260
421
Include the unit type in bug report. I'm guessing this is not Type B.
P.S. Type C only. Fixing shortly.
Reactions: eyeidea
omega
32
I put the version I used in my signature so I wouldn't forget it.
The speed is now OK.
eyeidea
20
Still getting some anomalies, FPS, data rates and also one capture stalled, the film was moving through, but the SD card just repeated the same frame for many seconds
Movie specs - 0dan0 V7.1 on Type C ...
Also I was seeing 464x224x256 in the WB values on this. Going above 256 for the first RGB value?
Went back to 0dan0 V7.0 on Type C and got this ....
260
421
Seems you did get the update to work. You need to redownload v7.1
within the zip you will have 71a.
But otherwise would be hard to tell, also the file date is 10/22 not 10/21.
eyeidea
20
Opps, do I load both?
FWDV280.BIN
AND
FWDV280-C-71a-Odan0.rbn
... to the root or just the .BIN file?
260
421
Correct, users wanted the setting of 0 WB to look natural, however that is not neutral in RGB gains. 464/256 = 1.81 gain is applied to the red channel.
Reactions: eyeidea
260
421
Argg! This is Mac issue, it is reading the fps from a different location in the file. ;( I have some more work to do.
  • Sad
Reactions: eyeidea
eyeidea
20
ok, new capture on V7.1a on Type C – also I am getting consistent data failure around the 17 sec. mark. Unit continues moving film, capture continues, movie hangs at ~17 sec and repeats same frame for the rest of the movie, in my case 51 sec mark. I am using SanDisk 280mbs SDXC II U3.
eyeidea
20
If its any help ... here is Quicktime data on capture from V6.1
However this was a different Type C unit from January.
I am gonna try V6.1 on my current Type C unit and see what the result is.
eyeidea
20
Here's V6.1 on my newest Type C purchased a couple months ago ... looks like correct data, same SD card, no stalled frames or captures issues. 10 sec clips plays all frames
finally the correct screenshot
260
421
Trying again for v7.1.
I did covered that the base timescale for the MP4 was hardcoded to 60000. To get the frame rate changes correct, a lot of code used 60000 directly at the assembly level. When fixing the 20fps to 18fps, all I changed was the numerator in the frame rate setting. But for 24fps, the numbers exceeded 16-bit, so I need to change the time scale.
This are all the locations I have found that I believe are timescale.
While the is unlikely to be useful information for others. It is here to keep a record. If something else breaks, one of these changes might have been wrong. I was searching for uses of 60000 in MIPS assemble code. Hoping these are all the timescales. I'm now using 20000 for the timescale (solving the 3x error you may have seen.)
Both Mac and Windows users need this fix. All working well in my testing.
  • FWDV280-TypeA-V7.1.1-0dan0.zip
  • FWDV280-TypeB-V7.1.1-0dan0.zip
  • FWDV280-TypeC-V7.1.1-0dan0.zip
eyeidea
20
V7.1.1 working great on my Type C, no longer hangs (stalls) at 0:17, Quicktime .MP4 shows 18fps and ~22Mbit/s, picture looks very good.
Can't wait for my lens to arrive! Have boxes and boxes of old film that still needs to see the light.
Thank you @0dan0 and everyone else here making all this possible!
QuickTime info:
Sample from V7.1.1 on Type C
Stock Lens + Settings: Exp: Default WB: 0.0 Sharp: -1.0 Tint: 0.0 Frame: adjusted to a sweet spot
Reactions: ThePhage and 0dan0
ThePhage
31
26
@0dan0 I tested the 7.1.1 firmware on my Model C scanner and a 5" reel scanned really well. Really great results with my 8mm scan (50' roll, no issues so far).
I'm developing an "Operating Guide" that incorporates your latest changes that I'll post here a little later; will edit as needed to help new-comers.
I did note that a 64 GB card I had been using with Mac84's firmware did not work well with 7.1.1, but a 32 GB card worked well with no issues.
Really liking the ability to set the Frame rate, Exposure Bias, White Balance, and tint. Particularly the recent WB trim adjustment for the LED backlight has been a solid improvement for me.
To confirm, is the Menu control labeled as "Tint" now functioning as a "Saturation" control where -2 is monochrome, 0 is normal color, and +2 equals very increased color saturation?
Thank you, thank you, THANK YOU, for all of these improvements. They are sooooooo good!
Reactions: eyeidea and fishgee
260
421
Thank you.
Tint always acted as saturation control, but is setting went from 25% to 200% (guessing). I just made -2.0 set to 0% saturation, to make working with B&W film easier.
Yes 64GB card support is broken. Someone will have to go through all the releases to find out when that happened.
sheider
14
Thank you.
FWIW, I am able to save an MP4 file of ~4,000 frames (50-ft roll) created by fw v7.1.1 on my Type B device using the 128 GB SDXC memory card formatted as FAT32 in the attached photo. After the last frame has been scanned, I press the 'OK' button, then select 'Close', and finally turn off the unit before I eject the memory card.
Surely I'm not the only person who is able to save an MP4 on a memory card larger than 32 GB?
Reactions: eyeidea and 0dan0
260
421
It seems than that it is exFAT, not the media size that is the issue. These units do not support files greater than 4GB, so formatting larger media as FAT32 is of little harm.
Reactions: eyeidea and sheider
sheider
14
Sticking to FAT32 with these units doesn't bother me one bit. That said, I believe that other folks have reported that the firmware (stock and presumably all mods created to-date) formats memory cards as exFAT when someone chooses to use that feature on the unit. That is why I suggested trying to disable that feature in the firmware and/or the UI, to avoid user questions / complaints.
jackmonte1987
30
Yes please, an operating guide would be fantastic, there are now so many settings that require remembered long pressses etc that im getting confused lol
Reactions: 0dan0 and fishgee
jackmonte1987
30
I went back to the MAC84 firmware because i was getting frustrated at the colors I was getting with the newer FW. I scanned about 15 reels and they look great aside from the AWB causing tonal shifts. However using the 0dan0 FW, I am finding that every time the scene changes it looks blue-ish or washed until I go back into the settings and tinker with it a bit. I think I understand why Kodak went with the AWB to begin with, I have found on a lot of my old reels that they are changing locations a lot, causing the white balance to look great one minute and wildly inaccurate the next. Is it possible to get a FW with ll the upgraded settings but with AWB enabled? I love the upgraded resolution and bit rates of the newer fw, but the white balance controls don't seem to work nicely with my reels. I have tried all suggestions that you have given me 0dan0.
Edit: I'm going to post another side-by-side of the 0dan0 fw and mac84 fw to give an idea. Stand by
I wasnt able to do video because im currently at work. The side by side comparisons look close, and I do prefer the look that the 0dan0 fw has, but something definitely happens in overexposed scenes that shifts the highlights and blows out the whites. I am not a professional by any means and this is all new to me. I'm just reporting what im seeing. The Mac84 config seems to work great albeit the auto white balance changing the tone in the scene. I plan on doing my best to correct that in post. I prefer using the 0dan0 fw because i like having fine control and a visual histogram, i just cant seem to get the hang of it.
