I will give this a try and provide an update. Working on another item at the moment.Does the MacSnap provide enough term power to power the BlueSCSI? Have you tried it powering the blueSCSI via usb?
When will which part be available? There's no overclocking support in the F4 series currently. Here's the F4 BlueSCSI discussion thread: https://tinkerdifferent.com/threads/f4-bluescsi-a-bluescsi-fork-by-androda.1336/
Alright, thank you, @Androda! I am posting there now.When will which part be available? There's no overclocking support in the F4 series currently. Here's the F4 BlueSCSI discussion thread: https://tinkerdifferent.com/threads/f4-bluescsi-a-bluescsi-fork-by-androda.1336/
So I tested blueSCSI with the MaSnap scsi and at first, would not work. Added an external usb power to the blue pill and it now boots up fine. Will need to try some more things with it. So I have a 512Ke with MacSnap, Plus 128K ROMs V2 1mb Ram and a 400/800K floppy in it. Nice. I have another logic board 512Ke with the plus ROMs on it but the flyback on that analog is bad so can’t use till I get the analog board fixed.Eric does the blueSCSI work with MacSnap scsi? I got a 512K unit today with this in it with the Plus ROMS as needed. Tried it but it would not boot up. All I got was the red light on the blue active.
thanks
That is correct. The Mac 128k, 512k, and Plus do not provide the 5v termination power through SCSI. That is why you need to use USB to power the external BlueSCSI.So I tested blueSCSI with the MaSnap scsi and at first, would not work. Added an external usb power to the blue pill and it now boots up fine.
Ah! Recap the analog board?Will need to try some more things with it. So I have a 512Ke with MacSnap, Plus 128K ROMs V2 1mb Ram and a 400/800K floppy in it. Nice. I have another logic board 512Ke with the plus ROMs on it but the flyback on that analog is bad so can’t use till I get the analog board fixed.
On my plus I added the resistor for it to work.Hi @Willj!![]()
On the Mac Plus, there is a way to add a small part so that it will provide the 5v termination power through SCSI. Let us know if you need more information on that.
Ah! Recap the analog board?![]()
Here some pics.Hi @Willj!![]()
The flyback transformer, aka that big black thingy on the analog board, right? IIRC, @Kai Robinson did order a new one from Dalbani. I will try to find the right part number.On my plus I added the resistor for it to work.
I have recapped the analog board but it’s the flyback had that bad smell of dryer or ozone after a few minutes on and I get no picture. I get the chime but screen black and no current comes out of the flyback. There is no discharge spark after it being on.
Nice!Here some pics.
Thanks for the report! Will add it to the list.Added an external usb power to the blue pill and it now boots up fine
This how the unit came. The battery still behind it. But I have no battery in it.Nice!![]()
You routed the SCSI to behind the battery door? Did you relocate the battery or is it still there?
Love this!BlueSCSI no longer reports as a QUANTUM FIREBALL1 - Some formatting utilities send vendor specific commands because they assume the drive can respond. BlueSCSI now reports as a QUANTUM BLUESCSI F1 - which is still passes the Apple SCSI checks so no need for patched utilities. If for some reason you need to change this - you can customize it using the scsi-info.txt file.
Can you create a new thread on this? I am sure others will be happy to help as well.This how the unit came. The battery still behind it. But I have no battery in it.
Thanks. I found them also and they are close to me in Miami so will be easy to get and ship to Cayman Islands. Just need bunch other items also like the 1N4150 and the BU406.@Willj, this should be the right one:
Pardon Our Interruption...
www.ebay.com
Here is information from Mac GUI on replacing the Flyback Transformer.
