rdesros
26
I think I’ve spotted a bug. The capture quality looks fine when starting from a blank movie strip (the white section), but if you begin capturing with existing footage beyond the white area, even with QP set to 16, you can end up with high-bandwidth media that doesn’t match in quality. Film grain disappears, and there’s noticeable macroblocking in dark areas, almost like recording at 20 Mbit or less.
442
615
Share examples? I do this all the time, not seeing it.
omega
36
15
Maybe it is more of a support question rather than a hack, but how can I improve my capture?
I am trying to digitize old Super8 reels and the capture is jumping around like crazy. The footage to me is useless this way.
The result:
What is happening during capture:
Is my machine faulty? Or they all this bad? Can I do anything to improve?
I tried this with three reels (two sizes/types) and the film seems fine.
After reading and watching a ton, I started prodding the machine like a monkey, I tried: 1) creating slack in the take up reel, 2) no take up reel, 3) slack in the film reel, 4) different paths (this you see in the video), 5) toggled the selector switch to improve engagement with the film, 6) slide finger pressure on right side of the guide. Nothing has really improved my situation. Sometimes it seems like something is working until it doesn't.
Thanks!
My experience is that the shaking is caused by dried or poorly cut film. The gripper on dried film does not fit exactly into the perforation. On poorly cut film, the gripper does not have the strength to advance the film. Both of these problems are indicated by a loud clicking sound.
Try using my modification that I write about here #573
Reactions: ph4z and sheider
P-car
25
7
I've noticed that the scanner sometimes stops mid roll , and just freezes up. has anyone else noticed this behavior ? is there a solve? thanks
ThePhage
80
78
This is most likely due to the encoder freezing up and can be mitigated in various ways. See the “Known Issues” section of the User Guide (link in my signature).
Also, it could be the file size limit being reached.
Reactions: 0dan0
442
615
This is the risk you take when using a Qp below 22. Unit will randomly crash with the highest bitrates. This is way I added the Qp control, for max quality, you might have to rescan more, for a longer reels that you want to work reliability use a higher Qp.
Reactions: Umba67 and P-car
MHreels
I experienced this several times with Version 7.4. I guess that this was due to a falsly triggered automatic film stop. This version also in low quality (i.e. high Qp) showed jitter on the bottom of the film which was not due to missed transport of the film during scanning. As I needed the scans for a Bday present on 14th Dec, I did not wait for any new versions and resorted to reinstall one of the first versions with 20fps, 1920 x 1440 resolution and about 17 Mbit/s data rate. This worked fine for my 10 rolls normal 8 film. I may try the newer versions whether they show improved results....
P-car
25
7
I raised the Qp above 22 - as OdanO suggested - and it sopped locking up mid-roll. Unfortunately, quality is not very good now.
442
615
It is not a hard number, as it also depends on the grain and detail in your footage, and the rate of change in the footage. The original firmware would have averaged a Qp around 35. This is not a firmware bug, we simply running the compression beyond the design spec. For the highest quality scans, I just pick-up where the scan stopped, and continue the scan.
442
615
It is not falsing triggering the auto stop, unless you have about 40 frames of completely clear. This is just the limitations of the hardware running at higher bitrate.
hasi
16
After scanning varios Kodahchrome films, here are my white balance numbers: 321,176,145. No blue snow and no reddisch faces any more. Thank you OdanO!
hasi
16
By the way: I use Qp of 16 and it works fine. Sometimes it stops after an unpredictable number of frames. Can be as high as 17`000.
Update on 8 of January 2026: Meanwhile I established a Qp of 22. With this setting the scanner goes through large Reels without stopping.
Reactions: 0dan0
hasi
16
What was your average bit-rate?
Average bitrate of the scan is 33000 kBit/sec.
The enclosed sample scan is stored in HD- Format with a bitrate of 19000kBit/sec. It has been created with Vegas pro 20 with "Neat Video" plug- in, using noise reduction amount of 15%. For my filmtransfers Neat Video is an essential tool. -> HD- Format because TV players often don`t support 1600 x 1200.
  • Sample_Scan_Kodak_Reels_FW_7.5.mp4
  • Original_Sample_Scan_Kodak_Reels_FW_7.5.mp4
Reactions: Mac84
Mikm
When I need to adjust the frame while it's recording, I stopped first the recording, select adjust from the menu and on the moment I push one of the buttons the frame automatically zoom out fully (three frames seen on the screen) and buttons/frame adjustment were freezed, I need to restart the unit.
Type B unit, v7.6.1, std lens, recording with zoom-in.
Furthermore I like the way how we can adjust the WB values now, I'm still testing to find the correct values (agfa chrome films, also a bit too blue).
Thanks Odano!
Mac84
312
450
New Jersey, USA
www.mac84.net
Hello @0dan0,
FYI I encountered this interesting glitch after I was zooming in and out of the frame, and it is persistent after power cycling. Notice how the top section has a hard line. It's like it's repeating a section or cutting out a section.
I haven't updated the FW in a while, so maybe this is just a side effect of the additional zoom/frame adjust options. However, just sharing in case it's helpful. In addition, when zooming in and out, the screen can glitch out for a fraction of a second, displaying horizontal bars for a moment.
FW model: 7.6.1
HW model: A
Thanks again for all your hard work!
442
615
Hello @0dan0,
FW model: 7.6.1
HW model: A
I expect your new lens might be pointing to far to one side. When you are reframing to centering, might be using some out-of-range values. During preview share these numbers:
442
615
Thanks Odano!
I don't understand this one. Can you video what is happening?
442
615
33K is a tad low for Qp 16. But for stock lens at 16 or 18fps it could be okay.
