Status
Not open for further replies.
sheider
26
No unit playback for about 6 months. I didn't even notice I had broken that for ages as it wasn't useful for high resolution quality testing. Goals have always been high quality, even at the expense of some convenience.
I concur with your goal to focus on improving image quality before pursuing "convenience" features. That said, a lot of questions / complaints could be avoided if the stock features that no longer work as a result of the firmware mods would be hidden / disabled in the UI. Video playback is one example; I believe that on-device SD card formatting is another.
sheider
26
7.0. Will have a fix for the issue would scanning over 16384 frames.
New ideas of v7.0 are welcome.
I want to add support negative film, as this setup currently does a very poorly. I was looking for the color matrix, figuring the Tint control might lead to something useful for inverting the image. I didn't, instead I found how to make a true black and white scan. So in 7.0, setting Tint at -2.0 will now remove all color. This is useful for scanning B&W Film, which would have a slight color cast in current firmware.
I'm ordered a 16mm Macro, to see if that is practical (trying AZURE-1622MAC https://www.rmaelectronics.com/azure-photonics-azure-1622mac/)
I wish you luck with the 16mm macro lens... IMHO, the ultimate "practical" goal would be to determine a lens / spacing combo that maximizes image capture quality while eliminating the need to cut the case or otherwise void the manufacturer's warranty.
I really want to upgrade the stock lens, but I'm equally reluctant to cut into the case, voiding the unit's 1-year warranty. (I'm scheduled to receive my new unit tomorrow.)
442
613
What are the chances of having (fairly rapid) auto-exposure that varies through the capture? Set a level on a good frame then try to maintain the same luminance level throughout the capture.
Many old cine films have normal bits followed by overexposed bits followed by dark bits followed by.... Just a few seconds each. The only way to cope with it at the moment is to scan multiple times at different exposure levels, and then chop the scans up in Resolve of FCX or whatever, selecting the best version of each segment.
I know that AGC wouldn't be right for ALL captures - it would ruin some. But to have it as a selectable option would be really good.
It has an AGC, just not as fast as the stock FW. It is has limits to prevent too much gain lift black too much into grey. The speed of the ACG could be a control, but you will find there is not perfect setting.
442
613
Unfortunately change anything in the UI is likely much more work than quality enhancement. All changes are through educated guesses at best, modifying the binary of the firmware, there is no source code to work from. The only UI elements I've successful changed is the boot JPEG, and one word, in one language only.
442
613
It is very unlikely that there is a macro lens, with sufficient quality, and doesn't require a different mounting position. I've tried a dozen lenses, only one is good so far (with a mount move.)
larryc39
34
35
What timing 🤣 Great find on the US supplier lens. I'd looked several times and never found one with all the right specs it seems. That's definitely more palatable than the shipping from the UK or the 50% tax from China. The IR question came about because the Chinese seller offered both versions of the lens.
Could you explain how the 5mm spacer need came about? I see you said it had something to do with how far the lens needs to be from the sensor, but I was lost after that.
sheider
26
@larryc39 When you install your replacement lens and spacer, would you be willing to document and share the process (preferably with photos) for those of us who are a bit nervous about damaging our units?
442
613
Enough enhancement already to release 7.0.
- Added auto exposure back into preview
- Added ISO 50 back to the exposure range
- Added Tint -2.0 is now true B&W
Let me know if you seeing much jitter in 7.0, as the preview auto exposure was originally disabled to reduce jitter. Now the preview auto exposure biases to a short shutter, hopefully to achieve the same jitter reduction. I'm not seeing any jitter my brief testing.
  • FWDV280-TypeA-V7.0-0dan0.zip
  • FWDV280-TypeB-V7.0-0dan0.zip
  • FWDV280-TypeC-V7.0-0dan0.zip
sheider
26
Bummer! I still like the hack idea you proposed way back in February in post #317 of "frame control for 18 or 24, would be nice (20 is weird)". I agree that 20 is weird. Actually, I would prefer 16 fps for my regular 8mm film, to match the original filming speed. However, I can certainly deal with a hardcoded value of 18 (using ffmpeg after encoding to manually convert from 18 fps to 16) if you are unable to add frame control to the UI without access to the fw source code.
442
613
Setting 16fps in your own firmware is straightforward.
Type A/B - offset 0x1fe974
Type C - offset 0x1fe984
0xD2F0 is 54000. 54000 / 3000 = 18fps
For 16fps, 16 * 3000 = 48000 in hex 0xBB80
So change the four characters with the .rbn file to 80 BB (little endian), run the NtkTool Pack Firmware option, and the firmware will now encode 16fps files.
omega
36
14
I'm trying out a new version of #7. The first set is from a black and white film, where everything is at 0 and only the white balance changes.
The second set is a color film and like the first set, everything is at 0 and only the white balance changes.
It is firmware version "C".
Reactions: Umba67 and eyeidea
442
613
I could bias the the white balance, so 0 is closer to normal. T
// Plus +2.0 to -2.0
if(*whitebal == LVL_P20) { r = 0x1C0; g = 0x100; b = 0x100; } //1.75,1,1
if(*whitebal == LVL_P15) { r = 0x180; g = 0x100; b = 0x100; }
if(*whitebal == LVL_P10) { r = 0x140; g = 0x100; b = 0x100; }
if(*whitebal == LVL_P05) { r = 0x120; g = 0x100; b = 0x100; }
if(*whitebal == LVL_000) { r = 0x100; g = 0x100; b = 0x100; } //1,1,1
if(*whitebal == LVL_N05) { r = 0x100; g = 0x100; b = 0x120; }
if(*whitebal == LVL_N10) { r = 0x100; g = 0x100; b = 0x140; }
if(*whitebal == LVL_N15) { r = 0x100; g = 0x100; b = 0x180; }
if(*whitebal == LVL_N20) { r = 0x100; g = 0x100; b = 0x1c0; } //1,1,1.75
So currently WB of 0 has unity RGB gains (the reason it is as it is.)
Reasons to add bias. The sensor doesn't seem to be very red sensitive, and the back light is very blue. Will address in the next release
442
613
Beta v7.1 for Type B. Please test if I broken anything.
Changes:
Exposure: Went back to ISO 100-400, as was seeing more exposure stepping with ISO 50.
White balance: 0 is now normalized to color of the backlight.
FPS: is now selectable between 16, 18 and 24fps. Long hold on up or down, arrows to increase or decrease the frame rate. You will be remembered, and can be changed during capture, as the value is only unused as the capture is stopped.
I will do Type A & C soon after positive feedback on the Type B build.
  • FWDV280-TypeB-V7.1-0dan0.zip
ThePhage
79
75
Changes:
Selectable Frame Rate: Outstanding!!!!!!!! Can't wait to get cracking with my C model, but will gladly wait.
442
613
"Official" V7.1 for Types A,B & C
Please test if I've broken anything (more, other 64GB+ support and Playback).
Changes:
updated with v7.1.1 (fixing the fps issues)
  • FWDV280-TypeA-V7.1.1-0dan0.zip
  • FWDV280-TypeB-V7.1.1-0dan0.zip
  • FWDV280-TypeC-V7.1.1-0dan0.zip
eyeidea
21
View attachment 24120View attachment 24121View attachment 24122
Changes:
FPS: is now selectable between 16, 18 and 24fps. Long hold on up or down, arrows to increase or decrease the frame rate. You will be remembered, and can be changed during capture, as the value is only unused as the capture is stopped.View attachment 24123
@0dan0
I just ran V7.0 on Type C without issue.
Can you give me a quick refresh on settings ... is this correct?
WB: 0.0
Sharp: -1
Tint: 0.0
Frame adjust/zoom: whatever
Just flashed Type C to 7.1, gonna do a 50' reel now.
Ordered my lens!
Thank you so much for all this work!
omega
36
14
I did new tests and the color matches in my opinion. The speed is worse. With 16 set the real speed is 5.333. With 18 it is 6 and with 24 it is 8. It looks like you need to multiply by 3.
Hopefully this will help you. I really admire your knowledge and selfless help for those of us who can't do this. Many thanks.
Status
