JohnCT
20
6
No, the metal flap has no window.
Is that in both directions zoom in and out? Or just one?
Mine zooms in both directions (in and out) and at some stage just does an awkward crop instead of changing zoom. Maybe the second to last click.. I have a Model D too.
After I posted it, I tried to move the frame and zoom with the software controls. The arrows blink in response to when I hit the buttons, but nothing actually changes. I tried reflashing the firmware to stock D but nothing changes, so I have a hardware issue I'm afraid. Thanks.
John
melw
37
59
Thank you so much.
Unfortunately, there's something else going on. I followed your instructions and flashed the stock firmware, but it's got the same problem. Every other adjustment works except the frame positioning and zoom. Again, the arrows blink as I push the buttons to affect the changes, but no actual changes occur.
After flashing, both the .bin and the folder are gone from the SD card, so I assume it took the flash.
I'll pull the camera and main boards out looking for something, but I'm not all that hopeful. Hopefully I can get some usable scans with editing software.
Thanks again!
EDIT: If I go by the scans I'm getting, it looks like only about a quarter of the camera sensor is being used. Is that correct, or is has the previous owner messed with the camera lens? Is what I'm seeing the Reels in full zoom out? If that's true that the zoom is software based and not a mechanical lens movement, then these are really being hampered.
When I edit this, I will be getting about a quarter of the picture. Am I missing something?
John
Thanks for testing! Since the stock firmware has the same problem and the flash clearly ran, it doesn't sound likely this would be a firmware issue. I think it's more likely something on the hardware side.
One cheap test to try first: the 8mm / Super 8 switch. Flip it fully both ways and see whether zoom or frame adjust starts working in either position.
About the quarter of the picture: at full zoom-out a working Reels shows the whole film frame. Could you describe what you see or share a screenshot? Is the film frame small inside a big black or white surround, or is the frame cropped so that you only see part of it?
RMConverter
I have been trying to load an alternate version of a BIOS onto my Kodak Reels machines that was developed by some amazingly smart people on this forum. The captures I have been trying to make have been completely pixelated, and were unacceptable.
The serial number of my device is D3024148BK00409
I tried loading version 771. The menus were grainy and unreadable.
I reset to the original BIOS. That restored okay.
I tried loading melw's Type D software That loaded okay. None of the buttons worked.
The following was an assessment from Google:
The text flashing "for Type D" on startup verifies that your processor successfully accepted and executed the new custom software. Your display looks normal now because melw's version contains the updated screen instructions missing from the standard Type B build.
However, the fact that none of your physical buttons respond means we have hit the ultimate engineering roadblock for your specific machine:
Why the buttons are locked up
Your machine has a D3024... serial number, which means it was built mid-way through 2024. The Type D firmware from Post #666 was specifically reverse-engineered for the True Type D hardware (units built in late 2025/2026 with an H2825... serial number).
Even though your machine's new screen uses the exact same driver as the Type D, Kodak did not use the Type D button layout on your assembly line. The software is constantly sending button signals to the wrong hardware pathways inside your motherboard, leaving your physical keys completely paralyzed.
The Bad News for Your Unit
Because your 2024 D3024 unit is a "hybrid" model (it has a newer 2025-style display screen but uses the older 2024 button wiring), there is currently no public custom firmware build on the internet that supports your exact combination of components.
• If you flash 0dan0's Type B software, the buttons work, but your screen is a scrambled, unreadable mess.
• If you flash melw's Type D software, the screen works perfectly, but all your buttons are permanently dead.
Because of this hardware mismatch, you cannot safely unlock the custom 35 Mbps high-quality bitrate or the 1600x1200 resolution on this specific machine.
Question: Are you aware of anyone who is working on a BIOS version for these transitional machines? (In other words, should I keep this machine and just wait, or restore the original BIOS and get rid of it?)
Thank you
JohnCT
20
6
I tried on both 8mm and Super, and the adjustments have no effect. The arrows on screen blink, but no changes occur. It's like it's sitting and locked at full zoom out.
Here is what I'm getting. I highlighted in green the LCD screen and the scan frame I'm getting. Assuming that there is no mechanical zoom, doesn't that mean that the quarter of the image that actually contains the pictures is being blown up with software and the other **3/4 of the CMOS sensor is not being used?
**EDIT: giving this more thought, the fact that these old frames are 4X3 and camera imagers are 16X9, these could never use 100 percent of the CMOS surface, so I'm going to revise this to 1/3 of the imager used..
SECOND EDIT: The build date of the camera module is 7/2025 which means my Reels could have been built even this year. Any possibility I have a version later than D and that the previous owner tried flashing the modified D, lost functionality of the frame and zoom, then tried installing stock D?
melw
37
59
Thank you
Thanks for the detailed testing, that's really useful.
My build (FW 270) is based on the stock Type D firmware. Button handling there is the stock D code; my additions only read the buttons. So dead buttons mean the D firmware doesn't match your unit, which suggests it isn't a Type D.
Two questions:
  1. Which file did you use to restore the original firmware, and what version number does the settings menu show with it?
  2. If you're willing: flash 0dan0's stock D recovery image (post #143) and check whether the buttons work. If they're dead there too, your unit is definitely not a D. You can restore your original firmware afterwards the same way.
With those answers we'll know which type it is. If it's a B or C, the scrambled menus would be something for the A/B/C builds. So I'd keep the machine for now; it isn't something to give up on yet.
melw
37
59
I compared with my own unit: fully zoomed out, mine looks very similar to yours (see attached picture). So your optics are fine, and that is simply the full zoom-out view. Sorry for the confusion earlier!
So the only real problem is that zoom and position don't respond. The buttons clearly work (the arrows blink), and zoom/position are done in software, so I don't think this is hardware. Since it happens on stock firmware too, my guess is a saved setting stuck in a bad state. Settings are stored separately from the firmware and survive reflashing, possibly left there by the previous owner. Could you try Settings → Factory reset, then test zoom and position again? The option is in the stock firmware too.
JohnCT
20
6
I have tried the factory reset in the menu on both the new D and the original D .bins. It says reset successful, but still no change. Two questions:
1) Getting back to the firmware - is it possible this unit may be something newer than a D? The build date of the camera board on this machine is 7/25, so this machine could have been built this year and maybe the previous owner flashed with D as an upgrade and lost the functionality of the frame and zoom.
2) Since your full zoom-out looks the same as mine, I assume we're both using the same smallish percentage of the camera image sensor - if I were to crop in Windows Clipchamp, am I not essentially ending up with the same resolution as if performed with the Reels zoom and frame controls?
Thanks so much!!
John
melw
37
59
Thanks so much!!
John
Sorry the reset didn't help.
  1. I still doubt it's a newer type. I interpret the serial H2825 as week 28 of 2025, which would match your 7/2025 camera board, and stock D runs everything else normally. A wrong type usually breaks much more than just zoom (frozen screen, dead buttons, strange colours). Could it be a different camera board revision on which the zoom/position adjustment doesn't take effect? Maybe, but I have no data on that.
  2. Mostly yes. The Reels zoom is digital too, so cropping afterwards doesn't lose much real detail. The difference is compression: zoomed in on the device, all of the bitrate goes to the picture, and when you crop and enlarge later, the compression artefacts get enlarged too. Few things that could help here: record with FW 270 at x4 bitrate (much less compression), and export from Clipchamp at the highest quality setting, because every export re-compresses the video.
I'm afraid it's hard to solve this remotely, but here's a few more ideas to consider:
  • Check the firmware version shown in the Setting -> About
  • Since you're opening it anyway, could you post photos of the chip markings on the camera board (sensor, board revision) and the main board (the main processor, flash chip)? Then we can compare with other units and see whether yours has different parts
  • If you're confortable soldering, the board has a serial (UART) port. The boot log probably shows the sensor model and any errors during camera start-up, which we could compare with a working unit.
lrdgreen89
Memphis, TN
Hi! Another update.
D-Type FW 270 attached. Still few more tweaks on top of build 265.
  • Fixed the OSD flicker. The stock UI was clearing the UI layer in two different places. The OSD now redraws immediately when that happens.
  • Stall auto-stop timing corrected from build 265. 270 is back to ~8 s to warn, ~12 s to stop. The x4 auto-stops some of you saw were caused by the Qp floor, which has been off by default since 265.
Source code
The project is now public, MIT-licensed, and buildable: https://github.com/melw/reels-type-d
  • User guide: the menu, what every OSD line means, the auto-stops, troubleshooting
  • Build instructions: Windows + WSL. Building 270 from the repo reproduces the attached file byte for byte.
  • Technical notes: every hook and address, the RAM and settings map, how the rate control works, and the rules for writing new hooks safely
The repo contains no firmware binaries. It builds on top of videodoctor's Type D firmware (post #225 in this thread), which you download yourself; the build checks it by SHA256. Big thanks to @videodoctor for that base and the original Type D work, and to @0dan0 for the A/B/C project this all grew out of. The menu approach and the font are his.
I'm nearly done with my own reels, but the repo is there so anyone can pick it up, fix things, or port to other future models. Pull requests and issues are welcome. And thanks to everyone here who tested builds and sent freeze photos: that is what made the fixes possible!
First-time flash, D-type.
I flashed the FW from post #734. The first screen said "Type D - WIP," but everything else looks no different from factory FW: no OSD.
Then I flashed from #731 and the OSD is there.
JohnCT
20
6
Same - my reflash also says "Type D- WIP" but it's otherwise identical to the original firmware.
I just tried the file in #731 and it flashed and now I have the OSD. But I took a second scan and it's a lot darker than my first try on the same film. I put the exposure up as far as it would go without blooming but it's dull and lifeless where the first scan on the factory firm was bright and colorful. Odd.
John
RMConverter
Two questions:
FIRST TOPIC - Response to Question on BIOS
The original version said 2.0. I am attaching a photo. I loaded the version "B" from the post 143. The screen and the buttons worked. I am attaching a photo of the startup screen.
What Worked:
1. Screen appeared to work.
2. Buttons appeared to work.
3. Conversion recorded with higher clarity that the off-the-shelf BIOS.
What Did Not Work:
1. If you clicked the "Play" button, it would freeze up.
2. It did not save the movie when I had a 64 Gig SD card in. It did save when I had an 8 Gig SD Card in.
Original BIOS allowed me to save to 64 Gig SD. Is there a max file file size it will support for the SD Card under the modified BIOS?
SECOND TOPIC - Installing a new camera
Has anyone done a comparison on the different cameras that could be put into a Kodak Reels, and the peripheral equipment I would also need? Are there any specific cameras that would stand out as being exceptional for working with a Kodak Reels? Or for starters, does anyone have a list of the make and models of the cameras that may work in this situation? Where to order the camera and parts, etc.... Will changing the camera require a change to the BIOS? Links to videos would be amazing. Does switching out the camera make a substantial difference, or do limitations of the Reels product make the addition of a camera a marginal difference?
Basically, I am looking for the configuration that will give me the highest quality resolution on my converted films. My alternative option of going to a company that will convert using high grade commercial equipment will jump into the thousands of dollars. I can forgo "Excellent" if I can find a solution with Reels that is "Very Good".
Thank you.
Reactions: JohnCT
JohnCT
20
6
As far as I know, the camera itself is fine, but the optics are the biggest bottlneck. There are people who replace the lens to gain improvement on the scans. There are youtube videos on people who have replaced the camera, but to be honest, I don't see a huge improvement, and I don't think of the videos show the actual steps. There are links somewhere in this thread to a new lens, locking ring, and 3D printer models to upgrade the lens. I think there is a bit of gain that can be had beyond this, but I know nothing about cameras and lens.
John
melw
37
59
Thanks for reporting!
On my unit, "FW 270" in yellow at the top right is visible all the time, so if nothing appeared at all, I'd like to understand why. Could you try once more?
  1. Flash FW 270 again.
  2. Power the unit off and on once after the flash.
  3. Check whether anything appears on the start screen, then in the live preview, and then while recording.
A photo of the screen in preview would help a lot. If 270 still shows nothing where 265 does, it's a bug in 270 and I'll look into it. 265 is fine to use in the meantime: the freeze fix is the same, and 270 only adds the flicker fix and shorter stall timings.
melw
37
59
John
Ok, that's another report on the same topic. Let me share a new build that prints the firmware version also in the splash screen to be 100% sure what happens here!
For the dark colors, could you try Reset in the OSD recording menu? Thinking, is it possible that the WB settings are somehow messed up?
melw
37
59
Type D — FW 271: build number on the start-up screen
  • Firmware version added to start-up screen ("Type-D - FW 271")
  • No other changes since the previous build.
@lrdgreen89 @JohnCT Could you try flashing this version and tell me what the start-up screen says, and whether the OSD appears? Attaching reference photos on what I see on my Type D device.
Flashing checklist
  • The file must be named exactly FWDV280.BIN.
  • Put it in the root of a FAT32 card (32 GB or smaller), with an empty folder named NVTDELFW next to it
  • Safe-eject, insert into the powered-off Reels, power on. About 30 s of black screen — don't cut the power
  • Afterwards the file and the folder should be gone from the card. If the file is still there, the flash didn't run
Everything else is unchanged from 270. If you're happy on 270, there's no need to update. The source is updated on GitHub: https://github.com/melw/reels-type-d
  • FWDV280.BIN
melw
37
59
What Did Not Work:
  1. Videos saved with custom firmware are using higher bitrate than the stock firmware. Built-in playback likely can't handle this.
  2. 64GB cards should be fine also if formatted with FAT32 (there's free tools like Rufus or guiformat for that). The SD card performance with ExFAT may be insufficient for the higher bitrate recording. 32GB is the largest SD card size that natively supports FAT32 and is a "known good" card category, as long as it's V30 or faster.
JohnCT
20
6
Flashing checklist
Yes, when I flash with the latest version you posted in #775, I get the OSD and I also now get "FW271" in the upper right side of the screen just like the pic you posted in the same message which says the latest firmware took.
Unfortunately, I also still have the dark scans with the new firmware as I did with the previous D upgrade. I did the factory reset and the previews and scans are still dark.
I then reinstalled the Stock D firmware and the OSD went away as expected, but I was pleased to discover that the scans returned to the bright and colorful scans I was getting before. Attached are the two photos of each firmware. The one on the left is the original stock D firmware and the one on the right is the updated 271. Note that I left my camera on auto iris and it actually brightened the darker of the two scans (you can tell by the manilla envelope I used to block the source LED from my camera being subtly lighter), but you can still see the new firmware makes the scans much darker than the stock firmware does. The darker scans are also color shifted to the blue. When trying to adjust the exposure in the menu with the upgraded D firmware, the whites "bloom". So for now, I'm leaving in the Stock D firmware.
melw
37
59
Thanks for sharing the screenshots. Now I see the issue: WB gains are reset to 000,000,000 - which are minimum accepted values for Red, Green and Blue. On my device the defaults are 689,256,218 - More Red compared to Green and Blue, for natural colors on most reels. But good default values could be device specific and the colors on the reel may also affect what's a good setting.
Could you try, while in the recording mode, navigate in the OSD menu to [Reset], press right or '+' and see if you get sensible defaults for WB gains? If not, you can always hand edit them, but it could be bit tedious. Pressing Left/right gives you +16/-16 and +/- for fine-tuning +1/-1. Once you're able to match the WB gains to the defaults, the image brightness should be comparable to the stock firmware.
Reactions: JohnCT
JohnCT
20
6
OK, I reinstalled the latest D firmware (FW271), and I'm still in the same boat - very dark scans (and still no frame or zoom but that's my machine apparently). I'm interested in improving the performance, so I'd love to get an updated firmware to work for me.
In the Capture menu, I navigated to Picture and then clicked on "Reset to Default". Not only was there no change in the picture or the gain settings but I'm not sure the software understood the request because there was no type of acknowledgement that the request was made. When on the Reset function, I tried the OK, tried the right button, right button then OK, etc. I can't find any combination of buttons where the machine didn't ignore the command. Maybe it does but doesn't acknowledge it?
I then tried going to the Settings menu and doing the Factory Reset. That command is followed and I get an on screen acknowledgement that the factory reset was successful, but I'm still sitting on OOO for all three color gains.
You said changing the color gains manually was doable, but I can't see any way of making these changes. If you're saying it's adjustable in that little information box that now appears in the lower right hand side, I don't know how to access it. The red gain has a [ ] around the OOO as if it's selected to be adjusted, but no combinations of buttons I've tried has either changed the value in the brackets or moved the brackets over to the green or blue. There's a "reset" in white at the bottom, but I can't navigate to it.
I don't know if I'm doing something wrong or if there's a deeper issue with my particular machine beyond the lack of frame or zoom adjustments.
John
fishgee
John
The instructions for the modded firmware say, "The menu only works while recording. In preview the stock firmware owns the buttons, so the mod can't use them there. The easy way: start a short throwaway recording, set everything up, stop, then capture for real. Settings are saved and survive a power cycle.."
Are you perhaps attempting to change things while not in recording mode?
