I don't think others have reported that specific issue in these threads. My 2 cents... it may be worth requesting a replacement unit. While you might be able to snap things into their right place, it could be that there are other build quality issues connected to the body mis-alignment. Some folks have reported on how delicate some of the inner components are and a weak connection may not fully manifest until after having used the unit for a while.Hello Everyone
I too am very impressed by this very activ Forum, which inspired me to order a Kodak reel. I am based in Europe and sadly I received a D-Typ yesterday.
(H2825148BKxxxxx). So I guess I will have to wait a while till I can install the new Firmware, is that correct?
Also after unpacking I noticed that the 8mm to super8mm handle was stuck about 1/2 cm under the opening and also the SD card reader was not aligned with the slit of the cover. After opening everything, I could shift the loose mechanics into the correct position. It works all fine now, but has anyone had the same issue?
Best Regards
Roderick
Also, since there is no custom firmware for the D unit yet, you've got some time to attempt a replacement with your seller.
