Mikm
I don't understand this one. Can you video what is happening?
Sure, see the video, I just went from recording mode to Frame adjustment mode and when pushing the < > button(s) the frame on screen jump to totally zoom out.
442
604
This might be a new limitation. It seems it was broken in V7.4 (v7.3 is okay). So two steps forward, one step back. In three weeks no one else has reported it, as we general frame, then capture, not capture then frame. It is a bug, and worth looking into.
sheider
26
I've seen this bug, but I didn't bother reporting it because it only happened once and I couldn't repeat it. Anyway, the workaround is simple enough: restart the unit. That said, if you are able to find and fix the bug, then you rock, as always!
JKCalhoun
Hi, all—
Just picked up the Kodak REELS. I was able to digitize an old 8mm reel my daughter found at an estate sale—with the shipping firmware.
Trying to install various firmware versions I have found in this thread have failed to work on my device. I also am unable to find a default firmware that will restore the device. Any ideas?
FWIW, S/N: H2825148BK00161
It was not recognized by the lookup tool so suggested version B.
A and C give me a messed up display when the machine powers up to the Home Screen.
B looks good (the Home Screen), but the buttons do not function.
Thanks!
442
604
Hi, all—
Thanks!
Do the buttons work with type A or C? If this is a new configuration, it would nice to see what it shares with other configurations.
MHreels
Hi, all—
Thanks!
Hi JKCalhoun , I have a European version bought in Nov 2025 which works with the attached original Kodak FW for H2324148BK Series. Might work for you too. Good luck.
  • Kodak FW for H2324148BK Series.zip
Reactions: Mac84
Mikm
Thanks Odano,
I always start to adjust the frame first however from time to time I need to re-adjust the frame while I'm recording.
(it happens when it moves to another part/scenario of the film (reel consists of several small films, all super-8), do not know why or how this can occur with the same reel, not all my reels have this behavior).
The re-adjustment issue as described is always: Buttons to adjust the frame freeze and 3times out of 5 re-tries it even jump to total zoom-out and freeze.
Mac84
311
447
New Jersey, USA
www.mac84.net
Oh interesting! Let us know @JKCalhoun if this works for you, if so, this may be a new model "D" variant.
Also, I finally opened the replacement unit I got in January, the serial number is:
K3124148bk00221
I can dump this to see if it's a "newer" version too.
JKCalhoun
Thanks for uploading the European firmware, but it did not work. The screen was rotated 180 degrees and the colors clearly wrong (as though inverted or just the RGB values shifted or such). The buttons did not work either.
From my experiments with the various A, B, and C versions yesterday, the buttons did not work for any of them. I tried the arrow buttons to see if I could navigate off of the "Capture" button (nope)— I tried the "OK" button to see if it would take me to the next screen (nope).
Maybe Steve has a newer version like mine.
(My S/N: H2825148BK00161)
442
604
Based on the posts on this forum, and those that shared serial numbers, it seems there is a fourth hardware configuration and therefore a Type D firmware needed. We have seen two units on this forum with H2825xx serials, that will not support button presses after update, but the LCD driver suggests it is very close to type B. Anyone else with H2825 serials please do not install, but do post here so we can work out how to extract your original firmware before it is erased with any firmware update.
Based on these serials post to this forum and ranges extracted from Mac84 javascript code:
A2021148BKxxxxx A
J2021148BKxxxxx A
M2021148BKxxxxx A
P2021148BKxxxxx A
A2022148BKxxxxx A
M2023148BKxxxxx B
A2724148BKxxxxx B
E3124148BKxxxxx B
H2324148BKxxxxx C
K3124148BKxxxxx C
C1725148BKxxxxx C
D2825148BKxxxxx Unsure (@Xanadude hasn't confirmed)
H2825148BKxxxxx D (Do not install, yet)
---25---
I believe this might be the manufacturing year, or at least when the serial number was generated. The oldest Type A units are 21 and 22, then Type B from 23, and 24 (although some 25), and Type C is 24 and 25.
On eBay right now is this open box unit (https://www.ebay.com/itm/257252730912):
A serial number range we've yet to see. I expect this is either a Type C or the new mystery D type. The seller turned down my $320 offer (Amazon is selling new for $336 today.) I don't need a fourth unit (particularly if it is another C), but I will buy any confirmed type D that is not had the firmware updated/replaced.
Reactions: Mac84 and fishgee
442
604
Here is v7.6.2, this has two bug fixes. First that the reframing wouldn't work immediately after the update, and the second that reframing was bizarre after capturing, if you used the arrow navigation controls. These both had the same root cause.
All the code changes are on https://github.com/0dan0/4reels
  • FWDV280-A762-0dan0.zip
  • FWDV280-B762-0dan0.zip
  • FWDV280-C762-0dan0.zip
Mac84
311
447
New Jersey, USA
www.mac84.net
Thanks for the great post!
Damn, I was afraid of a new revision popping up...
I just opened my K3124148BK00221 unit and dumped the firmware. It seems to be nearly identical (except for a minor change) as @MHreels posted (SN: H2324148BK...). The only difference is on the very first address line.
I think mine maybe a revision C then?
442
604
@Mac84 Yep, that is a type C.
@JKCalhoun and @Grandson (if you still have your scanner), I now believe there has been a new hardware release, which we don't have the baseline firmware. This is likely fixable. The easiest approach, if @Mac84 or myself, or someone willing to add a serial port, can find a brand new H2625xx unit (that hasn't had any new firmware flashed.) The harder solution, from within, determine what has changed in the hardware. As your buttons aren't working, I can use the capture display for feedback, and without a serial, there would be no other way. Until, I just worked out how to render pixels directly to the screen.
For D-Type only with the buttons not work (so only @JKCalhoun and @Grandson), please run this test build (zip attached.) It will not fix the issue, but does it say "Hello World" next to the color palette test?
This will test if the unit has crashed, or happily running the wrong firmware.
P.S. Placed a slightly higher bid in the Ebay unit (no competition please.) Hoping it is Type D.
  • FWDV280-D.zip
JKCalhoun
Thanks. It occurred to me that I could return the unit to Amazon where I bought it and exchange it for another unit—and not molest that one. It seems like a rotten thing to do though…
I tested your "D" test version and did not see a "color palette test". In fact it booted to a normal looking Home Screen—non-functional buttons.
Is there a way to enable the color palette test? Or ought it have kicked off itself?
Attached is the (brief) info screen before the Home Screen and the final Home Screen (buttons do not work):
442
604
This suggests the unit is crashing, it is not the buttons aren't working. Return it. The manufacture can easily refurb the units, and would have this issue if A) they didn't do a sloppy design, and B) they would provide users installable firmware.
ph4z
My experience is that the shaking is caused by dried or poorly cut film. The gripper on dried film does not fit exactly into the perforation. On poorly cut film, the gripper does not have the strength to advance the film. Both of these problems are indicated by a loud clicking sound.
Try using my modification that I write about here #573
Thanks, as per 0dan0's advice I returned my unit, so I'm currently without. I'll try this if the next one has this too.
Mac84
311
447
New Jersey, USA
www.mac84.net
If anyone gets a new unit with potentially new firmware within the US, and you don't mind shipping it, I’d be more than happy to solder serial cables to it and dump the firmware and send it back.
I'm also trying to figure out if there's a way to trigger the command line interface from the SD card to dump the firmware without cracking the unit open...
I'll update the 1st page here and the lookup tool to inform folks that a new firmware exists. I'm very sorry @JKCalhoun and @Grandson for all the trouble, sadly as @0dan0 echos, this could all be avoided if Kodak once again had firmware downloads on their website. I have a feeling not even they are keeping track of how many firmware revisions there are!
sdezego
Just wanted to pop in and say thanks to all here!! Amazing efforts.
I just bought a unit (US) with D2825148BKxxxxx and used B Firmware (7.6.1) and have only experienced a crash or two, but think it was the film error triggering (Splice perhaps). Also using a High Speed micro SD with adapter 256GB (which I know was not recommended). Recored a couple more films and no crashes. Lots of user error on Color, etc, but need to work through those. Might need to change the lens as well.
I did capture one film before updating FW, so will do a compare.
@Mac84 that was my thinking as well, that one would think there would be a way to dump the firmware to the SD during a FW update. Maybe a special folder/name is required to trigger.
I do have the GX EEPROM reader and was going to dump the Firmware JIC, but was in a rush to get a few movies before Christmas and took the chance LOL.
Also, in past experience with Car Guage clusters, there is usually a "Country Code" in the firmware. Usually, this changes the Clock from 12hr to 24 hr, etc.
Reactions: fishgee and Mac84
