440
600
I have now had the chance to set out the new firmware and comeaccross 2 problems i do not seem to able to access some of controls eg setting fps rate . Secondly when i try to replay a recording most of the time nothing happpensd and i cannot then either scroll down the screen or return to the main menu none of buttons seem to work. Occasionally if i hold down to button to replay the screen comes up but ask to restart which takes me back to begining. Any ideas should i reinstall firmware?
That is normal for the hacked firmware, playback is broken. To improve the image quality, more memory is used for capture, so on the unit playback suffered.
ThePhage
74
66
Playback function from the scanner has been broken in the recent firmware mod efforts. It is documented in the user guide:
Scanner Cannot Playback Captured Files. Some firmware versions have broken the scanner's playback capability. Workaround is to transfer your files to a computer for reviewing/editing/storage. Discussed in post #870 and elsewhere in thread.
As to the frame rate setting (while using 0dan0's firmware for A,B, and C units) have you tried this during capture?
  • During Capture, press the up/down arrow buttons so that the OSD "FPS" value is selected in brackets
  • Then press the +/- buttons to adjust the frame rate
  • Is not written to the file until the capture is stopped
  • 8mm film is 16 or 18 fps; Super8 film is 18 or 24 fps
However, if you are attempting to use VideoDoctor's work-in-progress firmware for Version D scanners, the frame rate change may not currently be supported or needs work.
Mark Dawson
10
Hello, I hope someone out there can help with this issue. I've got myself into a bit of a downward spiral having tried the firmware updates. Has anyone else experienced this screen before and if so what does it mean? All appears to be fine but this appears when "record" is selected and it's impossible to proceed beyond that. Grateful for any info! And could someone point me towards the link for the original Kodak firmware please; I think I want to try to restore the factory settings, make sure everything works and then start from the beginning again. It's a RODREELSEU model, Serial number is C1725148BK00614, which I assumed to be a "C" model but I'm wondering if this is correct, any thoughts?
omega
36
Don't you have a firmware file on the card? That's what happened to me with the forgotten file. Or a different card format, it should be FAT32.
Mark Dawson
10
Thanks for the reply. Strangely, several hours after installing the firmware, the problem seems to have resolved itself and that strange screen is no longer appearing, no idea why! I do have a few other issues and queries but I'll put these in a new post.
ThePhage
74
66
@0dan0, reporting a new issue. I'd describe what I'm seeing as a intermittent "wobble" or waviness where vertical lines from subsequent frames are not consistently straight/vertical.
I'm currently running firmware 7.7.1 on a modified C scanner (8mm film with a 12mm lens).
Investigation so far makes me feel that it might be an artifact of the shutter speed setting, or some other Auto-Exposure related control. With the scanner set to Auto Exposure mode, I notice the wobble when the source image is inherently bright, which sets the ISO to a low value (50). However, when the image is very dark, and the Auto exposure adjusts a higher ISO (100, 200, 400) the wobble generally does NOT appear.
I have some further video that demonsrates what the on-screen display displays when the wobble happens, and when it doesn't. I'll share it with you if you like.
If it sounds like I'm on the right track, and if you have time, perhaps you could provide a test-build where a minimum ISO can be set, or a similar setting for the shutter (max speed or min speed). That could help validate what I'm seeing with bright footage.
As an alternative, I may purchase a lighting diffusion sheet or ND gel and stack it on the LED light plate (under the film) to cut the brightness of the backlight illumination, which could force the ISO/Shutter into a range that doesn't result in wobble artifacts.
Thanks!
edale
in case anybody else has this problem the answer is erase the sd card with the kodakreels software and then restart it should then work
Asielus
Deano has in this post what is probably the most comprehensive report on the process.
From the firmware guide, here's a running list of links to such posts:
That's a big help. Thanks a lot!
Mark Dawson
10
Has anyone in the UK or Europe tried the 12mm lens upgrade? if so could you tell me which lens you obtained? The one recommended in this thread seems to be very difficult to source this side of the pond!
GilDS
Hello everyone!
My scanner has a problem with its flashlight; it no longer works.
After reading all the posts, I still don't really understand how to get the original firmware for the scanner !
I haven't modified it yet.
The serial number is K2225148BK0xxxx, and I don't yet have an SD card specifically for it.
Which one should I buy, and does it need to be formatted as FAT32?
I'd then like to consider modifying my camera with the latest FireWire update for this model.
Thank you!
Gil
ThePhage
74
66
Hello everyone!
Thank you!
Gil
If you haven’t modified it yet, you may consider returning/replacing it (if applicable). Probably defective. You wouldn’t need any firmware to deal with that situation.
GilDS
Hello,
Thank you for your reply.
Yes, I've already taken the necessary steps about replacing, and this resulted in a refund and the option to keep the item.
So I'm trying to find solutions to fix it.
fishgee
31
Hello,
Here's what should happen when you insert the power cable (12V @ 1.5A), and press the Power button:
1) White power LED illuminates
2) Large center display lights up, shows the Kodak logo
3) The Capture/Menu/Settings menu is displayed
4) The motor turns on for 1 second
You then insert an SD card (32GB, formatted as FAT 32 will work) (you don't have to have film loaded for this test)
5) Press the OK button with the Capture option higlighted
6) The film exposure lamp lights under the film transport
7) Press the OK button (twice) with the Record menu selection highlighted
8) The transport motor will turn on and run, attempting to capture frames
At what step does your unit fail?
WowIndescribable
6
I’m installing the 3D printed spacer for the upgraded lens and have questions.
it seems that the back is resting on one of the board components and this doesn’t look right. If I assume a bit needs to be filed away so this doesn’t happen, then it would seem that the recessed part of the 3D print does not allow for all four screw locations to sit flush on the same plane with the board.
i hope that is clear from these photos. Am I missing something?
