Status
Not open for further replies.
fishgee
32
Hey all, just picked up a used Kodak Reels sn: D3024148BKxxxx which should be a Type B firmware.
Before flashing the 1440p mod I had a question on what the typical file size for the common regular 8 reels at the new resolution and bitrate, e.g. 50 ft, 100 ft and 200 ft?
Thanks in advance.
I'm using the 5.8 version right now, and the file sizes for 3" - 50 foot reels is coming in just under 700MB per reel. I realize the B firmware isn't available in version 5.8 (yet ;-) ), but it should give you some indication of what to expect.
NotaNumber
I'm using the 5.8 version right now, and the file sizes for 3" - 50 foot reels is coming in just under 700K per reel. I realize the B firmware isn't available in version 5.8 (yet ;-) ), but it should give you some indication of what to expect.
Thanks for the info. Maybe I'll bite the bullet and flash the B firmware or may be wait for the type B v5.x.
I have to order some leader and splicing tapes anyway.
Edit: I couldn't wait. The firmware loaded and files as scanned with the modded settings. Playback and thumbnails on the scanner show green and magenta patches but playback of the files on my PC are "normal".
Attached are mediinfo screenshots on files scanned with original vs version B firmware.
I am curious about the encoded time and date. The date appears fixed and the time perhaps random. Does the date have any relationship to the original firmware version?
442
615
Hi folks,
I'm still around and need to revisit more Reelz hacking. I finished scanning all my families 8mm and Super8 from the 60s and 70s, about 4 hours run time, so that took a while. So I needed new sources to continue this hacking hobby. So I'm now shooting my own modern 100D Ektachrome, using a Super8 camera from the 70s. Also can now do film development at home, so other that film and development chemicals, I can shoot, develop and scan in about 3 hours. I did find the fixed WB was wrong for modern film, and my development look, so I need to add a user control for WB Auto and manual.
I'm very slow hacking Type A and B units, now with fixed WB, not much else yet. Having units at different stages helps for progress comparisons.
Shot this film yesterday:
domb84
27
6
Hi folks,
I should have a bit of time this week to look at the M127 firmware again and seeing if I can get a modded one booting. Do you know if any of the fixes you've applied would work on the one I uploaded? i.e. are there any matching code across the firmwares? Perhaps you have a list of hex codes that you modified I can check against?
ThePhage
80
78
Hi folks,
Fun to read and see what you've been up to over these recent months. I love the clarity in your fresh footage, especially with the new lens. Looking forward to whatever advancements you and the community can make with regard to user-adjustable settings. I wonder if the frame rate (16, 18, 24) is something that you would consider for that too. Plenty of old 8mm footage out there in need of scanning with this machine.
While it's a trivial task to adjust the playback frame rate after capture, it would be nice to have the original mp4 files reflect the correct frame rate from the beginning (like the full range flag).
Anyways, thanks for the update!
442
615
I'm sure somewhere there is an fopen(), fread() and fwrite(), to open a config file with user controllable parameters, rather than flashing builds custom parameters. But this I have not yet found. Once I have that, then I could build a small UI (if I find the button events) to set fps, white balance, etc. Taking priority is catching Type A and B up, and maybe more importantly (but harder), working out a fix for the top and bottom frame jitter issues.
Gewendell
Long time lurker, first time poster. 0dan0 & Mac84, do either of you have Venmo or other way for us to throw you some cash for your troubles? I'm on a Model "A" and cannot WAIT to utilize your updates. If a little USD$ thrown your way by the community (assuming this is allowed in this space to even suggest), I'd HAPPILY contribute for your efforts in the community's behalf. Seriously, the least we can do. Would also pay for a step-by-step guide/video for the lens swap. (and I'm sure I'm not the only one). Thank you all for your posts and for pushing the envelope for this humble scanner!!
CineMark
Hi, I'd like to report that I just bought a Reels from Amazon. The serial number is: k3124148bk01699 which was reported by the website as serial not found, and needing firmware B. However, when I loaded that, I got the electric fireplace screen show on my Reels. I then proceeded to load the C firmware on the unit, and it booted on as original. I'm now running a film through and will report back with any issues.
442
615
Help is a video of my progress so far, and request for technical help at the end.
@Gewendell money will not help, I just the find enough time, and I'm looking for new leads to fix the remaining issues.
If some with a Type C Reels unit, could test all the versions I've posted, to see when the chroma artifact was introduced (or if it was there all the time.) If you have a stock lens, zoom all the way out, as this will emulate Ideas so far. 1) there is a chance is the increased bit-rate is on for Luma, and I'm starving chroma compression 2) As I used larger image buffering, maybe I'm stomping on some memory that is used for UV chroma compression (I would think it was be worse if that was the case.)
larryc39
34
35
Curious if anyone has a second source (US distributor maybe) for the lens? It seems that store is the only one that has specifically the 2/3 frame and narrow FoV lens, I've seen plenty of places retailing similar lenses but with a 1/3 frame and slightly wider FoV. That lens seems unique to Scorpion Vision.
442
615
The Scorpion Vision lens is very good, but technically overkill for this system. We don't need a 10MP 2/3" lens, as the sensor is only 1/3" and 1600x1200 is only 2MP. So a 1/3" lens can work, the issue is it must be designed to be a macro lens. I went through a dozen (cheaper) lenses, but none could focus at the distance needed, or if I could get a focus, the was other artifacts like halos for using the lens beyond its design. Very likely there are US suppliers for a nice 12mm macro for 1/3" with a 2-3MP rating, but so few vendor spec. the minimum focus distance.
Reactions: eyeidea and Umba67
442
615
I have now Type B and C running all the current hacks, unfortunately the Type A (with the same changes) crashes on boot. I expect there is a device drive address change I haven't handled yet.
My default (fixed/manual) white balance has moved to better match the modern film I'm scanning. Manually editing the .rbn for other WB values is not too hard.
Attached are V6.0 for Type B and C
P.P.S. I just fixed the color reversal error in Type B. I had just missed a 4 bytes in the port from Type C.
  • FWDV280-TypeC-V6.0-0dan0.zip
  • FWDV280-TypeB-V6.0-0dan0.zip
442
615
Just fixed Type B (see above.) The link has been updated, Types B and C are now equivalent.
Reactions: eyeidea
domb84
27
6
Hi @domb84
I was messing with the firmware you dumped last night and noticed that after repacking the firmware partitions and merging them, like you have done, that the first 2,296 bytes of the original file are not reinstated. What they are and whether or not some of them need to be updated to reflect the modified firmware I don't know. But prepending them to the merged binary as is is worth a try. You could also try using ntkcalc to update the checksum of the whole binary after merging and prepending. I don't have one of the M127 machines to test with, sorry.
Best,
Joe
I've had another crack at this and copied the first 2296 bytes to the merged modified firmware and recalculated the checksum.
.\ntkcalc.exe -cw .\final_firmware.bin
Sadly still doesn't boot. My modified firmware still ends up being 1,706,556 bytes rather than 4MB which is still confusing me. This happens after packing ad merging with NTKtool.
eyeidea
21
Hello everyone,
Just wanted to say hi and introduce myself. I have been curating my grand-father and father's old film collections for many years. It has been amazing to find so many shots of far off places and experiences. I started about 8 years ago with Wolverine 720, and using a Wolverine 1080 for the last 3-4 years. I ordered a Kodak Reels a few days ago after watching all the video y'all have posted. Very impressive!
Just wanted to say thank you for tinkering and sharing all this. It is a huge help!
442
615
Hello everyone,
Are you planning a Lens upgrade, as that create the biggest benefit? I'm in the process of replacing the lens on my Type B unit, to match my Type C. I haven't set the mounting position yet.
Reactions: Umba67 and eyeidea
442
615
Has anyone tried Vision 3 color negative with a Kodak Reels scanner? I'm now scanning my own home development Ektachrome, but Vision 3 is cheaper and higher quality (but negative.) It might be future hack to offer negative film support.
Reactions: Umba67
domb84
27
6
I seem to have made some kind of progress with the M127 firmware. I've been struggling to open the firmware in any of the tools were supposed to be able to work with it (JNovatekDec.jar and Novatek-FW-info). I managed to find the string FW96650A.bin in the firmware dump. A quick google of this took me to the dashcamtalk forums again so this seems to be a common modified firmware. I also found some other interesting strings:
A:\uengmode
I tried creating a folder named this on the sdcard and booting the device. Amazingly it boots to some kind of engineering mode where it tried to flash the device with a logo and configuration. Very cool! It then shuts down again after it fails but thats progress.
I then found A:\DUMPCFGINFO.bin. I googled this which took me to a device called the RunCamHD. According to their firmware update page this file is created upon successfully updating the device! Instructions are here:
I downloaded their firmware from here:
Now I had some firmware to compare with. I found their firmware starts with a string NT96650 very early in the code. I search for this in my dump and it's there. I stripped everything from before 0x00004000 so that the start of my dumped firmware now matches the RunCamHd firmware.
Hoorah! I can open the firmware in JNovatecDecoder and edit it!
My issue now is I do not know how much of this file I need in order to successfully flash the machine...
Reactions: Umba67
domb84
27
6
Success at last! I've managed to modify and flash back the firmware for the M127 machine while increasing the bitrate to 30Mbps. Put the FWDV180N.BIN file from the link on an sdcard, boot the machine and it will have a red light flash slowly around 5 times, then it will flash very quickly. Finally the machine will boot with the modified firmware. It seems to reset to Chinese, so you'll need to set it back (menu button, down 6 times, then ok to get to the language menu)
Here's my repo with the source firmware dump and a script that has the process to modify it.
Thanks for this thread for showing me it's possible. The scans are already much better with the increased bitrate. The white balance is the next thing I would like to fix if possible. Any help in that regard now we have a working flashable firmware for this model would be appreciated.
Status
