elling
I'm back!
melw, your type-D firmware from #695 is running well on our H2825.
A few things for anyone else doing this with an H2825:
  • Standard install worked first try! (FAT32 with FWDV280.BIN in the root, with an empty NVTDELFW folder for good luck)
  • The 32 GB limit: For the first run I tried a 128 GB Lexar V30 and it stalled within a few minutes every time (CARD STALLED / AUTO-STOPPED / FILE SAVED) but everything was saved automatically and the same reel on a 32 GB card ran fine.
  • Film jammed partway through one reel, so auto-stop was triggered and saved the file
After comparing earlier scan, I'm very happy with this! There's noticeably better tonal range, and it's less mushy for sure.
No freezing so far and I've done a reel and a half. Thank you Hook Line and Tinker and melw!!
A still from a dark Kodak Tri-X B&W scan:
BEFORE (I believe this was set to -1.0 exposure, -2.0 sharpness, not sure of the tint, it seems to be reduced. If you've adjusted your image settings, I recommend before updating your firmware making a note of what they were):
AFTER (-0.5 exposure, -2.0 sharpness, 0 tint):
JohnCT
26
10
Glad it helped and hope your unit works when you get the socket in.
"proven safe" --- Read the disclaimer in the first post and decide if you want to take the risk. Many have, including myself, and are happy with the results. If you're uncomfortable updating the firmware, some have gone ahead and archived their collection with stock firmware before experimenting with the modifications. You took the risk on the damaged unit, why not go ahead and try the enhanced firmware?
I think the 4th and 5th digit of the serial number seems to loosely follow the year of manufacture so I would say yours is a more recent unit.
Looking forward to hearing about your results and if you run into trouble, someone here will probably be able to help.
Well, I think I reached the end of the road.. :(
I removed the hacked-in micro reader thingy and installed a new SD socket onto the main board, then installed a new SD card. The unit powered up, and this time it went to the scan screen when I pushed the OK button and it didn't ask for the card like last time.. But, then it again asked for the card. With it running (I know), I fiddled with the SD card and found that the new socket is, I believe, defective. The card won't lock into the socket - the spring inside pushes the card back out. There is no flux inside the socket as I'm very experienced with that type of repair.
But while I fiddled with the SD card and tried to get it to lock, the Kodak shut off. I pushed the power button and no white power LED. I unplugged it for half an hour and still nothing. I disassembled and reseated all the ribbons (they are in good shape as are the ribbon sockets), but still nothing. I get 12V on the input board and 3.3VDC on the main board. I get 3.3 on the keyboard, but I don't see any SDA info on the keyboard. Under a microscope, I don't see any fuses. The board stays "cold" when power is applied.
There are four pins on the SC socket reading at ground potential, which seems like two or three too many. I'll check the pinout if I can find one on line and see if that's correct, and if not, see if removing the socket will clear the shorts to ground.
EDIT: the pic of the card socket with the red pins show which pins are reading short to ground. I haven't removed the socket yet, but will. But if this is the end, then thanks everyone for the advice!!
John
SECOND EDIT: I found out that pin 4 is Vdd (power source), so it should not be grounded. When I get a chance, I'll remove the socket and see if the short goes away. If it does, I'll order a socket that doesn't use a spring loaded mechanism because internet searching suggests the new socket could have failed mechanically inside shorting pins. Hopefully it didn't trash the board.
Reactions: ArgieBargie
Mearcstapa
Hello all!
I recently purchased a Reels unit myself, and have spent much time poring through the discussions here about it.
My unit is a serial M2025 and works with melw's Type-D custom firmware. I will probably wait until I have finished an initial pass of my stockpile of old family films before attempting to upgrade the lens.
Before getting started, I wanted to ask: In the old thread, @0dan0 posted a picture of pec-pads wrapped around the guideposts on his unit to reduce scratching. I was wondering, how did you affix the pads to the posts; some kind of glue or adhesive tape?
Teflon tape was also suggested for the guideposts as an anti-scratching method in another post, but then discouraged in another still. I am terrified of damaging/scratching my film in any way, and cannot find definitive guidance on this.
Thanks to all for the wealth of information and software hacks shared thus far.
Reactions: JohnCT
mpc2000
Hello,
first of all, thank you for the great work on this project!
I recently bought a Kodak Reels scanner in Europe. It is the European version, RODREELSEU, and the stock firmware reports version 2.0.
The device’s serial number is D0926148BKxxxxx.
According to the database, I should use firmware version B. However, with version B, I can’t use the buttons. Versions A and C did not work either; they displayed distorted colors on the startup screen.
However, the D WIP firmware from August 24 works fine :). The stock firmware version D also worked, in case I want to revert to it.
So far, the scanner has frozen twice while scanning. It continues moving the film, but the screen freezes, and the only button that still works is the power button. I am posting the on-screen text from those moments below. Maybe it could be useful for debugging?
Reactions: melw
34
20
Hello,
What size SD card are you using and is it formatted to FAT32?
34
20
That card should be fast enough unless it's counterfeit or defective which doesn't seem likely.
August 24th "D" version from post #695 should have the stall feature so it's odd that you're experiencing this.
When you say, " formatted to FAT32 in the Kodak Reels" what do you mean by that? My Reels unit has an erase option for the card but no format option. Did you format it with a Windows PC?
It is a 16GB Sandisk Extreme. It is formatted to FAT32 in the Kodak Reels.
KingTyla
I'm new to the forums but Ive been asking around on if there is anyone with the existing bin files for the original Wolverine Film2Digital Movie Maker. I attempted to modify mine and flashed a firmware for a different hardware and broke it. The firmware I was on prior to flashing was 20161103-P08b.
If anyone has that firmware or one that works I would very much appreciate a link. Thank you guys in advance.
jmccabe
How to adjust custom settings? I just got a brand new Reels scanner this week and the work-in-progress D firmware from 2026-Aug-24 seems to be working fine for my first test reel. However, I'm confused about how to adjust the custom settings, can someone explain how a user can change the settings?
The User Guide and Reference gives the impression that some settings are changeable before capture, and others during capture, but I don't really see any way to change them before capture at all. During capture, at least on this firmware, it seems like the arrow buttons don't do much. The on-screen display shows various things but the setting with [ ] brackets is "sel: [FPS]" and if I use the up/down arrows it stays on "sel" but simply lets me pick other values (instead of just "FPS"). The left/right arrows do nothing during capture, as far as I can tell.
Is there a guide that goes into more explanation about how the settings are meant to be tweaked?
In good news, the default settings seem pretty good, already a huge improvement over a couple things that were dealbreakers for me in the stock firmware (auto white balance turned off, improved resolution, 18 fps metadata on the final MP4, etc)
Thanks to everyone who has advanced the project this far already!
34
20
Maybe you've already seen this but post #653 has instructions for changing settings:
For me, they are not intuitive and I don't think I'm using them correctly so if you figure out the best way to tweak them, please share!
I agree that the defaults are good and I agree with your deal breakers.
melw
42
64
Type D — New build, found and fixed a freeze bug (please test!)
Short version: Found a bug in my code that causes a freeze, and it's fixed in this build.
I can't promise it was the only one. So please try this build and report back — including "no problems here", which is also as useful. The only way to measure a random failure is over a lot of captures.
Freeze bug in detail
The firmware hooks the device's UI timer. A piece of hand-written assembly that jumps back into the original timer routine was holding the jump address in a CPU register that is reserved for the interrupt handler. If an interrupt took place in a two-instruction window, the handler overwrote that register, and the jump went to a garbage address. Instant hard lock: screen frozen, film still advancing, buttons dead, no file saved.
That fits the issues reported and what I've seen in my testing:
  • Random timing — it needs an interrupt in a ~2-instruction window, so it can hit at frame 100 or frame 3000
  • No correlation with anything — not Qp, not frame size, not bitrate, not recording length. It's interrupt timing, so none of those matter
  • Motor keeps running — the motor is driven by hardware, not controlled in the same code path
Also fixed: Random "CARD STALLED" auto-stops
Separate bug. The stall detector declared a problem after ~1.5 s without a new frame — but the scanner only produces about 1.8 frames per second, so frames are normally ~0.55 s apart. That left almost no margin, and a slightly larger frame or a momentary film-advance hiccup could trip it and abort a otherwise healthy capture.
Regarding the changes done:
  • Thresholds are now ~3 s to warn, ~5 s to stop — a real stall still gets caught quickly, a hiccup doesn't kill your capture
  • The message is now "REC STALLED", not "CARD STALLED" as the stalling may not be related to SD card performance at all
  • If you reported the auto-stop firing on normal footage — could you tell me whether the message said CARD STALLED or REEL ENDED? If it said CARD STALLED, it was likely hitting this bug
Other changes
  • Bitrate is selectable — new BR menu item: x1 (~8 Mbps, stock), x2 (~16), x4 (~32). Default stays x4
  • The Qp floor is now OFF by default. It was added to prevent an encoder crash that, as far as I can tell, was never actually happening — and at x4 it caused auto-stops by pinning the rate control so it could never reach its target. Still selectable (-, or 15–22) if you want to experiment, but leave it off unless you're troubleshooting. Raising it at x4 bitrate can cause auto-stops
  • Diagnostics survive a stop — Qp / Sz / C u m no longer reset to zero the instant recording ends, so they can still be read after an auto-stop
  • Build number on screen — FW 265 in the top right. Please include it in any report — makes it easier to distinguish which build version was used
The settings menu has been reworked
Now the [ ] marks the value you are editing, directly:
WB gains:
[689],256,204     <- editing red
FPS: [18]
BR: [x4]
ASt: [ON]
Qp:22/16 f[-]
Date:
[1984]-09-01
[Reset]
  • Up / Down — move between settings; the brackets walk down the list and wrap around
  • Left / Right — change the value by a big step (white balance moves in 16s, the year in 10s)
  • Minus / Plus — fine adjustment, one step at a time
Few things worth knowing:
  • Settings can only be changed during a recording. In preview the stock firmware owns the buttons, so there is nothing to find there — you are not missing a menu
  • Settings are saved and survive a power cycle. So the easy way is to start a short throwaway recording, set everything up, stop, and then do your real captures. [Reset] puts everything back to defaults
  • FPS and BR settings only apply for the next recording cycle, not the currently ongoing one
What I'd like from you
  • Try it on your normal reels and say how it goes — good or bad
  • If you do hit a freeze, photograph the frozen screen. It now shows the build number, bitrate, Qp range, frame sizes and total bytes in one shot
  • If anything else behaves oddly, just let me know!
  • FWDV280.BIN
melw
42
64
Hi @jmccabe - please try the build I just shared (forum post #731). Among all the fixes, reworked also how the menu & settings functions. Hopefully it's bit more usable now!
Helmuto
hi, i just bought a Kodak Reels over Amazon (seller was get your goods GmbH). I am in Austria and have 50+ 20cm rolls to digitize.
I hoped for a D-Type to be able to use your latest firmware. But i could not find my serial number anywhere in this thread: D0926148BK00321
Any ideas what type i have got?
The picture quality of the stock firmware is actually not that bad. But the film transport is quite bad and i need to do a lot of post-processing. I am currently using Final Cut Pro, but want to switch to Davinci Resolve.
If there is a thread to discuss how to improve the film transport i would be happy if you could point me to it.
but really cool, that you already put a lot of time into reverse engineering that hardware/firmeware to improve the picture quality.
melw
42
64
Hi! Another update.
D-Type FW 270 attached. Still few more tweaks on top of build 265.
  • Fixed the OSD flicker. The stock UI was clearing the UI layer in two different places. The OSD now redraws immediately when that happens.
  • Stall auto-stop timing corrected from build 265. 270 is back to ~8 s to warn, ~12 s to stop. The x4 auto-stops some of you saw were caused by the Qp floor, which has been off by default since 265.
Source code
The project is now public, MIT-licensed, and buildable: https://github.com/melw/reels-type-d
  • User guide: the menu, what every OSD line means, the auto-stops, troubleshooting
  • Build instructions: Windows + WSL. Building 270 from the repo reproduces the attached file byte for byte.
  • Technical notes: every hook and address, the RAM and settings map, how the rate control works, and the rules for writing new hooks safely
The repo contains no firmware binaries. It builds on top of videodoctor's Type D firmware (post #225 in this thread), which you download yourself; the build checks it by SHA256. Big thanks to @videodoctor for that base and the original Type D work, and to @0dan0 for the A/B/C project this all grew out of. The menu approach and the font are his.
I'm nearly done with my own reels, but the repo is there so anyone can pick it up, fix things, or port to other future models. Pull requests and issues are welcome. And thanks to everyone here who tested builds and sent freeze photos: that is what made the fixes possible!
  • FWDV280.BIN
RudyWells
Hi! Another update.
Source code
Supportive lurker and D owner here. Nice! Thank you for this work and sharing, it's super appreciated.
Reactions: melw
jmccabe
Hi! Another update.
Source code
Thanks for the super-fast update! It's perfect timing for me because just today I had my first experience of the capture process aborting (on my 8th reel, only 112+ to go). The digitizer was continuing to move the reel along just fine, but about 15 minutes into the scan the software was no longer capturing and had stopped responding to button presses. I had to unplug it from power in order to reboot it.
The new firmware seems to be working fine so far! The only weird surprise for me is that when I booted up with the new firmware on an SD card, it didn't apply the update, and continued to boot up in the existing firmware (from last month). It initially seemed like SOMETHING was happening because the boot-up screen was present for like 15-20 seconds, instead of the usual 4 or 5 seconds. But when I started another capture, I didn't see the new firmware indicator in the upper right. To investigate, I turned it off, unplugged the power supply, checked the SD card on my computer to make sure it was the new firmware (it was), then powered up again. On this second power-up the screen stayed black and it successfully applied the firmware update just fine.
Thank you so much for adding the FW build number on the capture screen now! It made it trivial to verify that I had the correct version installed.
And again, I can't say this enough, thank you so much for putting these updates out into the world for us to use, totally for free! I'm unlocking a bunch of childhood memories from 50+ years ago and this improved firmware raises the quality level to something I will be happy with for a long time.
Jim
Reactions: melw
34
20
but really cool, that you already put a lot of time into reverse engineering that hardware/firmware to improve the picture quality.
I don't think D0926 has been verified yet so there would be a risk in trying new firmware. Based on the serial number, I think it is safe to say it is either type "D" or a new, unidentified variant so don't try "A" "B" or "C" versions. I think the version tool was created when there were only three known variants and some have said unknown serial numbers receive suggestions to use "B" but again, when the 4th and 5th digit is a 25 or 26, I think it is safe to say these are not "B" units.
Regarding the film transport problems you're having, could you be more specific?
This is what works for me:
1. Thread the film per the original instructions
a. Film must pass under all 4 tabs
b. I thread the film exactly as the instructions suggest, using all stationary idler pins
2. Make sure super 8 vs. regular 8 is selected appropriately
3. Advance the film to where the frames start (not the leader)
4. Power the unit off and back on to set the initial position (important step before making frame position adjustments)
5. Use the frame adjust function to center the frame
a. I go all the way left, then all the way right, not including the sprocket windows, counting the clicks, then split the difference - same with up and down
1. Some zoom all the way out and trim with software later but I think you're trying to avoid that. Either way, you need to at least be centered top to bottom
6. Start the recording and monitor. Should be good at this point but might have to readjust once
Others on here have had luck letting the film collect into a basket rather than using a take-up reel but for some reason that doesn't work for me and the tension when threaded per the manual seems to keep the frames centered with no need for post-processing.
Reactions: Helmuto
mpc2000
My fault. I erased it with the Kodak. I formated it to FAT32 on MacOS.
mpc2000
Hi, in post #724 i wrote about my new scanner from in germany. I have almost the same serial number (D0926148BKxxxxx) an d it works with the D-Firmware.
I can confirm transport issues on some film rolls. Others a working perfectly. Until now i do not say, what is the "point". But i scanned only 12 rolls until now.
Davinci Resolve Studio works great for me with stabilizer, auto dust remove and deflickering. (Maybe not perfect, but for my needs good enough)
Reactions: Helmuto
jmccabe
Small update - I've been using the D 270 firmware for a few days and it's been absolutely rock-solid, completely reliable. I've scanned about 12-15 reels with this latest build and it has performed perfectly the whole time.
Reactions: melw
