitor bodges. Mark Benson said recaps done with axial caps on SMD pads had lifted the pads on two SE/30s.
  • Mac IIci SIMM socket bodge: BigBadBiologist explained their floating-socket IIci repair. Cheap SIMM sockets are spaced for PCs, which is too narrow for Macs. As a workaround, they paired machine-pin sockets with SIMM precision headers, which also left the damaged vias visible. DosFox designed an adapter board called "anticordyceps" after seeing the bodge. max1zzz mentioned that the current IIci Reloaded PCB has footprints for both normal and narrow sockets.
  • Cutting dual sockets: People suggested a Dremel with a thin disc, a hot knife made from a blade on a soldering iron (mmu_man showed one), and micro or craft saws. seatsafetyswitch reminded everyone to wear a respirator and have a plan for cleaning up shavings.
  • mmu_man shared a Newton eMate repair where a zener diode had sacrificed itself after more than 12V went into the machine.
#the-lab-software
  • SHORK 486 updates from Admiral Shark:
    • CTris, a compact Tetris clone, is now included in the default, offline and plus builds. The nbsdgames pack of 22 minigames was also added but doesn't fit in the default edition's 100MiB budget yet. The largest builds are now approaching 600MiB because everything is statically compiled.
    • GNU Autotools, along with m4 and Perl, is now in the Plus and Max editions.
    • Admiral Shark found and patched a bug in the Linux 387 FPU emulation code, which SHORK re-adds so current kernels run on 486SX CPUs. An FPU control word was being zeroed instead of set to mask, which caused spurious SIGFPEs in programs like GnuPG. With the fix, SHORK no longer needs the libsoftfp workaround. That saves about 10MiB and lets programs use a real FPU when one is present.
#self-promotion
  • Bruce (Branchus) streamed a live recap of a 37-year-old NuBus display card.
  • BigBadBiologist streamed three repairs. The first was a serial port (1101 error) on an IBM PS/2 Model 50z. The second modded 30-pin SIMMs to work on its Memory Expansion Adapter. The third was a teardown of a Sony GV-8 Video Walkman, a Mac Classic and a Classic II.
  • Trina's Technobabble streamed ISA card testing, learning trace repair, and DDR4 and DDR3 laptop memory testing.
  • techknight posted a walkthrough video of VCF Midwest 2026.
  • Ron's Computer Videos interviewed Brian Silverman, former Director of Research at Logo Computer Systems.
  • mmu_man appeared on a French podcast about repair, low-tech and planned obsolescence.
#the-lab-networking
  • The group traded rack cable management tips. Mark Benson suggested clip-in cable hangers, noting that stick-on zip-tie mounts come loose over time. max1zzz bundles each server's cables with enough slack to pull the server out for maintenance.
Links & Resources
This summary was generated by an LLM and may contain errors or omissions. Please check the original Discord conversations for full context and accuracy.
2,309
Discord Weekly Summary — Week Ending October 3, 2026
Summary
#the-lab-software
  • Admiral Shark posted a run of SHORK 486 updates. The distribution is getting chrony for NTP, following a suggestion from Reddit. It now has an ftpd, sshd (Dropbear), telnetd and tftpd, which together add less than 1MiB, and tcpdump has been added since.
  • The SHORK 486 build script was refactored so most CFLAGS live in a handful of variables, and libsoftfp is no longer used. The aim is to later offer builds optimised for 486SX, 486DX, the AMD/Cyrix "586" in-betweens or Pentium/P5.
  • A pull request standardises how libraries are told about sysroot in the cross-compiler and reduces the build script's reliance on sudo. The user who reported the original issue says it fixes it for them, and it is waiting on Admiral Shark's testing on Fedora before merging.
  • Admiral Shark created patches for kernel 7.2.x and the upcoming 7.3.x that restore PCMCIA Bluetooth, the DoubleTalk PC speech-synthesising ISA card, MDA/Hercules-compatible console support and Hercules-compatible framebuffer support.
  • Other user suggestions already acted on: a prompt before the build script installs host packages, poweroff and reboot utilities (enabled if the system supports them), and a fix for SHORKSET respawning the terminal on every exit.
  • Kai Robinson asked about an X implementation. Admiral Shark said there is an optional "SHORKGUI" that provides TinyX, though the GUI side is not well developed yet.
  • techknight shared news that PocketJS now supports Windows 3.1 and Windows 11, and guessed it would need a CPU with some horsepower to run a JS framework under Windows 3.1.
#the-lab-hardware
  • DosFox got Tashtari's ADB replacement working with WDC VIAs, and found it needed a 470R pulldown on the ADB line. Tashtari was puzzled, since the Bomarc SE schematic shows the line pulled up to 5 V through 470 Ω. DosFox noted that with the system held in reset and the original PIC controller fitted, the ADB signal floats at about 2.5v, which suggests a pulldown somewhere fighting the pull-up. saybur wondered if a driver isn't strong enough to pull the line low without help.
  • max1zzz thought their Radius Precision Colour 24X NuBus card had died: it showed the Radius splash screen but the Mac couldn't see it and it didn't appear in TattleTech. Two other Radius cards did the same, even after swapping the IIci logic board. The fix turned out to be a different monitor, as DosFox had suggested, even though it is an identical model. Bolle explained that some Radius cards disable the DeclROM unless a pin on the video connector is pulled low, which doesn't always match Apple's sense line logic.
  • saybur's new NuBus card is now a proper hard drive replacement and reached the point of booting, at about 1.5-2x SCSI speeds on a IIci. It is backed by a modified version of ZigZagJoe's sample DeclROM driver. There is still lots to do.
  • DosFox reported that the 341-0269, the 6805 microcontroller on the Apple II mouse card, can be cloned. The dumped firmware flashes to a new 68705 without any changes. The PAL has already been reverse engineered, and DosFox has designed a replica of the mouse card that still needs to be built and proven.
  • mitchkramez lamented the $30 minimum order at peconnectors when all they wanted was a Socket 7 socket. max1zzz recalled the international minimum being $400.
#vintage-apple
  • KennyPowers shared photos of a boxed item. This Does Not Compute pointed out that the box is trapezoid-shaped, which is hard to tell from photos.
  • dev1098's son's G5 from VCF Midwest is working again with a new power supply, and now runs Minecraft.
  • nulleric shared a TinkerDifferent thread about newly manufactured ImageWriter color ribbons being restocked.
  • fogWraith announced version 1.0 of Liteline, a "feature complete" Hotline client for System 6.
  • aperture science has a PowerBook 165 with its dead display removed and only gets a grey screen on an external monitor. techknight explained that the external display is secondary by default. Mirroring is a PRAM setting made in the control panel, and it is lost whenever the PRAM is, so a permanent fix needs ROM or boot disk modifications. Scout described a similar situation with a PowerBook 2300, where disconnecting the bad screen's cable made it boot to the external display. dev1098 linked a 68kMLA thread where someone memorised the keyboard shortcuts to do it blind.
  • nulleric, seatsafetyswitch and techknight discussed writing an extension/INIT that sets the PRAM bit and switches mirroring on at boot. seatsafetyswitch also wondered about scripting the control panel with AppleScript, QuicKeys or Frontier.
  • techknight said display reverse engineering is happening on a few fronts, but doubted it will get beyond the hobbyist stage without serious financial backing. An FPGA timing converter project with MacEffects was shelved because of the cost of the FPGA.
  • kat! asked about a $40 snow iMac G3 said to be working, and Loafin thought it a good deal if it works. Loafin's own $100 graphite iMac had its tube die after five minutes, with the analog board, motherboard and PSU all still good.
  • techknight shared a IIgs render. Sharpie plans to send their TWGS to ReActive Micro to be overclocked to 16MHz.
  • twvd shared a Reddit thread about turning .hqx and .sit downloads into .dsk images for a Macintosh Plus with a BlueSCSI.
#self-promotion
  • Trina's Technobabble streamed a look at the engagement gift Tamsyn bought.
  • mmu_man posted a new video (in French) touring Fabrico.
  • Ron's Computer Videos announced that V3 of the PicoMicroMac is available at JCM-1.com, and posted a chat with Eric "EJ" Johnston, LucasArts Macintosh conversion specialist.
  • Jason Merrill premiered a video about a new wifi modem for old Macs, adapted from an existing open-source hardware project.
  • seatsafetyswitch published two blog posts: one on repairing a battery-damaged Sharp X68000 ACE, and one starting a Forth port for the Sega SG-1000 as part of RetroChallenge 2026/10.
  • RToD's 2026 giveaway for a Toshiba Satellite 435CDS is live and runs through October 31.
  • BigBadBiologist is streaming a test of the FNIRSI DWS-200 soldering iron on a battery-damaged 286 motherboard and an Apple IIgs, Saturday at noon EDT.
  • MacEffects has the inner bezel for the slot-loading iMac G3 back in stock and on sale.
#the-lab-networking
  • techiesplash plans to run new Cat5/6 and some fiber optic at some point.
#vintage-programming
  • Slaine reminisced about going from DOS to the Win16 and Win32 SDKs and early MFC, and said recently starting on classic Mac Toolbox applications felt just like those native Windows SDK programs.
Links & Resources
2,309
Discord Weekly Summary: October 5–12, 2026
Summary
#the-lab-hardware
  • Classic II ROM replacements: techknight has a 2-chip Classic II where both ROMs are cooked and asked about programmable replacements. max1zzz explained that the 2-chip boards need 27C400s (the 4-chip version uses 27C010s, IIRC), and that the only other pin-compatible part he knows of, the TC574200D, is usually even more expensive. TopherPerson noted he needed an adapter to program 27C400s. Since the LC III uses 27C400s as well, the two agreed an adapter PCB for more commonly available 128kx8 PLCC chips would be worth making.
  • FPGA FPU in a IIsi: Kai Robinson shared a TinkerDifferent thread about a IIsi running a 50 MHz "RD68884" FPU. Kai floated a PLCC-format PCB with castellated edges, and later an SE/30 repro built around it if a soft '030 core and cache would fit. mmu_man pointed out the Artix-7 is 3.3V at best, so it would need a lot of buffer chips. techknight added that FPGA prices are climbing, with the part he needs going from $20 to $215.
  • Daystar PowerCache in a Classic: Bolle got his adapter board working after finding a socket type that fits nicely over the 68000. He had to adjust the power supply pot on the analog board to get 5V dialed in before it would do anything. The adapter lets a Daystar PowerCache accelerator go into the Classic and carries 16MB of 32-bit RAM, alongside the 32k of SRAM cache on the PowerCache itself. That means up to a 50MHz 030 with an optional 68882. Next step is adding RAM to the adapter.
  • The accelerator era: Bolle's project kicked off a chat about when bolt-on upgrades made financial sense. Bolle mentioned Daystar more or less gave the adapters away at some point and ran a trade-in program for people switching machines. Andy dug up a 1994 book on the subject. Others brought up the PC Transporter for the IIgs, MacCharlie, the 7200/120 PC Compatible, Pentium OverDrive, the Intel Inboard and 486SLC drop-in upgrades. seatsafetyswitch shared a modern equivalent: a PCIe card carrying an AMD B650 chipset to add M.2 slots and USB.
  • Computer-in-computer oddities: KennyPowers posted a photo of his VCF East table on this theme. It included an LC expansion box with an accelerator and a IIe card, plus a machine with a DayStar 040 accelerator, Radius Thunder GT/24, one of max1zzz's Radius Rocket clones and a Stage 2 Rocket.
  • Logic analyzer: nulleric picked up a Sipeed SLogic32U3 from Kickstarter and said the interface is a lot nicer than his SCSI analyzer.
  • PSA for SE and SE/30 Reloaded builders: After a week of trial and error and about £80 in VIAs, DosFox reports that if your original VIA can't be used, the best alternative is an R65NC22P2 rather than the Western Digital part. With it the replacement ADB controller works without issues and the RTC works as expected. He had also tried the R65C22P2, R65C22P4, R6522 and W65C22N6. The hunt was complicated by a bad GLUE socket connection that showed up during testing. He noted the part has internal pull-up resistors.
  • techknight is looking for the SE/30 address/register map, and DosFox is hoping someone will port the MacLC MiSTer core to a Tang Nano.
#the-lab-software
  • SHORK 486 update: Admiral Shark's configurator now lets you select which 486 or 586 revision you are building for. For now it configures and optimises the kernel differently, and it will soon change compile flags for the bundled software too. He also patched in more descriptive messages for when you run a build optimised for a newer CPU than the one you have. Selecting a 586 target will soon make the distro call itself "SHORK 586", which is cosmetic apart from the optimisations.
  • In reply to timw4mail, Admiral Shark said the CPU requirement depends on what you pick in the configurator. Previously it always assumed a 486SX, so it ran on any 486. He also confirmed for Oelmuvun that the 486SLC works, since it implements the 486 ISA and reports itself as family 4.
  • Kai Robinson nudged him to write a forum thread about it, and he said he really should.
#vintage-apple
  • iMac G3 600MHz: kat! got one booting to OS X 10.2 with a warped CRT picture and an awful noise. The noise turned out to be the hard drive, and resetting the geometry to factory defaults fixed the distortion. TekTherapy - Ronnie has a similar G3/600 Snow overclocked to a stable 700MHz with an SSD, and suggested adjusting the focus pot for bad corner focus. Oelmuvun linked an archived guide to the overclock, which involves moving tiny resistors. Ronnie cautioned that the 600-700MHz boards have a revised layout, though the method is the same.
  • TransWarp GS: dev1098 used parts from ReActive Micro to fix up his TWGS and get it to 16MHz. He recommends it if you are comfortable with SMD soldering and hot air.
  • BlueSCSI in an LC III: Cassette-Chan installed an internal BlueSCSI and has a tantalum recap kit and a 256k VRAM module on the way. mitchkramez pointed to PotatoFi's LC bracket on Printables. PotatoFi said it needs updating for the newer BlueSCSI and he plans to do it, though it may be a couple of weeks.
  • LC III reversed capacitor: Psycho Soldier Soph reminded everyone that one cap on the LC III was installed backwards at the factory. TopherPerson found the Recap-a-Mac article, which identifies it as C22 on the -5V rail, matching an incorrect silkscreen '+' marking.
  • SE Reloaded files: Josh is still chasing a SCSI issue on his SE and asked whether the Sprint Layout files for the SE Reloaded board are still available, so he can trace VIA/SCC connections in software.
  • HyperDrive: DosFox asked whether anyone has a HyperDrive board. Jeremiah_B had a HyperDrive-upgraded Mac 512k until a few months ago, and Sharpie owns one whose drive has some stiction issues. Sharpie agreed to dump the ROMs and photograph both sides of the board for DosFox once he has it back.
  • Rackmount Macs: Xiang wants a rackmount Mac. max1zzz has an LC III in a switch shell in his rack, mounted with self-adhesive plastic PCB standoffs, and noted a PM6100 or WGS6150 fits perfectly on a 2U shelf with no mods.
  • Classic II Reloaded: zBradBell uploaded his "Classic II Reloaded" board to GitHub and is asking for feedback and for anyone interested in building one. He also spotted a PR from someone who built his non-reloaded reverse-engineered board and made videos about it.
  • Also asked: kat! is looking for a spare PowerBook G4 17" high resolution screen, and DosFox wondered whether Nutek ever shipped any computers.
#the-lab-networking
  • Netatalk 4.6.1 is out, per daniel, with many security patches and a lot of added unit tests.
  • timw4mail was happy to find that his no-name 2.5G switch can talk to a 10M AAUI transceiver. Stinkerton18 noted that not many switches go down to 10Mbps anymore.
  • fred121 is having trouble with Golden Gate and SMB shares from Debian 13. The share shows in the Connect to Server window but gives "Connection Failed", while AFP netatalk shares work fine. Stinkerton18 has had no issues with a Samba share from his NAS, though it isn't Debian. No resolution yet.
  • phlogios reverse engineered the Windows driver for the Huion H610 tablet and had AI write a proof-of-concept Mac OS 9 driver with Retro68. It works very well, giving pen input in AppleWorks and old Photoshop. He is considering rewriting it in CodeWarrior with a GUI settings app and asked if others are interested. Kai Robinson asked for a forum thread.
#self-promotion
  • mmu_man ran a series of streams repairing a second eMate with corrosion and a burnt zener diode, ending with the keyboard fixed.
  • seatsafetyswitch published part 2 of a blog series on CamelForth for the Sega SG-1000, covering keyboard handling.
  • Ron's Computer Videos interviewed Warren Robinett, cofounder of The Learning Company.
  • BigBadBiologist streamed a repair attempt on a badly battery-damaged Macintosh Classic.
  • Trina's Technobabble streamed testing of PS/2 mice and PC100/133 laptop memory, plus a second general repair stream.
  • HardwareHacker / Lord Heincrad streamed parts 21 and 22 of a Ni No Kuni Let's Play.
  • techknight mentioned he needs to stock up on 75175s and 26LS30s because they are failing often now.
Links & Resources
2,309
Weekly Discord Summary for October 12–19, 2026
Summary
#vintage-apple
  • Macintosh 16" Color Display: Jeremiah_B asked why the 16" Color Display only worked with a PowerBook 160 and not a IIci or SE/30. BigBadBiologist explained that the monitor can't do sync on green, which rules out the IIci's onboard video. techknight wondered whether an LM1881 sync separator could make it work. Slaine said the display pairs nicely with a Quadra 700.
  • BlueSCSI external antenna mod: Jeremiah_B added an external WiFi antenna to the BlueSCSI inside a PowerBook 160, following a guide written for the PicoMEM's Pico W. Shielded laptop cases can act like a Faraday cage, and moving the antenna outside improved the signal a lot. The same build also got the termination power diode mod and a CR2032 CMOS battery swap, and the antenna sits on a 3D-printed battery door. Jeremiah_B called the soldering extremely fine and doesn't recommend it over an external BlueSCSI for most people. Kai Robinson offered the Sprint Layout file to anyone who DMs.
  • Radeon 9200 flashing: fujiotard asked how to flash a Radeon 9200 for Mac without booting DOS from a floppy. Oelmuvun suggested using a programmer with a clip or desoldering the chip.
  • Romance of the Three Kingdoms V: killvore gave a shout-out to Livid on the Macintosh Garden Discord, who made a full English translation and OS X port of the previously Japanese-only game.
  • PowerBook G4 A1139 screen: kat! posted a damaged display, and techknight identified it as LCD layer delamination caused by a failed seal. kat! later shared a TinkerDifferent thread about the 17" WUXGA PowerBook G4.
  • Analog Horror wallpapers: Psycho Soldier Soph released a Halloween 68k wallpaper pack of stills from Gemini Home Entertainment, with about 26 1-bit images at 512x324 and 27 8-bit images at 640x480. It's headed to the Internet Archive and will be handed out on floppies at a SEMVCC meet.
  • MP3 on 68k: timw4mail asked about MP3 players and rippers for 68k Macs. fogWraith pointed to MpegDec. Others noted that encoding on 68k would be very slow and decoding needs a fast 030 or a decent 040. techknight floated a VS1053 decoder on a BlueSCSI, and 1Bit Fever Dreams said their code is ready if that ever happens. fred121 recommended XLD on an Intel Mac for converting a FLAC collection.
  • Linux on Macs: MParaGames asked how to get a 2011 Mac mini with a dead dGPU to use the Intel iGPU under Linux instead of software rendering. They also asked whether the 2015 MacBook Pro's Force Touch trackpad works on Linux. aperture science suggested testing it with a live USB.
#the-lab-software
  • SHORK updates: Admiral Shark patched the vga16fb framebuffer driver with a vga16fb.force kernel parameter. It lets the driver bind to EGA/VGA hardware that's still in text mode, which could bring SHORKGUI to generic VGA cards and machines like the original ThinkPad 700. An option for it is coming to SHORKSET, and EGA handling is still being worked on before the changes are pushed. SHORK also got a fancier boot screen with systemd-style log messages that can be turned off in SHORKSET, and it's already running Linux 7.3. Admiral Shark confirmed SHORK runs on Micro Channel machines, though without networking or sound.
  • Rustid 2.3.0: timw4mail released a new version of the CPU identification utility. It adds classic Mac ports for 68k and PowerPC and fixes L2 cache counts on some AMD chips.
  • VoxelSpace on a Quadra 700: Slaine finished a VoxelSpace engine running at about 8–12 fps on a 50MHz Quadra 700 with a RasterOps NuBus card. NuBus transfers of about 6MB/s look like the limit. Rather than have AI write the code, Slaine had an agent generate a tutorial series to work through by hand, and has since used the same approach for a neural net and genetic algorithm project. thecloud and phlogios said they like this way of learning.
  • Sierra-style adventure engine: 1Bit Fever Dreams shared a demo of "Whiskers Lounge." It uses a packed bitmap of "hot zones" to mark walkable areas and interaction points, now at 16 types (2 pixels per byte). Dorkulon said it had the feel of Little Computer People crossed with early Sierra.
#the-lab-hardware
  • Sprout Pi: nulleric shared the Sprout Pi, an RP2350-powered replacement mainboard for iPods. Androda wished the microSD card were reachable through the wide dock connector. TekTherapy noted that the board's Cirrus Logic DAC supports high sample rates and bit depths.
  • Docked Outbound + SE: zigzagjoe showed an Outbound docked with an SE, which works as an accelerated SE with an extra display, a hard drive and a RAM disk.
  • PicoPCMCIA: mmu_man shared a video of the PicoPCMCIA's USB passthrough working in Windows 95.
  • Fake chips: max1zzz received fake 555 timers from AliExpress.
#self-promotion
  • Trina's Technobabble streamed a Windows 11 install, an HP laptop that won't charge and its follow-up, a chill stream, and a friend setting up a new M6 Mac mini.
  • BigBadBiologist streamed a Packard Bell Legend 610 with a bad power supply and posted an update on the battery-damaged Mac Classic repair. The fault came down to data lines 8 and 9.
  • seatsafetyswitch wrote a blog post about CamelForth on the Sega SG-1000 and getting the SN76489 sound chip working.
  • Bruce (Branchus) tested VectorCraft as an alternative to Adobe Illustrator.
  • Ron's Computer Videos interviewed Lexie Cooper (TracketPacer), an aerospace networking engineer.
  • HardwareHacker / Lord Heincrad continued a Ni No Kuni Let's Play.
Links & Resources
2,309
Weekly Discord Roundup: Oct 19 – Oct 26, 2026
Summary
#the-lab-software
  • Admiral Shark had a busy week on SHORK 486. They patched the vga16fb driver so it can be forced into EGA mode. The first attempt lost its colour, but it was fixed the next day and the patch is now pushed. TinyX was then brought up to work with the driver, so SHORKGUI now runs on ISA-based EGA and VGA. They said it "runs like shit" for now but called it a start, and also showed it running on a 365ED.
  • Admiral Shark also got DOSEMU2 running on SHORK with MS-DOS and gpm mouse support. Memory was the main hurdle. It first needed 48MB without swap (or 24MB with swap), and their target is 16MB. After working through compile options and patches, DOSEMU2 now runs in 16MB with no swap, though very little RAM is left over. The longer-term goal is to run Linux and DOS apps side by side in tmux, and they'd love to see DOOM on it eventually.
#the-lab-hardware
  • Masterfalcon (David) recapped an LG Flattron and it works. A IIci is next.
  • WillJR picked up their first Mac, an ex-bank Macintosh SE, for $300 AUD. It doesn't boot yet. Mark Benson identified it as an early "squirrel cage" fan SE, which is notoriously loud. WillJR found and printed the open-source SE fan bracket, which bakkus has used on several machines, and swapped in a standard fan. It turned out most of the noise was actually the internal SCSI drive. DosFox confirmed the drive can be removed entirely once their external BlueSCSI arrives. killvore suggested a 3D-printed internal BlueSCSI mount that exposes the SD card at the back.
  • bakkus pointed WillJR to their retrorepro.wiki page for SE replacement parts, the open-source MiniPerformer+ accelerator (also sold by JCM), and open 30-pin SIMM designs. JC8080 and bakkus later noted that the MiniPerformer+ is a Plus-specific design, and that the MacEffects Performer clone fits the SE but is currently sold out.
  • The MIDI talk covered Cubase on compact Macs and the TashRecorder, a Farallon MacRecorder clone. Tashtari explained that the firmware was designed to also act as a MIDI interface, but the only current board (demik's) supports MacRecorder mode only because of space limits. 1Bit Fever Dreams noted that cheap eBay MIDI interfaces make a recreation PCB hard to justify.
  • techknight gave CRT safety advice. The yoke and neck controls are fine to touch, but be careful with the anode lead, whose aging insulation gets sticky as the plasticizer leaches out.
  • On accelerators, DosFox and techknight noted that a 68030 accelerator only speeds up 68000 software. It doesn't add Color QuickDraw or Mac II app support, and it can cause sound compatibility issues. techknight suggested porting Color QuickDraw or the SE/30 ROM to accelerated SEs. bakkus said their ROM decompile/annotation project is partway there but stalled. They've restarted it three times because of AI consistency problems and now run it under a very strict reference-only harness. Andy clarified that 32-bit QuickDraw (not Color QuickDraw) started as an extension.
  • Bolle said the DayStar PowerCache has fully working sound and floppy fixes without the video slowdown seen on most Plus/SE/Classic accelerators. They shared photos of a 50MHz 030 in a Classic with the adapter covering almost the whole logic board, and said they've found a way to properly secure backwards-facing CPU sockets on the Classic.
  • techknight showed off weatherbar7, which looks especially crisp on a Mac Portable. WillJR wants a period-correct weather dashboard on a compact Mac.
  • WillJR also built a temperature-controlled fan setup to ventilate behind their fridge, logging temperature and fan speed to InfluxDB.
  • mmu_man got a StyleWriter II / 1200 working and asked whether it needs recapping, but couldn't find a cap list. They also built a dock for the eMate that feeds barrel-jack power to its bottom charging pins. Andy found a reference to a Bretford charging cart in the Newton Teacher's Guide, but mmu_man said it was just a caddy with a power strip for the regular PSU bricks.
#vintage-apple
  • Jeremiah_B shared the chips needed to fill a 1MB-populated Mac Portable 3MB expansion card for a 4MB Portable, at just over $1 a chip. They also turned a PowerBook 160 into a 180 with a replacement CPU for a hardware FPU, and fitted a translucent blue 30mm acrylic juggling ball as the trackball with a blue LED backlight. That led to a discussion of trackball sizes: the Duos use smaller balls and the Portable a bigger one.
  • Sharpie built a photo viewer for the Apple /// with help from Claude. It uses Super High Res mode, switches between photos by swapping memory banks, and does simple slideshows. A companion web app converts photos onto a .dsk file. Sharpie said it took under 3.5 hours.
  • Several people shared Apple /// restoration progress. kat! listed the parts still needed. seatsafetyswitch is building a RAM board to replace eight 4332s at once. Jeremiah_B suspects a failed ROM is behind garbled video and shared photos of past battery corrosion and trace repairs. Sharpie recommended ReActive Micro PSUs for the ///.
  • techknight built a working LCIII out of a smashed unit and a bombed one.
  • Xodium's Harman/Kardon SoundSticks died. The original pot is essentially unobtainable, so they fitted the closest substitute with bent pins and kept the volume control somewhat reachable from outside.
  • PotatoFi's original AirPort Extreme lost its 56k modem after a flight, and the modem and dial-in options disappeared from the utility. Reseating the discrete modem card didn't fix it. The card turned out to be an Apple U01.029.C.00 iBook modem, and PotatoFi found one in Germany for €5 shipped in time for an upcoming showcase.
  • Josh traced a FloppyEmu failure on their SE (reading track 00, then ejecting with an X) to a misplaced bodge wire. The floppy now works, but SCSI is still broken, and the machine hangs at the grey screen with a BlueSCSI attached.
  • nulleric reminded bakkus of the name of the PLD Archive wiki for PAL/GAL/JEDEC files.
#self-promotion
  • seatsafetyswitch posted a new Leaded Solder entry adding TMS9918A VDP sprite words to CamelForth on the SG-1000.
  • RToD's 2026 giveaway of a Toshiba Satellite 435CDS runs through Oct 31.
  • Bruce (Branchus) streamed a live repair of a Macintosh Classic II after a botched earlier repair attempt.
  • Piper dismantled their dad's old PC and posted part 1 of an "Ultimate XP Machine" build for Windows XP's 25th anniversary.
  • Ron's Computer Videos interviewed Callan Brown of 74xx Arcade Repair.
  • BigBadBiologist streamed VLB video card tests and a 486 test bench upgrade.
  • Trina's Technobabble ran a dual YouTube/Twitch stream.
Links & Resources
