Seems you did get the update to work. You need to redownload v7.1Still getting some anomalies, FPS, data rates and also one capture stalled, the film was moving through, but the SD card just repeated the same frame for many seconds
Movie specs - 0dan0 V7.1 on Type C ...
Also I was seeing 464x224x256 in the WB values on this. Going above 256 for the first RGB value?
Went back to 0dan0 V7.0 on Type C and got this ....
No (although harmless), but it is showing that the ZIP has changed.Opps, do I load both?
AND
FWDV280.BIN
... to the root or just the .BIN file?
FWDV280-C-71a-Odan0.rbn
Thank you.@0dan0 I tested the 7.1.1 firmware on my Model C scanner and a 5" reel scanned really well. Really great results with my 8mm scan (50' roll, no issues so far).
I'm developing an "Operating Guide" that incorporates your latest changes that I'll post here a little later; will edit as needed to help new-comers.
I did note that a 64 GB card I had been using with Mac84's firmware did not work well with 7.1.1, but a 32 GB card worked well with no issues.
Really liking the ability to set the Frame rate, Exposure Bias, White Balance, and tint. Particularly the recent WB trim adjustment for the LED backlight has been a solid improvement for me.
To confirm, is the Menu control labeled as "Tint" now functioning as a "Saturation" control where -2 is monochrome, 0 is normal color, and +2 equals very increased color saturation?
Thank you, thank you, THANK YOU, for all of these improvements. They are sooooooo good!
FWIW, I am able to save an MP4 file of ~4,000 frames (50-ft roll) created by fw v7.1.1 on my Type B device using the 128 GB SDXC memory card formatted as FAT32 in the attached photo. After the last frame has been scanned, I press the 'OK' button, then select 'Close', and finally turn off the unit before I eject the memory card.Thank you.
Tint always acted as saturation control, but is setting went from 25% to 200% (guessing). I just made -2.0 set to 0% saturation, to make working with B&W film easier.
Yes 64GB card support is broken. Someone will have to go through all the releases to find out when that happened.
Sticking to FAT32 with these units doesn't bother me one bit. That said, I believe that other folks have reported that the firmware (stock and presumably all mods created to-date) formats memory cards as exFAT when someone chooses to use that feature on the unit. That is why I suggested trying to disable that feature in the firmware and/or the UI, to avoid user questions / complaints.It seems than that it is exFAT, not the media size that is the issue. These units do not support files greater than 4GB, so formatting larger media as FAT32 is of little harm.
