Siocnarf
Thanks a lot. I really appreciate the work you have been putting into this. I had a hunch that the answer i was looking for was already in the thread. I just tested it out and am pleased with the results. I'll be sure to read through the thread, so as not to post any duplicate questions.
ThePhage
64
64
Unfortunately I still have a bricked type D, so nothing to work with at the moment. More importantly I will not likely have any free time for this project until late May. I hope I can then recover the D unit I have, and start again. However, a lot of the development will need to be from scratch as so much changed. User wanting the features of this firmware should look for secondhand units will the older serial numbers, as there a good chance Type D unit will never be supported.
In the time between now and then, would you be open to a crowd-funded effort to provide you a new D unit? I think the community here would be able to make that happen in support your work?
hasi
16
I damaged the terminals of the 10 pin cable, joining the control board to the processor. I tried to reconfigure the contacts but did`n t suceed. Now I have ordered new cables. Can somebody tell me wether the straight connection (contacts on the same side, Type A) or the inverse one (Type B) is required? I missed to take a picture of the original.
For the 40 pin cable it is clear, that it is type A. Thank you for your help!
The modifyed Kodak Reels is a superb system and I wouldn`t go back to the previous scanner.
Federico
19
15
Hi @hasi here the pictures: I had to open my model B again because in the excitement of rebuilding, I've inserted the command board upside-down and I've noticed only when I' was ready to scan a reel...
The cable is not twisted, but it may be twisted on the board, or simply the board could be mounted reversed compared to the command board. In any cases check the picture: one side of the cable is printed so you can buy a type-a and mount it in the same way. Let me know if the pics are showing enough for you to understand how to mount it
Besides: why didn't you try to cut short the damaged cable, strip gently with some sandpaper the new end, to expose the connectors and give it a try?
Good luck, Federico
Federico
19
15
Hi everyone, I'm scanning with 7.7.0 a 8mm 1943 reel from my grandfather. Some war footage in b/w from Tunisia (with Panzer IVs, Macchi planes and burning airstrips: some examples attached) and I've noticed that the film has a bronze/brown strip outside of the driving holes and I reckon it might have an audio channel embedded.
Have a look to the two attached pictures: what do you think?
If so, is there any way to record it, maybe with an old cassette player? I am not aware that my grandfather duplicated the original footage over a new film, adding a post-production sound, so if it is an audio track indeed, it may be original.
Thank you, ciao, F.
Federico
19
15
Sorry, one more post for suggesting, if possible, an improvement to add to the next firmware development. I don't know if you guys have the same problem but it happens to me, when the reel has joints, that the frame zoom no longer adapts to the new segment: either on top or at the bottom some lines of the adjacent frame show up.
It would be wonderful if the zoom or even simply the offset point of the captured frame could be moved to match the new position.
The alternative is to capture a wider area and reframe it later on, but sometimes the leaking projector light is way to strong for the faded reels, and it creates a mess.
Probably during the adjustment, the auto exposure should be temporarily locked to the last position and then restored once the position rests for a few frames, so to avoid flickering.
What do you think?
Thank you! F.
hasi
16
Good luck, Federico
Thank you for the pictures! To me it shows, that the cable is B- Type with the pins inverted. The blue stripe is in both connectors pointing to the top, but since the connector of the control board is upside- down, relative to the cable the contacts are opposite. Please tell me if I see it wrong. For me it was also important to see, that the cable is not twisted 180 deg. -Not respecting that could cause short citcuit and my unit would be gone. I tried with sanding the ends but didn`t succed. I hope that with the ordered cales it returns to life again.
have a nice day!
Good luck, Federico
Hook Line and Tinker
I have a feeling time is a bigger hurdle than not having the D unit but I'm willing to contribute to the fund. The 20% off sale is back on for the time being on Amazon: https://amzn.to/4c8GFbb
Not sure how to guarantee we'd get a D unit though.
Reactions: Federico
fishgee
29
26
Thank you, ciao, F.
(From https://nostalgicmedia.com/blogs/media-conversion/does-your-film-reel-have-sound)​
Does 8mm Film Have Sound?​
"8mm film, also known as Standard 8mm or Regular 8mm, was introduced as a cost-effective alternative to 16mm film. Initially, 8mm film was not designed to include sound during filming. However, a technique called "sound striping" allowed for the addition of a magnetic stripe during film processing. To determine if your Regular 8mm film has sound, look for a bronze-colored stripe alongside the sprockets on one or both sides of the film. This stripe indicates the presence of a magnetic sound track."
I don't think you'd physically be able to run the 8mm film through a cassette deck. BUT if you removed the playback head from the deck, extended the wires, and held/positioned the head so that the audio track was in contact with the head, while the film is running at normal speed, maybe you could hear the audio (if present). Lots of variables there.... but sounds like a great project.
