WowIndescribable
Lens extension compatibility
I’m trying to do the lens upgrade but I’ve tried two different M12 lens extensions and neither of them seem to fit the threads on the sensor/board. Has anyone else had this issue? Suggestions welcome.
larryc39
34
34
Yes, sometimes, the chintzy plastic of the lens mount on the sensor board are just destroyed when you remove the lens (or even from the factory perhaps?). If it doesn't easily thread on with a couple tries, buy and install a new lens mount to the sensor board.
Reactions: WowIndescribable
WowIndescribable
Thanks for that. So the lens mount is replaceable…how does one look for/find a 1:1 replacement?
HGSiegel
Ok, I've created a new version of Rev D firmware---thanks for the feedback, @Hook Line and Tinker ! I wish I could test these builds first, but as I mentioned earlier, I'm traveling for a week and not gonna fly with the unit---especially on float planes. :) I've made this more of a diagnostic version that allows testers to give me some answers I can work with. Thank you!
Diagnostic Build — Stage Progress Test (April 15)
This firmware is for Revision D models ONLY. Do not flash on Type A, B, or C units.
This build adds numbered stage markers to the screen so we can pinpoint exactly where the overlay code gets to before
stopping. It also tests whether font rendering works on Type D.
What's new in this build:
- Numbered green squares (1-7) appear on screen as the code progresses
- If a stage is blocked, it shows as a RED square instead of green
- Auto-exposure code is DISABLED in this build to prevent the lockup
- Preview buffer fix — was pointing at the wrong image pipeline
*** ADDENDUM ****
This build also includes new 4:3 sensor patches from the previous build. These are separate from the overlay/stage marker changes but could independently cause issues:
  • OS04D10 sensor output changed from 1936x1076 (16:9 crop) to 1728x1296 (native 4:3)
  • Sensor register table patched: y_start, y_end, x_start, x_end, output width/height
  • ISP mode table updated to expect 1728x1296 input (modes 0-2)
  • Framerate set to 18fps
If the unit crashes immediately on power-up (before any stage markers appear), the sensor patch may be the cause — the ISP might reject the new dimensions, or the encode pipeline might not handle 4:3. If you see at least stage 1 (a green square), the sensor init passed and the crash is in the overlay code.
How to flash: Same as before — copy FWDV280.BIN to a FAT32-formatted SD card (16-32GB recommended), create an empty
NVTDELFW folder, insert and power on.
What to look for: After powering on and letting the unit initialize, look at the screen for small colored squares with
numbers.
┌───────┬─────────────────────────────────────────────────┐ │ Stage │ What it means │ ├───────┼─────────────────────────────────────────────────┤ │ 1 │ Overlay code is running │ ├───────┼─────────────────────────────────────────────────┤ │ 2 │ Frame counter initialized (startup complete) │ ├───────┼─────────────────────────────────────────────────┤ │ 3 │ Preview mode detected │ ├───────┼─────────────────────────────────────────────────┤ │ 4 │ Histogram data found in image buffer │ ├───────┼─────────────────────────────────────────────────┤ │ 5 │ Histogram rendered to memory │ ├───────┼─────────────────────────────────────────────────┤ │ 6 │ Histogram drawn to frame buffer │ ├───────┼─────────────────────────────────────────────────┤ │ 7 │ Auto-exposure checkpoint (stops here by design) │ └───────┴─────────────────────────────────────────────────┘
Please answer these questions:
  1. How many green squares do you see? (e.g. "I see green 1 through 5")
  2. Are any squares RED? If so, which number? (Red = code stopped at that stage)
  3. Can you see numbers inside/next to the squares? (This tells us if font rendering works on D)
  4. Where on the screen are the squares? (Top/bottom/left/right — helps us understand LCD rotation)
  5. Does the unit lock up or stay responsive? Can you navigate menus, or does it freeze?
  6. Does pressing OK still advance film? (Mechanical test)
  7. If you start a capture, do any squares change? (Stages may differ between preview and recording)
To revert: Same as before — format the SD card, or use the stock firmware .BIN to reflash.
I got the exact same result as shown in post #514 with the version you included in post #513: small colour bars and full unresponsiveness. My serial: K2225148BK00... Reverting to the stock firmware worked fine.
N.B.: My previous post #517 referred to your post #509. I'm sorry for the confusion that might have caused.
Asielus
10
1) stick with the the known lens 12mm at 2.8mm. I have three units running 2.8mm all work great. Use: https://www.rmaelectronics.com/azure-photonics-azure-1228mac/
2) Latest 3D spacers: https://tinkerdifferent.com/threads...-film-digitizer-firmware-hack.2897/post-42590
Locking rings: https://www.m12lenses.com/category-s/97.htm
Extension tube: https://www.m12lenses.com/7mm-Metal-Extension-Ring-for-M12-Mount-p/pt-erm12-700m.htm
3) I haven't seen one
4) Try it. Pec pads are working for me, haven't tried anything else.
Is there a manual on how to perform the 12mm lens replacement?
ThePhage
71
66
Deano has in this post what is probably the most comprehensive report on the process.
From the firmware guide, here's a running list of links to such posts:
hobbified
Hi,
I just bought a new unit, serial J2925148BK00028, which is a format that I haven't seen mentioned by anyone else. It seems to be a "type D" unit (works after flashing the D stock firmware).
My results with the Post #513 firmware are the same as HLT and others have seen: two red and two green bars in the upper-right corner with a bit of detritus beneath, no takeup reel activity, and no response to the controls besides the power button.
I have a bit of familiarity with embedded dev, and I can talk to the UART, but I haven't opened the unit up just yet.
ca.ro
I haven't caught up on this thread but it's exciting to see all the new posts!
I just thought I'd share something briefly. A company reached out to send me a Movie Maker Pro for review. I just took it out of the box and was curious how the capture quality compares with the Kodak.
I'm unsure if I got a lemon or what, but the Movie Maker seems to be wildly out of focus!
I hope to do an in-depth review and tear down of this product in a future video, but I thought you'd all appreciate a quick look. The top screen grab is from the Movie Maker, the later from the Kodak.
View attachment 27785View attachment 27784
Hello @Mac84!
I was wondering if you got any improvements out of the Movie Maker Pro (Eyesen branded). I've got the same unit and would like to hack it for a bitrate update as you guys incredibly did for the other scan models!
Bye!
edale
7
i bought my unit about 12 months ago and copied a number of cines. My serial number indicates it is a type c unit and so i downloaded the latest c firmware which appears to have been sucessfuully installed(see attached picure of the flash screen. everthing seemed to work and when i went to record the display screen seemed to be right but when i pressed ok the attached strange screen appeared ( i now find itt has been saved a .mov file) and nothing happened and a short period it returned to the display screen. i tested the rewind function which worked ok. any suggestions
  • IMG_0827.MOV
ThePhage
71
66
I remember seeing that before. It could be that you simply need to power it off after the successful firmware update, and power it back on to use it normally. Or if it's not that, please report on what size and format you're using for your SD card for capturing?
edale
7
i have tried 3 different sd cards kodak 32gb, kingston 8gb, sandisk 4gb all with the same resuit. i slso treid to load the previous firmware version 7.3 and then turned off with same result. i have read the user guide and i seemed to have followed the guide. however i do not hace osd options on capture but i presume this is because my software has not reached that part of operating instructions. Do youi suggest that I try version 6 or before or eveb download orginal version and start again?
edale
7
i have tried version 6 and orginal version and i get same result. i have tried fast forward which works with no film inserted so the motor is working correctly. any suggestions
edale
7
I have solved my problem I had to erase sd card within kodakreels software. I had previously alrready reformated my cards with partion magic but somwwhere within kodak it retained some code. Whilst I have not had time to test the updated firmware everthing seems OK
ThePhage
71
66
What format (NTFS, ExFat, Fat32, etc) were they formatted under "Partition Magic"?
ThePhage
71
66
the sd cards were formatted in fat32 by partition magic
Thanks edale, I have revised the firmware user guide to suggest using the scanner to format the card properly. I too have seen some strange behavior that seemed to resolve after formatting with the scanner.
edale
7
I have now had the chance to set out the new firmware and comeaccross 2 problems i do not seem to able to access some of controls eg setting fps rate . Secondly when i try to replay a recording most of the time nothing happpensd and i cannot then either scroll down the screen or return to the main menu none of buttons seem to work. Occasionally if i hold down to button to replay the screen comes up but ask to restart which takes me back to begining. Any ideas should i reinstall firmware?
7
What are the first 5 digits of your serial number?
